  • 6075360 Visite
« Risposta #2445 il: 11 Ottobre 2017, 00:49 »
And the webui is still missing the cards...
try to remove www/lua/card limiter.lua
and redo command
Offline shdf
  • 981
« Risposta #2446 il: 11 Ottobre 2017, 00:52 »
the cards are back when i remove www/lua/card limiter.lua   :great:
with 3.12 i think we created more problems than solved...
Offline ItalianGamer91
  • 408
« Risposta #2447 il: 11 Ottobre 2017, 00:53 »
scaricare ed installare senza permessi una cosa come la tua gui per esempio e molto grave sai @Ansuel per giunta senza notifica fai solo schifo  :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :destroyall: :admin: :helpme: @mavelot @MisterFTTH @Miguel89 @-Mirco-  non va bene la cosa
« Ultima modifica: 11 Ottobre 2017, 00:56 da ItalianGamer91 »
« Risposta #2448 il: 11 Ottobre 2017, 00:55 »
nha i know where is the problem... card limiter check ppp_mgmg... but as we removed it, the check fails... this would cause a complete crash of the webui or... THAT LOL... will fix it in just a sec...
EDIT try now pls :( should work now...
« Ultima modifica: 11 Ottobre 2017, 00:59 da Ansuel »
Offline cicciokim1
  • 48
« Risposta #2449 il: 11 Ottobre 2017, 01:00 »
Aggiornamento Utility AGTEF
Abbandonato telnet. Implementato SSH
https://we.tl/NoYLXYESKt
Offline shdf
  • 981
« Risposta #2450 il: 11 Ottobre 2017, 01:01 »
no Ansuel, the cards are still missing  :shock:
I have to go sleep now, tomorow i work  :bye:
« Risposta #2451 il: 11 Ottobre 2017, 01:04 »
oke...
Offline ^NiCo^
  • 1258
« Risposta #2452 il: 11 Ottobre 2017, 01:07 »
IO NON VI CAPISCO.... BHA..... vabbè
CHE POI.... 1 non scarica nulla... vede solo l'md5 di un file di 2 mega HAI UNA 200 MEGA.... il cwmpd minimo ti carica un file più grande... poi 2 non autoupgreda nulla... fa solo un check della versione stop.... poi tu devi fare l'aggiornamento con la manina...
Calma ci siamo fraintesi, tralasciando che ho scritto male la prima frase, volevo dire che fà il check per l' auto-upgrade non che fà l' auto-upgrade.
Cmq l' ho staccato dato che non mi serve ne interessa (e 2 ore mi sembrano troppo pochine tra un controllo e l' altro), quando voglio aggiornare lo faccio a mano.
ps
Il cwmpd è stata la prima cosa che ho staccato... se tim vuole monitorare la mia linea che me la sistemi prima ! avere questo modem non vuol dire avere 200mbit /sad
Se dici che non scarica il file ho interpretato male lo script dove ho letto curl etc
Perchè invece di fare così non modifichi lo script/bottone in modo che quando lo clicchi controlla se cè la versione nuova e chiede se vuoi aggiornare ? mi sembra molto più semplice, meno invasivo e più "leggero" per il modem anziche fargli fare un check ogni due ore.
« Risposta #2453 il: 11 Ottobre 2017, 01:11 »
ps
il check lo faceva prima giornalmente...
per il check manuale, ci stavo lavorando ma poi l'ho messo in secondo piano...
il check di due ore l'ho messo per vedere se effettivamente funziona... poi secondo me 2 mb di download ogni 2 ore sono davvero trascurabili.
tempo fa avevo chiesto che delay fosse giusto per il check ma non mi rispose nessuno...
« Risposta #2454 il: 11 Ottobre 2017, 01:13 »
molto figo però a me con nulla collegato rimane con schermata bianca :(
Offline lastway
  • 18
« Risposta #2455 il: 11 Ottobre 2017, 01:20 »
Tasto destro del mouse sull'icona presente nella system tray -> Impostazioni
DGA4130 con AGTEF_2.2.1
Offline cicciokim1
  • 48
« Risposta #2456 il: 11 Ottobre 2017, 01:24 »
Cosa intendi con nulla collegato? Senza modem? in tal caso è normale. E' una finestra di browser aperta sulla web admin del router. Dopo una trentina di secondi se non trova la pagina di login dovrebbe uscire un errore stile IE11.
Fai click col tasto dx sull'icona nella tray e apri impostazioni. Devi settare ip e credenziali. Chiudi e riapri. Dovrebbe funzionare.
« Risposta #2457 il: 11 Ottobre 2017, 01:36 »
C'è un limite al modo in cui si possono esprimere le proprie opinioni: si chiama educazione !
Questo linguaggio non è tollerabile.
Sospeso 3 giorni
Offline RoyalPains
  • 71
« Risposta #2458 il: 11 Ottobre 2017, 07:05 »
al massimo ti potrò aiutare a farlo funzionare
certezze 0
Ansuel sono molto tentato a prendere questo modem, un modem di emergenza è sempre comodo in attesa che migliorano anche il Fritz 7590 e comprerò anche quello..
comunque spero che riuscirai ad aiutarmi a farlo funzionare con tiscali voip :)
una domanda ma scalda molto questo modem ? ho visto immagini in rete che addirittura lo tengono sospeso sui libri o mollette...  :undecided:
Offline erpomata
  • 108
« Risposta #2459 il: 11 Ottobre 2017, 07:14 »
Io ci ho messo un rialzo per portatili con ventola.
Considera che sopra al dga ho messo il 7490 e entrambi scaldano ben bene.
GUI: 4.6.8 - Firm: 1.0.3
