  • 6038959 Visite
0 Utenti e 22 Visitatori stanno visualizzando questo topic.
Offline palazzetto07
  • 12
« Risposta #5910 il: 09 Gennaio 2018, 13:58 »
Grazie mille davvero:
non solo è andato al primo colpo col DDNS ma mi sento anche più tranquillo adesso, e prometto che seguirò con più attenzione il forum, anche perchè vorrei imparare qualcosina in più  8)
Offline lofgents
« Risposta #5911 il: 09 Gennaio 2018, 16:35 »
Firstly my apologies for posting in English.
We have been away for a few days and unplugged the modem on return the GUI and internet were inaccessible.
I was using v1.04 of the firmware and 3.25 GUI.
I had to reset using the rear reset button which left the firmware intact and unlocked but reverted to the original GUI.
I updated to GUI 3.9 then tried to update to one of the v4 GUI using putty commands the GUI would update but when entering the Gateway tab all the fields were empty and on the initial log on screen there was no firmware version present just dashes.
I tried a different version of GUI  and after the log in screen the modem would be inaccessible again.
I have reset and reverted back to 1.03 firmware and GUI 3.9 set everything up ready to reconnect and left powered off overnight to test, this morning I could log in to the modem as normal but the modem started up in bridge mode. I am concerned something is corrupted due to inability to update to the latest GUI and powering off for a few hours the modem starts in a different mode.
Is there something I am doing incorrectly or a better procedure I should follow to resolve the problems
Thanks
         Dave
Offline LorenzoL
  • 417
« Risposta #5912 il: 09 Gennaio 2018, 17:52 »
Ciao Dave, I would suggest you to try to flash  the 1.0.3 FW via Tftpd; it's a quite simple procedure and then see what happens. You will find many useful info here, on page 1 / F.A.Q
Offline reds
  • 105
« Risposta #5913 il: 09 Gennaio 2018, 19:29 »
Buonasera a tutti . ho sbloccato il mio :
Fornitore del prodotto   Technicolor
Nome prodotto       AGEVO
Versione Software   AGTEF_1.0.3
Versione Gui            2.10
Nome Host             modemtim
seguendo la guida.......... ma poi leggendo su questo Thread , vedo che la gui sta alla vers . 4.6.8 e quindi volevo aggiornarlo.
wget -P /tmp https://repository.ilpuntotecnico.com/files/Ansuel/AGTEF/GUI.tar.bz2
wget -P /root https://repository.ilpuntotecnico.com/files/Ansuel/AGTEF/GUI.tar.bz2
bzcat /tmp/GUI.tar.bz2 | tar -C / -xvf -
/etc/init.d/rootdevice force
ma non riesco a collegarmi ne con Winscp  ne Putty........ e ricevo il seguente messaggio:
Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione.
Connessione fallita.
devo abilitare qualcosa dalla pagina del router ??O lo sblocco non è stato eseguito x bene??e quindi da rieseguire?? grazie
« Ultima modifica: 09 Gennaio 2018, 19:31 da reds »
Offline mixmax
  • 698
« Risposta #5914 il: 09 Gennaio 2018, 20:41 »
@reds  ma lo sblocco lo hai fatto ora ? comunque se non riesci ad avere accesso a ssh lo sblocco non ha funzionato ,riprovaci.Ma prima prova a riavviare il modem e vedere se funziona Putty
« Ultima modifica: 09 Gennaio 2018, 20:43 da mixmax »
Offline smessina
« Risposta #5915 il: 09 Gennaio 2018, 20:47 »
Salve, seguendo le vostre utili guide ho sbloccato il router. Adesso avevo la necessità di montare una cartella condivisa  su un Nas Linux, quindi un percorso di rete locale, su un percorso locale del router: qualcuno sa indicarmi come fare? Ho provato con Mount ma fallisce. Leggendo in rete mi pare di aver capito che bisognerebbe installare un cliente NFS sul router (sul Nas gira un server NFS). per installare NFS ho provato con opgk update ma fallisce. Mi sapreste aiutare?
