  • 1596 Risposte
  • 904140 Visite
Offline andrea.ant
  • 109
« Risposta #525 il: 26 Ottobre 2019, 12:27 »
comando dato ma nessuna risposta xD quindi dovrebbe aver fatto ?
Offline lorenzocanalelc
  • 678
« Risposta #526 il: 26 Ottobre 2019, 12:28 »
Tutto insieme, comunque strano che la gui non ti abbia messo le repository in automatico... Che versione hai?
Riprova l'installazione dopo il comando
Offline andrea.ant
  • 109
« Risposta #527 il: 26 Ottobre 2019, 12:29 »
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/base/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/base/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/packages/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/packages/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/luci/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/luci/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/routing/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/routing/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/telephony/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/telephony/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/management/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/management/Packages.gz
No packages removed.
Unknown package 'libuci-lua'.
Unknown package 'luci'.
Unknown package 'rpcd'.
kage libuci-lua.
 * opkg_install_cmd: Cannot install package luci.
 * opkg_install_cmd: Cannot install package rpcd.
mv: can't rename '/www/cgi-bin': No such file or directory
mv: can't rename '/www/luci-static': No such file or directory
mv: can't rename '/www/index.html': No such file or directory
rm: can't remove '/usr/lib/lua/uci.so': No such file or directory
sed: /usr/lib/lua/luci/model/uci.lua: No such file or directory
uci: Entry not found
/usr/share/transformer/scripts/appInstallRemoveUtility.sh: line 422: /etc/init.d/uhttpd: not found
neache adesso
« Ultima modifica: 26 Ottobre 2019, 12:55 da MisterFTTH »
  • 678
« Risposta #528 il: 26 Ottobre 2019, 12:30 »
Ma il modem ha una connessione attiva?
Offline andrea.ant
  • 109
« Risposta #529 il: 26 Ottobre 2019, 12:33 »
root@OpenWrt:~# Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/luci/P
                ackages.gz
-ash: Downloading: not found
root@OpenWrt:~# wget: can't execute 'openssl': No such file or directory
> wget: error getting response: Connection reset by peer
  g/Packages.gz
-ash: wget:: not found
root@OpenWrt:~# wget: error getting response: Connection reset by peer
root@OpenWrt:~# *** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/a
-ash: GUI.tar.bz2: not found
root@OpenWrt:~#
root@OpenWrt:~# Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/teleph
                ony/Packages.gz
  ment/Packages.gz
root@OpenWrt:~#
root@OpenWrt:~# Collected errors:
-ash: Collected: not found
root@OpenWrt:~#  * opkg_download: Failed to download https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brc
                m63xx-tch/packages/base/Packages.gz, wget returned 1.
                m63xx-tch/packages/packages/Packages.gz, wget returned 1.
                m63xx-tch/packages/luci/Packages.gz, wget returned 1.
                m63xx-tch/packages/routing/Packages.gz, wget returned 1.
                m63xx-tch/packages/telephony/Packages.gz, wget returned 1.
                m63xx-tch/packages/management/Packages.gz, wget returned 1.
root@OpenWrt:~#
questo se faccio opkg update -_-
certo tramite porta wan seno qua sul sito non ci potevo navigare
« Ultima modifica: 26 Ottobre 2019, 12:53 da MisterFTTH »
  • 678
« Risposta #530 il: 26 Ottobre 2019, 12:36 »
Allora c'è stato sicuramente qualche problema durante l'installazione della gui, prova a dare un "upgradegui" da ssh e vedi se dopo funziona
P.S. non scrivere nuovi post uno dietro l'altro, modifica il predente se devi aggiungere qualcosa
Offline andrea.ant
  • 109
« Risposta #531 il: 26 Ottobre 2019, 12:42 »
scusami
ho fatto upgradegui ma dopo l'aggiornamento e provato a installare luci nullla da fare :(
se provo a reinstallare la gui tramite la gui stessa mi scrive IDLE -_-
non mi fa cambiare l'IP modem principale ed esce questo errore: Indirizzo IP SFP
169.0.0.2
Non può essere usato un IP appartenente all'intervallo degli IP pubblici
  • 678
« Risposta #532 il: 26 Ottobre 2019, 12:46 »
Nella Card "Gui Settings" le specific app risultano installate?
