TIM Hub DGA4132 (AGTHP) configurazione Vodafone
  • 237 Risposte
  • 116405 Visite
  • 3417
Re:TIM Hub DGA4132 (AGTHP) configurazione Vodafone
« Risposta #45 il: 17 Agosto 2019, 17:49 »
fate da ssh un bel cat /etc/config/mmpbx* condividetelo (ovviamente censurate il vostro numero di telefono/password) e confrontate le configurazioni...
Offline simosimone97
  • 37
« Risposta #46 il: 17 Agosto 2019, 18:20 »
Io ho anche copiato e incollato il suo file mmpbx in etc/config, ma continua a darmi registrazione rifiutata
Offline mastro1965
« Risposta #47 il: 17 Agosto 2019, 19:04 »
il mio mmpbxrvsipnet
config mmpbxrvsipnet 'global'
option trace_level '2'
option radvision_trace_level '0'
option mtf_priority '0'
config syslog 'syslog'
option registration '1'
option call_signalling '1'
option syslog_priority '6'
option hide_user_identity '0'
option log_sip_message '0'
config network 'sip_net'
option cac '-1'
option transparent_soc_transmission '0'
option interface 'wan'
option local_port '5060'
option primary_proxy_port '0'
option primary_registrar_port '5060'
option secondary_proxy_port '0'
option transport_type 'UDP'
option reg_expire_T_before '1'
option reg_back_off_timeout_algorithm 'exponential'
option reg_back_off_timeout_max '1920'
option reg_back_off_timeout_min '60'
option reg_back_off_on_500_response '0'
option realm_check '0'
option 401_407_waiting_time '0'
option dtmf_relay_translation '0'
option timer_T1 '500'
option timer_T2 '4000'
option timer_T4 '5000'
option timer_B '32000'
option timer_D '50000'
option timer_F '32000'
option timer_J '32000'
option remote_hold_tone_enabled '0'
option sdp_direction_call_hold 'sendonly'
option sdp_direction_call_hold_answer 'recvonly'
option uri_clir_format 'standard'
option privacy_handling 'apply'
option rejection_response '486'
option no_answer_response '480'
option call_waiting_reject_response '486'
option ingress_media_timeout '1000'
option min_session_expires '90'
option session_expires '180'
option fail_behaviour 'stop'
option min_period_proxy_redundancy '0'
option escape_hash '1'
option escape_star '0'
option control_qos_field 'dscp'
option realtime_qos_field 'dscp'
option from_anonymous_handling 'withheld'
option sip_over_ipv6 '0'
option rtp_local_port_min '16384'
option rtp_local_port_max '32767'
option user_param_value 'phone'
option include_sip_instance '1'
option feature_tag_value 'urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel'
option waiting_time_for_registration_on_400_or_503_response '60'
option conference_factory_uri_user_part '[email protected]'
option hide_serial_number '1'
option use_domain_in_contact '0'
option use_domain_in_via '0'
option update_support '1'
option sdp_direction_attribute_media_level_only '1'
option stick_to_outbound_proxy '1'
option registration_delay '5'
option enable_re_register_on_cancel_timeout '1'
option rport_in_via '1'
option optimized_authentication '1'
option repeat_ringing_interval '0'
option re_register_on_403 '0'
option check_ttl_for_dns_record '1'
option dns_query_timeout '5000'
option sip_message_max_size '4096'
option switch_back_to_primary_proxy_timer '0'
option conference_release_call_after_transfer '0'
option disconnect_on_bye_response '1'
option cancel_invite_timer '64000'
option dnd_response '486'
option early_media_detection '1'
option hide_userinfo_and_port_in_subscription_request '0'
option tls_support '0'
option tls_port '5061'
option tls_key_type 'rsaprivatekey'
option certificate_depth '5'
option tls_encryption_method 'ssl_v3'
option assert_tls_connection '0'
option hook_flash_relay '0'
option user_agent 'Technicolor / VBNT-S / AGTHP_2.2.0_001 / AGTHP_2.2.0_001'
option realtime_qos_value 'af42'
option re_registration_mode 'standard'
option session_timer 'enabled'
option control_qos_value 'ef'
option dtmf_relay 'auto'
option forking_mode 'default'
option call_waiting_provisional_response '182'
option reg_back_off_timeout '180'
option reliable_provisional_response 'supported'
option secondary_registrar_port '5060'
option domain_name 'ims.vodafone.it'
option primary_proxy 'Voip1.fixed.vodafone.it'
list ca_certificates ''
option reg_expire '3600'
option primary_registrar 'ims.vodafone.it'
option provisional_timer '180'
option user_friendly_name 'vodafone'
config profile 'sip_profile_0'
option network 'sip_net'
option display_name '****************'
option user_name '***************@ims.vodafone.it'
option enabled '1'
option uri '+******************'
option password '++++++++++++++++++++++++++++++++++++'
config profile 'sip_profile_1'
