  • 6103710 Visite
Offline shdf
  • 981
« Risposta #2850 il: 17 Ottobre 2017, 19:17 »
avete notato, quando si pinga il suo PC da SSH la latenza è maggiore di 1ms. Non ho mai visto questo prima, anche con 100 Mbit router.
Normalmente deve essere <1ms
root@livebox:~# ping 192.168.1.29
PING 192.168.1.29 (192.168.1.29): 56 data bytes
64 bytes from 192.168.1.29: seq=0 ttl=128 time=1.267 ms
64 bytes from 192.168.1.29: seq=1 ttl=128 time=1.558 ms
64 bytes from 192.168.1.29: seq=2 ttl=128 time=1.456 ms
64 bytes from 192.168.1.29: seq=3 ttl=128 time=1.538 ms
64 bytes from 192.168.1.29: seq=4 ttl=128 time=1.543 ms
64 bytes from 192.168.1.29: seq=5 ttl=128 time=1.527 ms
il mio cpuload è da 0
Mem: 243160K used, 242124K free, 0K shrd, 13708K buff, 44920K cached
CPU:   0% usr   0% sys   0% nic  98% idle   0% io   0% irq   0% sirq
Load average: 0.01 0.02 0.05 2/82 13245
  PID  PPID USER     STAT   VSZ %VSZ %CPU COMMAND
 1937     1 root     S     6112   1%   0% /usr/bin/swmdk
 2289     1 root     S    14100   3%   0% hostapd -bund -p /var/run/hostapd.pid
 5553     1 root     S     3084   1%   0% {lte-doctor-logg} /usr/bin/lua /usr/b
13241 13224 root     R     1708   0%   0% top
 1300     2 root     SW       0   0%   0% [wl0-kthrd]
 1161     2 root     SW       0   0%   0% [bcmsw_rx]
13106     1 root     S    16844   3%   0% lua /usr/bin/transformer
 6509  6501 nobody   S     6588   1%   0% nginx: worker process
 2500     1 root     S     6208   1%   0% {wansensing.lua} /usr/bin/lua /sbin/w
  963     1 root     S     4452   1%   0% /usr/sbin/cgrulesengd -n -Q -u root
 1915     1 root     S     3956   1%   0% {ledfw.lua} /usr/bin/lua /sbin/ledfw.
 6501     1 root     S     3688   1%   0% nginx: master process /usr/sbin/nginx
 1911     1 root     S     3456   1%   0% {status-led-even} /usr/bin/lua /sbin/
 2762     1 root     S     2432   1%   0% lua /usr/bin/hostmanager.lua
 5359     1 root     S     2344   0%   0% /usr/bin/igmpproxy
 5417     1 root     S     2284   0%   0% /usr/bin/mldproxy
 2000     1 root     S     1952   0%   0% /usr/bin/bcmubusbridge
 2404     1 root     S     1908   0%   0% /sbin/netifd
 2457     1 root     S <   1840   0%   0% /usr/sbin/conntrackd -C /etc/conntrac
 7041     1 root     S     1720   0%   0% /usr/sbin/telnetd -F -l /bin/login
« Ultima modifica: 17 Ottobre 2017, 19:20 da shdf »
  • 9344
« Risposta #2851 il: 17 Ottobre 2017, 19:24 »
puoi dirmi se il port forwading funziona?
si funziona
  • 9344
« Risposta #2852 il: 17 Ottobre 2017, 19:27 »
qualcuno mi può fare un recap dei bug nella gui? escluso il bug del wifi tod...
nello specifico mi servono test per l'upgrade per sapere se rimane il root...
e test approfonditi  su dmz e apertura porte....
mi è stato segnalato che non funziona... mi serve sapere se è così o no :)
nella rete mobile 3g nel profilo internet il tasto connetti rimane in off
Offline Akkor
  • 16
« Risposta #2853 il: 17 Ottobre 2017, 19:34 »
Confermo Pigr8.
Un Asus DSL-AC88U  modemrouter + TG789Vacv2 configurato come ata voip funziona perfettamente su numero Tim. Non vedo perchè mettendo anche il DGA 4130 in bridge da usarsi come modem puro, non dovrebbe funzionare in quel modo.
Perfetto ora mi serve solo aiuto per fare il downgrade dalla 1.04...........non riesco a far andare il metodo tftpd. Consigli ?