« Ultima modifica: 09 Gennaio 2018, 20:56 da MisterFTTH »
Offline smessina
« Risposta #5916 il: 09 Gennaio 2018, 20:51 »
Scusate ma la mia richiesta non era una risposta all'utilizzo thread, ma una nuova richiesta  :worry:
Offline reds
  • 105
« Risposta #5917 il: 09 Gennaio 2018, 20:55 »
Questa à la schermata della pagina del router :help:
Offline reds
  • 105
« Risposta #5918 il: 09 Gennaio 2018, 21:13 »
@ mixmax  riavviato da gui il modem e magicamente  putty si connette
dato i vari commandi  . . anche se l'ultimo :
/etc/init.d/rootdevice force mi ha riportato un errore.. ma credo la procedura sia andata a buon fine. almeno spero... :rotfl:
Offline lofgents
« Risposta #5919 il: 09 Gennaio 2018, 22:31 »
Thank you for the reply I will try your suggestion.
Cheers
          Dave
Offline aezakmi123
  • 201
« Risposta #5920 il: 09 Gennaio 2018, 23:24 »
Cosa restituisce esattamente? Hai questo file /etc/opkg.conf?
Puoi provare a reinstallare la GUI e riprovare con opkg update
Per la GUI:
wget https://repository.ilpuntotecnico.com/files/Ansuel/AGTEF/GUI.tar.bz2 -O /root/GUI.tar.bz2
wget https://repository.ilpuntotecnico.com/files/Ansuel/AGTEF/GUI.tar.bz2 -O /tmp/GUI.tar.bz2
/etc/init.d/transformer restart
/etc/init.d/nginx restart
Offline Lil-Koby
  • 44
  • May the FOURCC be with you.
« Risposta #5921 il: 10 Gennaio 2018, 01:02 »
Qualcuno ha mai sentito qualcosa di nuovo da Ansuel ?
Lentamente mi manca... ;)
Ed è sicuro passare ora alla 1.1.0_001_closed ?
Mi piacerebbe provare il nuovo driver adsl...
Nel peggiore dei casi, un downgrade non dovrebbe essere più un problema ?
Io uso google traduttore, ti prego perdonami...
Offline Ivymike
  • 103
« Risposta #5922 il: 10 Gennaio 2018, 10:09 »
qual'è la procedura nel 4130 per cambiare la zona wifi o aumentare la potenza?
Offline enrico2772
  • 327
« Risposta #5923 il: 10 Gennaio 2018, 11:06 »
ma si puo' installare il firmware 1.1.0 .001 closed ???  e' sicuro???
Offline Diavulrus
  • 128
« Risposta #5924 il: 10 Gennaio 2018, 11:20 »
Che versione gui hai?
Assicurati che nel file /etc/opkg.conf il contenuto sia questo:
dest root /
dest ram /tmp
lists_dir ext /var/opkg-lists
option overlay_root /overlay
src/gz chaos_calmer_base https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/base
src/gz chaos_calmer_packages https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/packages
src/gz chaos_calmer_luci https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/luci
src/gz chaos_calmer_routing https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/routing
src/gz chaos_calmer_telephony https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/telephony
src/gz chaos_calmer_management https://repository.ilpuntotecnico.com/files/roleo/public/agtef/brcm63xx-tch/packages/management
Poi prova a dare opkg update e vedi se aggiorna altrimenti prova a riavviare il modem e riprova.
Se il pacchetto di cui hai bisogno non è presente nel reposirory chiedi a roleo di aggiungerlo in questo[/code] thread.
@Lil-Koby @enrico2772 il firmware 1.1.0 non è ancora consigliato installarlo perché non è così stabile per ora inoltre il driver dsl non sembra portare particolari miglioramenti. Se volete provare provatelo pure e se qualcosa non va basta riflashare o da gui o via tftp un firmware vecchio
FTTC TIM 200/20
AGTEF - 1.1.1
