  • 6078709 Visite
Offline kirckc
  • 90
« Risposta #7020 il: 18 Marzo 2018, 22:13 »
@Ansuel
2 parte
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_WANSensing.': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.DeviceInfo.NetworkProperties.X_000E50_WANSensing.': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.DeviceInfo.NetworkProperties.X_000E50_WANSensing.Enable': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.DeviceInfo.NetworkProperties.X_000E50_WANSensing.L3Type': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.DeviceInfo.NetworkProperties.X_000E50_WANSensing.L2Type': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.DeviceInfo.NetworkProperties.X_000E50_WANSensing.InitMode': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_WiFiDoctorAgent.': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.Enabled': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.URL': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.ReportingPeriod': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.ActiveRadio': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.AuthPasswd': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.BufferSize': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_WiFiDoctorAgent.Radio.{i}.': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.Radio.{i}.': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.Radio.{i}.Name': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_WiFiDoctorAgent.Radio.{i}.ACSAllowedChannels': no description
Fri Feb 16 18:56:46 2018 daemon.err transformer: [/etc/smartcontrol/enable] open failed: /etc/smartcontrol/enable: No such file or directory
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_SmartControl.': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_SmartControl.': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_SmartControl.Enable': no description
Fri Feb 16 18:56:46 2018 daemon.warn transformer: 'Device.X_000E50_SmartControl.Status': no description
Fri Feb 16 18:56:46 2018 daemon.err transformer: /usr/share/transformer/mappings/clash/Command.Ip.map ignored (/usr/lib/lua/transformer/mapper/command.lua:54: assertion failed!)
Fri Feb 16 18:56:48 2018 user.notice pppoe-relay-hotplug: Interface wlnet_b_24 ifup
Fri Feb 16 18:56:49 2018 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Fri Feb 16 18:56:49 2018 daemon.notice wansensing: WAN Sensing Mobile: 1
Fri Feb 16 18:56:49 2018 kern.warn kernel: [   73.961000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76
Fri Feb 16 18:56:49 2018 kern.warn kernel: [   73.986000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76
Fri Feb 16 18:56:49 2018 kern.warn kernel: [   74.013000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76
Fri Feb 16 18:56:49 2018 kern.warn kernel: [   74.032000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76
Fri Feb 16 18:56:49 2018 kern.warn kernel: [   74.047000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76
Fri Feb 16 18:56:49 2018 user.notice mobiled: Starting Mobiled
Fri Feb 16 18:56:49 2018 daemon.info mobiled[4255]: [mobiled] Adding statemachine 1
Fri Feb 16 18:56:50 2018 daemon.warn transformer: 'Device.DeviceInfo.NetworkProperties.X_000E50_WanSyncStatus': no description
Fri Feb 16 18:56:50 2018 daemon.warn transformer: 'Device.DeviceInfo.NetworkProperties.X_BELGACOM_WanSyncStatus': no description
Fri Feb 16 18:56:50 2018 daemon.warn transformer: 'Device.DeviceInfo.X_000E50_SoftwareBank.{i}.': no description
Fri Feb 16 18:56:50 2018 daemon.warn transformer: 'Device.DeviceInfo.X_000E50_SoftwareBank.{i}.SoftwareVersion': no description
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.857000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.863000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.870000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.876000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.882000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.889000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.895000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.901000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.911000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 kern.warn kernel: [   74.917000] netlink: 20 bytes leftover after parsing attributes.
Fri Feb 16 18:56:50 2018 user.notice cwmpd: Starting cwmpd on boot
Fri Feb 16 18:56:50 2018 user.notice cwmpd: Calling cwmpd-boot-delay script.
