  • 6100564 Visite
Offline LorenzoL
  • 417
« Risposta #8505 il: 31 Gennaio 2019, 23:43 »
@lofgents - Not a big expert here, but I would suggest you to flash a recent FW via Tftpd, then try to install via Putty a recent GUI: 1.0.3+3.39 are really outdated.
« Ultima modifica: 31 Gennaio 2019, 23:45 da LorenzoL »
« Risposta #8506 il: 31 Gennaio 2019, 23:52 »
eth4 era l'sfp
:huh:
ma stiamo parlando del 4130? la eth4 dovrebbe corrispondere alla porta WAN fisica (al contrario del timhub che ha 4 porte lan e la quarta diventa eth4 o eth3 a seconda dei casi)
eth5 e' la porta "fake" per il wifi 5ghz
@lofgents never seen 3.39 firmware O.o
Offline jarod73
  • 45
« Risposta #8507 il: 01 Febbraio 2019, 08:01 »
Buongiorno @FrancYescO , e' un timhub.
Saluti j.
Offline lofgents
« Risposta #8508 il: 01 Febbraio 2019, 08:53 »
Thanks that is what I am trying to do as soon as I go beyond 3.39 GUI using this method everything looks O.K. but on closer inspection after reflashing with putty the log in screen does not show a version number of the GUI as it did previously and as soon as an attempt at log in is made I lose access to the log in screen and the browser cannot find anything with 192.168.1.1. Have to start again with a reset , unlock and then begin to flash GUI again from Tftpd and putty.
Offline LorenzoL
  • 417
« Risposta #8509 il: 01 Febbraio 2019, 11:30 »
@lofgents - When you flash a new FW with Tftpd, dont forget to hard-reset the device when the first boot has just ended and clear the browser cache too. If nothing changes, then the device is possibly stuck on bank2 where Tftpd can do nothing. Did you try to use Autoflashgui?
Offline lofgents
« Risposta #8510 il: 01 Febbraio 2019, 13:18 »
Thank you I will try the Autoflash not used that before.
Offline Galactus62
« Risposta #8511 il: 01 Febbraio 2019, 19:26 »
Grazie  naima_is_online per le tue informazioni sul riavvio del 4130 davvero preziose. Finalmente sono diuscito a far riavviare il modem con il firmware 1.0.3, almeno credo, perchè poi mi dice passwords non valida e il tool di @Ansuel non si connette. Qualcuno sa come posso risolvere? Grazie.
Offline uomoukko
  • 121
    • github.com/uomoukko
« Risposta #8512 il: 01 Febbraio 2019, 20:41 »
scusate, ho una domanda per quanto riguarda il settaggio di vpn.
con la versione originale e un banale file di conf
dev tun
ifconfig 10.8.0.1 10.8.0.2
port 1194
proto tcp-server
secret static.key
mi da questo messaggio:
# openvpn-liblzo server.conf
Fri Feb  1 20:20:00 2019 OpenVPN 2.3.18 arm-openwrt-linux-gnu [LZO] [EPOLL] [MH] [IPv6] built on Feb 21 2018
Fri Feb  1 20:20:00 2019 library versions: , LZO 2.10
Fri Feb  1 20:20:00 2019 ******* WARNING *******: OpenVPN built without OpenSSL -- encryption and authentication features disabled -- all data will be tunnelled as cleartext
Fri Feb  1 20:20:00 2019 ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
Fri Feb  1 20:20:00 2019 Exiting due to fatal error
e con quello compilato da me stessa cosa:
# openvpn-nocry server.conf
Fri Feb  1 20:19:39 2019 OpenVPN 2.4.6 armv7l-unknown-linux-uclibc [LZ4] [EPOLL] [MH/PKTINFO] built on Jan 31 2019
Fri Feb  1 20:19:39 2019 library versions:
Fri Feb  1 20:19:39 2019 ******* WARNING *******: OpenVPN built without crypto library -- encryption and authentication features disabled -- all data will be tunnelled as cleartext
Fri Feb  1 20:19:39 2019 ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
Fri Feb  1 20:19:39 2019 Exiting due to fatal error
ho provato a creare il device
# ls -l /dev/net/tun
crw-rw-rw-    1 root     root       10, 200 Feb  1 16:57 /dev/net/tun
ma purtroppo cambia solo l'errore
Fri Feb  1 16:58:01 2019 ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such device (errno=19)
Potreste dirmi dove sbaglio? grazie!
