  • 1597 Risposte
  • 928530 Visite
« Risposta #360 il: 10 Agosto 2019, 23:38 »
Mi mandi in privato la cartella /etc/config
Con SCP
« Risposta #361 il: 10 Agosto 2019, 23:42 »
@Sberta qui dice che c'è un errore di sintassi nei file di config:
uci: Parse error (EOF with unterminated ') at line 33, byte 333
« Risposta #362 il: 10 Agosto 2019, 23:43 »
Esatto voglio capire cosa è successo mi sa che c'è un bug nella conversione dei file config
Offline Sberta
  • 60
« Risposta #363 il: 10 Agosto 2019, 23:59 »
Relativo al VoIP o alla GUI?
Offline darklight
  • 27
« Risposta #364 il: 11 Agosto 2019, 03:37 »
ho reinstallato la gui sulla stock 248
curl -k https://raw.githubusercontent.com/Ansuel/gui-dev-build-auto/master/GUI_dev.tar.bz2 --outpu
t /tmp/GUI_dev.tar.bz2
bzcat /tmp/GUI_dev.tar.bz2 | tar -C / -xvf -
/etc/init.d/rootdevice debug
Root Script: Setting root flag
Root Script: Reset unlock bit
Root Script: Save root password if modified
Root Script: Setting & Enabling Dropbear SSH Server
Root Script: Restarting Dropbear SSH Server
Root Script: Disable reboot after crash, this gives race condition...
Root Script: Installing in progress...
Root Script: Start rooting
Root Script: Executing /etc/modgui_scripts/01_prereq.sh
Root Script: Disable watchdog
Root Script: Executing /etc/modgui_scripts/02_specific.sh
uci: Invalid argument
Root Script: Applying specific model fixes...
Collected errors:
 * wfopen: /tmp/3.4_ipk/wget_1.17.1-1_brcm63xx-tch.ipk: No such file or directory.
 * pkg_init_from_file: Failed to extract control file from /tmp/3.4_ipk/wget_1.17.1-1_brcm63xx-tch.ipk.
rm: can't remove '/tmp/3.4_ipk': No such file or directory
rm: can't remove '/tmp/4.1_ipk': No such file or directory
Root Script: Checking downgrade limitation bit
Root Script: Removing ripdrv and resuming root process...
Root Script: Executing /etc/modgui_scripts/03_various.sh
Root Script: Enabling hardware serial console...
Root Script: Fixing sysupgrade if needed...
Root Script: Restoring and enabling few transformer mappers...
Root Script: Transformer lib check
Root Script: Creating custom GUI utils symlinks...
Root Script: Add checkversion to cron...
Root Script: Executing /etc/modgui_scripts/04_config.sh
Root Script: Check original config
Root Script: Unlocking web interface if needed
Root Script: Check if variant_friendly_name set
Root Script: Remove https check
Root Script: Check for CSS themes
Root Script: Check driver setting
Root Script: Check Dropbear config file
Root Script: Adding Dropbear wan config
Root Script: Check eco paramaters
Root Script: Restarting power management
Root Script: Create GUI type in config
Root Script: Add new web options
Root Script: New DHCPRelay Option
Root Script: Disable trace from igmpproxy
Root Script: Create new option for led definitions
Root Script: LedEventing new md5sum: ae62bfe6297c81c5c2024ec94b922c84
Root Script: LedEventing md5sum: c2994cf472060f933bfb703c9c15535d
Root Script: Creating and checking real version
Root Script: Implementing WoL
Cannot find device "lan"
Warning: Option 'lan'.wan is unknown
Warning: Option 'mgmt'.wan is unknown
Warning: Section 'mgmt' cannot resolve device of network 'mgmt'
Warning: Option 'wan'.wan is unknown
Warning: Option 'wwan'.wan is unknown
Warning: Section 'wwan' cannot resolve device of network 'wwan'
Warning: Option 'Guest'.wan is unknown
Warning: Option 'hotspot'.wan is unknown
Warning: Option 'Allow_DHCP_Renew_mgmt'._key is unknown
