  • 3535 Risposte
  • 1706155 Visite
Offline SpiK369
« Risposta #1905 il: 02 Gennaio 2021, 11:25 »
Nada!
Fa' il trasferimento, poi tenta di partire si accendono per pochissimo due led rossi a bassissima luminosità (lettere: i e chiocciola), si riavvia nuovamente, e riaparte a lampeggiare la lettera i.
E' diventato un ferma lettere?
Ggrrr....
Offline iHero96
  • 21
« Risposta #1906 il: 02 Gennaio 2021, 11:27 »
Ho provato a fare il downgrade ad un firmware stabile ma non è andato a buon fine. Mi sono ritrovato con la GUI stock e reinstallando questa vedevo ancora la versione vecchia... Vi metto alcuni log:
firmware_upgrade_log_20-06_01-01-21
Copying GUI package and emergency dir to RAM...
Error in preserving GUI files.
Base Files preserved!
Saving root password to modgui file...
Copying config files to homeware_conversion_tmp dir in RAM...
Config files preserved!
GUI File found! Good Job!
Setting reapply_due_to_upgrade flag
Found config dir in RAM!
Config files restored to homeware conversion dir! File will be updated on next boot.
Rooting file not present in new config! Aborting...
Rooting file not found! Using emergency method.
Device Rooted
rootdevice_log_20-13_01-01-21
Root Script Checking installation prerequisites, if needed installation will continue after reboot...
Root Script Enabling hardware serial console...
Root Script Saving hashed root password in uci if modified...
Root Script Enabling ash shell to root...
Root Script Shadow contains different pass than saved one. Save it!
   New password detected!
   Storing encrypted password...
Root Script Checking and force-enabling dropbear SSH Server for root on lan
Root Script Restarting Dropbear SSH Server...
Root Script Disable reboot after crash, this gives race condition...
Root Script OBP sanity check succeeded.
Root Script No force/install flag detected! Doing nothing.
Root Script Changed-and-ucisaved root password detected!
Root Script Force/install flag detected! Reinstalling...
   force/install flag detected! Reinstalling...
Root Script Installing in progress...
Root Script Start rooting
Root Script Executing /etc/modgui_scripts/01_prereq.sh
Root Script Disabling watchdog...
Root Script Checking Free RAM...
Root Script Saving GUI package to /root...
Root Script Executing /etc/modgui_scripts/02_specific.sh
Root Script Checking opkg feeds...
Root Script Applying specific model fixes...
Root Script Installing specificDGA package...
Root Script WARNING! RIP_ID_RESTRICTED_DOWNGR_OPT detected!!
Root Script Executing /etc/modgui_scripts/03_various.sh
Root Script Fixing sysupgrade if needed...
Root Script Restoring and enabling few transformer mappers...
Root Script Transformer lib check
Root Script Creating custom GUI utils symlinks...
Root Script Add checkversion to cron...
Root Script Executing /etc/modgui_scripts/04_config.sh
Root Script Check original config
Root Script Unlocking web interface if needed
Root Script Check if variant_friendly_name set
Root Script Check Dropbear config file
Root Script Check eco paramaters
Root Script Add app-extension var in modgui uci config
Root Script Reinstalling blacklist app after upgrade...
Root Script Add new web options
Root Script New DHCPRelay Option
Root Script Suppressing wansensing logs
Root Script Setting transformer log level to 2
Root Script Setting cron log level to 5
Root Script Create new option for led definitions
Root Script LedEventing new md5sum: ae62bfe6297c81c5c2024ec94b922c84
Root Script LedEventing md5sum: 6a070606c3ab17090438aec778195ec8
Root Script Creating and checking real version
Root Script Disable CWMP update by default
Root Script Implementing WoL
Root Script Apply new xDSL options
Root Script Adding fast cache options
Root Script Checking DoSprotect kernel modules...
Root Script Enabling and starting DoSprotect service...
Root Script Checking mobiled libs...
Root Script Checking if intercept is enabled and disabling if it is...
Root Script Disabling coredump reboot...
Root Script Restoring nginx additional options if needed...