« Risposta #8513 il: 02 Febbraio 2019, 02:53 »
@FrancYescO il problema è che io non ho il tim hub e quindi non ho un'idea ben chiara di come sia fatto. Comunque ora mi è chiaro cosa sia la eth5, ma quindi quante porte rj45 ha? Quattro di cui una wan/lan a seconda dei casi? Lo so che siamo OT, ma almeno chiariamo la scemenza che avevo detto sopra, nel caso qualcuno dovesse leggerla.
« Risposta #8514 il: 02 Febbraio 2019, 08:51 »
esatto https://i.postimg.cc/bNvj0PBV/B3250524-B109-47-AF-BC83-1-B54-CE8764-A5.jpg (le etichette ovviamente non corrispondono ai naming del firmware dato che iniziano da eth0)
su come funzioni la sfp ancora abbiamo dubbi ma che la quarta porta fisica diventi eth3/4 a seconda dell'opzione eth4lanwanmode posso dirlo con sicurezza
@Galactus62 se sei su firmware 1.0.3 fai un reset da tastino dopodiche' dovresti poter usar anche autoflashgui per sbloccare
« Ultima modifica: 02 Febbraio 2019, 08:55 da FrancYescO »
« Risposta #8515 il: 02 Febbraio 2019, 14:50 »
Ok, allora è come sul mio 4131. Tornando a quello che stavamo dicendo allora, sul 4132 in cascata eth4 va semplicemente ignorata, lasciandola dov'è come da impostazioni di fabbrica, eth3 va usata così come si usa la eth4 sul 4130.
Offline jarod73
  • 45
« Risposta #8516 il: 02 Febbraio 2019, 18:41 »
Scusate, non vorrei proseguire con l'off topic, posso garantirvi che con eth3  il tutto non funziona.
Tra l'altro (ma non ho verificato se dipendesse dalla confusione derivata dal  mio errore nel setup iniziale) ora il router secondario si connette regolarmente anche con banda larga in "ethernet",
prima no. In questa modalità ho tutte le funzioni attive (conservando quanto abbiamo discusso con LuKePicci) mentre in bridge perdo quasi tutto.
Saluti J.
edit
Un gigantesco grazie a @LuKePicci  per disponibilità e pazienza.
P.s. ho la 4rta porta ethernet in modalità wan.
« Ultima modifica: 02 Febbraio 2019, 19:14 da jarod73 »
« Risposta #8517 il: 02 Febbraio 2019, 19:45 »
Devo ancora capire alcune cose riguardo il funzionamento di quello switch, comunque credo che la porta giusta debba essere la eth3 am solo dopo aver switchato un paio di cose, in ogni caso così come sei ora problemi non ne hai, dovrebbe funzionare lo stesso.
Offline lukigno95
  • 12
« Risposta #8518 il: 03 Febbraio 2019, 03:29 »
Sto cercando di installare la Luci web gui.
Ho installato la gui di ansuel, vado nella riquadro "estensioni" e installo luci, il problema è che non posso collegare il router a internet con il doppino dato che ora ho una connessione fibra e credo che la gui stia cercando di scaricare i file necessari da internet.
Il mio obbiettivo sarebbe di usare il router come antenna wifi per i dispositivi collegati all'ethernet (e quindi usarlo in client mode), l'ho già fatto con un altro router con openwrt e luci e per questo sto provando a mettere luci anche sul mio tg789vac v2.
Come mi consigliate di installare luci offline? Oppure mi consigliate un altro metodo per usare il router come ricevitore wifi?
« Risposta #8519 il: 03 Febbraio 2019, 15:24 »
@lukigno95 ti ho gia' dato la soluzione per installare luci sul github.
in ogni caso la parte wifi su luci non e' funzionante, e i modem in questione sembrano non supportare la modalita' sta (client) https://www.ilpuntotecnico.com/forum/index.php/topic,80344.msg246530.html#msg246530
