  • 1597 Risposte
  • 913409 Visite
Offline sob0
  • 18
« Risposta #1110 il: 03 Giugno 2020, 09:30 »
Prove effettuate sulla 1° porta lan. A4:9x:xx:xx:xx:F2 E' il MAC originale del DGA. 10:1x:xx:xx:xx:EA invece è quello che ho preso dal TG1100
route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         10.192.216.65   0.0.0.0         UG    0      0        0 eth4
10.192.216.64   *               255.255.255.192 U     0      0        0 eth4
81.208.50.214   10.192.216.65   255.255.255.255 UGH   0      0        0 eth4
169.0.0.0       *               255.255.255.0   U     0      0        0 eth4
192.168.1.0     *               255.255.255.0   U     0      0        0 br-lan
192.168.78.0    *               255.255.255.0   U     0      0        0 wl0_2
239.0.0.0       *               255.0.0.0       U     0      0        0 br-lan
ifconfig
6rd-6rd   Link encap:IPv6-in-IPv4
          inet6 addr: 2001:b07:ac0:d876::1/32 Scope:Global
          inet6 addr: ::10.192.216.118/96 Scope:Compat
          UP RUNNING NOARP  MTU:1280  Metric:1
          RX packets:5371 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4339 errors:0 dropped:845 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:652536 (637.2 KiB)  TX bytes:525434 (513.1 KiB)
bcmsw     Link encap:Ethernet  HWaddr A4:9x:xx:xx:x2:F2
          RX packets:100768 errors:0 dropped:0 overruns:0 frame:0
          TX packets:103046 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:15689165 (14.9 MiB)  TX bytes:63567572 (60.6 MiB)
          Base address:0xffff
br-lan    Link encap:Ethernet  HWaddr A4:9x:xx:xx:xx:F2
          inet addr:192.168.1.254  Bcast:192.168.1.255  Mask:255.255.255.0
          inet6 addr: fe80::a691:b1ff:feb4:92f2/64 Scope:Link
          inet6 addr: 2001:b07:ac0:d876::1/64 Scope:Global
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:188282 errors:0 dropped:92 overruns:0 frame:0
          TX packets:215132 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:167086245 (159.3 MiB)  TX bytes:178440302 (170.1 MiB)
eth0      Link encap:Ethernet  HWaddr A4:9x:xx:xx:xx:F2
          RX packets:21664 errors:0 dropped:103 overruns:0 frame:0
          TX packets:30936 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3416856 (3.2 MiB)  TX bytes:32685198 (31.1 MiB)
eth1      Link encap:Ethernet  HWaddr A4:9x:xx:xx:xx:F2
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth2      Link encap:Ethernet  HWaddr A4:9x:xx:xx:xx:F2
eth3      Link encap:Ethernet  HWaddr A4:9x:xx:xx:xx:F2
          RX packets:11419 errors:0 dropped:633 overruns:0 frame:0
          TX packets:7239 errors:0 dropped:24 overruns:0 carrier:0
          RX bytes:1688023 (1.6 MiB)  TX bytes:4581120 (4.3 MiB)
eth4      Link encap:Ethernet  HWaddr 10:1x:xx:xx:xx:EA
          inet addr:169.0.0.2  Bcast:169.0.0.255  Mask:255.255.255.0
          inet6 addr: fda2:81b8:d2b7::1/64 Scope:Global
          inet6 addr: fe80::1213:31ff:fe1f:ceea/64 Scope:Link
          RX packets:251670 errors:0 dropped:0 overruns:0 frame:0
          TX packets:180648 errors:0 dropped:16 overruns:0 carrier:0
          RX bytes:162853444 (155.3 MiB)  TX bytes:159500474 (152.1 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:204 errors:0 dropped:0 overruns:0 frame:0
          TX packets:204 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:34571 (33.7 KiB)  TX bytes:34571 (33.7 KiB)
vlan_eth4 Link encap:Ethernet  HWaddr 10:1x:xx:xx:xE:EA
          TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:438 (438.0 B)
wl0       Link encap:Ethernet  HWaddr A4:9x:xx:xx:x2:F3
          inet6 addr: fe80::a691:b1ff:feb4:92f3/64 Scope:Link
          RX packets:76039 errors:0 dropped:2 overruns:0 frame:644293
          TX packets:161830 errors:1 dropped:0 overruns:0 carrier:0
          RX bytes:53879784 (51.3 MiB)  TX bytes:122227876 (116.5 MiB)
          Interrupt:92
wl0_1     Link encap:Ethernet  HWaddr A4:9x:xx:xx:x2:F3
          RX packets:0 errors:0 dropped:0 overruns:0 frame:644293
wl0_2     Link encap:Ethernet  HWaddr A4:9x:xx:xx:x2:F3
          inet addr:192.168.78.1  Bcast:192.168.78.255  Mask:255.255.255.0
wl0_3     Link encap:Ethernet  HWaddr A4:xx:xx:xx:92:F3
wl1       Link encap:Ethernet  HWaddr A6:9x:xx:xx:92:FB
          inet6 addr: fe80::a491:b1ff:feb4:92fb/64 Scope:Link
          RX packets:86273 errors:0 dropped:0 overruns:0 frame:0
          TX packets:82115 errors:0 dropped:240 overruns:0 carrier:0
          RX bytes:108620270 (103.5 MiB)  TX bytes:18730040 (17.8 MiB)
wl1_1     Link encap:Ethernet  HWaddr A6:xx:xx:xx:92:FB
          TX packets:36486 errors:0 dropped:14 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:7738676 (7.3 MiB)
wl1_2     Link encap:Ethernet  HWaddr A6:9x:xx:xx:92:FB
wl1_3     Link encap:Ethernet  HWaddr A6:xx:xx:xx:92:FB
Per quanto riguarda ifstatus non so come si utilizzi :noob: , quindi ho provato sia con la voce ifstatus wan e ifstatus lan. Se serve altro rimango a disposizione.
root@OpenWrt:~# ifstatus wan
        "up": true,
        "pending": false,
        "available": true,
        "autostart": true,
        "dynamic": false,
        "uptime": 36531,
        "l3_device": "eth4",
        "proto": "dhcp",
        "device": "eth4",
        "metric": 0,
        "dns_metric": 0,
        "delegation": true,
        "ipv4-address": [
                        "address": "10.192.216.118",
                        "mask": 26
        "ipv6-address": [
        "ipv6-prefix": [
root@OpenWrt:~# ifstatus lan
        "up": true,
        "pending": false,
        "available": true,
        "autostart": true,
        "dynamic": false,
        "uptime": 36871,
        "l3_device": "br-lan",
        "proto": "static",
        "device": "br-lan",
        "updated": [
                "addresses"
        "metric": 0,
        "dns_metric": 0,
        "delegation": true,
        "ip6weight": 1,
        "ipv4-address": [
                        "address": "192.168.1.254",
                        "mask": 24
        "ipv6-address": [
        "ipv6-prefix": [
        "ipv6-prefix-assignment": [
                        "address": "2001:b07:ac0:d876::",
                        "mask": 64,
                        "local-address": {
                                "address": "2001:b07:ac0:d876::1",
                                "mask": 64
        "route": [
        "dns-server": [
        "dns-search": [
        "inactive": {
                "ipv4-address": [
                "ipv6-address": [
                "route": [
                "dns-server": [
                "dns-search": [
        "data": {
« Ultima modifica: 03 Giugno 2020, 22:29 da MisterFTTH »
« Risposta #1111 il: 03 Giugno 2020, 09:58 »
Ok, in pratica ti manca l'ipv4 (il .118) su eth4, che però il dhcp vedo ti ha correttamente assegnato. Prova a disabilitare l'interfaccia SFP, mettici una option auto '0' e riavvia tutto. Vediamo se in mancanza dell'altro indirizzo glielo assegna correttamente. Devi anche spegnere il wansensing, mettigli enable su 0.