Warning: Option 'Allow_DHCP_Renew_wan'._key is unknown
Warning: Option 'Allow_Ping_mgmt'._key is unknown
Warning: Option 'Allow_Ping_wan'._key is unknown
Warning: Option 'Allow_DHCPv6'._key is unknown
Warning: Option 'Allow_Encapsulated_IPv6'._key is unknown
Warning: Option 'Allow_ICMPv6_Input'._key is unknown
Warning: Option 'Allow_ICMPv6_Forward'._key is unknown
Warning: Option 'Deny_HTTPS_lan'._key is unknown
Warning: Option 'Deny_HTTP_lan'._key is unknown
Warning: Option 'Deny_HTTPS_lan_v6'._key is unknown
Warning: Option 'access_2_LAN_IP'._key is unknown
Warning: Option 'access_2_GUEST_IP'._key is unknown
Warning: Option 'Deny_Guest_lan_gateway'._key is unknown
Warning: Option 'Deny_lan_2_Guest'._key is unknown
Warning: Option 'Deny_Guest_2_lan'._key is unknown
Warning: Option 'Access_Guest_ICMP'._key is unknown
Warning: Option 'SpeedTest_Allow_8888'._key is unknown
Warning: Option 'SpeedTest_Allow_7548'._key is unknown
Warning: Option 'redirectdmz'._key is unknown
Warning: Option 'MARK_CPE_DNSQUERY_SRCIP'._key is unknown
Warning: Option 'MARK_SPEEDTEST_DATA_SRCIP'._key is unknown
Warning: Option 'MARK_DATA_SRCIP'._key is unknown
Warning: Option 'MARK_BULKDATA_SRCIP'._key is unknown
Warning: Option 'MARK_LAN_TO_WAN'._key is unknown
Warning: Option 'MARK_WAN_TO_LAN'._key is unknown
Warning: Option 'MARK_GUEST_TO_WAN'._key is unknown
Warning: Option 'MARK_WWAN_TO_LAN'._key is unknown
Warning: Option 'Allow_ACS_1'._key is unknown
Warning: Option 'Allow_ACS_2'._key is unknown
Warning: Option 'Allow_restricted_sip_1'._key is unknown
Warning: Option 'Allow_restricted_sip_2'._key is unknown
Warning: Option 'Allow_restricted_sip_3'._key is unknown
Warning: Option 'Allow_restricted_sip_4'._key is unknown
Warning: Option 'Allow_restricted_sip_5'._key is unknown
Warning: Option 'Allow_restricted_sip_6'._key is unknown
Warning: Option 'Allow_restricted_sip_7'._key is unknown
Warning: Option 'Allow_restricted_sip_8'._key is unknown
Warning: Option 'Allow_restricted_sip_9'._key is unknown
Warning: Option 'Allow_restricted_sip_10'._key is unknown
Warning: Option 'Allow_restricted_sip_11'._key is unknown
Warning: Option 'Allow_restricted_sip_12'._key is unknown
Warning: Option 'Allow_restricted_sip_13'._key is unknown
Warning: Option 'Allow_restricted_sip_14'._key is unknown
Warning: Option 'Allow_restricted_sip_15'._key is unknown
Warning: Option 'Allow_restricted_sip_16'._key is unknown
Warning: Option 'Allow_restricted_sip_17'._key is unknown
Warning: Option 'Allow_restricted_sip_18'._key is unknown
Warning: Option 'Access_Guest_DHCP'._key is unknown
Warning: Option 'Access_Guest_DNS'._key is unknown
Warning: Option 'Access_Guest_DNS_input'._key is unknown
Warning: Option 'Access_Guest_ICMPv6'._key is unknown
Warning: Option 'Access_Guest_Browser'._key is unknown
Warning: Option 'telnetlan'._key is unknown
Warning: Option 'telnetguest'._key is unknown
does not specify a protocol, assuming TCP+UDP
Warning: Section 'wanapi' has no target specified, defaulting to DNAT
Warning: Section 'SNAT_PING' has no src_dip option specified
Warning: Section @zone[1] (mgmt) has no device, network, subnet or extra options
Warning: Section @zone[3] (wwan) has no device, network, subnet or extra options
 * Clearing IPv4 filter table
 * Clearing IPv4 nat table
 * Clearing IPv4 mangle table
 * Clearing IPv4 raw table
 * Populating IPv4 filter table
   * Zone 'lan'
   * Zone 'mgmt'
