help: Alice dial face (AGIB) non funzionante
  • 3933 Visite
Offline axilot
« il: 06 Febbraio 2012, 13:20 »
ciao a tutti
Ho per le mani un alice dialface AGIB che non vā , pare avviarsi ma poi le spie diventano tutte rosse e poi si spengono.
Non riesco a colelgarmi via browser allora ho seguito questo thread https://www.ilpuntotecnico.com/forum/index.php/topic,9480.0.html e mi sono collegato col jtag tramite putty.
In pratica il router sembra riavviarsi di continuo
questo č il log di putty
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.02.04 14:45:36 =~=~=~=~=~=~=~=~=~=~=~=
Version 1.0.1
Read EEPROM
Jump to Flash
Version 1.0.1
Read EEPROM
Jump to Flash
Head : Amazon Version 1.0.0
DRAM:  16 MB
 Head : relocate_code start
Head: relocate code finish.
   Image Name:   u-boot image
   Image Type:   MIPS Linux Firmware (lzma compressed)
   Data Size:    40668 Bytes = 39.7 kB
   Load Address: 80100000
   Entry Point:  80100000
Disabling all the interrupts
   Uncompressing UBoot Image ...
   Uncompression completed successfully with destLen 124144.
 Head: Jumping to u-boot in the ram at 0x80100000
Infineon Amazon
U-Boot 2.0.16-16 (Mar 30 2007 - 09:11:18)
In env_init : env_ptr = 0xb37c0000
For enviornment CRC32 is OK
Board: AMAZON Yangtse Version, Chip V1.3, CPU Speed 235 MHz
IDF LED fix ... done
DRAM:  16 MB
USB support: 48Mhz clock enabled
 relocate_code start
Entering flash_init()
detected SPANSION S29GL064A
IDF-FLASH fix...done
Flash:  8 MB
env_relocate[228] malloced ENV at 80aa0008
Initialize devices...
In:    serial
Out:   serial
Err:   serial
Net:   AMAZON Switch
Type "run flash_nfs" to mount root filesystem over NFS
Press enter key to stop autoboot:  2  1  0
getting active image...
active image seems to be 0
## Booting image at b3020094 ...
   Image Name:   openrg_AGIB_1.2.1
   Created:      2008-03-26  17:48:43 UTC
   Image Type:   MIPS Linux Kernel Image (lzma compressed)
   Data Size:    2626643 Bytes =  2.5 MB
   Load Address: 80002000
   Entry Point:  80003d50
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... Uncompression time : 1074557/117500000
Uncompression length is 4083712
OK
Starting kernel ...
Yangtse Version
Dopodichč riparte da zero indefinitamente.
Ho provato anche a resettarlo inviando il comando
erase B3760000 B379FFFF
ma riparte sempre di continuo.
E' recuperabile o lo butto via?
« Ultima modifica: 06 Febbraio 2012, 13:22 da axilot »
Offline axilot
Re:help: Alice dial face (AGIB) non funzionante
« Risposta #1 il: 07 Febbraio 2012, 13:59 »
Mal'ultimo firmware AGIB_1.2.1_2563-t.rmt   che trovo qui  https://repository.ilpuntotecnico.com/files/jackthevendicator/official/agib/  posso caricarlo per vedere se riparte?
Ho capito che devo mettere il firmware su sun server tftp ma poi che comandi devo dare?
« Ultima modifica: 07 Febbraio 2012, 14:25 da axilot »
Offline toretto_5
  • 1226
« Risposta #2 il: 08 Febbraio 2012, 13:54 »
usa il comando da riga telnet FLASHIMAGE e poi vedi le opzioni
Offline axilot
« Risposta #3 il: 08 Febbraio 2012, 14:29 »
Grazie mille!
Stasera ci provo.