Fri Feb 16 18:56:50 2018 user.notice igmpproxy: Starting igmpproxy
Fri Feb 16 18:56:50 2018 daemon.notice mobiled[4255]: [mobiled] (PlatformConfigure) runs PlatformConfigure-Main.check(timeout, 1)
Fri Feb 16 18:56:50 2018 user.notice cwmpd:  Voice not up yet ... delaying startup
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Intf br-lan becomes downstream
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Registered 'UCI' plugin (/usr/lib/igmpproxy/libuciubusplugin.so)
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Address 127.0.0.1/255.0.0.0 created on intf lo
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Address 192.168.168.1/255.255.255.128 created on intf wl0_1
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Address 192.168.1.1/255.255.255.0 created on intf br-lan
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Add intf br-lan as MRT virtual interface 0
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Add membership 224.0.0.2 on intf br-lan
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Add membership 224.0.0.22 on intf br-lan
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Send IGMP packet to group 224.0.0.1 on intf br-lan
Fri Feb 16 18:56:51 2018 daemon.notice igmpproxy[4332]: Address 192.168.168.129/255.255.255.128 created on intf wl1_1
Fri Feb 16 18:56:51 2018 daemon.notice mobiled[4255]: [mobiled] (WaitingForDevice) runs WaitingForDevice-Main.check(timeout, 1)
Fri Feb 16 18:56:51 2018 user.notice firewall: Reloading firewall due to ifupdate of lan (br-lan)
Fri Feb 16 18:56:51 2018 daemon.warn transformer: 'Device.IP.Interface.{i}.X_BELGACOM_PreferredGlobalIPv6Addr': no description
Fri Feb 16 18:56:51 2018 user.notice mldproxy: Starting mldproxy
Fri Feb 16 18:56:51 2018 user.notice wol: Starting WOL
Fri Feb 16 18:56:52 2018 daemon.warn transformer: 'Device.PPP.Interface.{i}.X_BELGACOM_LCPRetryAttempts': no description
Fri Feb 16 18:56:52 2018 daemon.info odhcpd[3093]: Using a RA lifetime of 0 seconds on wl1_1
Fri Feb 16 18:56:52 2018 daemon.notice odhcpd[3093]: Failed to send to ff02::1%wl1_1 (Operation not permitted)
Fri Feb 16 18:56:52 2018 daemon.info odhcpd[3093]: Using a RA lifetime of 0 seconds on wl0_1
Fri Feb 16 18:56:52 2018 daemon.notice odhcpd[3093]: Failed to send to ff02::1%wl0_1 (Operation not permitted)
Fri Feb 16 18:56:52 2018 daemon.warn transformer: 'Device.PPP.Interface.{i}.X_BELGACOM_LCPRetryIntervalMax': no description
Fri Feb 16 18:56:52 2018 daemon.info odhcpd[3093]: Using a RA lifetime of 0 seconds on br-lan
Fri Feb 16 18:56:52 2018 daemon.notice odhcpd[3093]: Failed to send to ff02::1%br-lan (Operation not permitted)
Fri Feb 16 18:56:52 2018 daemon.warn transformer: 'Device.PPP.Interface.{i}.X_BELGACOM_LCPRetryInterval': no description
Fri Feb 16 18:56:52 2018 kern.warn kernel: [   77.072000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76 MARK=0x8000
Fri Feb 16 18:56:52 2018 kern.warn kernel: [   77.088000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76 MARK=0x8000
Fri Feb 16 18:56:52 2018 kern.warn kernel: [   77.104000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76 MARK=0x8000
Fri Feb 16 18:56:52 2018 kern.warn kernel: [   77.129000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76 MARK=0x8000
Fri Feb 16 18:56:52 2018 kern.warn kernel: [   77.146000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76 MARK=0x8000
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_HotspotService.WlanGW.{i}.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.Status': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.VLANID': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.CheckPrivateWifi': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.GRETunnel': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.Enable': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.AllowEthWanMode': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.SSIDReference': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.WlanGW.{i}.CheckPrivateWifiEncryption': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_HotspotService.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_000E50_HotspotService.Enable': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_TV.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_HotspotService.GUI.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_HotspotService.GUI.User.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_HotspotService.GUI.Expert.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_HotspotService.GUI.Admin.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_MPTCP.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_MPTCP.GUI.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_MPTCP.GUI.User.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_MPTCP.GUI.Expert.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_MPTCP.GUI.Admin.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.PM.Overflow.Dynamic.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.PM.Overflow.Static.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.PM.Overflow.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.PM.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.Policy.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.Scheduler.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.Stats.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.Stats.Server.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_TESSARES_MPTCP.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_WANBackup.GUI.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_WANBackup.GUI.User.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_WANBackup.GUI.Expert.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_WANBackup.GUI.Admin.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.Services.X_BELGACOM_WANBackup.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.X_000E50_ACL.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.X_000E50_ACL.Mode': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.X_BELGACOM_ACL.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.X_000E50_ACL.MACAddresses.{i}.': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.X_000E50_ACL.MACAddresses.{i}.MACAddress': no description
