USB 4G/LTE WAN con AGTHP rooted
  • 88 Risposte
  • 36657 Visite
Offline rospy
  • 56
Re:USB 4G/LTE WAN con AGTHP rooted
« Risposta #30 il: 16 Novembre 2020, 11:11 »
Ho provato ad installare LuCI dalla Gui dopo aver riconfigurato il TimHub per avere accesso a Internet tramite il mio router ma ricevo questi errori:
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/base/Packages.gz
*** Failed to download the package list from https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/base/Packages.gz
*** Failed to download the package list from https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/packages/Packages.gz
*** Failed to download the package list from https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/luci/Packages.gz
*** Failed to download the package list from https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/routing/Packages.gz
*** Failed to download the package list from https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/telephony/Packages.gz
*** Failed to download the package list from https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/target/packages/Packages.gz
No packages removed.
Unknown package 'libuci-lua'.
Unknown package 'luci'.
Unknown package 'rpcd'.
usercontent.com/Ansuel/GUI_ipk/kernel-4.1/target/packages/Packages.gz, wget returned 1.
Collected errors:
 * opkg_install_cmd: Cannot install package libuci-lua.
 * opkg_install_cmd: Cannot install package luci.
 * opkg_install_cmd: Cannot install package rpcd.
mv: can't rename '/www/cgi-bin': No such file or directory
mv: can't rename '/www/luci-static': No such file or directory
mv: can't rename '/www/index.html': No such file or directory
rm: can't remove '/usr/lib/lua/uci.so': No such file or directory
sed: /usr/lib/lua/luci/model/uci.lua: No such file or directory
uci: Entry not found
/usr/share/transformer/scripts/appInstallRemoveUtility.sh: line 480: /etc/init.d/uhttpd: not found
Se però provo dal browser me li fa scaricare. Allora li ho scaricati tutti tenendo il riferimento alla directory prima del Packages.gz comune e cioè:base-packages-luci-routing-telephony-target/packages. Ora però non so bene dove metterli (/tmp ?) e che comando dare per eseguirli. Ma possibile che capitino tutte a me?
  • 3408
« Risposta #31 il: 16 Novembre 2020, 11:15 »
Quando hai installato la GUI il modem era connesso ad internet? altrimenti vai nella pagina Impostazioni GUI e segui le istruzioni per installare le "Specific App", dopo rimuovi e reinstalla da gui luci.
Offline rospy
  • 56
« Risposta #32 il: 16 Novembre 2020, 11:23 »
Ovviamente sì che ero collegato a internet. Come detto il collegamento è dal mio router (192.168.3.x) in statico sulla Wan del TimHub (192.168.3.2 ecc.) e mi collego dal PC al TimHub sulla 192.168.1.x.
Nella Opzione e Utility GUI alla voce App specifica trovo che c'è scritto App specifica già installata e non c'è possibilità di installare altro e anche cliccando sopra non mi dice quale sia stata installata (ovviamente non ho mai installato niente).
Ma va fatto un reboot magari?
Offline rospy
  • 56
« Risposta #33 il: 16 Novembre 2020, 11:49 »
E' il solito problema con queste chiavette e di come si applica lo switch.
La tua dovrebbe avere un id iniziale 12d1:1f01
che con la versione mobile del router switcha in un modo e con openwrt in un altro.
Per cominciare a capirci qualche cosa (o non capirci nulla)
https://forum.openwrt.org/t/usbmode-huawei-hilink-mode-to-stick-mode-support/61572
https://jtanx.github.io/2018/12/28/huawei-e8372h-a5-v11-notes/
In realtà quando faccio il comando lsusb la riconosce con id 12d1:155e cioè modalità stick-ncm (la modalità 12d1:1f01 è quella Mass Storage mentre la modalità 12d1:14db è la modalità Hilink riconosciuta da Rooter). Inoltre i comandi suggeriti di modem switch con il comando usb_modeswitch non funzionano perché manca qualche pacchetto aggiuntivo che non so dove prendere.
« Risposta #34 il: 16 Novembre 2020, 14:06 »
usb_modeswitch non c'è e non deve essere installato.