PS: sulo una curiosità, ma quell'81.x.x.214 è il tuo ip pubblico statico?
PS 2: in vlan_eth4 hai messo il mac del tg1100, non serve perchè quella non la stai usando, rimetti quello originale
« Ultima modifica: 03 Giugno 2020, 10:11 da LuKePicci »
  • 3401
« Risposta #1112 il: 03 Giugno 2020, 10:14 »
penso sia il gw di uscita di fastweb
Offline sob0
  • 18
« Risposta #1113 il: 03 Giugno 2020, 11:01 »
Faccio subito un tentativo.
Il mio IP pubblico statico è del tipo 2.235.xxx.xxx (per lo meno, è questo sul TG)
Quindi in network metto
config device 'vlan_eth4'
option type '8021q'
option ifname 'eth4'
option mtu '1500'
option name 'vlan_eth4'
option vid '835'
  option macaddr 'A4:xx:xx:xx:xx:F2'
config interface 'sfp'
option proto 'static'
option ipaddr '169.0.0.2'
        option auto '0'
E su wansensing metto
config wansensing 'global'
option enable '0'
Riavviato.
Rieseguendo ifstatus wan sembra simile
ifstatus wan
        "up": true,
        "pending": false,
        "available": true,
        "autostart": true,
        "dynamic": false,
        "uptime": 209,
        "proto": "dhcp",
        "device": "eth4",
        "updated": [
                "data"
        "metric": 0,
        "dns_metric": 0,
        "delegation": true,
        "ipv4-address": [
                        "mask": 26
        "ipv6-address": [
        "ipv6-prefix": [
                        "address": "fda2:81b8:d2b7::",
                        "mask": 64,
                        "local-address": {
                                "address": "fda2:81b8:d2b7::1",
                                "mask": 64
        "route": [
                        "target": "0.0.0.0",
                        "mask": 0,
                        "nexthop": "10.192.216.65",
                        "source": "10.192.216.118\/32"
        "dns-server": [
                "83.103.25.250",
                "62.101.93.101"
        "dns-search": [
                "fastwebnet.it"
        "inactive": {
                "ipv4-address": [
                "ipv6-address": [
                "route": [
                "dns-server": [
                "dns-search": [
        "data": {
                "leasetime": 28800,
                "passthru": "0104ffffffc003040ac0d8410608536719fa3e655d650f0d666173747765626e65742e69742b290127687474703a2f2f35392e302e3132312e3139313a383038302f4143532d7365727665722f41435333040000708036040afe03fd3a04000038403b040000387cd416002020010b0700000000000000000000000051d032d6"
Se servono anche gli altri comandi li giro qui. Per ora il problema sull'ipv4 rimane
« Ultima modifica: 03 Giugno 2020, 11:45 da sob0 »
« Risposta #1114 il: 03 Giugno 2020, 12:13 »
si mi servono sempre anche ifocnfig, route e il contenuto di network. In quest'ultimo devo vedere se è cambiato qualcosa dopo aver spento wansensing, visto che da quanto dicevi disattivandolo avevi un "peggioramento". Da ifconfig devo vedere cosa ha attualmente assegnato come ipv4 la porta eth4. Da route devo controllare che non sia cambiato nulla. Fai anche un "/etc/init.d/network restart" e logread, vediamo se segnala qualche errore in fase di setup dell'ip ricevuto.
E' facile che se ti dico di impostare a mano l'ip su eth4 - sempre dopo averlo comunque ricevuto in dhcp - poi ti funziona ma dobbiamo capire perchè non succede in automatico.
« Ultima modifica: 03 Giugno 2020, 12:14 da LuKePicci »
Offline sob0
  • 18
« Risposta #1115 il: 03 Giugno 2020, 12:26 »
Si, avevo fatto in precedenza un test con wansensing disabilitato e non andava, mi sono stupito di aver ottenuto un risultato diverso.
Ifconfig
ifconfig
          RX packets:342 errors:0 dropped:0 overruns:0 frame:0
          TX packets:236 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:202743 (197.9 KiB)  TX bytes:43959 (42.9 KiB)
bcmsw     Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F2
          RX packets:9109 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8018 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1843922 (1.7 MiB)  TX bytes:1877005 (1.7 MiB)
          Base address:0xffff
br-lan    Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F2
          RX packets:6386 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5228 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1050756 (1.0 MiB)  TX bytes:3005923 (2.8 MiB)
eth0      Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F2
          RX packets:6916 errors:0 dropped:98 overruns:0 frame:0
          TX packets:5787 errors:0 dropped:52 overruns:0 carrier:0
          RX bytes:1117601 (1.0 MiB)  TX bytes:2986215 (2.8 MiB)
eth1      Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F2
eth2      Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F2
eth3      Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F2
eth4      Link encap:Ethernet  HWaddr 10:XX:XX:XX:XX:EA
          inet addr:10.192.216.118  Bcast:10.192.216.127  Mask:255.255.255.192
          RX packets:5269 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4621 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2726119 (2.5 MiB)  TX bytes:698417 (682.0 KiB)
          RX packets:49 errors:0 dropped:0 overruns:0 frame:0
          TX packets:49 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7144 (6.9 KiB)  TX bytes:7144 (6.9 KiB)
vlan_eth4 Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F2
wl0       Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F3
          RX packets:355 errors:0 dropped:1 overruns:0 frame:3392
          TX packets:2120 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:140278 (136.9 KiB)  TX bytes:499935 (488.2 KiB)
          Interrupt:92
wl0_1     Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F3
          RX packets:0 errors:0 dropped:0 overruns:0 frame:3392
wl0_2     Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F3
wl0_3     Link encap:Ethernet  HWaddr A4:XX:XX:XX:XX:F3
wl1       Link encap:Ethernet  HWaddr A6:XX:XX:XX:XX:FB
          TX packets:1899 errors:0 dropped:143 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:436236 (426.0 KiB)
wl1_1     Link encap:Ethernet  HWaddr A6:XX:XX:XX:XX:FB
          TX packets:1894 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:435382 (425.1 KiB)
wl1_2     Link encap:Ethernet  HWaddr A6:XX:XX:XX:XX:FB
          TX packets:1890 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:434035 (423.8 KiB)
wl1_3     Link encap:Ethernet  HWaddr A6:XX:XX:XX:XX:FB
          TX packets:1888 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:433683 (423.5 KiB)
root@OpenWrt:~# route
Network
config interface 'loopback'
option ifname 'lo'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fda2:81b8:d2b7::/48'
option default_ps '0'
config interface 'lan'
option ifname 'eth0 eth1 eth2 eth3'
option type 'bridge'
option ipaddr '192.168.1.254'
option ip6assign '64'
option force_link '0'
option ip6class '6rd'
option ipv6 '1'
option ip6hint '0'
option ip6weight '1'
option stp '1'
option rpfilter '1'
config interface 'Guest'
option ipaddr '192.168.78.1'
option ifname 'wl0_2'
option ipv6 '1'
option ip6hint '1'
option ip6weight '0'
option rpfilter '1'
list pppoerelay ''
config switch 'bcmsw'
option reset '1'
option enable_vlan '0'
option qosimppauseenable '0'
option jumbo '0'
config interface 'wan'
option proto 'dhcp'
option reqopts '1 3 6 15 33 42 43 51 121 249 212'
option vendorid 'Technicolor_DGA4131FWB/dslforum.org'
option authfail '0'
option iface6rd '6rd'
option zone6rd 'wan'
option mtu '1500'
option initboot '1'
option ipv6 '0'
option notused 'A4:XX:XX:XX:XX:F3'