Fri Feb 16 18:56:53 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.X_BELGACOM_ACL.MACAddresses.{i}.': no description
Fri Feb 16 18:56:54 2018 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Fri Feb 16 18:56:54 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.WPS.X_000E50_PairingProtection.': no description
Fri Feb 16 18:56:54 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.WPS.X_000E50_PairingProtection.Mode': no description
Fri Feb 16 18:56:54 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.WPS.X_000E50_PairingProtection.AcceptList': no description
Fri Feb 16 18:56:54 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.WPS.X_000E50_PairingProtection.DenyList': no description
Fri Feb 16 18:56:54 2018 user.notice lte-doctor: Starting LTE Doctor
Fri Feb 16 18:56:54 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.WPS.X_000E50_Trigger': no description
Fri Feb 16 18:56:54 2018 daemon.debug urlfilterd[4607]: parsing configuration
Fri Feb 16 18:56:54 2018 daemon.debug urlfilterd[4607]: config_set_general
Fri Feb 16 18:56:54 2018 daemon.info urlfilterd[4607]: nfq_init done
Fri Feb 16 18:56:54 2018 daemon.debug urlfilterd[4607]: nfq_thread entering main loop
Fri Feb 16 18:56:54 2018 daemon.warn transformer: 'Device.WiFi.AccessPoint.{i}.X_000E50_BandSteerEnabled': no description
Fri Feb 16 18:56:55 2018 daemon.notice wansensing: WAN Sensing Mobile: 1
Fri Feb 16 18:56:55 2018 user.notice upnp daemon: external interface(s) not found, not starting
Fri Feb 16 18:56:55 2018 user.notice pppoe-relay-hotplug: Interface lan ifupdate
Fri Feb 16 18:56:55 2018 daemon.err transformer: /usr/share/transformer/mappings/device2/X_000E50_ngwfdd.map ignored (/usr/lib/lua/transformer/typestore.lua:88: 'Device.Services.X_000E50_ngwfdd.' is already registered!)
Fri Feb 16 18:56:55 2018 daemon.err transformer: /usr/share/transformer/mappings/device2/Cellular.AccessPoint.map ignored (/usr/lib/lua/transformer/typestore.lua:88: 'Device.Cellular.AccessPoint.{i}.' is already registered!)
Fri Feb 16 18:56:56 2018 daemon.info transformer: [gre-hotspotd] Daemon started
Fri Feb 16 18:56:56 2018 user.notice cwmpd:  Voice not up yet ... delaying startup
Fri Feb 16 18:56:56 2018 daemon.warn transformer: 'InternetGatewayDevice.LANDevice.{i}.WLANConfiguration.{i}.X_000E50_RadiusServer.{i}.': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSState': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_RemotelyManaged': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_PacketsDropped': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSRescanDelay': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_UpgradeURL': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSRescan': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSRescanDelayMaxEvents': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSMode': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ShortGuardInterval': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSBssList': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_UpgradeCheckPeriod': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_UpgradeSWVersion': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSScanHistory': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ChannelBandwidth': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_BandSteerEnable': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_PacketsErrored': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_PowerList': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_Power': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_PowerDefault': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSRescanDelayPolicy': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_CyclicDelayDiversity': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_SpaceTimeBlockCoding': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ChannelWidth': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSRescanPeriod': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ChannelMode': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSCHFailLockoutPeriod': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSCHMonitorPeriod': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: '#ROOT.WLANConfiguration.{i}.X_000E50_ACSScanReport': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: 'InternetGatewayDevice.LANDevice.{i}.WLANConfiguration.{i}.AssociatedDevice.{i}.X_Stats.': no description
Fri Feb 16 18:56:57 2018 daemon.warn transformer: 'InternetGatewayDevice.LANDevice.{i}.X_0876FF_ALG.{i}.': no description
Fri Feb 16 18:56:57 2018 user.notice fseventd: start fseventd.
Fri Feb 16 18:56:58 2018 daemon.warn transformer: 'InternetGatewayDevice.WANDevice.{i}.WANConnectionDevice.{i}.X_0876FF_WANIPv6Connection.{i}.': no description
Fri Feb 16 18:56:58 2018 daemon.warn transformer: 'InternetGatewayDevice.WANDevice.{i}.WANConnectionDevice.{i}.X_0876FF_WANIPv6Connection.{i}.Stats.': no description
Fri Feb 16 18:56:58 2018 user.notice fseventd: fseventd is started.
