App blacklist telefonica per Smart Modem (DGA4130) e TIM HUB (DGA4132) sbloccati
  • 802 Risposte
  • 394443 Visite
Offline wolfanger
Non ho modificato, almeno di recente nulla. C'è da dire che root a parte ho usato poco e nulla ansuel. Ho aggiornato proprio oggi TIMHub all'ultimo firmware (AGTHP_2.3.2).  Per me l'architettura è sempre armv7l.
Probabilmente l'errore è nel repo distfeeds
opkg update restituisce questo errore:
Collected errors:
 * opkg_download: Failed to download http://downloads.openwrt.org/snapshots/targets/brcm6xxx-tch/VBNTJ_502L07p1/packages/Packages.gz, wget returned 8.
« Ultima modifica: 24 Settembre 2021, 17:21 da wolfanger »
Offline Marvel
  • 200
    • Macoers
Aggiungi i repo validi nel file /etc/opkg.conf:
arch all 100
arch arm_cortex-a9 200
arch arm_cortex-a9_neon 300
src/gz chaos_calmer_base https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/base
src/gz chaos_calmer_packages https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/packages
src/gz chaos_calmer_luci https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/luci
src/gz chaos_calmer_routing https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/routing
src/gz chaos_calmer_telephony https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/telephony
src/gz chaos_calmer_core https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/target/packages
src/gz chaos_calmer_base_macoers https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/base
src/gz chaos_calmer_packages_macoers https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/packages
src/gz chaos_calmer_luci_macoers https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/luci
src/gz chaos_calmer_routing_macoers https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/routing
src/gz chaos_calmer_telephony_macoers https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/telephony
Collected errors:
E commenta il contenuto del file /etc/opkg/distfeeds.conf, quel repo non esiste, normale ti dia errore.
Offline wolfanger
Fatto, grazie mille! Rimosso i duplicati, ora sembra tutto coerente e opkg risponde a dovere.
« Ultima modifica: 24 Settembre 2021, 17:49 da wolfanger »
Offline reynud
Scusate, sono totalmente inesperto e ho bisogno che qualcuno mi metta sulla buona strada per ciò che vorrei realizzare.
Ho un modem TIM Hub Technicolor   (connessione fibra FTTC) con questa release di firmware (mai sbloccato né fatto altro):
Fornitore del prodotto
Technicolor
Nome prodotto
AGHP
Versione Software
AGTHP_2.2.1
Versione Datapump
A2pvfbH043q.d26u
Firmware OID
5f170a2f58c6fb4e96662e74
Versione Bootloader
17.19.1062-0000000-20170512080206-5bebd9fb97718f93b20bca231a620df630da9918
Bootloader OID
59156bce30d40f7fd11860f1
Versione Hardware
VBNT-S
Vorrei poter bloccare alcuni numeri di telefono che mi perseguitano, eventualmente anche senza lista autoaggiornante, li inserisco io... Come posso procedere?  Spero che ci sia qualcuno che possa spiegarmi in pochi semplici step.  Grazie!
  • 9345
ciao prima devi sbloccare il router e poi installare la l'app blacklist
oppure seguire questa guida senza sbloccare
http://blacklist.satellitar.it/#:~:text=L'app%20blacklist%20%C3%A8%20un,filtro%20delle%20chiamate%20in%20entrata.
« Ultima modifica: 01 Ottobre 2021, 06:56 da natalinux »
Offline reynud
Ciao, grazie.
Se provo ad inserire la stringa nel campo dominio della sezione per dyndns mi dice che il formato è errato, non mi lascia salvare. Penso che quel metodo fosse valido per versioni precedenti del firmware... Per sbloccare c'è una guida semplice che posso seguire? Grazie ancora
Offline pluri
Ciao,
mi sto cimentando con l'installazione dell' App blacklist telefonica su TIM HUB (DGA4132) sbloccato con GUI ANSUEL.
Ho prima provato con un setup derivante dall'ultimo fw. 2.3.5 che da quanto ho capito è basato su Homeware 19.
Ho installato i feed disponibili qui https://www.macoers.com/blog/antonio-macolino/feeds_openwrt_homeware_19_brcm6xxx_tch ma in fase di installazione avevo diversi errori tra download falliti e architettura errata.
Ho provato quindi a ripartire da zero installando il fw. 2.2.1 e la GUI Ansuel, ho installato i feed per Homeware 18 ma il risultato è simile. Ho provato ad installare l' App blacklist sia da GUI che da SSH ma il risultato è simile.
Ho un sacco di errori di questo tipo:
Package lttng-tools version 2.6.0-1 has no valid architecture, ignoring.
Qualcuno ha fatto recentemente l'installazione e mi può consigliare quale versione fw. conviene utilizzare ?
Grazie mille !
Offline giottos
  • 185
Buongiorno raga, volevo avere qualche soluzione alla mia problematica se è possibile. Ho un router DGA4132 sbloccato con firmware 2.4.1 e GUI Ansuel 9.7 funziona tutto (sembra) tranne la black list viene caricata ma non blocca i numeri. Ho provato a disistallarla ma non succede nulla. qualche idea? Poi se cortesemente qualcuno mi dice cosa è la SHELL del modem per trovo in alcuni posti im metodo per caricare la black list ma non so cosa sia a meno che non è la procedura di winscp, e poi sapete come si scrive dentro il PUTTY di winSCP? io ho provato ma non mi fa scrivere e devo agire con un PUTTY esterno. Grazie e una buona giornata.