option auto '1'
option macaddr '10:XX:XX:XX:XX:EA'
option ipv4 '1'
option ipaddr '2.235.120.161'
option password 'password'
config interface 'mgmt'
config device 'vlan_ptm0'
option type '8021q'
option ifname 'ptm0'
option mtu '1500'
option name 'vlan_ptm0'
option vid '100'
config interface 'wantag'
option proto 'dhcp'
option reqopts '1 3 6 15 33 42 51 121 249 212'
option authfail '0'
option mtu '1500'
option initboot '1'
option ipv6 '0'
option ifname '@vlan_wan_eth4'
option auto '0'
config interface 'wwan'
option proto 'mobiled'
option session_id '0'
option profile '1'
option iface_464xlat '0'
option auto '0'
option enabled '0'
config interface 'vlan_wan'
option ifname 'vlan_ptm0'
config device 'if0atm'
option enable '1'
option name 'atm0'
config device 'if1atm'
option enable '1'
option name 'atm1'
option type '8021q'
option mtu '1500'
option vid '835'
option macaddr 'A4:XX:XX:XX:XX:F2'
config interface 'vlan_wan_eth4'
option ifname 'vlan_eth4'
option auto '0'
config config 'config'
option wan_mode 'dhcp'
config interface 'ipoe'
option proto 'dhcp'
option metric '1'
option release '1'
option ipv6 '1'
config device 'waneth4'
option enabled '1'
option type '8021q'
option name 'waneth4'
option vid '835'
config device 'wanptm0'
option enabled '1'
option type '8021q'
option name 'wanptm0'
option vid '835'
EDIT
Logread dopo il restart di network. Il comando l'ho dato alle 12.21 circa (minuti piu minuto meno), quindi non so se tutto il pezzo prima possa servire, ma l'ho messo ugualmente.
EDIT: Come non detto, mi dice che il post supera il massimo consentito di caratteri. Cerco di accorciarlo il più possibile
root@OpenWrt:~# logread
Wed Jun  3 12:17:09 2020 daemon.info cwmpd[8518]: PROT_TRACE: Effective retry wait time 498
Wed Jun  3 12:17:09 2020 daemon.info cwmpd[8518]: APP_TRACE: TRANSFER <states>: State = FINISHED; subState = WAITING FOR CONFIRMATION
Wed Jun  3 12:17:09 2020 daemon.info cwmpd[8518]: PROT_TRACE: LAST STATE: <Idle>
Wed Jun  3 12:17:59 2020 daemon.debug mmpbxfwctl[5577]: received cmd:iptables -t filter -C MMPBX  --src 10.247.0.10 -p udp --dport 5060 -m comment --comment Allow_SIP -j ACCEPT
Wed Jun  3 12:17:59 2020 daemon.debug mmpbxfwctl[5577]: received cmd:iptables -t filter -C MMPBX  --src 10.247.0.10 -p tcp --dport 5060 -m comment --comment Allow_SIP -j ACCEPT
Wed Jun  3 12:18:00 2020 user.info mmpbxd[7002]: SIP Registration: SIP: 023xxxx68 : Deregister
Wed Jun  3 12:18:00 2020 user.info mmpbxd[7002]: SIP Registration: SIP: 023xxxx68 : Failure Reason: 403 Forbidden
Wed Jun  3 12:18:00 2020 daemon.debug mmpbxfwctl[5577]: received cmd:iptables -t filter -C MMPBX  --src 10.247.0.10 -p udp --dport 5060 -m comment --comment Allow_SIP -j ACCEPT
Wed Jun  3 12:18:00 2020 daemon.debug mmpbxfwctl[5577]: received cmd:iptables -t filter -C MMPBX  --src 10.247.0.10 -p tcp --dport 5060 -m comment --comment Allow_SIP -j ACCEPT
Wed Jun  3 12:18:00 2020 user.info mmpbxd[7002]: SIP Registration: SIP: 023xxxxx68 : Deregister
Wed Jun  3 12:20:37 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 1800 seconds on br-lan
Wed Jun  3 12:21:42 2020 daemon.warn odhcpd[3052]: A default route is present but there is no public prefix on wl0_2 thus we don't announce a default route!
Wed Jun  3 12:21:42 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on wl0_2
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'Guest' is now down
Wed Jun  3 12:22:34 2020 daemon.notice miniupnpd[7640]: ProcessInterfaceWatchNotify RTM_DELADDR index=24 fam=2
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'Guest' is disabled
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface '6rd' is now down
Wed Jun  3 12:22:34 2020 daemon.notice netifd: tunnel '6rd-6rd' link is down
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'lan' is now down
Wed Jun  3 12:22:34 2020 daemon.notice miniupnpd[7640]: ProcessInterfaceWatchNotify RTM_DELADDR index=26 fam=2
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.824926] br-lan: port 11(wl1_3) entered disabled state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.825057] br-lan: port 10(wl1_2) entered disabled state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.825105] br-lan: port 9(wl1_1) entered disabled state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.825164] br-lan: port 8(wl1) entered disabled state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.825210] br-lan: port 7(wl0_3) entered disabled state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.825253] br-lan: port 6(wl0_1) entered disabled state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.825295] br-lan: port 5(wl0) entered disabled state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.825378] br-lan: port 1(eth0) entered disabled state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.847120] device eth0 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.848269] br-lan: port 1(eth0) entered STP off state
Wed Jun  3 12:22:34 2020 daemon.info hostmanager: Probing device e0:xx:5e:xx:xx:c9 IP address 192.168.1.81 on interface br-lan
Wed Jun  3 12:22:34 2020 daemon.info hostmanager: Probing device e0:xx:5e:xx:xx:c9 IP address 2001:b07:ac0:d876:181f:a770:58a2:8b28 on interface br-lan
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.867080] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.867147] device eth1 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.867577] br-lan: port 2(eth1) entered STP off state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.886975] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.887030] device eth2 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.887480] br-lan: port 3(eth2) entered STP off state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.898288] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.898355] device eth3 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.914183] br-lan: port 4(eth3) entered STP off state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.944198] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.944349] device wl0 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.946388] br-lan: port 5(wl0) entered STP off state
Wed Jun  3 12:22:34 2020 daemon.info hostmanager: Probing device f8:0d:60:07:d9:6e IP address 192.168.1.187 on interface br-lan
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.952074] device wl0_1 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.953824] br-lan: port 6(wl0_1) entered STP off state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.954893] device wl0_3 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.956220] br-lan: port 7(wl0_3) entered STP off state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.957959] device wl1 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.966279] br-lan: port 8(wl1) entered STP off state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.975140] device wl1_1 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.977750] br-lan: port 9(wl1_1) entered STP off state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.984278] device wl1_2 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1008.986814] br-lan: port 10(wl1_2) entered STP off state
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1009.001007] device wl1_3 left promiscuous mode
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1009.005615] br-lan: port 11(wl1_3) entered STP off state
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'lan' is disabled