option enabled '0'
option user_name 'line1'
option uri 'line1'
option password 'line1'
config profile 'sip_profile_2'
option enabled '0'
option user_name 'line2'
option uri 'line2'
option password 'line2'
« Ultima modifica: 18 Agosto 2019, 10:23 da MisterFTTH »
  • 37
« Risposta #48 il: 17 Agosto 2019, 21:30 »
option cac '-1'
option call_waiting_alert_info '0'
option primary_proxy 'Voip3.fixed.vodafone.it'
option enabled '1'
option uri '+numeroditelefono'
option user_name '[email protected]'
option display_name '+numeroditelefono'
option enabled '0'
option uri 'line1'
option enabled '0'
option uri 'line2'
Ecco il mio mmpbxrvsipnet
« Ultima modifica: 18 Agosto 2019, 10:22 da MisterFTTH »
Offline mastro1965
« Risposta #49 il: 17 Agosto 2019, 21:46 »
 option call_waiting_alert_info '0'    a me manca
 option control_qos_value 'ef'  a  te manca
 option reliable_provisional_response 'supported' a me manca
queste  le differenze
  • 37
« Risposta #50 il: 17 Agosto 2019, 23:11 »
Anche rimuovendo ciò che è in più continua a non andare
Offline mastro1965
« Risposta #51 il: 17 Agosto 2019, 23:32 »
se  non erro  avevo letto da qualche parte  che  il  voip3.fixed.vodafone.it  era pu ostico  rispetto a  voip1.fixed.vodafone.it  stentavo  a crederci .. ma  a quanto  pare   ... è cosi e  non so che pesci  pigliare .. mi spiace   :'(
  • 37
« Risposta #52 il: 17 Agosto 2019, 23:52 »
Domani per sicurezza riprovo a fare la procedura da zero, spero che almeno così si risolva, sennò non so cosa fare  :'(
  • 3417
« Risposta #53 il: 18 Agosto 2019, 03:17 »
@mastro1965 a te che funziona hai provato a mettere al posto di voip1, voip2 o voip3.fixed....
Magari è come con Tiscali che vengono assegnati dei server ma sono comunque intercambiabili
E anche se non funziona controlla il codice di errore che ti viene fuori nella pagina statistiche
Un'altro valore che potrebbe influire è quello del nat helper SIP ma se partite entrambi con una configurazione pulita la cosa è davvero strana...
Offline mastro1965
« Risposta #54 il: 18 Agosto 2019, 10:21 »
allora  con  voip3.fixed.vodafone.it non mi  va piu e da  questi errori
Aug 18 10:06:34 user.debug mmpbxd[16045] [MMRVSIPIMPL::REGTERMOBJ]:E: regTermObjFirewallRuleUpdate:4158 - Unable to retrieve currentDestination from SIP network ..
Aug 18 10:06:34 user.debug mmpbxd[16045] [MMRVSIPIMPL::NETWORKOBJ]:C: onStackLogEvent:2052 - TRANSC_CLIE - TranscClientDNSContinue: Transc-client 0x0x1935188 - no failed message. transc-client state - Failed
Aug 18 10:06:34 user.info mmpbxd[16045] SIP Registration: SIP: +************* : Deregister
Aug 18 10:06:34 user.info mmpbxd[16045] SIP Registration: SIP: +************* : Failure Reason: 403 Forbidden
la cosa  strana che adesso rimettendo  il server giusto non va piu ...  adesso devo capire  cosa ha cambiato ..
« Ultima modifica: 18 Agosto 2019, 10:24 da MisterFTTH »
  • 37
« Risposta #55 il: 18 Agosto 2019, 11:37 »
@mastro1965 sei riuscito a rimettere a posto il tuo numero di telefono con il VoIP? io provo a rifare tutta la procedura da capo sul mio per vedere se riesco ad impostarlo
Ma se io rimuovo il root dopo posso rifarlo oppure non mi è più consentito?
« Ultima modifica: 18 Agosto 2019, 11:52 da simosimone97 »
Offline mastro1965
« Risposta #56 il: 18 Agosto 2019, 12:07 »
non va  ancora .. il  root  lo puoi rifare  se metti  il  firmware 103
e mi sa che  dovro  farlo pure io ...
Offline mastro1965
« Risposta #57 il: 18 Agosto 2019, 14:44 »
ok  ora funziona ancora ..  ho dovuto   resettare tutto  e  caricare  firmware  1.03 tramite  tftp  per essere sicuro  di  cancellare tutto
una  volta  fatto  ho rimesso la  gui  ansuel  .. rimesso  tutti  i parametri a mano  senza  passare  dal  wizard ..( fa  qualche  casino ancora )
la  telefonia  funziona  anche col firmware  1.03  tra un po  rimeto  ultimo  firmware  e sono a posto :)
  • 37
« Risposta #58 il: 18 Agosto 2019, 16:10 »
@mastro1965 come si fa con tftp ? Io ho rimosso il root ma la versione è ancora la AGTHP _2.2.0_001_
  • 3417
« Risposta #59 il: 18 Agosto 2019, 19:51 »
cmq 403 significa appunto che con il server voip ci comunica... da quanto vedo invece simo riceve solo timeout il che e' un po diverso, sembra lui abbia proprio qualche problema di routing...
@simosimone97 e' inutile che scomodi tftp, fai lo sblocco normale tenendolo staccato dal doppino, flasha il firmware 1.0.3 da interfaccia e rifai tutta la tiritera per il root e riaggiornare, cmq fare l'unroot e' superfluo basta un reset (non di config ma completo) nella maggior parte dei casi
