  • 6118628 Visite
  • 3417
Re:[GUIDA] Root e Modding Smart Modem Plus AGTEF DGA4130 (VBNT-K)
« Risposta #9450 il: 28 Giugno 2021, 19:38 »
Sempre la stessa storia: cambia IP sulla LAN in modo che sia nella stessa subnet ma non abbia lo stesso ip del router a monte, disattiva DHCP, e ficca il cavetto che proviene dal modem a monte in una delle porte LAN.
Offline BTrRJ
« Risposta #9451 il: 05 Luglio 2021, 08:53 »
Hi all!
I´m from Brazil and i´m using a capped TIM DGA4130 modem here.
I want to root it (or install custom firmware) mainly for 2 things: 1- Use the USB Ports to share my printer and make an external HDD file server. 2- Have a fully functional router.
I tried to follow the steps but i don´t  even know where to start. I´m no inexperienced user but all steps seems very confuse to me. So i can´t even begin, and need your help!
Here are the main gateway and information screen:
Where can i start to root this modem, which tutorial and firmware should i follow? Please help me here...
Any help would be very appreciated, i thank you all
« Risposta #9452 il: 05 Luglio 2021, 09:40 »
Start here: https://hack-technicolor.readthedocs.io/en/stable/
As you can see your firmware is not supported yet, so try some Type 2 root strategies first. If you manage to get root into the UVE firmware make sure you take a backup dump before installing a different firmware from TIM or doing any custom mods.
I suggest you to open a new model support request issue here: https://github.com/hack-technicolor/hack-technicolor/issues
Offline BTrRJ
« Risposta #9453 il: 06 Luglio 2021, 06:34 »
I opened the request on github, thanks.
Tried almost all type 2 root access with no success. Is there any more thing i can try?
Can i try to update firmware to one of the AGTEF ones (1.0.3 or 1.0.4 (same firmware version as mine)) without root? How can i do a dump?
« Ultima modifica: 06 Luglio 2021, 09:59 da MisterFTTH »
  • 3417
« Risposta #9454 il: 07 Luglio 2021, 00:40 »
Also the #D strategy failed? in the #C was the ACS url set? do you have the Update firmware option on your firmware in the gateway modal or somewhere else?
You can forcely change the firmware via TFTP or via the upgrade option, but you will potentially lose the old firmware with no possibility to go back as no RBI or dumps are in the repo
« Ultima modifica: 07 Luglio 2021, 00:47 da FrancYescO »
Offline BTrRJ
« Risposta #9455 il: 07 Luglio 2021, 05:26 »
#D strategy i coudn't login using the engineer user, the default's gateway password didn't work.
On C# it wouldn't pass the second step, locks up there...
Yes, it has a firmware upgrade under Gateway tab, i could use it...but it is like you said. I fear to lose something like VOIP or essential messing with Firmware. Best path should be root, but i don´t know more what to do...
« Ultima modifica: 07 Luglio 2021, 09:52 da MisterFTTH »
Offline lorenzocanalelc
  • 678
« Risposta #9456 il: 21 Luglio 2021, 17:29 »
Nuovo Firmware Stabile AGTEF_2.3.0_CLOSED, non so se verrà rilasciato ma è base 19.4
https://www.mediafire.com/file/2uqgftgt9srifq6/AGTEF_2.3.0_CLOSED.rbi/file
Attenzione, sconsiglio vivamente l'update se si ha la GUI (Io non ho testato personalmente)
« Ultima modifica: 21 Luglio 2021, 17:36 da lorenzocanalelc »
Offline bovirus
  • 301
« Risposta #9457 il: 21 Luglio 2021, 21:13 »
@lorenzocanalelc
Grazie per il firmware.
Per il modem ed il frimware esiste un thread dedicato (vedi link firma).
