  • 2281 Risposte
  • 1186921 Visite
Offline nclmrc
  • 246
@LuKePicci ma nel file ethernet ci devo mettere wl1?
EDIT: fatto ma perche spunta fuori questo w11??
https://imgur.com/jt5Vcd8
errata traduzione
root@DGA4132:/www# grep -r w11 *
lang/it-it/webui-core.po:msgstr "w11"
« Ultima modifica: 07 Maggio 2020, 14:19 da nclmrc »
No nel file ethernet ci deve restare eth5
A parte la traduzione cosa è successo?
Offline nclmrc
  • 246
@LuKePicci wifi 5ghz si avvia ma non ci connette nemmeno dopo network restart
La ospiti invece si connette?
mi fai un ifconfig -a in quella situazione, devo vedere i mac address
Offline nclmrc
  • 246
root@DGA4132:~# ifconfig
atmvoip   Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          RX packets:402 errors:0 dropped:0 overruns:0 frame:0
          TX packets:11585 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:24128 (23.5 KiB)  TX bytes:1577320 (1.5 MiB)
atmwan    Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          RX packets:22293 errors:0 dropped:0 overruns:0 frame:0
          TX packets:16579 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:3596965 (3.4 MiB)  TX bytes:1740131 (1.6 MiB)
bcmsw     Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          RX packets:36190 errors:0 dropped:0 overruns:0 frame:0
          TX packets:19679 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5187698 (4.9 MiB)  TX bytes:7923220 (7.5 MiB)
          Base address:0xffff
br-lan    Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          inet addr:192.168.1.254  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:7282 errors:0 dropped:50 overruns:0 frame:0
          TX packets:3031 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1599041 (1.5 MiB)  TX bytes:595601 (581.6 KiB)
br-voip   Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          inet6 addr: fe80::a691:b1ff:fe2b:8ec/64 Scope:Link
          RX packets:3395 errors:0 dropped:0 overruns:0 frame:0
          TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:190040 (185.5 KiB)  TX bytes:972 (972.0 B)
br-wan    Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          inet addr:192.168.10.254  Bcast:192.168.10.255  Mask:255.255.255.0
          RX packets:3506 errors:0 dropped:0 overruns:0 frame:0
          TX packets:148 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:195146 (190.5 KiB)  TX bytes:8518 (8.3 KiB)
eth0      Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          RX packets:38628 errors:0 dropped:1820 overruns:0 frame:0
          TX packets:27440 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5591663 (5.3 MiB)  TX bytes:4538830 (4.3 MiB)
eth0.1    Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          RX packets:8289 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4511 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1746154 (1.6 MiB)  TX bytes:757922 (740.1 KiB)
eth0.10   Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          RX packets:5376 errors:0 dropped:0 overruns:0 frame:0
          TX packets:788 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:381341 (372.4 KiB)  TX bytes:90464 (88.3 KiB)
eth0.20   Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          RX packets:11595 errors:0 dropped:0 overruns:0 frame:0
          TX packets:404 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1414524 (1.3 MiB)  TX bytes:24616 (24.0 KiB)
eth1      Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth1.1    Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
eth2      Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
eth2.1    Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
eth3      Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
eth3.1    Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
eth4      Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          inet addr:192.168.100.1  Bcast:192.168.100.255  Mask:255.255.255.0
eth5      Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          RX packets:10849 errors:0 dropped:8 overruns:0 frame:0
          TX packets:13883 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1075880 (1.0 MiB)  TX bytes:6902769 (6.5 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1008 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1008 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:63568 (62.0 KiB)  TX bytes:63568 (62.0 KiB)
wl0       Link encap:Ethernet  HWaddr A4:91:B1:2B:08:ED
          inet6 addr: fe80::a691:b1ff:fe2b:8ed/64 Scope:Link
          RX packets:1572 errors:0 dropped:5 overruns:0 frame:1673
          TX packets:7839 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:175134 (171.0 KiB)  TX bytes:1760498 (1.6 MiB)
          Interrupt:92
wl0_1     Link encap:Ethernet  HWaddr A4:91:B1:2B:08:ED
          inet addr:192.168.168.1  Bcast:192.168.168.127  Mask:255.255.255.128
          RX packets:0 errors:0 dropped:0 overruns:0 frame:1673
wl1       Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          TX packets:6665 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:1519611 (1.4 MiB)
wl1_1     Link encap:Ethernet  HWaddr A4:91:B1:2B:08:EC
          inet addr:192.168.168.129  Bcast:192.168.168.255  Mask:255.255.255.128
          TX packets:18 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:2236 (2.1 KiB)
EDIT sulla rete ospiti non ti so dire perchè non sono in casa.