   * Zone 'wan'
   * Zone 'wwan'
   * Zone 'Guest'
   * Zone 'hotspot'
   * Rule 'Allow-DHCP-Renew-mgmt'
   * Rule 'Allow-DHCP-Renew-wan'
   * Rule 'Allow-Ping-mgmt'
   * Rule 'Allow-Ping-wan'
   * Rule 'Allow-Encapsulated-IPv6'
   * Rule 'Deny-HTTPS-lan'
   * Rule 'Deny-HTTP-lan'
   * Rule 'Only-allow-access-to-LAN-IP'
   * Rule 'Only-allow-access-to-GUEST-IP'
   * Rule 'Deny-Guest-lan-gateway'
   * Rule 'Deny-lan-2-Guest'
   * Rule 'Deny-Guest-2-lan'
   * Rule 'Allow-Guest-ICMP'
   * Rule 'SpeedTest_Allow_8888'
   * Rule 'SpeedTest_Allow_7548'
   * Rule 'Allow-ACS-1'
   * Rule 'Allow-ACS-2'
   * Rule 'Allow-restricted-sip-from-wan-again-1'
   * Rule 'Allow-restricted-sip-from-wan-again-2'
   * Rule 'Allow-restricted-sip-from-wan-again-3'
   * Rule 'Allow-restricted-sip-from-wan-again-4'
   * Rule 'Allow-restricted-sip-from-wan-again-5'
   * Rule 'Allow-restricted-sip-from-wan-again-6'
   * Rule 'Allow-restricted-sip-from-wan-again-7'
   * Rule 'Allow-restricted-sip-from-wan-again-8'
   * Rule 'Allow-restricted-sip-from-wan-again-9'
   * Rule 'Allow-restricted-sip-from-wan-again-10'
   * Rule 'Allow-restricted-sip-from-wan-again-11'
   * Rule 'Allow-restricted-sip-from-wan-again-12'
   * Rule 'Allow-restricted-sip-from-wan-again-13'
   * Rule 'Allow-restricted-sip-from-wan-again-14'
   * Rule 'Allow-restricted-sip-from-wan-again-15'
   * Rule 'Allow-restricted-sip-from-wan-again-16'
   * Rule 'Allow-restricted-sip-from-wan-again-17'
   * Rule 'Allow-restricted-sip-from-wan-again-18'
   * Rule 'Allow-Guest-DHCP'
   * Rule 'Allow-Guest-DNS'
   * Rule 'Allow-Guest-DNS-input'
   * Rule 'Access-Guest-Browser'
   * Rule 'Refuse_TELNET_LAN'
   * Rule 'Refuse_TELNET_GUEST'
   * Rule 'Default action for outgoing NAT'
   * Rule 'Default action for outgoing NAT for Guest'
   * Redirect #0
   * Forward 'lan' -> 'wan'
   * Forward 'lan' -> 'wwan'
   * Forward 'Guest' -> 'wan'
   * Forward 'Guest' -> 'wwan'
 * Populating IPv4 nat table
   * Zone 'lan'
   * Zone 'mgmt'
   * Zone 'wan'
   * Zone 'wwan'
   * Zone 'Guest'
   * Zone 'hotspot'
   * Redirect #0
 * Populating IPv4 mangle table
   * Zone 'lan'
   * Zone 'mgmt'
   * Zone 'wan'
   * Zone 'wwan'
   * Zone 'Guest'
   * Zone 'hotspot'
 * Populating IPv4 raw table
   * Zone 'lan'
   * Zone 'mgmt'
   * Zone 'wan'
   * Zone 'wwan'
   * Zone 'Guest'
   * Zone 'hotspot'
 * Clearing IPv6 filter table
 * Clearing IPv6 mangle table
 * Clearing IPv6 raw table
 * Populating IPv6 filter table
   * Zone 'lan'
   * Zone 'mgmt'
   * Zone 'wan'
   * Zone 'wwan'
   * Zone 'Guest'
   * Zone 'hotspot'
   * Rule 'Allow-DHCPv6'
   * Rule 'Allow-ICMPv6-Input'
   * Rule 'Allow-ICMPv6-Forward'
   * Rule 'Deny-HTTPS-lan-v6'
     ! Skipping due to different family of ip address
   * Rule 'Allow-Guest-ICMPv6'
   * Rule 'Allow incoming IPv6 when firewall off'
 * Populating IPv6 mangle table
   * Zone 'lan'
   * Zone 'mgmt'
   * Zone 'wan'
   * Zone 'wwan'
   * Zone 'Guest'
   * Zone 'hotspot'
 * Populating IPv6 raw table
   * Zone 'lan'
   * Zone 'mgmt'
   * Zone 'wan'
   * Zone 'wwan'
   * Zone 'Guest'
   * Zone 'hotspot'
 * Set tcp_ecn to off
 * Set tcp_syncookies to on
   ! Unable to write value: No such file or directory
 * Set tcp_window_scaling to on
 * Running script '/etc/firewall.user'
 * Running script '/lib/functions/firewall-ext-tch.sh'
 * Running script '/lib/functions/tod.sh'
iptables: Chain already exists.
ip6tables: Chain already exists.