Wed Jun  3 12:22:34 2020 daemon.notice netifd: bridge 'br-lan' link is down
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'lan' has link connectivity loss
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Network device 'eth0' link is down
Wed Jun  3 12:22:34 2020 daemon.err odhcpd[3052]: setsockopt(IPV6_ADD_MEMBERSHIP): No such device
Wed Jun  3 12:22:34 2020 daemon.err odhcpd[3052]: setsockopt(SO_BINDTODEVICE): No such device
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'loopback' is now down
Wed Jun  3 12:22:34 2020 daemon.notice miniupnpd[7640]: ProcessInterfaceWatchNotify RTM_DELADDR index=1 fam=2
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'loopback' is disabled
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Network device 'lo' link is down
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'loopback' has link connectivity loss
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Network alias '' link is down
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'wantag' has link connectivity loss
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is now down
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1009.165438] device eth4 left promiscuous mode
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is disabled
Wed Jun  3 12:22:34 2020 daemon.notice netifd: 8021q 'vlan_eth4' link is down
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' has link connectivity loss
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'wan' is now down
Wed Jun  3 12:22:34 2020 daemon.notice miniupnpd[7640]: ProcessInterfaceWatchNotify RTM_DELADDR index=15 fam=2
Wed Jun  3 12:22:34 2020 daemon.err miniupnpd[7640]: Failed to get IP for interface eth4
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'wan' is disabled
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'sfp' is disabled
Wed Jun  3 12:22:34 2020 kern.info kernel: [ 1009.345969] IPv6: ADDRCONF(NETDEV_UP): eth4: link is not ready
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Network device 'eth4' link is down
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'wan' has link connectivity loss
Wed Jun  3 12:22:34 2020 daemon.notice netifd: Interface 'sfp' has link connectivity loss
Wed Jun  3 12:22:34 2020 daemon.warn miniupnpd[7640]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Wed Jun  3 12:22:35 2020 user.notice pppoe-relay-hotplug: Interface 6rd ifdown
Wed Jun  3 12:22:35 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on br-lan
Wed Jun  3 12:22:35 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%br-lan (No such device)
Wed Jun  3 12:22:35 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on wl0_2
Wed Jun  3 12:22:36 2020 user.notice netifd: Added device handler type: tunnel
Wed Jun  3 12:22:36 2020 user.notice netifd: Added device handler type: Network device
Wed Jun  3 12:22:36 2020 user.notice netifd: Added device handler type: bridge
Wed Jun  3 12:22:36 2020 user.notice netifd: Added device handler type: veth
Wed Jun  3 12:22:36 2020 user.notice netifd: Added device handler type: macvlan
Wed Jun  3 12:22:36 2020 user.notice netifd: Added device handler type: 8021ad
Wed Jun  3 12:22:36 2020 user.notice netifd: Added device handler type: 8021q
Wed Jun  3 12:22:36 2020 user.notice pppoe-relay-hotplug: Interface Guest ifdown
Wed Jun  3 12:22:38 2020 kern.info kernel: [ 1013.213946] device eth0 entered promiscuous mode
Wed Jun  3 12:22:38 2020 kern.info kernel: [ 1013.222358] br-lan: port 1(eth0) entered listening state
Wed Jun  3 12:22:38 2020 kern.info kernel: [ 1013.222442] br-lan: port 1(eth0) entered listening state
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'lan' is enabled
Wed Jun  3 12:22:38 2020 kern.info kernel: [ 1013.224497] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Wed Jun  3 12:22:38 2020 kern.info kernel: [ 1013.228956] device eth1 entered promiscuous mode
Wed Jun  3 12:22:38 2020 kern.info kernel: [ 1013.232784] device eth2 entered promiscuous mode
Wed Jun  3 12:22:38 2020 kern.info kernel: [ 1013.236939] device eth3 entered promiscuous mode
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'wan' is enabled
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'sfp' is enabled
Wed Jun  3 12:22:38 2020 kern.warn kernel: [ 1013.239979] netdev path : vlan_eth4 -> eth4
Wed Jun  3 12:22:38 2020 kern.info kernel: [ 1013.243445] device eth4 entered promiscuous mode
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is enabled
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'Guest' is enabled
Wed Jun  3 12:22:38 2020 daemon.notice miniupnpd[7640]: ProcessInterfaceWatchNotify RTM_NEWADDR index=1 fam=2
Wed Jun  3 12:22:38 2020 user.err dlnad: 292>No matching interface
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'loopback' is enabled
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'loopback' is setting up now
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'loopback' is now up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Network device 'wl0_2' link is up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'Guest' has link connectivity
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'Guest' is setting up now
Wed Jun  3 12:22:38 2020 daemon.notice miniupnpd[7640]: ProcessInterfaceWatchNotify RTM_NEWADDR index=24 fam=2
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'Guest' is now up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Network device 'eth0' link is up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Network device 'eth4' link is up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'wan' has link connectivity
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'wan' is setting up now
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'sfp' has link connectivity
Wed Jun  3 12:22:38 2020 daemon.notice netifd: 8021q 'vlan_eth4' link is up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' has link connectivity
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is setting up now
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'wantag' is enabled
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Network alias 'vlan_eth4' link is up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'wantag' has link connectivity
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is now up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Network device 'lo' link is up
Wed Jun  3 12:22:38 2020 daemon.notice netifd: Interface 'loopback' has link connectivity
Wed Jun  3 12:22:39 2020 daemon.notice netifd: wan (12815): Starting in init-reboot
Wed Jun  3 12:22:39 2020 daemon.notice netifd: Network device 'wl1' link is up
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.046752] device wl1 entered promiscuous mode
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.056066] br-lan: port 5(wl1) entered listening state
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.056180] br-lan: port 5(wl1) entered listening state
Wed Jun  3 12:22:39 2020 daemon.notice netifd: Network device 'wl1_1' link is up
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.086412] device wl1_1 entered promiscuous mode
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.090144] br-lan: port 6(wl1_1) entered listening state
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.090249] br-lan: port 6(wl1_1) entered listening state
Wed Jun  3 12:22:39 2020 daemon.notice netifd: Network device 'wl1_2' link is up
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.114985] device wl1_2 entered promiscuous mode
