amule@kamikaze perfettamente funzionante
  • 193 Risposte
  • 104588 Visite
Re: amule@kamikaze perfettamente funzionante
« Risposta #75 il: 26 Ottobre 2007, 20:31 »
A me amule ufficiale funziona!  :D
Cioè per lo meno non mi da errori. Poi continuo la configurazione via SSH da casa  ;)
Il tuo problema dev'essere legato alla piattaforma x86.
root@OpenWrt:/$ amuled
amuled: OnInit - starting timer
Initialising aMule
Checking if there is an instance already running...
No other instances are running.
ERROR: Warning Warning! You are running aMule as root.
Doing so is not recommended for security reasons,
and you are advised to run aMule as an normal
user instead.
user instead.
ERROR: Info  --- This is the first time you run aMule 2.1.3 ---
More information, support and new releases can found at our homepage,
at www.aMule.org, or in our IRC channel #aMule at irc.freenode.net.
Feel free to report any bugs to http://forum.amule.org
Loading temp files from /root/.aMule/Temp.
All PartFiles Loaded.
ListenSocket: Ok.
External connections disabled in config file
*** Server UDP socket (TCP+3) at 0.0.0.0:4665
*** TCP socket (TCP) listening on 0.0.0.0:4662
*** Client UDP socket (extended eMule) at 0.0.0.0:4672
Empty dir /root/.aMule/Incoming/ shared
ERROR: aMule daemon cannot be used when external connections are disabled. To enable External Connections, use either a normal aMule or set the key"AcceptExternalConnections" to 1 in the file ~/.aMule/amule.conf
Now, exiting main app...
aMule OnExit: Terminating core.
aMule shutdown completed.
root@OpenWrt:/$
Offline ramponis
  • 888
« Risposta #76 il: 27 Ottobre 2007, 07:38 »
Beato te, speriamo che lo fixino presto, lo voglio nella mia supermacchina openwrt  >:(
Ho installato e configurato anche samba.
Così posso accedere alla compact flash e agli storage usb.
Ora voglio far funzionare l'ftp (vsftpd).
L'ho installato, funziona, ma ho dei problemini nel configurarlo  :-\
Offline ramponis
  • 888
« Risposta #77 il: 27 Ottobre 2007, 08:56 »
Forse ho capito...
Ho controllato il tuo archivio e ho visto che nel mio openwrt mancano alcuni package:
jpeg-tools_6b-1
libstdcxx_0.9.28-8
openssl-util_0.9.8e-1
wxbase_2.8.0-1
Solo che non so come compilarli o dove trovarli, riesci ad aiutarmi?
Offline ramponis
  • 888
« Risposta #78 il: 27 Ottobre 2007, 09:15 »
Trovato... sto compilando, poi li carico e vediamo se funzia ;)
Offline ramponis
  • 888
« Risposta #79 il: 27 Ottobre 2007, 13:22 »
Ho compilato il tutto... ma non funziona, stesso problema  :'(
Ora ho tutti i pacchetti tranne:
libstdcxx_0.9.28-8
wxbase_2.8.0-1
Questi due non so come compilarli   :-\
Però penso che libwxbase 2.6.4-1 sia il sostituto di wxbase_2.8.0-1 (o no?)
e per l'altro hai qualche dritta?   ???
Offline ramponis
  • 888
« Risposta #80 il: 29 Ottobre 2007, 11:05 »
Ho trovato nel make del libwxbase commentate delle righe necessarie ad amule.
Le puoi vedere qui...
https://dev.openwrt.org/browser/packages/libs/wxbase/Makefile?rev=9173
Le ho riabilitate e ho ricompilato il tutto (ora con la r9457).
Il package di amule è passato da 1,3Mb a 1,5Mb e mi sono detto è fatta.
Ho installato il tutto, ma stesso risultato quando do il comando amuled
Segmentation fault  :'(
« Risposta #81 il: 29 Ottobre 2007, 12:33 »
Eccomi di nuovo qui dopo 2 giorni di blackout ADSL (a casa non ce l'ho più, per il momento)
Ramponis, lascia perdere tutto e fai così:
1) Scaricati il trunk e i packages ed elimina amule e libwxbase
2) Patcha (devi usare patch) il trunk con i 3 file che ci sono qui:
https://dev.openwrt.org/ticket/1248
Verranno create le directory amule (sotto net), wxbase sotto libs e libstdc++ non ricordo dove.