Vi ringrazio ma proprio non vuole andare
metto gli screenshot della configurazione che uso e il log
https://ibb.co/eKwG0m
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 12:13:31:63:99:03 [17/10 16:44:50.284]
Client requested address 0.0.68.0 [17/10 16:44:50.285]
no more address or address previously allocated by another server [17/10 16:44:50.285]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 12:13:31:63:99:03 [17/10 16:44:53.288]
Client requested address 0.0.68.0 [17/10 16:44:53.288]
no more address or address previously allocated by another server [17/10 16:44:53.288]
Rcvd DHCP Discover Msg for IP 0.0.0.0, Mac 12:13:31:63:99:03 [17/10 16:45:16.361]
Client requested address 0.0.68.0 [17/10 16:45:16.361]
no more address or address previously allocated by another server [17/10 16:45:16.361]
Rcvd BootP Msg for IP 0.0.0.0, Mac 10:13:31:63:99:FA [17/10 16:45:33.591]
Client requested address 0.0.68.0 [17/10 16:45:33.592]
no more address or address previously allocated by another server [17/10 16:45:33.592]
Rcvd BootP Msg for IP 0.0.0.0, Mac 10:13:31:63:99:FA [17/10 16:45:34.687]
Client requested address 0.0.68.0 [17/10 16:45:34.689]
no more address or address previously allocated by another server [17/10 16:45:34.689]
Rcvd BootP Msg for IP 0.0.0.0, Mac 10:13:31:63:99:FA [17/10 16:45:35.786]
Client requested address 0.0.68.0 [17/10 16:45:35.786]
no more address or address previously allocated by another server [17/10 16:45:35.786]
Datemi una mano pls
Offline TeddyRaspin76
  • 340
« Risposta #2854 il: 17 Ottobre 2017, 19:38 »
si funziona
A me no. Se provengo dalla gui tim con regole già impostate, nessun problema. Se le aggiungo dalla gui nuova, me le salva correttamente, ma all'atto pratico non vanno (infatti su Emule, ad esempio ho ID Basso, mentre le stesse regole create da GUI Tim mi permettono di avere ID Alto). Non si capisce perché.  :help:
  • 340
« Risposta #2855 il: 17 Ottobre 2017, 19:42 »
Devi usare TFTPd ultima versione, impostare IP del modem su 192.168.1.1 e LAN su quello che vuoi e fare il BIND IP sia sul menu DHCP che nelle impo generali, poi tra le opzioni metti IP del modem 192.168.1.1 e Subnet Mask : 255.255.255.0. Size of Pool : 1 salvi e riapri TFTPd, spegni il modem, inserisci uno spillo dietro al reset e tenendo premuto accendi finché il LED arancione non inizia a lampeggiare. A quel punto se hai seguito le procedure della guida in PDF del Technicolor, ti partirà il trasferimento del file del firmware.
Tuttavia, tieni presente che se sei su BANK_2 e sei senza sblocco, tale procedura non avrà alcun effetto, cioè non potrai fare alcun upgrade/downgrade manuale del firmware.
Offline pigr8
  • 175
« Risposta #2856 il: 17 Ottobre 2017, 19:44 »
dunno, it's not a problem btw
first one router, the other is the dga
« Risposta #2857 il: 17 Ottobre 2017, 19:57 »
si funziona
nel senso che crea la regola senza problemi o che la regola effettivamente la apre?
  • 9344
« Risposta #2858 il: 17 Ottobre 2017, 19:58 »
  • 340
« Risposta #2859 il: 17 Ottobre 2017, 20:02 »
E hai verificato che funzioni tale regola ? Tipo su Emule ?
Offline ervius2
  • 79
« Risposta #2861 il: 17 Ottobre 2017, 20:05 »
X il port forwarding, dopo aver creato le regole, ho dovuto riavviare il modem per farle funzionare...
« Risposta #2862 il: 17 Ottobre 2017, 20:19 »
la gui ultima versione? questo posso risolverlo :)
Offline Akkor
  • 16
« Risposta #2863 il: 17 Ottobre 2017, 20:33 »
Ti ringrazio! quando parli di ultima versione ti riferisci alla versione 32 o 64bit ? Deve lampeggiare l'arancione o il verde della lan ? sulla guida inglese diceva il verde lan..............
Offline ervius2
  • 79
« Risposta #2864 il: 17 Ottobre 2017, 20:49 »
... Ho fatto dei test prima di risponderti, e si, con la 3.16, eliminata e reinserita regola, ha funzionato solo dopo il riavvio del modem.