Fri Feb 16 18:56:58 2018 user.notice mvfsd: start mvfsd.
Fri Feb 16 18:57:00 2018 cron.info crond[3116]: USER root pid 5021 cmd /sbin/trafficdata.lua
Fri Feb 16 18:57:00 2018 user.err syslog: metadb_init (Heap)
Fri Feb 16 18:57:00 2018 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Fri Feb 16 18:57:00 2018 daemon.notice wansensing: WAN Sensing Mobile: 1
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_Cellular.SIMPIN.': no description
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_Connection.': no description
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_Connection.Stats.': no description
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_Connection.Stats.Protocol.': no description
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_Connection.Stats.TCP.': no description
Fri Feb 16 18:57:00 2018 user.notice mud: mud start.
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.X_0876FF_NUD.': no description
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_NUD.': no description
Fri Feb 16 18:57:00 2018 daemon.notice transformer: [timeofday] no action configured
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.Services.X_000E50_ngwfdd.': no description
Fri Feb 16 18:57:00 2018 daemon.warn transformer: 'InternetGatewayDevice.X_000E50_Cellular.AccessPoint.{i}.': no description
Fri Feb 16 18:57:01 2018 user.err [mud][5048]: mud_monitor_mounted_usb (1494): in mud_monitor_mounted_usb
Fri Feb 16 18:57:01 2018 user.notice dlnad: Starting dlnad
Fri Feb 16 18:57:01 2018 daemon.notice procd: /etc/rc.d/S98mmpbxbrcmdect: mknod: /dev/dectshim: File exists
Fri Feb 16 18:57:01 2018 user.notice dlnad: Renaming unknown_HGSTHTS_545050A7E680_1_f7ae to unknown_<share_name>
Fri Feb 16 18:57:01 2018 user.notice cwmpd:  Voice not up yet ... delaying startup
Fri Feb 16 18:57:02 2018 user.notice ipks: Installing prebuilt ipks:
Fri Feb 16 18:57:02 2018 user.notice ipks: Done installing prebuild ipks
Fri Feb 16 18:57:02 2018 user.err syslog: ILibGetLocalIPAddressList :292>No matching interface
Fri Feb 16 18:57:02 2018 user.crit mountd[5151]: Starting OpenWrt (auto)mountd V1
Fri Feb 16 18:57:02 2018 user.crit mountd[5151]: trying to mount /tmp/run/mountd/ as the autofs root
Fri Feb 16 18:57:03 2018 daemon.err rmmod: module is not loaded
Fri Feb 16 18:57:03 2018 kern.warn kernel: [   87.682000] sfpPhy_probe:Entering the functio,client->addr=0x50
Fri Feb 16 18:57:03 2018 kern.warn kernel: [   87.693000] sfpPhy_probe:Entering the functio,client->addr=0x51
Fri Feb 16 18:57:03 2018 user.info root: Mmpbx stopping, mmpbx.state=STOPPING
Fri Feb 16 18:57:03 2018 lpr.info cupsd[3182]: Generating printcap /etc/printcap...
