  • 6089206 Visite
Offline laciodrom80
  • 15
« Risposta #4995 il: 07 Dicembre 2017, 15:11 »
ho router 1.0.3 sbloccato gui tim originale in quanto mi interessa solo il wol. Come fare ad aggiornare a 1.0.4 senza perdere il root?Conviene cambiare driver xdsl con quello Asus?
Offline BILBO
  • 36
« Risposta #4996 il: 07 Dicembre 2017, 15:13 »
@BILBO put ptm0 instead of wanptm0 in lan and restart
Like this:  ?
config interface 'lan'
        option type 'bridge'
        option proto 'static'
        option ipaddr '192.168.1.1'
        option ip6assign '64'
        option force_link '0'
        option ipv6 '0'
        list pppoerelay 'ptm0'
        list ifname 'eth0'
        list ifname 'eth1'
        list ifname 'eth2'
        list ifname 'eth3'
        list ifname 'eth5'
        list ifname 'ptm0'
Thank you Ansuel
« Risposta #4997 il: 07 Dicembre 2017, 15:14 »
@BILBO yes
Offline BILBO
  • 36
« Risposta #4998 il: 07 Dicembre 2017, 15:30 »
@Ansuel
Still no ptm0 in ifconfig with vlan set to off and adding ptm0 under lan and rebooting. What else could I try?
        option ipv6 '0'
        list ifname 'eth0'
        list ifname 'eth1'
        list ifname 'eth2'
        list ifname 'eth3'
        list ifname 'eth5'
        list ifname 'ptm0'
root@modemtim:~# ifconfig
bcmsw     Link encap:Ethernet  HWaddr 10:13:31:xx:xx:xx
          RX packets:6842 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6704 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:458320 (447.5 KiB)  TX bytes:9458042 (9.0 MiB)
          Base address:0xffff
br-lan    Link encap:Ethernet  HWaddr 10:13:31:xx:xx:xx
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          RX packets:6738 errors:0 dropped:0 overruns:0 frame:0
          TX packets:155 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:328853 (321.1 KiB)  TX bytes:28046 (27.3 KiB)
eth0      Link encap:Ethernet  HWaddr 10:13:31:xx:xx:xx
          RX packets:384 errors:0 dropped:5 overruns:0 frame:0
          TX packets:172 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:42675 (41.6 KiB)  TX bytes:30893 (30.1 KiB)
eth1      Link encap:Ethernet  HWaddr 10:13:31:xx:xx:xx
eth2      Link encap:Ethernet  HWaddr 10:13:31:xx:xx:xx
eth3      Link encap:Ethernet  HWaddr 10:13:31:xx:xx:xx
eth5      Link encap:Ethernet  HWaddr 10:13:31:xx:xx:xx
          RX packets:6464 errors:0 dropped:5 overruns:0 frame:0
          TX packets:6623 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:416029 (406.2 KiB)  TX bytes:9411888 (8.9 MiB)
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:72 errors:0 dropped:0 overruns:0 frame:0
          TX packets:72 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4968 (4.8 KiB)  TX bytes:4968 (4.8 KiB)
wl0_1     Link encap:Ethernet  HWaddr 10:13:31:6F:42:E3
          RX packets:0 errors:0 dropped:0 overruns:0 frame:95
wl1_1     Link encap:Ethernet  HWaddr 10:13:31:xx:xx:xx
« Risposta #4999 il: 07 Dicembre 2017, 15:32 »
did you try to check if it connect?
also type of connection ? vdsl or adsl ?
Offline -Mirco-
  • 1832
    • Ilpuntotecnicoeadsl
« Risposta #5000 il: 07 Dicembre 2017, 15:40 »
Se permette di tweakkare la banda in down conviene, bisogna capire un pò meglio la situazione però.
Ayrton Senna
Offline neo27
  • 83
« Risposta #5001 il: 07 Dicembre 2017, 15:45 »
fai la prova... togli il driver e vedi se funziona ;)
Fatto... non funge... si è reso necessario un hard reset per ripristinare.
a questo punto deduco che l'output di xdslctl è riferito al driver di /rom/etc/adsl/ mentre quello in funzione è effettivamente quello in /etc/adsl/
Offline aezakmi123
  • 201
« Risposta #5002 il: 07 Dicembre 2017, 15:47 »
Sono abbastanza sicuro che aggiornando senza GUI ti farà lo switch di bank e perderai la root, nel file GUI.tar.bz2 non c'è solo l'interfaccia web ma anche molte altre funzioni.
Secondo me dovresti aggiornare la GUI, fare l'update caricando il file AGTEF_1.0.4_CLOSED.rbi e poi resettando alle impostazioni di fabbrica dovrebbe tornare tutto normale con la GUI di Tim
Dopo l'aggiornamento perderai tutte le configurazioni e dovrai rimetterle
Offline shdf
  • 981
« Risposta #5003 il: 07 Dicembre 2017, 15:57 »
ragazzi ma siamo sicuri che per cambiare i driver xdsl vada inserito in /etc/adsl/ il file adsl_phy.bin???  :smirk:
Non basta solo cambiare il file, bisogna anche fare un stop/start (vedere la faq pagina 1).
31.   E' possibile cambiare versione di driver xdsl?
Da WinSCP è necessario sostituire il file /etc/adsl/adsl_phy.bin
Per applicare le modifiche dare i seguenti comandi:
xdslctl connection --down
xdslctl stop
xdslctl start
xdslctl connection --up
Per vedere la versione in uso
xdslctl --version
« Ultima modifica: 07 Dicembre 2017, 16:03 da shdf »
« Risposta #5004 il: 07 Dicembre 2017, 15:58 »
no in parole povere la versione del driver è scritta nel programma xdslctl, non lo prende dal driver in se... che in ogni caso con la tua prova sappiamo viene caricato da /etc/adsl/...
« Risposta #5005 il: 07 Dicembre 2017, 15:59 »
l'aggiornamento firmware resetta le impostazioni di default
Offline neo27
  • 83
« Risposta #5006 il: 07 Dicembre 2017, 16:10 »
@shdf
col riavvio credo di ottenere lo stesso risultato, correggimi se sbaglio
@Ansuel
quindi oltre al driver in sè bisognerebbe importare il relativo xdslctl altrimenti la verifica è solo un specchietto per allodole ottenebrante... grazie per avermi "caviato" alla grande  :rotfl:
« Ultima modifica: 07 Dicembre 2017, 16:14 da neo27 »
« Risposta #5007 il: 07 Dicembre 2017, 16:13 »
no perchè il driver cambia comunque... quindi sarebbe solo un bug grafico...
Offline neo27
  • 83
« Risposta #5008 il: 07 Dicembre 2017, 16:26 »
e ho capito... peccato che c'è gente (come me e @mixmax) che si è rincoglionita per stò bug grafico... come usare una calcolatrice che dà sempre lo stesso risultato. Forse sarebbe da mettere in prima pagina?
Offline aezakmi123
  • 201
« Risposta #5009 il: 07 Dicembre 2017, 16:28 »
Sì ma la GUI dopo l'aggiornamento rimane e lui non la vuole (che poi non ne capisco il senso ma vabbè)
PS
Hai dato un'occhiata al bug che non fa funzionare i DNS interni? https://www.ilpuntotecnico.com/forum/index.php/topic,77878.msg225258.html#msg225258