« Ultima modifica: 07 Maggio 2020, 16:25 da nclmrc »
Offline Frankobeatz
Salve. Ho aggiornato all'ultima dev e mi ha chiesto il riavvio per applicare OPB Planning.
Ho erroneamente spento e riacceso il modem ed adesso lampeggia la spia info arancione e poi si auto riavvia e ritorna a lampeggiare arancione all'infinito.
Come posso risolvere? 😔 Temo di aver fatto una cazzata
Riavvio non vuol dire spegni/riaccendi.
Ti è andato in BOOTP e si aspetta il caricamento del firmware. Se hai caricato l'ultima beta leggi da qua
https://www.ilpuntotecnico.com/forum/index.php/topic,81461.msg264479.html#msg264479
Altrimenti carica l'ultima versione stabile del firmware con tftp.
Offline Frankobeatz
Immaginavo di aver fatto una topica clamorosa.
Sinceramente ci capisco poco...
Ho messo l'ultima beta, eventualmente per ripristinare al firmware originale quale guida e file devo seguire?
Aggiornamento; ripristinato firmware Tiscali originale.
Nell'eventualità di ri-aggiornare alla gui, per riavvio del dispositivo si intende da gui stessa?
Grazie e scusate le domande da niubbazzo
« Ultima modifica: 08 Maggio 2020, 18:20 da Frankobeatz »
Offline magnus71
  • 42
Salve a tutti.
QUalcuno mi aiuta con multi wan 4.1?
Ho abilitato luci e installato mwan 4.1.
ORa vorrei che un cavo che proviene dall'ONT Open Fiber con fibra.city si colleghi ad una porta ethernet e possa fare binding tra le due connessioni con ISP diverse, Open Fiber e TIM 200 megabit.
https://forum.openwrt.org/t/best-way-to-configure-bonding-in-openwrt/26290
https://openwrt.org/docs/guide-user/network/wan/multiwan/mwan3
L'alternativa è mettere questo su x86 e due schede NIC della Intel:
https://www.openmptcprouter.com/
Offline lorenzocanalelc
  • 678
@magnus71 Sei poi riuscito ad ottenere qualche risultato? Vorrei provare anch'io a fare il Load Balancing di due adsl, stavo pensando di comprare un router apposito per questo ma volevo capire prima se era possibile ottenere qualche risultato con il DGA4130/4131
Offline magnus71
  • 42
Ho risolto con il Linksys Lrt224-Eu
« Ultima modifica: 05 Luglio 2020, 11:11 da MisterFTTH »
Puoi farlo di sicuro con mwan3, forse anche con l'mwan di tch ma non so come
Qualcuno vuole provare su agtef/hp 1.1.1/.2 ?
https://github.com/hack-technicolor/hack-technicolor/issues/115
Offline mscuttari
Re:L'angolo di Ansuel: ricerca e sviluppo su DGA4130 (AGTEF) & DGA4132 (AGTHP)
« Risposta #2233 il: 01 Settembre 2020, 18:11 »
Ho un DGA4132 e vorrei configurare 1 vlan untagged (ethernet + wifi) + 1 vlan tagged (ethernet), in modo che chi si connette senza specificare nulla finisca sulla vlan untagged e chi invece lo desidera, sulla seconda. Mi sono letto diverse pagine per capire come configurare le VLAN ma mi pare ci siano problemi relativi al wifi 5 ghz. Potreste dirmi com'è la situazione in merito ed eventualmente indicarmi la configurazione da usare?
Offline grzmrc
  • 38
« Risposta #2234 il: 09 Settembre 2020, 01:00 »
Posso suggerire qualcosa per la ricerca e sviluppo che mi piacerebbe fosse integrato?
Ci provo:
Vorrei che il modem potesse partecipare come nodo mesh ad una rete wifi mesh già esistente per ampliare la copertura wifi dell'abitazione. Utilizzo il sistema velop di linksys :)
Grazie anche a chi semplicemente dirà "No non si può fare"