 * Running script '/lib/functions/firewall-wol.sh'
   ! Skipping due to path error: No such file or directory
 * Running script '/lib/functions/firewall-cwmpd.sh'
 * Running script '/usr/share/miniupnpd-tch/firewall.include'
 * Running script '/lib/functions/firewall-mmpbx.sh'
 * Running script '/lib/functions/weburl-tch.sh'
 * Running script '/lib/functions/firewall-dropbear.sh'
 * Running script '/lib/functions/firewall-telnet.sh'
Root Script: Apply new xDSL options
Root Script: Adding fast cache options
Root Script: Checking if wan_mode option exists...
Root Script: Inizialize and start DoSprotect...
Root Script: Checking if intercept is enabled and disabling if it is...
Root Script: Disabling coredump reboot...
Root Script: Restoring nginx additional options if needed...
Root Script: Adding missing voicednd rule if needed
Root Script: Doing various checks and generating hashes...
Root Script: Setting update branch to STABLE
ash: 9: unknown operand
Root Script: Stable GUI not found in /root
Root Script: Stable GUI not found in /tmp, checking for GUI_dev...
Root Script: Found GUI_dev in /tmp, copying in /root to generate a valid hash
Root Script: Updating GUI in /root folder from /tmp
Root Script: Assuming first time install, cleaning /www dir and re-extracting .bz2
Root Script: Detected upgrade!
Root Script: Old GUI hash:
Root Script: New GUI hash: 1c5ccb47d3f748bc0781b601b090ca98
Root Script: Updating version saved to 9.3.73
Root Script: Resetting version info...
Root Script: Decrypting any encrypted password present in config
Root Script: Executing /etc/modgui_scripts/05_app.sh
Root Script: Trafficmon inizialization
Root Script: Enable DLNAd
Root Script: Enable new upnp
Root Script: Move Aria2 dir
Root Script: Checking opkg feeds config
Root Script: No opkg file supported
Root Script: Reinstalling Telstra GUI if needed...
Root Script: Executing /etc/modgui_scripts/06_network.sh
Root Script: Detecting ISP and cleanup...
Root Script: Adding ipoe in network config...
Root Script: Removing default loopback DNS Servers...
Root Script: Purify WAN network config...
Root Script: Fix DNS bug
Root Script: Checking and fixing dnsmasq daemon naming...
Root Script: Sync DHCP configuration for new GUI
Root Script: Attempt to clean the wansensing script from hardcoded interfaces...
Root Script: Cleaning cups firewall rule...
Root Script: Checking detected ISP and setting CWMP...
Root Script: Apply CVE 2019-11477 workaround
Root Script: Checking atmdevice interface naming...
Root Script: Restarting dnsmasq if needed...
Root Script: Executing /etc/modgui_scripts/99_postreq.sh
Root Script: Applying modifications
Root Script: Resetting cwmp and watchdog
Root Script: Process done.
Root Script: Restarting transformer
Root Script: Stopping nginx
Root Script: Restarting nginx...
hmm non so se sono stanco io o è sparito nella gui... prima mi veniva detto l'ipv6 che mi era stato assegnato, cambiando il driver dsl, switch dhcp della connessione e alcuni device, era sparito completamente la dicitura ipv6 sotto Internet Access
non so se erano presenti tute le personalizzazzioni ipv6, ad esempio su "ip extras" ho solo ipv4
  (edit ero stanco io l'ip lo trovavo sotto diagnostics :noob:
Secondo me aggiungerlo anche a internet access non sarrbbe male.