Capisco che la cosa è un po' difficile da capire, ma le prove le puoi fare solo tu. Però qualche indicazione te l'ho data.
L'ID della  tua chiavetta é 12d1:1f01, poi in base ai driver installati e al software utilizzato cambia ID.
Da file presente nel router /etc/usb-mode.json
"12d1:1f01": {
"t_vendor": 4817,       <- 12d1 in esadecimale
"t_product": [ 5470 ],  <- 155E in esadecimale
"no_driver": true,
"msg": [ 22 ]    <- numero della riga dei messaggi in cima al file
https://openwrt.org/docs/guide-user/network/wan/wwan/usb-modeswitching
Prova a modificare 1f01 e 5470 e vedere se viene vista in maniera diversa.
« Ultima modifica: 16 Novembre 2020, 14:21 da larsen64it »
Offline rospy
  • 56
« Risposta #35 il: 17 Novembre 2020, 12:40 »
Grazie per i suggerimenti e i vari link ma non ci sono riuscito.
Nelle mie peregrinazioni trovato questo sito molto interessante https://www.draisberghof.de/usb_modeswitch/ USB_ModeSwitch - Handling Mode-Switching USB Devices on Linux che contiene una lista di chiavette funzionanti con i loro codici e messaggi https://www.draisberghof.de/usb_modeswitch/device_reference.txt che penso possa essere d'aiuto a chi ne capisce più di me. Purtroppo questa lista non è aggiornata e nel mio caso ho trovato solo i riferimenti a
Con la 12d1:1f01 c'erano solo due chiavette di cui una simile alla mia anche se solo 3G (cioè Huawei E355s-1 wifi-USB).
# Huawei E353 (3.se) Chiavetta Internet E353, 21.1 Mbps 3g HSPA+
# Contributor: Ulf Eklund
DefaultVendor= 0x12d1
DefaultProduct=0x1f01
TargetVendor=  0x12d1
TargetProduct= 0x14db
MessageContent="55534243123456780000000000000a11062000000000000100000000000000"
# Driver is cdc_ether
NoDriverLoading=1
# Huawei E355s-1 3G Mobile WiFi Modem Router
# Contributor: Mihail Zenkov
MessageContent="55534243123456780000000000000011062000000100000000000000000000"
Come visto viene usato la modalità HiLink 14db e non la modalità USB-Stick 155e come invece viene riconosciuto da me dal router. Ho provato varie combinazioni di TargetProduct e di MessageContent modificando il file /etc/usb-mode.json ma in tutti quei casi non viene nemmeno vista dalla LUCI nel Mobile.
Visto che quando uso la configurazione standard con il cavo wan scollegato la chiavetta mi viene riconosciuta e definita come connessa ritengo che il vero problema sia la sua associazione nella tabella di routing ed ho provato a seguire anche la via delle modifiche in /etc/network, come suggerito da Larsen64it, senza risultato.
Mi dichiaro sconfitto!
Offline rospy
  • 56
« Risposta #36 il: 17 Novembre 2020, 12:49 »
Può essere OT ma l'unica soluzione che mi rimane è quella di usare un router a monte del TimHub. Per chi fosse interessato ho trovato questo router su amazon GL.iNet GL-MT300N-V2 che costa 23 Euro, sul quale è tra l'altro possibile installare ROOTER firmware, che ha 16MB RAM e 128MB ROM con due porte ethernet 100Mb (LAN e WAN) con wireless 2.4GHz e porta USB per Chiavetta 3g/4G-Hard Disk DLNA e che può essere usato come router, repeater, AP Mode e Hotspot Mode sia con chiavette wifi sia con Android in USB Tethering.
Sempre su amazon ho trovato la USB Tim 772355 Chiavetta 4G LTE che proverò a comprare. Chissà se usando la chiavetta USB di TIM con SIM TIM sarò più fortunato?
« Ultima modifica: 19 Novembre 2020, 17:13 da rospy »
Offline rospy
  • 56
« Risposta #37 il: 19 Novembre 2020, 17:03 »
EUREKA!
