  • 1597 Risposte
  • 910465 Visite
Offline ramponis
  • 888
« Risposta #585 il: 29 Novembre 2019, 14:26 »
Confermo anche io il problema sia con wget che opkg update:
root@OpenWrt:/tmp# nslookup repository.ilpuntotecnico.com
Server:    62.101.93.101
Address 1: 62.101.93.101 anyres1.fastwebnet.it
Address 1: 2606:4700:30::681f:4c3a
Address 2: 104.31.76.58
Address 3: 104.31.77.58
root@OpenWrt:/tmp# wget https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/base/badblocks_1.42.12-1_brcm63xx-tch.ipk
Connecting to repository.ilpuntotecnico.com (104.31.76.58:443)
wget: error getting response: Connection reset by peer
root@OpenWrt:/tmp#
Provider fastweb
« Risposta #586 il: 29 Novembre 2019, 15:08 »
Ma riesci a scaricare da un altro sito in https?
Offline ramponis
  • 888
« Risposta #587 il: 29 Novembre 2019, 15:44 »
Certo, nussun problema...
root@OpenWrt:~# cd /tmp/
root@OpenWrt:/tmp# wget https://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/x/fujifilm_xm1_manual_it.pdf
Connecting to www.fujifilm.com (54.201.103.159:443)
root@OpenWrt:/tmp# wget https://files.canon-europe.com/files/soft38021/manual/EOS%20550D_HG_IT_Flat.pdf
Connecting to files.canon-europe.com (84.53.184.18:443)
root@OpenWrt:/tmp# wget https://www.nikonsupport.eu/europe/Manuals/vqUaOfFVeV/d90_it_06.pdf
Connecting to www.nikonsupport.eu (188.138.80.247:443)
root@OpenWrt:/tmp# wget http://gdlp01.c-wss.com/gds/7/0300027837/01/EOS_6D_Mark_II_Instruction_Manual_IT.pdf
Connecting to gdlp01.c-wss.com (23.0.35.174:80)
root@OpenWrt:/tmp# wget https://www.cinquephoto.com/wp-content/uploads/2017/11/Manuale-Canon-EOS-200D.pdf
Connecting to www.cinquephoto.com (192.124.249.104:443)
root@OpenWrt:/tmp#
Cercato dei pdf a caso... solo nikonsupport ha fallito come il repository
« Risposta #588 il: 29 Novembre 2019, 16:14 »
Se non basta ca-certificates wget bisogna installare anche libopenssl ma non dai repo di roleo ma da qui
src/gz base https://raw.githubusercontent.com/BoLaMN/brcm63xx-tch/master/packages/base
src/gz luci https://raw.githubusercontent.com/BoLaMN/brcm63xx-tch/master/packages/luci
src/gz management https://raw.githubusercontent.com/BoLaMN/brcm63xx-tch/master/packages/management
src/gz packages https://raw.githubusercontent.com/BoLaMN/brcm63xx-tch/master/packages/packages
src/gz routing https://raw.githubusercontent.com/BoLaMN/brcm63xx-tch/master/packages/routing
src/gz telephony https://raw.githubusercontent.com/BoLaMN/brcm63xx-tch/master/packages/telephony
Offline ramponis
  • 888
« Risposta #589 il: 29 Novembre 2019, 16:49 »
Ciao fatto il downgrade alla versione indicata:
root@OpenWrt:/tmp# opkg install --force-downgrade libopenssl_1.0.2n-1_brcm63xx-tch.ipk
Downgrading libopenssl on root from 1.0.2q-2 to 1.0.2n-1...
Configuring libopenssl.
root@OpenWrt:/tmp# wget https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/luci/Packages.gz
Ha fixato il download da nikonsupport, ma non dal repository
« Risposta #590 il: 29 Novembre 2019, 17:43 »
Io sono messo così:
root@openwrt:/tmp# opkg list-installed |grep ssl
libmosquitto-ssl - 1.4.10-2
libopenssl - 1.0.2n-1
openssl-util - 1.0.2n-1
root@openwrt:/tmp# opkg list-installed |grep wget
wget - 1.17.1-1
root@openwrt:/tmp# opkg list-installed | ca-certificates
-ash: ca-certificates: not found
root@openwrt:/tmp#
root@openwrt:/etc# opkg install ca-certificates
Installing ca-certificates (20161130+nmu1) to root...
Downloading https://raw.githubusercontent.com/BoLaMN/brcm63xx-tch/master/packages/base/ca-certificates_20161130+nmu1_all.ipk
Collected errors:
 * check_data_file_clashes: Package ca-certificates wants to install file /etc/ssl/certs/578d5c04.0
But that file is already provided by package  * https-certificates
 * check_data_file_clashes: Package ca-certificates wants to install file /etc/ssl/certs/aee5f10d.0
 * opkg_install_cmd: Cannot install package ca-certificates.
root@openwrt:/etc# opkg list-installed | grep https-certificates
https-certificates - 0.1-1
root@openwrt:/etc#
« Ultima modifica: 29 Novembre 2019, 17:50 da larsen64it »
Offline ramponis
  • 888
« Risposta #591 il: 29 Novembre 2019, 18:20 »
Elimina i due certificati e poi riprova l'installazione
rm /etc/ssl/certs/578d5c04.0
rm /etc/ssl/certs/aee5f10d.0
« Risposta #592 il: 29 Novembre 2019, 18:35 »
ca-certificates va installato con --force-overwrite o qualcosa del genere.