  • 678
« Risposta #9458 il: 22 Luglio 2021, 09:48 »
Si, hai ragione, ho scritto in questo perché è quello in evidenza, metto i due firmware sui relativi thread
Offline ftp30
« Risposta #9459 il: 30 Luglio 2021, 00:11 »
Immagino che sarà una domanda trita & ritrita... ma ho fatto search (e se l'ho fatto male siate indulgenti).
Voglio levare il DGA 4130 e metter il 7590 (Fritz). ma mi servono tutte le configurazioni per mantenere il Voip e l'IP fisso (è una linea Business).
NON ho le credenziali TIM, quindi non posso usare il giochino dell'App mobile e mi devo attenere al piano di "leggere in chiaro la configurazione attuale del DGA 4130.
Per fare questo ho capito che posso sbloccare il DGA4130 con la procedura TIM che si trova qui https://www.ilpuntotecnico.com/forum/index.php/topic,78162.0.html
dovrei avere accesso al DGA "sbloccato".
Domande semplici alle quale servirebbe un Vostro graditissimo riscontro:
A) il link suggerito dice TIM Hub AGTHP DGA4132, va bene anche per il mio AG EVO (più giù ci sono le info relative al mio HW) ? Si sblocca nello stesso modo??
B) Se adesso con il Router, ancora in configurazione TIM, faccio l'export della configurazione, poi, una volta sbloccato con il metodo trovato https://www.ilpuntotecnico.com/forum/index.php/topic,78162.0.html, posso fare il Restore o l'import della configurazione esportata ottenendo le stesse caratteristiche operative precedenti?
C) conoscete altri metodi più semplici ai quali non sto pensando?
/grazie in anticipo
Product Vendor
Technicolor
Product Name
AGEVO
Software Version
AGTEF_2.2.1
Datapump Version
fsdfsdfgsdfsdfgsdfg
Firmware OID
dsfgsdfgsdfgsdfgsgsdfg
Bootloader Version
16.11.1013-0000000-20160314084347-870409210027d7bcfa4d54666160c0bb5322e291
Bootloader OID
unofficialbuildOID0000
Hardware Version
VBNT-K
Serial Number
xyxyxyxyxxyxx
MAC Address
XX:YY:ZZ::31:6F
  • 3417
« Risposta #9460 il: 30 Luglio 2021, 01:25 »
Si la guida è quella (ma devi usare il firmware AGTEF per il downgrade come indicato)
La via più semplice è semplicemente attaccare il 7590, e selezionare Tim dal wizard iniziale di configurazione, anche il VoIP si autoconfigurerá.
Offline ftp30
« Risposta #9461 il: 30 Luglio 2021, 23:52 »
Intanto grazie ;).
Perdona se chiedo, ma siccome è una linea business, sei sicuro che attacco il 7590 (comprato da una grande catena di ditribuzione) lo attacco alla linea, scelgo TIM e "automaticamente" si configura tutto e prende le credenziali Voip giuste e si rialloca l'IP statico che ho sul DGA 4170?
Grazie in anticipo :help:
  • 3417
« Risposta #9462 il: 31 Luglio 2021, 02:08 »
Sinceramente non ne ho la certezza, ma insomma provare non ti costa niente, ipotizzo l'IP fisso sicuro è da mettere manualmente
« Risposta #9463 il: 31 Luglio 2021, 11:49 »
@ftp30 se non è cambiato qualcosa ultimamente, anche i Fritz non distrbuiti direttamente da TIM - e con FW aggiornato - una volta scelto il profilo adeguato si interfacciano con l'opportuno server TIM per scaricare la configurazione dati e fonia.
Non dovesse accadere poco male, puoi procedere manualmente seguendo QUESTE indicazioni.
@FrancYescO l'IP PtP è assegnato alla PPPoE utilizzando credenziali ad hoc  :P
« Ultima modifica: 31 Luglio 2021, 11:50 da MisterFTTH »
  • 3417
« Risposta #9464 il: 31 Luglio 2021, 12:12 »
Ah pensavo fosse una IPoE ma forse sono altre tipologie di contratto