Ho ricevuto la Chiavetta LTE TIM che in realtà è una ZTE MF833U1 all'interno della quale ho messo una SIM TIM (usa microsim non normale o nano e ho usato un adattatore). La chiavetta viene già configurata con l'APN di TIM ma in accesso manuale. Dalla finestra browser su 192.168.0.1 è possibile abilitare l'accesso automatico oltre a cambiare l'APN e definirlo predefinito.
Il DGA 4132 è configurato:
Banda Larga: Rilevazione automatica (se metto il cavo dall'altro router passa in Ethernet) con VLAN disabiltato. Solo con chiavetta lo stato è WAN Ethernet Disabiltato
Accesso a Internet: Modalità di connessione-DHCP Rooted (va bene sia con cavo che con chiavetta)
Dopo aver inserito la chiavetta usando il comando lsusb viene riconosciuta con ID 19d2:1405
Nella scheda Mobile: Abilitato - Stato Connesso - Tipologia Radio LTE - Qualità segnale Buono
Dopo un attimo appare nella scheda Accesso Internet: Mobile Internet connected - Indirizzo IP WAN 10.41.119.146
e accedo a Internet: FUNZIONA!
 :clap: :clap: :clap:
Le prestazioni non sono granché ma sufficienti: con test.eolo.it ho 32 di ping e 4 di jitter con 17,6 in Download e 6,8 in Upload ma presumo dipenda solo dalla connessione LTE.
GRAZIE a FrancYescO e a larsen64it per la pazienza e le indicazioni. Questa volta però ha funzionato tutto senza toccare niente. Si vede proprio che questa combinazione (chiavetta TIM con sim TIM) gli piace. Più avanti proverò ad usare una sim diversa ma penso che il risultato non cambierà.
p.s. la chiavetta funziona anche con il microrouter GL.iNet GL-MT300N-V2 in modalità USB Tethering inserita nella porta USB. Un ottimo acquisto! Il modello più corretto sarebbe però il suo fratello maggiore il GL-AR750S-Ext che ha la doppia banda wifi e 3 porte GB (1 Wan e 2 Lan) oltre a una microSD ma che però costicchia.
Offline rospy
  • 56
« Risposta #38 il: 19 Novembre 2020, 17:09 »
Per chi ne capisce più di me a seguire i vari risultati:
root@modemtim:~# lsusb
Bus 001 Device 003: ID 19d2:1405
root@modemtim:~# dmesg | tail -n20
[  234.449242] dosprotect rpfilter drop IN=br-lan OUT= MAC=01:00:5e:00:00:fb:ac:81:12:70:ea:a7:08:00 SRC=169.254.234.62 DST=224.0.0.251 LEN=65 TOS=0x00 PREC=0x00 TTL=1 ID=17397 PROTO=UDP SPT=5353 DPT=5353 LEN=45
[  630.284771] usb 2-1: new full-speed USB device number 2 using ohci-platform
[  630.458757] usb 2-1: not running at top speed; connect to a high speed hub
[  630.477230] usb-storage 2-1:1.0: USB Mass Storage device detected
[  630.481419] usb-storage 2-1:1.0: Quirks match for vid 19d2 pid 1225: 1
[  630.485281] scsi host0: usb-storage 2-1:1.0
[  633.787511] usb 2-1: USB disconnect, device number 2
[  634.119705] usb 1-1: new high-speed USB device number 3 using ehci-platform
[  634.456723] cdc_ether 1-1:1.0 eth6: register 'cdc_ether' at usb-ehci-platform.0-1, CDC Ethernet Device, 00:a0:c6:00:00:00
[  634.458405] usb-storage 1-1:1.2: USB Mass Storage device detected
[  634.459441] scsi host1: usb-storage 1-1:1.2
[  635.461169] scsi 1:0:0:0: CD-ROM            ZTE      USB SCSI CD-ROM  2.31 PQ: 0 ANSI: 2
[  635.463555] scsi 1:0:0:1: Direct-Access     ZXIC     MMC Storage      2.31 PQ: 0 ANSI: 2
[  635.470893] sd 1:0:0:1: [sda] Attached SCSI removable disk
[  639.144480] dosprotect rpfilter drop IN=eth6 OUT= MAC=00:a0:c6:00:00:00:4a:ab:3e:9a:da:c9:08:00 SRC=192.168.0.1 DST=192.168.0.179 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=27510 PROTO=UDP SPT=67 DPT=68 LEN=308
[  639.160187] dosprotect rpfilter drop IN=eth6 OUT= MAC=00:a0:c6:00:00:00:4a:ab:3e:9a:da:c9:08:00 SRC=192.168.0.1 DST=192.168.0.179 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=27513 PROTO=UDP SPT=67 DPT=68 LEN=308