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.118991] br-lan: port 7(wl1_2) entered listening state
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.119136] br-lan: port 7(wl1_2) entered listening state
Wed Jun  3 12:22:39 2020 daemon.notice netifd: Network device 'wl1_3' link is up
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.142990] device wl1_3 entered promiscuous mode
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.146942] br-lan: port 8(wl1_3) entered listening state
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.147072] br-lan: port 8(wl1_3) entered listening state
Wed Jun  3 12:22:39 2020 daemon.notice netifd: Network device 'wl0' link is up
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.164978] device wl0 entered promiscuous mode
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.165459] br-lan: port 9(wl0) entered listening state
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.165534] br-lan: port 9(wl0) entered listening state
Wed Jun  3 12:22:39 2020 daemon.notice netifd: Network device 'wl0_1' link is up
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.171385] device wl0_1 entered promiscuous mode
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.172039] br-lan: port 10(wl0_1) entered listening state
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.172120] br-lan: port 10(wl0_1) entered listening state
Wed Jun  3 12:22:39 2020 daemon.notice netifd: Network device 'wl0_3' link is up
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.183961] device wl0_3 entered promiscuous mode
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.185271] br-lan: port 11(wl0_3) entered listening state
Wed Jun  3 12:22:39 2020 kern.info kernel: [ 1014.185356] br-lan: port 11(wl0_3) entered listening state
Wed Jun  3 12:22:39 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on br-lan
Wed Jun  3 12:22:39 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%br-lan (Permission denied)
Wed Jun  3 12:22:39 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on wl0_2
Wed Jun  3 12:22:39 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%wl0_2 (Cannot assign requested address)
Wed Jun  3 12:22:40 2020 user.notice pppoe-relay-hotplug: Interface loopback ifup
Wed Jun  3 12:22:40 2020 kern.info kernel: [ 1015.223896] br-lan: port 1(eth0) entered learning state
Wed Jun  3 12:22:41 2020 daemon.notice netifd: wan (12815): Switching to rebooting
Wed Jun  3 12:22:41 2020 daemon.notice netifd: wan (12815): Switching to bound; server 10.254.3.253 assigned ip 10.192.216.118 (leasetime 28799 T1 14399 T2 14459)
Wed Jun  3 12:22:41 2020 daemon.notice miniupnpd[7640]: ProcessInterfaceWatchNotify RTM_NEWADDR index=15 fam=2
Wed Jun  3 12:22:41 2020 user.err dlnad: 292>No matching interface
Wed Jun  3 12:22:41 2020 daemon.notice netifd: Interface 'wan' is now up
Wed Jun  3 12:22:41 2020 user.debug lua: [defaultGW] get interface eth4 and defaultGW 10.192.216.65
Wed Jun  3 12:22:41 2020 daemon.err miniupnpd[7640]: SendNATPMPPublicAddressChangeNotification: sendto(s_udp=8): Invalid argument
Wed Jun  3 12:22:41 2020 daemon.notice netifd: Interface '6rd' is setting up now
Wed Jun  3 12:22:41 2020 user.err lua: [processvendorinfo] Failed to set acs url as cwmp interface does not match
Wed Jun  3 12:22:41 2020 kern.info kernel: [ 1016.059677] br-lan: port 5(wl1) entered learning state
Wed Jun  3 12:22:41 2020 kern.info kernel: [ 1016.095672] br-lan: port 6(wl1_1) entered learning state
Wed Jun  3 12:22:41 2020 kern.info kernel: [ 1016.119673] br-lan: port 7(wl1_2) entered learning state
Wed Jun  3 12:22:41 2020 kern.info kernel: [ 1016.151671] br-lan: port 8(wl1_3) entered learning state
Wed Jun  3 12:22:41 2020 kern.info kernel: [ 1016.167675] br-lan: port 9(wl0) entered learning state
Wed Jun  3 12:22:41 2020 kern.info kernel: [ 1016.175668] br-lan: port 10(wl0_1) entered learning state
Wed Jun  3 12:22:41 2020 kern.info kernel: [ 1016.191674] br-lan: port 11(wl0_3) entered learning state
Wed Jun  3 12:22:41 2020 daemon.warn netifd: Failed to assign requested subprefix of size 64 for Guest, trying other
Wed Jun  3 12:22:41 2020 daemon.warn netifd: Failed to assign subprefix of size 65 for Guest
Wed Jun  3 12:22:41 2020 daemon.warn netifd: Failed to assign subprefix of size 65 for wan
Wed Jun  3 12:22:41 2020 daemon.notice netifd: Interface '6rd' is now up
Wed Jun  3 12:22:41 2020 daemon.notice netifd: tunnel '6rd-6rd' link is up
Wed Jun  3 12:22:42 2020 user.notice firewall: Reloading firewall due to ifup of Guest (wl0_2)
Wed Jun  3 12:22:42 2020 kern.info kernel: [ 1017.227660] br-lan: topology change detected, propagating
Wed Jun  3 12:22:42 2020 kern.info kernel: [ 1017.227707] br-lan: port 1(eth0) entered forwarding state
Wed Jun  3 12:22:42 2020 kern.info kernel: [ 1017.227955] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Wed Jun  3 12:22:42 2020 daemon.notice netifd: bridge 'br-lan' link is up
Wed Jun  3 12:22:42 2020 daemon.notice netifd: Interface 'lan' has link connectivity
Wed Jun  3 12:22:42 2020 daemon.notice netifd: Interface 'lan' is setting up now
Wed Jun  3 12:22:42 2020 user.err dlnad: 292>No matching interface
Wed Jun  3 12:22:42 2020 daemon.notice hostapd: Detected new IP address for br-lan: 192.168.1.254
Wed Jun  3 12:22:42 2020 daemon.notice miniupnpd[7640]: ProcessInterfaceWatchNotify RTM_NEWADDR index=29 fam=2
Wed Jun  3 12:22:42 2020 daemon.notice netifd: Interface 'lan' is now up
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.063623] br-lan: topology change detected, propagating
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.063643] br-lan: port 5(wl1) entered forwarding state
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.099647] br-lan: topology change detected, propagating
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.099667] br-lan: port 6(wl1_1) entered forwarding state
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.123627] br-lan: topology change detected, propagating
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.123647] br-lan: port 7(wl1_2) entered forwarding state
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.155628] br-lan: topology change detected, propagating
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.155652] br-lan: port 8(wl1_3) entered forwarding state
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.171643] br-lan: topology change detected, propagating
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.171666] br-lan: port 9(wl0) entered forwarding state
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.179632] br-lan: topology change detected, propagating
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.179650] br-lan: port 10(wl0_1) entered forwarding state
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.196607] br-lan: topology change detected, propagating
Wed Jun  3 12:22:43 2020 kern.info kernel: [ 1018.196626] br-lan: port 11(wl0_3) entered forwarding state
Wed Jun  3 12:22:43 2020 daemon.warn odhcpd[3052]: A default route is present but there is no public prefix on br-lan thus we don't announce a default route!
Wed Jun  3 12:22:43 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on br-lan
Wed Jun  3 12:22:43 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%br-lan (Cannot assign requested address)
Wed Jun  3 12:22:43 2020 daemon.warn odhcpd[3052]: A default route is present but there is no public prefix on wl0_2 thus we don't announce a default route!
