DGA4132 & Gui Ansuel apertura porte verso il Router
  • 17 Risposte
  • 8791 Visite
Offline kirckc
  • 90
« il: 08 Aprile 2020, 20:23 »
mi sapete dire come si aprono le porte esterne verso il router ?
vorrei aprire la 4569 IAX2 ma , ovviamente, la gui non permette di aprirle verso se stesso.
@Ansuel @FrancYescO
Online FrancYescO
  • 3408
Re:DGA4132 & Gui Ansuel apertura porte verso il Router
« Risposta #1 il: 09 Aprile 2020, 00:50 »
uci add firewall redirect
uci set firewall.@redirect[-1]=redirect
uci set firewall.@redirect[-1].src_dport='8081'
uci set firewall.@redirect[-1].dest_port='443'
uci set firewall.@redirect[-1].dest='lan'
uci set firewall.@redirect[-1].proto='tcp'
uci set firewall.@redirect[-1].src='wan'
« Ultima modifica: 09 Aprile 2020, 21:33 da FrancYescO »
Offline kirckc
  • 90
« Risposta #2 il: 09 Aprile 2020, 18:02 »
@FrancYescO
sul primo comando gia' mi da'
uci add firewall.redirect
root@modemtim:/etc/config# uci add firewall.redirect
Usage: uci [<options>] <command> [<arguments>]
Commands:
   batch
   export     [<config>]
   import     [<config>]
   changes    [<config>]
   commit     [<config>]
   add        <config> <section-type>
   add_list   <config>.<section>.<option>=<string>
   del_list   <config>.<section>.<option>=<string>
   show       [<config>[.<section>[.<option>]]]
   get        <config>.<section>[.<option>]
   set        <config>.<section>[.<option>]=<value>
   delete     <config>[.<section>[[.<option>][=<id>]]]
   rename     <config>.<section>[.<option>]=<name>
   revert     <config>[.<section>[.<option>]]
   reorder    <config>.<section>=<position>
Options:
   -c <path>  set the search path for config files (default: /etc/config)
   -d <str>   set the delimiter for list values in uci show
   -f <file>  use <file> as input instead of stdin
   -m         when importing, merge data into an existing package
   -n         name unnamed sections on export (default)
   -N         don't name unnamed sections
   -p <path>  add a search path for config change files
   -P <path>  add a search path for config change files and use as default
   -q         quiet mode (don't print error messages)
   -s         force strict mode (stop on parser errors, default)
   -S         disable strict mode
   -X         do not use extended syntax on 'show'
al posto di 8081 metto la porta interna , 4569 ??
al posto di 443 metto la porta esterna 4569 o una a piacere  ??
la destinazione 192.168.1.1 o 127.0.0.1 me la da quel ...
qui cambio da tcp a udp ?
per farlo funzionare che comando do ?
devo riavviare il router o va in funzione da solo ?
« Ultima modifica: 09 Aprile 2020, 18:04 da kirckc »
Online FrancYescO
  • 3408
« Risposta #3 il: 09 Aprile 2020, 21:34 »
modificato il messaggio di sopra uno spazio al posto del punto nel primo comando
8081 la porta esterna 443 la porta sul timhub
l'altro se ti serve udp lo cambi...
Offline kirckc
  • 90
« Risposta #4 il: 09 Aprile 2020, 22:45 »
uci set firewall.@redirect[-1].src_dport='4569'
uci set firewall.@redirect[-1].dest_port='4569'
uci set firewall.@redirect[-1].proto='udp'
niente , porta sempre chiusa , ho anche riavviato il router.
Offline kirckc
  • 90
« Risposta #5 il: 10 Aprile 2020, 12:04 »
@FrancYescO
su che file scrive ??
per vedere se ha fatto qualcosa.
Online FrancYescO
  • 3408
« Risposta #6 il: 10 Aprile 2020, 15:24 »
/etc/config/firewall
dopo i comandi dai uci commit
« Risposta #7 il: 10 Aprile 2020, 21:05 »
Ma asterisk ce l'hai sul router o su un PC in lan?
Ad intuito mi sa che state andando dalla parte sbagliata, non vi serve un redirect.
Ti metto quella che uso io per Transmission, devi solo cambiare nome, porte e protocolli.
config rule 'Allow_Transmission_TCP'
        option name 'Allow-Transmission-TCP'
        option src 'wan'
        option proto 'tcp'
        option dest_port '12345'
        option target 'ACCEPT'
        option family 'ipv4'
        option enabled '1'
Offline kirckc
  • 90
« Risposta #8 il: 10 Aprile 2020, 23:52 »
dopo uci command , trovo finalmente la modifica in /etc/config/firewall, ma .... la porta risulta sempre chiusa , irragiungibile.
Online FrancYescO
  • 3408
« Risposta #9 il: 11 Aprile 2020, 01:29 »
hai fatto anche un restart di firewall?
prova con quella di luke, anche se son sicuro quella che ti ho postato funziona... ci redireziono il suo webserver ssl su wan
« Risposta #10 il: 11 Aprile 2020, 02:11 »
Si ma il webserver di default è già aperto su LAN, perciò ti funziona.
Offline kirckc
  • 90
« Risposta #11 il: 11 Aprile 2020, 02:36 »
Perfetto, questo va benissimo allo scopo.
Asterisk e' sul Router
config rule 'Allow_Asterisk_UDP'
        option name 'Allow-Asterisk-UDP'
        option src 'wan'
        option proto 'udp'
        option dest_port '4569'
        option enabled '1'
buona sera, premesso che ho cambiato la linea da vdsl a ftth , ora utilizzo la porta wan collegato all'ONT. per aprire le porte interne del router , la porta in entrata rimane sempre :
option src 'wan'
oppure si chiama in qualche altra maniera , visto che adesso l'ingresso non e' piu' il doppino della vdsl ma la porta ethernet.
ovviamente ho gia' provato a lasciare 'wan' ma risulta chiusa.
« Ultima modifica: 24 Giugno 2020, 20:28 da kirckc »
Offline kirckc
  • 90
« Risposta #12 il: 25 Giugno 2020, 09:37 »
nessuna idea ?
@FrancYescO @LuKePicci
« Risposta #13 il: 25 Giugno 2020, 10:16 »
 Sempre wan, quello che è cambiato è l'ifname di wan nel file network
Offline kirckc
  • 90
« Risposta #14 il: 25 Giugno 2020, 10:19 »
e perche' adesso asterisk (che gira dentro il router) non e' piu' raggiungibile ?
da aprile ad oggi con la vdsl e' stato impeccabile