La confivurazione ipv6 sia della lan che router a me manca
trovato un bug credo...
dmesg mi da questo output
109963.872000] [[0;33;41mBLOG ERROR blog_request :blog_key corruption when deleting flowfor net_p=d11ede38 (ed altri numeri)
« Ultima modifica: 11 Agosto 2019, 11:17 da darklight »
Offline Sberta
  • 60
« Risposta #365 il: 11 Agosto 2019, 07:28 »
@LuKePicci @Ansuel ho riprovato a flashare la GUI e ora funziona  :nod:
L'unico problema rimane il VoIP ora  :headbang:
  • 3418
« Risposta #366 il: 11 Agosto 2019, 09:21 »
Ma che errore ti dà il voip? (Nella pagina con le statistiche nello stato dovrebbe esserci un errore per un minimo parlante)
Hai mica cambiato i DNS? Il cwmp è configurato?
« Ultima modifica: 11 Agosto 2019, 09:41 da FrancYescO »
Offline Sberta
  • 60
« Risposta #367 il: 11 Agosto 2019, 11:00 »
@FrancYescO In statistiche la parte telefono è
Linea: Registering
Chiamate: non attivo
DNS non li ho toccato e non so come si configuri il cwmp  :help:
Offline darklight
  • 27
« Risposta #368 il: 11 Agosto 2019, 11:06 »
Aug 11 11:02:00
daemon.err
transformer[403]
[truncated] getter(rpc.network.interface.@., ipv6uniqueglobaladdr) threw an error: ...share/transformer/mappings/rpc/network.interface.map:39: attempt to concatenate field 'ip' (a nil value)
credo la mancanza del mostrare ipv6 sia dovuta a questo
Che errore é?
« Ultima modifica: 11 Agosto 2019, 11:12 da darklight »
Offline darklight
  • 27
« Risposta #369 il: 11 Agosto 2019, 11:26 »
Per configurare il voip il file é questo /etc/config/mmpbxrvsipnet
Se lo modifichi credo il servizio si ravvii con /etc/init.d/mmpbxd restart
Non postare turto il file qua se ha password. Io non ho voip e come ip proxy ho 192.168.1.100 con password come parola chiave.
Sicuramente da qualcge parte trovi le info per il tuo provider da sostituire a queste di default
  • 3418
« Risposta #370 il: 11 Agosto 2019, 12:28 »
@darklight quell'errore dovrebbe essere risolto nell'ultima versione della GUI ma credo ci sia comunque qualcosa che manchi per ipv6... Tu sei connesso sia in ipv4 che 6?
Offline Sberta
  • 60
« Risposta #371 il: 11 Agosto 2019, 13:07 »
@darklight ho provato a toccacciare il file in questione ma ho solo ottenuto la perdita del profilo .. quindi sono tornato indietro ahahahah
Config estratto dal 789 Tiscali:
config network 'sip_net'
option user_friendly_name 'SIP network'
option cac '-1'
option transparent_soc_transmission '0'
option local_port '5060'
option domain_name 'ims.tiscali.net'
option primary_proxy_port '0'
option primary_registrar 'ims.tiscali.net'
option primary_registrar_port '5060'
option secondary_registrar 'ims.tiscali.net'
option secondary_proxy_port '0'
option transport_type 'UDP'
option reg_expire '3600'
option reg_expire_T_before '1'
option reg_back_off_timeout '60'
option realm_check '0'
option 401_407_waiting_time '0'
option dtmf_relay 'auto'
option dtmf_relay_translation '0'
option timer_T1 '500'
option timer_T2 '4000'
option timer_T4 '5000'
option timer_B '32000'
option timer_D '50000'
option timer_F '32000'
option timer_J '32000'
option provisional_timer '180'
option remote_hold_tone_enabled '0'
option sdp_direction_call_hold 'sendonly'
option sdp_direction_call_hold_answer 'recvonly'
option uri_clir_format 'standard'
option privacy_handling 'apply'
option rejection_response '486'
option no_answer_response '480'
option call_waiting_provisional_response '182'
option call_waiting_reject_response '486'
option reliable_provisional_response 'supported'
option re_registration_mode 'ims'
option forking_mode 'default'
option ingress_media_timeout '1000'
option session_timer 'enabled'
option min_session_expires '90'
option session_expires '1800'
option fail_behaviour 'stop'
option min_period_proxy_redundancy '0'
option escape_hash '1'
option escape_star '0'
option control_qos_field 'dscp'
option control_qos_value 'ef'
option realtime_qos_field 'dscp'
option realtime_qos_value 'ef'
option from_anonymous_handling 'withheld'
option sip_over_ipv6 '0'
option include_sip_instance '0'