Wed Jun  3 12:22:43 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on wl0_2
Wed Jun  3 12:22:44 2020 user.err lua: [defaultGW] Ignoring improper event
Wed Jun  3 12:22:45 2020 user.notice pppoe-relay-hotplug: Interface Guest ifup
Wed Jun  3 12:22:46 2020 user.notice pppoe-relay-hotplug: Interface vlan_wan_eth4 ifup
Wed Jun  3 12:22:47 2020 user.err lua: [defaultGW] Ignoring improper event
Wed Jun  3 12:22:47 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 1800 seconds on br-lan
« Ultima modifica: 03 Giugno 2020, 22:27 da MisterFTTH »
Offline sob0
  • 18
« Risposta #1116 il: 03 Giugno 2020, 12:32 »
Rifatto il log segnandomi esattamente il momento in cui viene dato il comando di restart. Magari è inutile ma mi sentivo di rifarlo in modo più preciso  :-\
Wed Jun  3 12:29:43 2020 user.info mmpbxd[7002]: SIP Registration: SIP: 023xxxxx68 : Deregister
Wed Jun  3 12:29:43 2020 user.info mmpbxd[7002]: SIP Registration: SIP: 023xxxxx68 : Failure Reason: 403 Forbidden
Wed Jun  3 12:29:43 2020 daemon.debug mmpbxfwctl[5577]: received cmd:iptables -t filter -C MMPBX  --src 10.247.0.10 -p udp --dport 5060 -m comment --comment Allow_SIP -j ACCEPT
Wed Jun  3 12:29:43 2020 daemon.debug mmpbxfwctl[5577]: received cmd:iptables -t filter -C MMPBX  --src 10.247.0.10 -p tcp --dport 5060 -m comment --comment Allow_SIP -j ACCEPT
Wed Jun  3 12:29:59 2020 daemon.notice netifd: Interface 'Guest' is now down
Wed Jun  3 12:29:59 2020 daemon.notice miniupnpd[16343]: ProcessInterfaceWatchNotify RTM_DELADDR index=24 fam=2
Wed Jun  3 12:29:59 2020 daemon.notice netifd: Interface 'Guest' is disabled
Wed Jun  3 12:29:59 2020 daemon.notice netifd: Interface '6rd' is now down
Wed Jun  3 12:29:59 2020 daemon.notice netifd: tunnel '6rd-6rd' link is down
Wed Jun  3 12:29:59 2020 daemon.notice netifd: Interface 'lan' is now down
Wed Jun  3 12:29:59 2020 daemon.notice miniupnpd[16343]: ProcessInterfaceWatchNotify RTM_DELADDR index=29 fam=2
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.589451] br-lan: port 11(wl0_3) entered disabled state
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.589585] br-lan: port 10(wl0_1) entered disabled state
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.589648] br-lan: port 9(wl0) entered disabled state
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.589734] br-lan: port 8(wl1_3) entered disabled state
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.589778] br-lan: port 7(wl1_2) entered disabled state
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.589824] br-lan: port 6(wl1_1) entered disabled state
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.589866] br-lan: port 5(wl1) entered disabled state
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.589911] br-lan: port 1(eth0) entered disabled state
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.627067] device eth0 left promiscuous mode
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.628664] br-lan: port 1(eth0) entered STP off state
Wed Jun  3 12:29:59 2020 daemon.info hostmanager: Probing device e0:d5:xx:6d:xx:c9 IP address 192.168.1.81 on interface br-lan
Wed Jun  3 12:29:59 2020 daemon.info hostmanager: Probing device e0:d5:xx:6d:xx:c9 IP address 2001:b07:ac0:d876:181f:a770:58a2:8b28 on interface br-lan
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.650164] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.650280] device eth1 left promiscuous mode
Wed Jun  3 12:29:59 2020 kern.info kernel: [ 1454.652506] br-lan: port 2(eth1) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.672093] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.672150] device eth2 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.674094] br-lan: port 3(eth2) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.686275] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.686347] device eth3 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.690574] br-lan: port 4(eth3) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.715357] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.719296] device wl0 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.721847] br-lan: port 9(wl0) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.730402] device wl0_1 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.732677] br-lan: port 10(wl0_1) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.736577] device wl0_3 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.736949] br-lan: port 11(wl0_3) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.740488] device wl1 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.743768] br-lan: port 5(wl1) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.757374] device wl1_1 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.759803] br-lan: port 6(wl1_1) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.770414] device wl1_2 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.773255] br-lan: port 7(wl1_2) entered STP off state
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.781534] device wl1_3 left promiscuous mode
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.783743] br-lan: port 8(wl1_3) entered STP off state
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'lan' is disabled
Wed Jun  3 12:30:00 2020 daemon.notice netifd: bridge 'br-lan' link is down
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'lan' has link connectivity loss
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Network device 'eth0' link is down
Wed Jun  3 12:30:00 2020 daemon.err odhcpd[3052]: setsockopt(IPV6_ADD_MEMBERSHIP): No such device
Wed Jun  3 12:30:00 2020 daemon.err odhcpd[3052]: setsockopt(SO_BINDTODEVICE): No such device
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'loopback' is now down
Wed Jun  3 12:30:00 2020 daemon.notice miniupnpd[16343]: ProcessInterfaceWatchNotify RTM_DELADDR index=1 fam=2
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'loopback' is disabled
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Network device 'lo' link is down
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'loopback' has link connectivity loss
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Network alias '' link is down
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'wantag' has link connectivity loss
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is now down
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1454.993534] device eth4 left promiscuous mode
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is disabled
Wed Jun  3 12:30:00 2020 daemon.notice netifd: 8021q 'vlan_eth4' link is down
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' has link connectivity loss
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'wan' is now down
Wed Jun  3 12:30:00 2020 daemon.notice miniupnpd[16343]: ProcessInterfaceWatchNotify RTM_DELADDR index=15 fam=2
Wed Jun  3 12:30:00 2020 kern.info kernel: [ 1455.179869] IPv6: ADDRCONF(NETDEV_UP): eth4: link is not ready
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'wan' is disabled
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'sfp' is disabled
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Network device 'eth4' link is down
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'wan' has link connectivity loss
Wed Jun  3 12:30:00 2020 daemon.notice netifd: Interface 'sfp' has link connectivity loss
Wed Jun  3 12:30:00 2020 daemon.err miniupnpd[16343]: Failed to get IP for interface eth4
Wed Jun  3 12:30:00 2020 daemon.warn miniupnpd[16343]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Wed Jun  3 12:30:01 2020 user.notice pppoe-relay-hotplug: Interface 6rd ifdown
Wed Jun  3 12:30:01 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on br-lan
Wed Jun  3 12:30:01 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%br-lan (No such device)
Wed Jun  3 12:30:01 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on wl0_2
Wed Jun  3 12:30:02 2020 user.notice netifd: Added device handler type: tunnel
Wed Jun  3 12:30:02 2020 user.notice netifd: Added device handler type: Network device
Wed Jun  3 12:30:02 2020 user.notice netifd: Added device handler type: bridge
Wed Jun  3 12:30:02 2020 user.notice netifd: Added device handler type: veth
Wed Jun  3 12:30:02 2020 user.notice netifd: Added device handler type: macvlan
Wed Jun  3 12:30:02 2020 user.notice netifd: Added device handler type: 8021ad
Wed Jun  3 12:30:02 2020 user.notice netifd: Added device handler type: 8021q
Wed Jun  3 12:30:02 2020 user.notice pppoe-relay-hotplug: Interface Guest ifdown
Wed Jun  3 12:30:04 2020 kern.info kernel: [ 1458.929749] device eth0 entered promiscuous mode
Wed Jun  3 12:30:04 2020 kern.info kernel: [ 1458.939574] br-lan: port 1(eth0) entered listening state
Wed Jun  3 12:30:04 2020 kern.info kernel: [ 1458.939688] br-lan: port 1(eth0) entered listening state
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'lan' is enabled