Probabilmente l'aver installato una versione non corretta di openssl ha rotto la compatibilità con alcuni server. Io non ho problemi a scaricare da qualsiasi di quei link.
« Risposta #593 il: 29 Novembre 2019, 20:05 »
Con
wget - 1.17.1-1
non ho problema a scaricare da tutti i repo.
Offline LorenzoL
  • 417
« Risposta #594 il: 01 Dicembre 2019, 00:08 »
Ciao, anzitutto grazie @LuKePicci per l'ottima guida e anche agli altri esperti che postano qui. Avrei un problemino di poco conto che mi piacerebbe comunque risolvere. Ho rootato il 4131 e ho installato la GUI di Ansuel; tutto funziona a dovere, a parte quando tento di modificare qualche parametro Wifi da GUI, poiché mi appare sempre questo errore:
Alcuni parametri hanno fallito la convalida
wps_button_handler: Valore non valido.
Inoltre rimane sempre bloccato  al led lampeggiante verde 'verifica connessione'
Ovviamente la modifica la posso fare via WinSCP, ma se fosse possibile risolvere il problemino sarei contento.
RISOLTO: ho reinstallato la gui+upgradeGUI; ho dovuto riscrivere la stringa modificata in etc/config/button > WPS perché era scomparsa. Rimarrebbe solo da sistemare il led verde che lampeggia all'infinito.
« Ultima modifica: 01 Dicembre 2019, 03:33 da LorenzoL »
Offline Buta4kun
  • 17
« Risposta #595 il: 06 Dicembre 2019, 12:36 »
Buongiorno ragazzi. Mi spiace disturbare ma vorrei un vostro parere. Seguendo le indicazioni reperite sul forum ho installato la GUI mod, fixato i problemi di pianificazione del wifi, associato l'attivazione/disattivazione del wifi a un tasto fisico. Ringrazio tutti per questo. Ora il mio problema attuale è che vorrei utilizzare il Fastgate come print server. Connetto la mia HP multifunzione all'USB del router, che la rileva correttamente. Attivo DNLA, condivisione stampante. Vado su stampanti di Win10, aggiungo stampanti ma non trova nulla... Poco male, mi dico. Il router stesso non è visibile su risorse di rete di WIn10 se non connettendo un percorso di rete tramite IP (misteri di WIn10... Mi capita anche con il pc dell'ufficio; evidentemente c'è qualcosa, anzi più di qualcosa, che mi sfugge...).
Aggiungo la stampante tramite TCP/IP, associo i driver giusti, la stampante si installa ma in realtà non comunica con il PC. Sono abbastanza convinto che il problema sia di WIn10 e non del Fastgate, ma il risultato non cambia...
Qualche anima pia ha informazioni da darmi su come risolvere il problema? Ancora una volta credevo che fosse semplice utilizzare il router come print server. Ancora una volta mi sbagliavo...
Scusate il pippone e grazie per la collaborazione.
Buona giornata a tutti
« Risposta #596 il: 06 Dicembre 2019, 14:13 »
Per iniziare.
La cosa più difficile di installare una stampante di rete e disinstallarla:
https://gioxx.org/2015/10/16/rimozione-delle-stampanti-di-rete-o-locali-da-registro-di-windows/
Visto che cups server è installato ed attivabile da gui mod consiglio di usalo:
Collega la stampante al router
Accedi all pagina
http://iprouter:631/admin
ed aggiungi la stampante seguendo la procedura guidata
poi
https://zedt.eu/tech/windows/installing-an-ipp-printer-in-windows-10/
https://www.markreds.it/2008/03/27/stampare-con-cups-da-windows/
« Risposta #597 il: 06 Dicembre 2019, 14:53 »
Disabilita la condivisione stampanti tramite samba d vai con cups come ti ha detto @larsen64it
Offline Buta4kun
  • 17
« Risposta #598 il: 06 Dicembre 2019, 15:51 »
Grazie ragazzi! Gentilissimi... Stasera secondo round (sperando di finire prima dell due, come stanotte...). Ho smanettato su CUPS però siccome quella U sta per Unix, pensavo di non averne bisogno, beata ignoranza... Vi faccio sapere. Buona giornata e un saluto a tutti
Offline Buta4kun
  • 17
« Risposta #599 il: 09 Dicembre 2019, 09:32 »
Grazie al vostro aiuto ho condiviso la stampante tramite Fastgate. Ora non mi resta che capire se e come condividere anche lo scanner (trattasi di multifunzione HP)... Grazie ancora e buona giornata a tutti.