option waiting_time_for_registration_on_400_or_503_response '60'
option update_support '1'
option use_domain_in_contact '0'
option use_domain_in_via '0'
option sdp_direction_attribute_media_level_only '0'
option registration_delay '0'
option enable_re_register_on_cancel_timeout '1'
option rport_in_via '1'
option optimized_authentication '0'
option repeat_ringing_interval '60'
option re_register_on_403 '0'
option check_ttl_for_dns_record '1'
option stick_to_outbound_proxy '1'
option switch_next_proxy_on_failure_response '0'
option dns_query_timeout '5000'
option conference_release_call_after_transfer '1'
option disconnect_on_bye_response '0'
option cancel_invite_timer '32000'
option user_agent 'MediaAccess TG789vac v2 Build 16.3.7636-2921'
option primary_proxy 'srvmi.p.ims.tiscali.net'
option interface 'wan'
option network 'sip_net'
option display_name '0039XXXXX'
option user_name '0039XXXX'
option password 'XXXXXX'
option uri '0039XXXX'
option enabled '1'
Config originale 4131 Fastweb:
option cac '-1'
option primary_proxy '192.168.1.100'
option primary_proxy_port '5060'
option secondary_proxy_port '5060'
option primary_registrar '192.168.1.100'
option secondary_registrar_port '5060'
option reg_expire_T_before '72'
option reg_back_off_timeout '180'
option reg_back_off_timeout_algorithm 'random'
option reg_back_off_timeout_max '900'
option reg_back_off_timeout_min '600'
option dtmf_relay 'rfc2833'
option provisional_timer '430'
option remote_hold_tone_enabled '1'
option sdp_direction_call_hold_answer 'inactive'
option no_answer_response '486'
option call_waiting_provisional_response '180'
option reliable_provisional_response 'when_supported'
option re_registration_mode 'standard'
option forking_mode 'replace'
option early_media_detection '1'
option session_timer 'disabled'
option session_expires '180'
option accept_call_from_unconfigured_proxy '1'
option control_qos_value 'cs5'
option realtime_qos_value 'cs5'
option waiting_time_for_registration_on_400_or_503_response '300'
option stick_to_outbound_proxy '0'
option enable_re_register_on_cancel_timeout '0'
option re_register_on_504 '1'
option switch_back_to_primary_proxy_timer '0'
option rtp_local_port_min '4000'
option rtp_local_port_max '4015'
option dnd_response '486'
option hide_userinfo_and_port_in_subscription_request '0'
option interface_update_delay '15'
option user_agent 'MediaAccess DGA4131FWB Build 17.2.0412-2141'
option enabled '0'
option password 'password'
option user_name 'username'
option uri 'profile_0'
option display_name 'displayname'
Al momento ho preso tutto il sip net e spi profile di Tiscali e l'ho copiato sostituendo i relativi paragrafi nel file del Fastweb, il modem vede il profilo ma non lo registra...
La prova fatta prima è stata prendere l'originale Fastweb e modificare solo proxy, domain e dati per l'accesso, così non mi vedeva proprio il profilo...
« Risposta #372 il: 11 Agosto 2019, 13:15 »
@Sberta mi devi trovare l'errore nel log del voip come ti avevo detto, altrimenti non so come aiutarti. Inoltre ti avevo suggerito di posticipare l'istallazione della gui a dopo averlo fatto funzionare perchè ora ti viene difficile capire quando il problema riguarda o meno la gui. Riprova come avevi fatto all'inizio prendendola tutta di sana pianta e recupera nuovamente un log.
Offline Sberta
  • 60
« Risposta #373 il: 11 Agosto 2019, 13:43 »
@LuKePicci Perdonami, non avevo visto il tuo consiglio? Non c'è un modo semplice per cancellare la costume GUI?
Ho appena fatto un logread, dopo 10 che andava avanti ho chiuso...
Naturalmente non ci capisco nulla.. però l'errore non lo vedo più...
« Ultima modifica: 11 Agosto 2019, 23:41 da Sberta »
« Risposta #374 il: 11 Agosto 2019, 16:59 »
mmpbxd[8428]: [MMRVSIPIMPL::REGTERMOBJ]:I: registerStateChanged:937 - regTerm=0x100ab20, hProfile=0x100d070, networkRegisterType 0, oldState Registering eState Msg Send Failure, eReason 8
Controlla i server dns. assicurati che stia usando quelli tiscali. Quelli per il voip su wan pubblica non li conosco quindi prendili dal 789 nel caso.