Wed Jun  3 12:30:04 2020 kern.info kernel: [ 1458.942336] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Wed Jun  3 12:30:04 2020 kern.info kernel: [ 1458.946576] device eth1 entered promiscuous mode
Wed Jun  3 12:30:04 2020 kern.info kernel: [ 1458.951036] device eth2 entered promiscuous mode
Wed Jun  3 12:30:04 2020 kern.info kernel: [ 1458.955585] device eth3 entered promiscuous mode
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'wan' is enabled
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'sfp' is enabled
Wed Jun  3 12:30:04 2020 kern.warn kernel: [ 1458.959670] netdev path : vlan_eth4 -> eth4
Wed Jun  3 12:30:04 2020 kern.info kernel: [ 1458.964438] device eth4 entered promiscuous mode
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is enabled
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'Guest' is enabled
Wed Jun  3 12:30:04 2020 daemon.notice miniupnpd[16343]: ProcessInterfaceWatchNotify RTM_NEWADDR index=1 fam=2
Wed Jun  3 12:30:04 2020 user.err dlnad: 292>No matching interface
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'loopback' is enabled
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'loopback' is setting up now
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'loopback' is now up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Network device 'wl0_2' link is up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'Guest' has link connectivity
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'Guest' is setting up now
Wed Jun  3 12:30:04 2020 daemon.notice miniupnpd[16343]: ProcessInterfaceWatchNotify RTM_NEWADDR index=24 fam=2
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'Guest' is now up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Network device 'eth0' link is up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Network device 'eth4' link is up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'wan' has link connectivity
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'wan' is setting up now
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'sfp' has link connectivity
Wed Jun  3 12:30:04 2020 daemon.notice netifd: 8021q 'vlan_eth4' link is up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' has link connectivity
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is setting up now
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'wantag' is enabled
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Network alias 'vlan_eth4' link is up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'wantag' has link connectivity
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'vlan_wan_eth4' is now up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Network device 'lo' link is up
Wed Jun  3 12:30:04 2020 daemon.notice netifd: Interface 'loopback' has link connectivity
Wed Jun  3 12:30:04 2020 daemon.notice netifd: wan (19603): Starting in init-reboot
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Network device 'wl0' link is up
Wed Jun  3 12:30:05 2020 daemon.err miniupnpd[16343]: sendto(udp_notify=6, 192.168.1.254): Invalid argument
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.711526] device wl0 entered promiscuous mode
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.711833] br-lan: port 5(wl0) entered listening state
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.711897] br-lan: port 5(wl0) entered listening state
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Network device 'wl0_1' link is up
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.719767] device wl0_1 entered promiscuous mode
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.720052] br-lan: port 6(wl0_1) entered listening state
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.720160] br-lan: port 6(wl0_1) entered listening state
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Network device 'wl0_3' link is up
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.728214] device wl0_3 entered promiscuous mode
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.728608] br-lan: port 7(wl0_3) entered listening state
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.728681] br-lan: port 7(wl0_3) entered listening state
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Network device 'wl1' link is up
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.796236] device wl1 entered promiscuous mode
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.799646] br-lan: port 8(wl1) entered listening state
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.799741] br-lan: port 8(wl1) entered listening state
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Network device 'wl1_1' link is up
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.819177] device wl1_1 entered promiscuous mode
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.821796] br-lan: port 9(wl1_1) entered listening state
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.821927] br-lan: port 9(wl1_1) entered listening state
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Network device 'wl1_2' link is up
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.834406] device wl1_2 entered promiscuous mode
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.837064] br-lan: port 10(wl1_2) entered listening state
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.837235] br-lan: port 10(wl1_2) entered listening state
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Network device 'wl1_3' link is up
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.864570] device wl1_3 entered promiscuous mode
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.867039] br-lan: port 11(wl1_3) entered listening state
Wed Jun  3 12:30:05 2020 kern.info kernel: [ 1459.867210] br-lan: port 11(wl1_3) entered listening state
Wed Jun  3 12:30:05 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on br-lan
Wed Jun  3 12:30:05 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%br-lan (Permission denied)
Wed Jun  3 12:30:05 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on wl0_2
Wed Jun  3 12:30:05 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%wl0_2 (Cannot assign requested address)
Wed Jun  3 12:30:05 2020 daemon.notice netifd: wan (19603): Switching to rebooting
Wed Jun  3 12:30:05 2020 daemon.notice netifd: wan (19603): Switching to bound; server 10.254.3.253 assigned ip 10.192.216.118 (leasetime 28799 T1 14399 T2 14459)
Wed Jun  3 12:30:05 2020 daemon.notice miniupnpd[16343]: ProcessInterfaceWatchNotify RTM_NEWADDR index=15 fam=2
Wed Jun  3 12:30:05 2020 user.err dlnad: 292>No matching interface
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Interface 'wan' is now up
Wed Jun  3 12:30:05 2020 user.debug lua: [defaultGW] get interface eth4 and defaultGW 10.192.216.65
Wed Jun  3 12:30:05 2020 daemon.err miniupnpd[16343]: SendNATPMPPublicAddressChangeNotification: sendto(s_udp=8): Invalid argument
Wed Jun  3 12:30:05 2020 daemon.notice netifd: Interface '6rd' is setting up now
Wed Jun  3 12:30:06 2020 user.err lua: [processvendorinfo] Failed to set acs url as cwmp interface does not match
Wed Jun  3 12:30:06 2020 kern.info kernel: [ 1460.945339] br-lan: port 1(eth0) entered learning state
Wed Jun  3 12:30:06 2020 daemon.warn netifd: Failed to assign requested subprefix of size 64 for Guest, trying other
Wed Jun  3 12:30:06 2020 daemon.warn netifd: Failed to assign subprefix of size 65 for Guest
Wed Jun  3 12:30:06 2020 daemon.warn netifd: Failed to assign subprefix of size 65 for wan
Wed Jun  3 12:30:06 2020 daemon.notice netifd: Interface '6rd' is now up
Wed Jun  3 12:30:06 2020 daemon.notice netifd: tunnel '6rd-6rd' link is up
Wed Jun  3 12:30:07 2020 user.notice pppoe-relay-hotplug: Interface loopback ifup
Wed Jun  3 12:30:07 2020 kern.info kernel: [ 1461.713123] br-lan: port 5(wl0) entered learning state
Wed Jun  3 12:30:07 2020 kern.info kernel: [ 1461.722119] br-lan: port 6(wl0_1) entered learning state
Wed Jun  3 12:30:07 2020 kern.info kernel: [ 1461.729115] br-lan: port 7(wl0_3) entered learning state
Wed Jun  3 12:30:07 2020 kern.info kernel: [ 1461.801120] br-lan: port 8(wl1) entered learning state
Wed Jun  3 12:30:07 2020 kern.info kernel: [ 1461.825125] br-lan: port 9(wl1_1) entered learning state
Wed Jun  3 12:30:07 2020 kern.info kernel: [ 1461.841118] br-lan: port 10(wl1_2) entered learning state
Wed Jun  3 12:30:07 2020 kern.info kernel: [ 1461.873120] br-lan: port 11(wl1_3) entered learning state
Wed Jun  3 12:30:07 2020 daemon.warn odhcpd[3052]: A default route is present but there is no public prefix on br-lan thus we don't announce a default route!
Wed Jun  3 12:30:07 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on br-lan
Wed Jun  3 12:30:07 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%br-lan (Permission denied)
Wed Jun  3 12:30:07 2020 daemon.warn odhcpd[3052]: A default route is present but there is no public prefix on wl0_2 thus we don't announce a default route!
