Nuovi fw DSL320T moddati (Acorp) e originali (Dlink)
  • 472 Risposte
  • 258494 Visite
Offline superalino
Re: Nuovi fw DSL320T moddati (Acorp) e originali (Dlink)
« Risposta #345 il: 21 Marzo 2007, 22:06 »
« Risposta #346 il: 22 Marzo 2007, 00:37 »
che ritmo pazzesco... appena ho un attimo...
Offline bovirus1963
  • 1072
« Risposta #347 il: 22 Marzo 2007, 07:06 »
Changelog
v.1.1.00.21032007(.PreRelease1)
- is added the new version DSP 7.02.03.00 Release2 for Annex A.
- small corrections in the scripts of the load of system.
- is added the possibility of the installation of the maximum value of ip_.conntrack_.tcp_.timeout_.established for several days through env, on silence of 20 minutes. For example, in you telnete: echo "tcp_.timeout_.established max" /.proch/tichfg/env after this it is necessary to overload modem.
v.1.1.00.11032007(.Beta2)
- is added command unix2dos.
- is added the possibility of turning off of the conclusion of information to the cantilever port. Parameter console_.port in env. For example: echo "console_.port off" /.proch/tichfg/env - is improved the work of dynamic behavior in sheypere, for this is introduced the new parameter of the installation of the general maximum value of speed (byte per second) max Bandwidth.
v.1.1.00.27022007(.Beta1)
- is removed IGMP Proxy as useless option, for the place it is added Bandwidth Manager(.Rshaper), which makes it possible to regulate the entering speed for each ip address or networks. This sheyper includes the following options: 1. ip address or the address of network. 2. mask. 3. speed in the bytes. 4. size of turn in seconds. 5. start of dynamic speed control between all clients, who are described in the rules. Priorities are advanced with the aid of the size of turn, the less this value, the higher the priority. Dynamic behavior makes it possible to increase speed to the maximum value of channel speed, but in this case uchtyvayetsya the quantity of the users of those sitting into the given moment on the channel, the values of uniform velocity and the size of turn, the higher the speed and the less the turn, the greater the occupied strip, which will constantly change from the maximum to the values of those established in the rules. If only one person is sit on the channel, then he will engage entire channel strip, in spite of values in the rules. If in the rules is not described ip or network, then sheyper on them does not act and they work in the usual regime. If it is necessary to establish rules for the entire local network, then this must be made at the very beginning, and then already prescribed rules for the the separate ip. So one should take into consideration that the work of dynamic behavior is not very precise. - for PPPoE is added the possibility of introduction Access Concentrator Name and Service Name.
v.1.0.18.12022007()
- are added command cpu, analog of command top. Is started as cpu -.a, for the more detailed information use cpu -.h. - is removed the leakage of memory with the survey of statistics IP Account.
- is added the function of renovation dproxy after pere/podklyucheniya on PPPoA.
- is established delay pppd_.conndelay on 40 seconds.
v.1.0.18.09012007()
- are renovated modules ip_.conntrack PPTP and GRE to the new versions. New versions remove the problem of the simultaneous work of entering and emanating GRE/PPTP from one and the same machine, and so, are corrected some errors.
v.1.0.17.01012007(.Release2)
- is made optimization for the work in P2P networks.
- is inculcated checking types CPU of those utilized in modems Acorp.
v.1.0.17.26122006(.Release)
- is found and corrected the error in Wizard, which appeared after the addition of option Enable Save SID into PPPoE.
Da notare "is inculcated checking types CPU " che è il problema per cui viene verificato il tipo di CPU del modem.
Offline superalino
« Risposta #348 il: 22 Marzo 2007, 08:29 »
Sto testando questo ultimo firmware con dsp 7.2 ma è difficile stabilire se vi sono benefici tangibili rispetto al 7.1. Da quando ho installato la Beta1 con dsp 7.1 avevo già risolto tutti i problemi di disconnessione.
Offline Teknuccio
  • 21
    • Myspace - Teknuccio
« Risposta #349 il: 26 Marzo 2007, 21:10 »
Non va più il LED della Ethernet ma poco importa, è una sciocchezza... per il resto è sempre stabile e prestante!!
Offline passodombra
  • 12
« Risposta #350 il: 26 Marzo 2007, 23:21 »
Il nuovo firm acorp con dsp 7.2 va meglio del 7.1...identico problema con i led status e ethernet,  apparentemente migliori prestazioni soprattutto in p2p...
Offline bovirus1963
  • 1072
« Risposta #351 il: 27 Marzo 2007, 06:57 »
Il problema dei led non potranno mai essere risolti se non modificando il file dei led inserito nel file del firmware. Il file originale è Readonly & Sistem e quindi non può essere modificato. Si può caricare temporaneamente un'altro file ma la procedura va ripetuta ogni volta che si accende il modem.