Root Script Adding missing voicednd rule if needed
Root Script Doing various checks and generating hashes...
Root Script Update branch detected: STABLE
Root Script GUI hash set: c31283efcc59b512d60048daec46c56a
Root Script Resetting version info...
Root Script Decrypting any encrypted password present in config
Root Script Executing /etc/modgui_scripts/05_app.sh
Root Script Trafficmon inizialization
Root Script Enable DLNAd
Root Script Move Aria2 dir
Root Script Reinstalling Telstra GUI if needed...
Root Script Executing /etc/modgui_scripts/06_network.sh
Root Script Removing default loopback DNS Servers...
Root Script Purify WAN network config...
Root Script Fix DNS bug, make sure odhcp is enabled
Root Script Enabling odhcpd on boot
Root Script Checking and fixing dnsmasq daemon naming...
Root Script Sync DHCP configuration for new GUI
Root Script Attempt to clean the wansensing script from hardcoded interfaces...
Root Script Cleaning cups firewall rule...
Root Script Restarting firewall...
Root Script Apply CVE 2019-11477 workaround
Root Script Checking atmdevice interface naming...
Root Script Restarting dnsmasq if needed...
Root Script Executing /etc/modgui_scripts/99_postreq.sh
Root Script Applying modifications
Root Script Resetting cwmp and watchdog
Root Script Removing .install_gui flag
Root Script Process complete, restarting services.
Root Script Restarting transformer...
Root Script Stopping nginx
Root Script Restarting nginx...
Root Script Process complete. tch-nginx-gui is now installed!
migrate_log_00-00_01-01-70
mount_root-mod: checking if there are files to be removed...
mount_root-mod: checking if overlay must be transfered...
mountroot_log_00-00_01-01-70
mount_root-mod: modoverlay run_mount_checks
mount_root-mod: modoverlay mount checks passed
mount_root-mod: modoverlay moved to (/overlay/bank_X)/modoverlay...
mount_root-mod: modoverlay pivoting...
mount_root-mod: mounting overlay fs
mount_root-mod: modoverlay pivoting complete
Qualcuno mi può dare una mano??
GRAZIE! :)
« Ultima modifica: 02 Gennaio 2021, 11:47 da MisterFTTH »
  • 3403
« Risposta #1907 il: 02 Gennaio 2021, 11:41 »
@Nanjerd non hai i.pkstato alcun vendorid giusto? Prova ad impostare quello di un modem di Fastweb e prova anchebcambiando indirizzo Mac, ricordo di qualcun altro che aveva questo problema ma non ricordo se e come aveva risolto mi sembra in uno di questi modi..
@SpiK369 con che firmware stai provando? Prova 1.0.3 e 2.2.1, servirebbe un log da seriale...
@iHero96 che significa "reinstallando questa vedevo ancora la versione vecchia"?
Offline iHero96
  • 21
« Risposta #1908 il: 02 Gennaio 2021, 11:42 »
reinstallando la GUI custom...
« Ultima modifica: 02 Gennaio 2021, 11:46 da MisterFTTH »
  • 3403
« Risposta #1909 il: 02 Gennaio 2021, 11:55 »
Si ma cosa.vedevi di vecchio? Le config? la versione GUI? la versione firmware?
Offline iHero96
  • 21
« Risposta #1910 il: 02 Gennaio 2021, 12:05 »
Del firmware, se il downgrade del firmware non è andato :)
« Ultima modifica: 02 Gennaio 2021, 12:17 da MisterFTTH »
  • 3403
« Risposta #1911 il: 02 Gennaio 2021, 12:13 »
Hai fatto partire downgrade firmware
-si è messo stock al firmware downgradato
-hai reinstallato la GUI e ti segnava il firmware che avevi prima? Tralaltro, di che versioni stiamo parlando? Hai utilizzato altre versioni della GUI in passato oltre la .65?