Wed Jun  3 12:30:07 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on wl0_2
Wed Jun  3 12:30:08 2020 kern.info kernel: [ 1462.949082] br-lan: topology change detected, propagating
Wed Jun  3 12:30:08 2020 kern.info kernel: [ 1462.949120] br-lan: port 1(eth0) entered forwarding state
Wed Jun  3 12:30:08 2020 kern.info kernel: [ 1462.949167] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Wed Jun  3 12:30:08 2020 daemon.notice netifd: bridge 'br-lan' link is up
Wed Jun  3 12:30:08 2020 daemon.notice netifd: Interface 'lan' has link connectivity
Wed Jun  3 12:30:08 2020 daemon.notice netifd: Interface 'lan' is setting up now
Wed Jun  3 12:30:08 2020 daemon.notice miniupnpd[16343]: ProcessInterfaceWatchNotify RTM_NEWADDR index=32 fam=2
Wed Jun  3 12:30:08 2020 user.err dlnad: 292>No matching interface
Wed Jun  3 12:30:08 2020 daemon.notice hostapd: Detected new IP address for br-lan: 192.168.1.254
Wed Jun  3 12:30:08 2020 daemon.notice netifd: Interface 'lan' is now up
Wed Jun  3 12:30:08 2020 user.notice firewall: Reloading firewall due to ifup of Guest (wl0_2)
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.717086] br-lan: topology change detected, propagating
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.717108] br-lan: port 5(wl0) entered forwarding state
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.729071] br-lan: topology change detected, propagating
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.729092] br-lan: port 6(wl0_1) entered forwarding state
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.733071] br-lan: topology change detected, propagating
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.733096] br-lan: port 7(wl0_3) entered forwarding state
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.805084] br-lan: topology change detected, propagating
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.805106] br-lan: port 8(wl1) entered forwarding state
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.829068] br-lan: topology change detected, propagating
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.829090] br-lan: port 9(wl1_1) entered forwarding state
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.845074] br-lan: topology change detected, propagating
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.845094] br-lan: port 10(wl1_2) entered forwarding state
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.877071] br-lan: topology change detected, propagating
Wed Jun  3 12:30:09 2020 kern.info kernel: [ 1463.877093] br-lan: port 11(wl1_3) entered forwarding state
Wed Jun  3 12:30:09 2020 daemon.warn odhcpd[3052]: A default route is present but there is no public prefix on br-lan thus we don't announce a default route!
Wed Jun  3 12:30:09 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on br-lan
Wed Jun  3 12:30:09 2020 daemon.notice odhcpd[3052]: Failed to send to ff02::1%br-lan (Cannot assign requested address)
Wed Jun  3 12:30:09 2020 daemon.warn odhcpd[3052]: A default route is present but there is no public prefix on wl0_2 thus we don't announce a default route!
Wed Jun  3 12:30:09 2020 daemon.info odhcpd[3052]: Using a RA lifetime of 0 seconds on wl0_2
Wed Jun  3 12:30:09 2020 user.err lua: [defaultGW] Ignoring improper event
« Ultima modifica: 03 Giugno 2020, 12:34 da sob0 »
« Risposta #1117 il: 03 Giugno 2020, 17:17 »
Ebbene, l'indirizzo ipv4 corretto ora lo vedo anche in ifconfig (penso ci fosse anche prima anche se nascosto). Ora mi sembra tutto ok. Se dal pc e dal router provi a fare un ping verso 8.8.8.8 che succede?
C'è un errore in cwmpd sull'interface, dev'essere wan, non eth4, ma a parte renderti forse funzionante la telegestione non credo ti cambi nulla dal punto di vista della connettività.
Offline sob0
  • 18
« Risposta #1118 il: 04 Giugno 2020, 00:53 »
Così come era quando ho postato i log aveva lo stesso problema. Domani mattina appena rientro faccio la prova del ping e modifico il file cwmpd.
Intanto grazie e buona serata
« Ultima modifica: 04 Giugno 2020, 09:21 da MisterFTTH »
« Risposta #1119 il: 04 Giugno 2020, 02:39 »
oh grazie, ora mi torna, ebbene vuol dire che già ha anche connettività ipv4, per lo meno interna a fastweb
« Ultima modifica: 04 Giugno 2020, 15:16 da LuKePicci »
Offline sob0
  • 18
« Risposta #1120 il: 04 Giugno 2020, 11:11 »
Dunque,
corretto il file cwmpd, ma come avevi previsto non è cambiato nulla di particolare.
Ho provato a fare il test del ping (sia da pc che da router) e vanno a buon fine.
Il problema della connessione "ridotta" però rimane, vale lo stesso anche da cellulare collegato in wifi o dal portatile collegato sul un'altra lan (ma anche in wifi è lo stesso). Ovviamente gli stessi siti che non vanno sul fisso non vanno nemmeno sul cellulare.
Mentre stavo eseguendo i vari ping, è saltata la connessione (mi dava "connesso ma senza accesso alla rete"), i vari ping funzionavano ugualmente, semplicemente non riuscivo a navigare.
Non so se può servire, ma ad ogni accensione del router mi si apre chrome sul fisso e mi rimanda alla pagina
<http://megainternet.fastwebnet.it/home?CPURL=http%3A%2F%2Fwww.msftconnecttest.com%2Fredirect>
in cui mi dicono "Gentile cliente, contatta il nostro Servizio Clienti, i nostri operatori sono a tua disposizione per rispondere a ogni tua domanda."
« Ultima modifica: 04 Giugno 2020, 11:36 da sob0 »
Offline lorenzocanalelc
  • 678
« Risposta #1121 il: 04 Giugno 2020, 11:40 »
Hai provato ad andare a questo link http://registrazione.fastweb.it/ ed inserire il tuo codice Fiscale? Io in ADSL ULL ho dovuto solo fare questo per usare il mio router non Fastweb, senza nemmeno chiamare Fastweb o copiare il Mac Address
Offline sob0
  • 18
« Risposta #1122 il: 04 Giugno 2020, 12:08 »
Quando vado a quella pagina mi esce fuori
"Gentile Cliente,
ancora pochi istanti e potrai navigare in Internet alla massima velocità possibile!"
E in seguito senza schiacciare nulla, cambia schermata e mi dà
"BENVENUTO!
ORA PUOI INIZIARE A VOLARE CON FASTWEB
Seguici sulle nostre community:
Twitter     Facebook
o accedi alla tua Area Clienti — MyFASTPage
per restare sempre aggiornato sulle novità pensate per te."
Quindi non ho nessuna richiesta di dati da parte mia.
« Ultima modifica: 04 Giugno 2020, 12:16 da MisterFTTH »
  • 678
« Risposta #1123 il: 04 Giugno 2020, 12:11 »
E dopo quella pagina non riesci ancora a navigare? Perché a me subito BENVENUTO inizia a funzionare tutto (Dopo un DNS FLUSH)
« Risposta #1124 il: 04 Giugno 2020, 12:18 »
Prova a disabilitare ipv6 sul pc e vedi se a quel punto funziona normalmente. Controlla anche se con un altro mac address abbastanza diverso (cambia la terz'ultima cifra) ottieni il medesimo risultato. In tal caso è probabile che tu non abbia clonato quello corretto (oppure è corretto ma il vendorid non coincide, quindi per lui sei comunque un nuovo device da registrare), e che pertanto ti stia chiedendo di registrare quello attuale che lui non ha mai visto prima d'ora, quindi tenendo ipv6 spento vedi se ti apre ancora il browser su quella pagina e prova a riandare su registrazione.fastweb.it
« Ultima modifica: 04 Giugno 2020, 12:29 da LuKePicci »