Offline Doerwood
« Risposta #352 il: 27 Marzo 2007, 17:30 »
Scusate non riesco a configurare il router in modo da far funzionare apache. Sto usando il wamp5 ultima versione disponibile (1.7.0), ho settato nell'httpd Listen 443 per ascoltare su una porta secondaria dato che se tento di connettermi alla 80 usando il mio ip pubblico mi appare la schermata di login del router stesso. Ora, tramite netstat, ho visto che la porta 443 è in stato listening, perfetto. Ho allowato connessioni in entrata sulla porta 443 (abilitando la regola predefinita "Web Server"), ma quando tento di connettermi alla porta 443 tramite ip pubblico mi dà impossibile trovare pagina. Al contrario provando sia con ip privato locale (localhost insomma) oppure con ip privato a livello di rete lan (192.*) la pagina viene visualizzata correttamente. Ne deduco essere un problema di filtraggio del router, come dovrei procedere? Grazie
ps: aggiungo che il firmware che ho messo è quello acorp sul sito di submax82
Offline passodombra
  • 12
« Risposta #353 il: 28 Marzo 2007, 17:33 »
@Doerwood
Non ho capito nulla di quello ke stai facendo (non sono al tuo livello) ma se accetti un consiglio...prova con il nuovo firm acorp:
http://mcmcc.bat.ru/dlinkt/acorp-russia/LAN120/Acorp_nsp_LAN120_V.1.1.00.RU.21032007_AnnexA_DSP72.zip
questo dovrebbe essere più performante di quello che hai scaricato dal sito di submax...ma ti avverto che non funzioneranno più i led dello status e della ethernet...per il resto va che è una bomba...magari cosi ti funziona tutto.
« Risposta #354 il: 28 Marzo 2007, 22:51 »
@Doerwood
appena ho tempo lo aggiorno all'ultima versione di mcmcc con led sistemati
Offline dia3olik
« Risposta #355 il: 29 Marzo 2007, 01:03 »
Grende submax,
saresti mitico!
telnettare tutte le volte per i led...
Offline dia3olik
« Risposta #356 il: 29 Marzo 2007, 01:30 »
Appena provato il DSP72 di oggi a mezzanotte (29.03.2007)!!!!
fresco fresco!
Va 'na bombaaaaaa!
(almeno qui con tiscali 12)
Ping "a vuoto" son scesi circa da 32 a 28-29!!!
Non male!!!
Vi saprò dire se avrò tempo libero per fare delle prove...
'notte a tutti!
Offline belgico
  • 40
« Risposta #357 il: 29 Marzo 2007, 01:56 »
Ciao submax, visto che dai un'occhiata al nuovo firm con DSP 7.2, perchè non cerchi di capire come mai a me e credo anche ad altri, che abbiamo connessioni con modulazioni in adsl 2+, qualsiasi firm McMcc o Acorp/jack si allineano in adsl 2+ solo con DSP 6.0 o 6.2, dalla 7.0 in poi vede la portante ma non riesce ad allinearsi se non in G.dmt con velocità dimezzate.
Grazie al vostro lavoro sono riuscito ad ottenere ottimi risultati con il vecchio 300T e speravo di migliorare ancora la stabiltà della mia disastrata portante con il 320T, ovviamente giro questo appello anche a jack.
Offline dia3olik
« Risposta #358 il: 29 Marzo 2007, 03:36 »
Ciao belgico,
a me in multimode va a meraviglia a 12 e con dei valori ottimi!
adsl2+ rilevato...
PS Ma voi nel port forwarding cosa mettete per forwardare le porte?????
Io ho seguito il manuale alla lettera ma non funge!!!
Sempre id basso!
Source -> 0.0.0.0
Source netmask 255.255.255.255
Dest ip -> 192.168.x.x (privacy ;-)
Dest netmask -> 255.255.255.255
Start, dest e mapped port ad es 4662
(le ho messe in tcp e udp e sia la 4662 che la 4672 che 4665 ma nada!!!!)
Voi come mettete?
Nel manuale dice che si possono usare le wildcards,
ma meglio *.*.*.* o semplicemente * ????
Ringrazio il santo che m'illuminerà la strada!
Basta ca**ate...nanna!
Offline bovirus1963
  • 1072
« Risposta #359 il: 29 Marzo 2007, 07:00 »
Changelog
1.1.00.29032007(.PreRelease2) - is added IGMP Snooping
Per le versioni precedenti vedere post changelog precedente.