root@modemtim:~# ifconfig
bcmsw     Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
          RX packets:145891 errors:0 dropped:0 overruns:0 frame:0
          TX packets:167682 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:40330226 (38.4 MiB)  TX bytes:78504071 (74.8 MiB)
          Base address:0xffff
br-lan    Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::a691:b1ff:fe2f:68c4/64 Scope:Link
          RX packets:140537 errors:0 dropped:0 overruns:0 frame:0
          TX packets:156541 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:37301202 (35.5 MiB)  TX bytes:70667672 (67.3 MiB)
eth0      Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
          RX packets:137307 errors:0 dropped:9 overruns:0 frame:0
          TX packets:156999 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:39732421 (37.8 MiB)  TX bytes:71665849 (68.3 MiB)
eth1      Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
eth2      Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
eth3      Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
eth4      Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
          inet addr:192.168.2.2  Bcast:192.168.2.255  Mask:255.255.255.0
eth5      Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
          RX packets:9178 errors:0 dropped:6 overruns:0 frame:0
          TX packets:11967 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:720879 (703.9 KiB)  TX bytes:6318707 (6.0 MiB)
eth6      Link encap:Ethernet  HWaddr 00:A0:C6:00:00:00
          inet addr:192.168.0.179  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::2a0:c6ff:fe00:0/64 Scope:Link
          RX packets:91721 errors:0 dropped:0 overruns:0 frame:0
          TX packets:148188 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:9683749 (9.2 MiB)  TX bytes:38985057 (37.1 MiB)
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:377 errors:0 dropped:0 overruns:0 frame:0
          TX packets:377 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:33447 (32.6 KiB)  TX bytes:33447 (32.6 KiB)
voipeth4  Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C5
          UP BROADCAST MULTICAST  MTU:1400  Metric:1
wl0       Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C5
          inet6 addr: fe80::a691:b1ff:fe2f:68c5/64 Scope:Link
          RX packets:77 errors:0 dropped:0 overruns:0 frame:9037
          TX packets:5382 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7447 (7.2 KiB)  TX bytes:991460 (968.2 KiB)
          Interrupt:92
wl0_1     Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C5
          RX packets:0 errors:0 dropped:0 overruns:0 frame:9037
wl1_1     Link encap:Ethernet  HWaddr A4:91:B1:2F:68:C4
          TX packets:30 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:3884 (3.7 KiB)
root@modemtim:~# ip r
default via 192.168.0.1 dev eth6 proto static
192.168.0.0/24 dev eth6 proto kernel scope link src 192.168.0.179
192.168.1.0/24 dev br-lan proto kernel scope link src 192.168.1.1
192.168.2.0/24 dev eth4 proto kernel scope link src 192.168.2.2
192.168.168.0/25 dev wl0_1 proto kernel scope link src 192.168.168.1
192.168.168.128/25 dev wl1_1 proto kernel scope link src 192.168.168.129
239.0.0.0/8 dev br-lan scope link
Per informazione: quando inserisco il cavo wan dall'altro router la connessione LTE si diabilita e si riabilita automaticamente se tolgo il cavo wan. In sostanza il failover è automatico.
« Ultima modifica: 19 Novembre 2020, 17:51 da rospy »
« Risposta #39 il: 20 Novembre 2020, 07:13 »
Sembra ok, quale è il problema?