« Ultima modifica: 26 Ottobre 2019, 12:51 da lorenzocanalelc »
Offline andrea.ant
  • 109
« Risposta #533 il: 26 Ottobre 2019, 12:49 »
si si mi scrive installata
  • 678
« Risposta #534 il: 26 Ottobre 2019, 12:51 »
Si basta che cambi l'ip dell'SFP in qualcosa come 172.16.1.1 e poi puoi cambiare gli ip, è un problema della configurazione originale Fastweb.
Fai una prova su Gui Settings, metti dev invece che stabile e dai nuovamente upgradegui da ssh, vediamo se risolvi
Offline a1pollo
  • 172
« Risposta #535 il: 26 Ottobre 2019, 12:52 »
dai questi comandi da shell:
curl -k https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/packages/wget_1.17.1-1_brcm63xx-tch.ipk -o /tmp/wget_1.17.1-1_brcm63xx-tch.ipk
opkg install /tmp/wget_1.17.1-1_brcm63xx-tch.ipk
opkg update
curl -k https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/base/openssl-util_1.0.2n-1_brcm63xx-tch.ipk -o /tmp/openssl-util_1.0.2n-1_brcm63xx-tch.ipk
opkg install /tmp/openssl-util_1.0.2n-1_brcm63xx-tch.ipk
opkg update
« Ultima modifica: 26 Ottobre 2019, 12:54 da MisterFTTH »
Offline andrea.ant
  • 109
« Risposta #536 il: 26 Ottobre 2019, 12:56 »
@a1pollo
OTTIMO :D adesso mi ha installato Luci dopo che ho fatto il tuo passaggio
« Ultima modifica: 26 Ottobre 2019, 13:01 da MisterFTTH »
Offline a1pollo
  • 172
« Risposta #537 il: 26 Ottobre 2019, 13:00 »
@andrea.ant
l'hai installata da shell o da gui?
Offline andrea.ant
  • 109
« Risposta #538 il: 26 Ottobre 2019, 13:05 »
@andrea.ant
prima da gui ed e andata ma poi come ti e successo a te mi e uscito l'errore provandoci ad entrare quindi ho applicato il consiglio che mi diedi post indietro
comunque a me servirebbe usare questo modem con wifi client ma non ho trovato nessuna guida a riguardo ma solo ce chi scrive di smanettare col comando wl ma io non ci riesco
ho letto che e l'unico che tramite il chip 5ghz riesce a risocndere al comando wl ma va fatto tutto tramite ssh
Riporto qui un dettaglio interessante riguardo questo dispositivo, nel caso qualcuno abbia voglia di indagare più a fondo
a mervirebbe riuscire a fare cio ma e tutto spiegato in modo blando -_-
« Ultima modifica: 31 Ottobre 2019, 18:48 da andrea.ant »
« Risposta #539 il: 26 Ottobre 2019, 14:25 »
@a1pollo
Avevo scritto "potrebbe": non volevo allarmare nessuno, ma siccome uso questi router testando i limiti a volte vanno in crash.
P.S. Almeno nel router in mio possesso il connettore della seriale era già saldato sulla board.
@andrea.ant
Forse perché nessuno a provato ad usare questo router come client. Poi usare il 5ghz come client è quasi una contraddizione in termini. Tieni presente che il chip è molto "permaloso" e a volte fallisce (boot loop continuo del router) e non so se il rischio vale la candela.
« Ultima modifica: 26 Ottobre 2019, 14:34 da larsen64it »