Poi nella dir di amule/patches copi le patch:
configure1.patch
math.patch
che trovi in questo pacchetto:
http://eko.one.pl/openwrt/amule_src.tgz
se compili per MIPS, copia anche la patch che trovi dentro questo file:
http://wl500g.info/attachment.php?attachmentid=1396&d=1176055300
ora devi selezionare amule come modulo in menuconfig. Salvi, esci e compili amule con
make package/amule--compile V=99
Se compili per MIPS nel makefile di amule devi eliminare la dipendenza
@LINUX_2_6_X86
altrimenti amule non ti compare nel menuconfig e inoltre, sempre se compli per MIPS, dei apportare un paio di modifiche, vado a memoria, a un file configure di amule che darà errore quando stai compilando, va tolto x86 e sostituito con mipsel. Per essere più preciso dovrei ricompilare il tutto. Se ho tempo lo faccio.
« Ultima modifica: 29 Ottobre 2007, 12:47 da marven »
Offline ramponis
  • 888
« Risposta #82 il: 29 Ottobre 2007, 12:46 »
Ci provo, ti dico che succede... ;)
Ps. come si usa patch, non l'ho mai usato  :-\
« Ultima modifica: 29 Ottobre 2007, 12:50 da ramponis »
« Risposta #83 il: 29 Ottobre 2007, 12:49 »
OK, dovrebbe fungere. Ad un utente del forum openwrt, con mobo x86, ha funzionato:
http://forum.openwrt.org/viewtopic.php?pid=58084
Offline ramponis
  • 888
« Risposta #84 il: 29 Ottobre 2007, 12:51 »
Mi spieghi come usare patch? ;)
« Risposta #85 il: 29 Ottobre 2007, 13:03 »
Copi le 3 patch nella directory packages poi
patch -p0 < add-libstdc++.patch
patch -p0 < add-wxbase-2.8.0.patch
patch -p0 < add-amule-2.1.3.patch
Una volta fatto le puoi eliminare.
Come ho detto queste tre patch creano le dir di amule e wxbase.
Per le altre patch non devi usare patch, le devi solo copiare nella dir patches di amule.
Offline ramponis
  • 888
« Risposta #86 il: 29 Ottobre 2007, 14:31 »
Ho applicato le patch e copiato i file dai sorgenti nel folder patch di amule, ma ora quando lancio make menuconfig ottengo:
Collecting package info: package/wxbaseERROR: please fix package/wxbase/Makefile
Collecting package info: package/amuleERROR: please fix package/amule/Makefile
e non mi mostra quei package nei menù.
Ho sbagliato qualche cosa?
« Risposta #87 il: 29 Ottobre 2007, 14:35 »
Prova a fare un
cd ~/trunk/
make package/symlinks
Offline ramponis
  • 888
« Risposta #88 il: 29 Ottobre 2007, 14:57 »
Eseguito:
/openwrt/trunk$ make package/symlinks
++ mkdir -p /home/ramponis/openwrt/trunk/staging_dir/toolchain-i386_gcc4.1.2
++ cd /home/ramponis/openwrt/trunk/staging_dir/toolchain-i386_gcc4.1.2
++ mkdir -p bin lib include stamp
Checking 'autoconf'... ok.
Checking 'bison'... ok.
Checking 'xgettext'... ok.
  make[1] package/symlinks
Perfetto ora vede Amule e Libstdcxx  :D , ma non so dove cercare wxbase...
ricerca in corso, se ti viene in mede in quale menù è fammi un fischio  ;)
« Ultima modifica: 29 Ottobre 2007, 15:01 da ramponis »
Offline ramponis
  • 888
« Risposta #89 il: 29 Ottobre 2007, 15:14 »
Stavo provando intanto a compilare amule e libstdcxx.
Questultimo mi va in errore perchè non trova il file libstdc++.so
/openwrt/trunk/staging_dir/i386/lib/libstdc++.so*': No such file or directory
Dove posso trovarlo?