Offline goleador
  • 56
« Risposta #40 il: 21 Novembre 2020, 10:10 »
Buongiorno, ho anch'io un problema a far funzionare una chiavetta Huawei (per la precisione un PocketCube o E5575s-210). Ho letto i vari thread ma non sono riuscito a capirci molto... Sono su un FastGate con Gui Ansuel. Vi posto i risultati dei vari comandi:
root@OpenWrt:~# lsusb
Bus 001 Device 004: ID 12d1:155e
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0001
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0003
root@OpenWrt:~# dmesg | tail -n20
[  766.042000] option 1-1:1.1: GSM modem (1-port) converter detected
[  766.050000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[  766.057000] huawei_cdc_ncm 1-1:1.2: bind() failure
[  766.061000] option 1-1:1.2: GSM modem (1-port) converter detected
[  766.068000] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
[  766.121000] huawei_cdc_ncm 1-1:1.3: MAC-Address: 00:1e:10:1f:00:00
[  766.127000] huawei_cdc_ncm 1-1:1.3: setting rx_max = 16384
[  766.140000] huawei_cdc_ncm 1-1:1.3: NDP will be placed at end of frame for this device.
[  766.147000] huawei_cdc_ncm 1-1:1.3: cdc-wdm0: USB WDM device
[  766.154000] huawei_cdc_ncm 1-1:1.3: wwan0: register 'huawei_cdc_ncm' at usb-ehci-platform.0-1, Huawei CDC NCM device, 00:1e:10:1f:00:00
[  767.861000] CONSOLE: 027494.601 wl1.0: wlc_send_bar: seq 0x2a2 tid 0
[  796.822000] CONSOLE: 027523.602 wl1: Proxy STA 38:37:8b:ac:dd:7d link is already gone !!??
[  885.197000] CONSOLE: 027612.086 flow_create : bitmap_size=512  maxitems=512
[  885.204000] CONSOLE: 027612.087 wl1.0: wlc_send_bar: seq 0x1 tid 7
[  885.479000] CONSOLE: 027612.144 flow_create : bitmap_size=512  maxitems=2048
[  885.485000] CONSOLE: 027612.150 wl1.0: wlc_send_bar: seq 0x1 tid 0
[  886.750000] CONSOLE: 027613.546 wl1.0: wlc_send_bar: seq 0x5 tid 0
[  886.756000] CONSOLE: 027613.548 wl1.0: wlc_send_bar: seq 0x6 tid 0
[  887.513000] CONSOLE: 027614.345 wl1.0: wlc_send_bar: seq 0x8 tid 0
[  888.515000] CONSOLE: 027615.456 wl1.0: wlc_send_bar: seq 0xf tid 0
root@OpenWrt:~# ifconfig
bcmsw     Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
          UP BROADCAST RUNNING MULTICAST  MTU:2044  Metric:1
          Base address:0xffff
br-lan    Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
          inet addr:192.168.1.254  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::1213:31ff:fef9:121e/64 Scope:Link
          RX packets:2711 errors:0 dropped:4 overruns:0 frame:0
          TX packets:1784 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:354668 (346.3 KiB)  TX bytes:384313 (375.3 KiB)
eth0      Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
          UP BROADCAST MULTICAST  MTU:2044  Metric:1
eth1      Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
eth2      Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
eth3      Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
eth4      Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
          inet addr:169.0.0.2  Bcast:169.0.0.255  Mask:255.255.255.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:758 errors:0 dropped:0 overruns:0 frame:0
          TX packets:758 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:51983 (50.7 KiB)  TX bytes:51983 (50.7 KiB)
ptm0      Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
vlan_ptm0 Link encap:Ethernet  HWaddr 10:13:31:F9:12:1E
wl0       Link encap:Ethernet  HWaddr 10:13:31:F9:12:1F
          inet6 addr: fe80::1213:31ff:fef9:121f/64 Scope:Link
          RX packets:0 errors:0 dropped:0 overruns:0 frame:4018