Offline iHero96
  • 21
« Risposta #1912 il: 02 Gennaio 2021, 12:17 »
Nope, fatto partire il downgrade, avevo la gui stock, fatto update della GUI da ssh ma dopo nelle info vedevo sempre la versione firmware precedente (ovvero SUCCESSIVA). Sì ho usato altre versioni della GUI.
Mi sembra non logico che la GUI aggiorni il firmware...
« Ultima modifica: 02 Gennaio 2021, 12:29 da MisterFTTH »
Offline SpiK369
« Risposta #1913 il: 02 Gennaio 2021, 12:49 »
Nessuno mi aiuta?
« Risposta #1914 il: 02 Gennaio 2021, 12:57 »
@SpiK369 hai parlato del tuo problema appena un'ora e mezza fa...invece di sollecitare una soluzione chiavi in mano come se questo forum fosse l'assistenza clienti di una azienda, inizia col ragionare in merito al suggerimento di @FrancYescO...
Offline SpiK369
« Risposta #1915 il: 02 Gennaio 2021, 13:07 »
Lungi da me considerare il forum un centro Assistenza.
La problematica è emersa con l'uso dell'ultima GUI stable tentando di aggiornare il device ad una versione firmware superiore alla 2.2.0.
Il motivo del sollecito è perché secondo me c'è qualche problema sulle ultime gui che possono compromettere i device e vorrei evitare la spiacevole situazione anche ad altri utenti.
La soluzione @FrancYescO, che ringrazio, già vagliata come scritto ma il loop permane.
Se può essere d'aiuto dopo aggiornamento firmware, con ultima GUI stable, il modem al riavvio s'è presentato con GUI TIM senza alcuna possibilità di entrare (non accettava nè password default nè  accesskey). SSH ancora disponibile tentativo di reinstallare GUI e al reboot, loop perenne.
  • 3403
« Risposta #1916 il: 02 Gennaio 2021, 13:21 »
@SpiK369 ti ripeto, se non va ne con un 1.0.3 ne con 2.2.1 (sperando che sia questo l'ultimo firmware che hai messo) serve un log da seriale per capire cosa sta succedendo, altrimenti consideralo fermacarte.
@iHero96 servono dettagli su tutto lo storico versioni che non stai dando, quindi formatta con mtd -r erase rootfs_data e controlla se anche ripartendo da 0 con l'ultima GUI hai il problema.
i problemi c'erano con le gui precedenti alcuni dei quali non si risolvono nemmeno aggiornando la GUI, l'unica è installare l'ultima GUI da 0: fin quando si continuano ad utilizzare GUI precedenti alla 9.6.65 (soprattutto se superiori alla 9.5.60) non ne veniamo più fuori.
Offline iHero96
  • 21
« Risposta #1917 il: 02 Gennaio 2021, 13:24 »
Grazie! Niente storico perché nessuno me lo aveva ancora chiesto 😅
Comunque ho fatto il root con la 1.0.3 installato l'ultima gui (.65) e poi aggiornato all'ultima beta 2.2.3.003 e installato la gui .65.
Il downgrade ho provato a farlo senza successo alla 2.2.1
Offline AndreaBallarin
  • 14
« Risposta #1918 il: 02 Gennaio 2021, 14:02 »
@Ansuel A casa ho un DGA4131, un DGA4130 e uno TG789vac2 tutti con la tua GUI! Hai fatto e stai facendo un lavoro super! Uno fa da router principale e due sono in bridge, li uso come AP.
Secondo te è possibile realizzare uno tool per la gestione centralizzata di tutti gli apparati? Dimmi se può sembrarti un'idea carina. Se vuoi ti posso aiutare su GitHub!
« Risposta #1919 il: 02 Gennaio 2021, 14:04 »
@SpiK369
Probabilmente con tftp carica il firmware ma non  fa il flash. Se fosse andato a buon fine il caricamento sarebbe partito "normalmente" per almeno10/15 secondi e non avrebbe fatto subito il fail boot. Per sicurezza serve il log da seriale.
@iHero96
Lascia perdere le beta la gui funziona solo con le stabili e a volte nemmeno con quelle.
« Ultima modifica: 02 Gennaio 2021, 15:49 da larsen64it »