          TX packets:1691 errors:2 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:217656 (212.5 KiB)
          Interrupt:92
wl0_1     Link encap:Ethernet  HWaddr 12:13:31:F9:12:20
          inet6 addr: fe80::1013:31ff:fef9:1220/64 Scope:Link
wl0_2     Link encap:Ethernet  HWaddr 12:13:31:F9:12:21
          inet addr:192.168.78.1  Bcast:192.168.78.255  Mask:255.255.255.0
          inet6 addr: fe80::1013:31ff:fef9:1221/64 Scope:Link
wl0_3     Link encap:Ethernet  HWaddr 10:13:31:F9:12:1F
wl1       Link encap:Ethernet  HWaddr 12:13:31:F9:12:27
          inet6 addr: fe80::1013:31ff:fef9:1227/64 Scope:Link
          RX packets:2711 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2264 errors:0 dropped:17 overruns:0 carrier:0
          RX bytes:354668 (346.3 KiB)  TX bytes:405403 (395.9 KiB)
wl1_1     Link encap:Ethernet  HWaddr 12:13:31:F9:12:27
          TX packets:1694 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:208182 (203.3 KiB)
wl1_2     Link encap:Ethernet  HWaddr 12:13:31:F9:12:27
wl1_3     Link encap:Ethernet  HWaddr 12:13:31:F9:12:27
          TX packets:1693 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:208032 (203.1 KiB)
root@OpenWrt:~# ip r
169.0.0.0/24 dev eth4  proto kernel  scope link  src 169.0.0.2
192.168.1.0/24 dev br-lan  proto kernel  scope link  src 192.168.1.254
192.168.78.0/24 dev wl0_2  proto kernel  scope link  src 192.168.78.1
root@OpenWrt:~#
Ad un certo punto era comparsa nella scheda "Mobile" la sigla della chiavetta, ma non riuscivo a navigare o raggiungere il suo IP, adesso invece neanche compare (segnala "0 dispositivi connessi"). Qualcuno saprebbe come aiutarmi?  :help:
« Risposta #41 il: 21 Novembre 2020, 10:32 »
C'è poco da dire. La tua chiavetta viene identificata come la Huawei di rospy e pare con gli stessi problemi. In generale con cavo dsl scollegato e chiavetta inserita ti dovrebbe alzare wwan0, se non si vede prova a ravviare.
Offline goleador
  • 56
« Risposta #42 il: 21 Novembre 2020, 16:48 »
Grazie mille per la risposta. Intendi riavviare il fastgate o la chiavetta? Io nel dubbio ho provato a riavviarli entrambi ma non sembra cambiare nulla. Il cavo DSL è sempre stato scollegato.
Offline rospy
  • 56
« Risposta #43 il: 25 Novembre 2020, 15:16 »
Come avrai visto ho abbandonato la possibilità di usare la E8372h-153 sul Tim DGA 4132. Ho però comprato la Chiavetta LTE TIM che in realtà è una ZTE MF833U1 e tutto funziona senza problemi. Tieni presente che in teoria, come detto, il firmware switcha la chiavetta Huawei da Hilink mode (14db) a Modem stick (155e) ma non è in grado di creare la eth5 e la eth6 come nell'esempio dell'ifconfig della ZTE. Non vedo creazione della wwan0 (contrariamente a quanto dice Larsen64it) quando collego la ZTE ma solo la eth5 e 6 e funziona! Forse è qualche routine che non crea le porte e le configura: boh!
« Ultima modifica: 25 Novembre 2020, 16:20 da MisterFTTH »
« Risposta #44 il: 26 Novembre 2020, 05:40 »
Bus 001 Device 003: ID 12d1:155e  questa è la Huawei vista come USB come dice Larsen64it
[ 6291.305607] huawei_cdc_ncm 1-1:1.3: cdc-wdm0: USB WDM device
[ 6291.306784] huawei_cdc_ncm 1-1:1.3 wwan0: register 'huawei_cdc_ncm' at usb-ehci-platform.0-1, Huawei CDC NCM device, 00:1e:10:1f:00:00
wwan0     Link encap:Ethernet  HWaddr 00:1E:10:1F:00:00
          inet6 addr: fe80::21e:10ff:fe1f:0/64 Scope:Link
          TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:3028 (2.9 KiB)
https://www.google.it/search?q=huawei_cdc_ncm+1-1%3A1.3+wwan0%3A+register+%27huawei_cdc_ncm%27+at+usb-ehci-platform.0-1&hl=it