Fri Feb 16 18:57:03 2018 daemon.notice procd: /etc/rc.d/S99sfpmon: cat: read error: Operation not permitted
Fri Feb 16 18:57:03 2018 user.info root: Mmpbx service_stop voice=NA@init_stop
Fri Feb 16 18:57:03 2018 user.info root: Mmpbx service_stop done
Fri Feb 16 18:57:03 2018 daemon.debug ledfw[1425]: applying action on voip:green
Fri Feb 16 18:57:03 2018 daemon.debug ledfw[1425]: writing to /sys/class/leds/voip:green with action none
Fri Feb 16 18:57:03 2018 daemon.debug ledfw[1425]: setting brightness to 0
Fri Feb 16 18:57:03 2018 user.info root: Mmpbx stopped, mmpbx.state=NAstopped
Fri Feb 16 18:57:04 2018 user.info root: Mmpbx starting mmpbx.state=STARTING
Fri Feb 16 18:57:05 2018 kern.warn kernel: [   89.888000] Endpoint: endpoint_init entry
Fri Feb 16 18:57:05 2018 kern.warn kernel: [   89.892000] Endpoint: endpoint_init COMPLETED
Fri Feb 16 18:57:05 2018 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Fri Feb 16 18:57:05 2018 user.crit mountd[5151]: new mount : USB-A1 -> sda1 (ext4)
Fri Feb 16 18:57:05 2018 kern.warn kernel: [   90.033000] mmConnKrnlBrcm: INIT: num_rtpsock_ctx = 42
Fri Feb 16 18:57:05 2018 kern.warn kernel: [   90.038000] mmConnKrnlBrcm: INIT: COMPLETED
Fri Feb 16 18:57:05 2018 user.crit mountd[5151]: mounting /tmp/run/mountd/sda1
Fri Feb 16 18:57:05 2018 kern.warn kernel: [   90.181000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=200 MARK=0x8000
Fri Feb 16 18:57:05 2018 user.crit mountd[5336]: mount -t ext4 -o errors=continue /dev/sda1 /tmp/run/mountd/sda1
Fri Feb 16 18:57:05 2018 daemon.err transformer: Set failed on network.config.nil = config: lua-uci: Invalid argument
Fri Feb 16 18:57:05 2018 kern.info kernel: [   90.449000] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: errors=continue
Fri Feb 16 18:57:05 2018 user.crit mountd[5151]: ----------> mount ret = 0
Fri Feb 16 18:57:06 2018 user.notice hotplug.d-mount-mounts: ACTION=add DEVICE=sda1 NAME=USB-A1
Fri Feb 16 18:57:06 2018 user.notice hotplug.d-mount-mounts: VENDOR=HGSTHTS MODEL=545050A7E680 START=2048 SIZE=976771072 HASH=f7ae STATUS=mounted
Fri Feb 16 18:57:06 2018 user.notice hotplug.d-mount-mounts: Add mount sda1 (/tmp/run/mountd/sda1)
Fri Feb 16 18:57:06 2018 daemon.notice wansensing: WAN Sensing Mobile: 1
Fri Feb 16 18:57:06 2018 user.notice hotplug.d-mount-mounts: Added disk sda
Fri Feb 16 18:57:06 2018 user.notice hotplug.d-mount-samba: ACTION=add DEVICE=sda1 NAME=USB-A1
Fri Feb 16 18:57:06 2018 user.notice cwmpd:  Voice not up yet ... delaying startup
Fri Feb 16 18:57:06 2018 user.notice hotplug.d-mount-samba: VENDOR=HGSTHTS MODEL=545050A7E680 START=2048 SIZE=976771072 HASH=f7ae
Fri Feb 16 18:57:07 2018 user.notice hotplug.d-mount-samba: Add share HGSTHTS_545050A7E680_1_f7ae (/var/etc/smb.auto/USB-A1.conf)
Fri Feb 16 18:57:07 2018 user.notice hotplug.d-mount-samba: Added disk sda ... reload
Fri Feb 16 18:57:07 2018 kern.warn kernel: [   92.202000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=200 MARK=0x8000
Fri Feb 16 18:57:07 2018 user.notice transmission: Starting with 290577600 virt mem
Fri Feb 16 18:57:07 2018 daemon.info procd: - init complete -
Fri Feb 16 18:57:08 2018 kern.notice kernel: [   92.605000] jffs2: notice: (5838) check_node_data: wrong data CRC in data node at 0x00482598: read 0x7878ddeb, calculated 0x5231e0b.
Fri Feb 16 18:57:08 2018 user.info root: the 2 values of max contact do not exist!
Fri Feb 16 18:57:09 2018 kern.warn kernel: [   94.223000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=200 MARK=0x8000
Fri Feb 16 18:57:10 2018 user.debug mmpbxd[5880]: [MEMM] Info: Pooldescr [memm_pooldesc] reallocated to increase its size (107 elements)
Fri Feb 16 18:57:10 2018 user.debug mmpbxd[5880]: [MMAPP]         :E: mmAppSetPriority:1816 - Configured priority value 0 or negative, priority not modified for mmapp
Fri Feb 16 18:57:10 2018 user.debug mmpbxd[5880]: [MMAPP]         :E: mmAppSetRefMediaFileGenPriority:1879 - Configured priority value 0 or negative, priority not modified for refmediafilegen
Fri Feb 16 18:57:10 2018 user.debug mmpbxd[5880]: [MMAPP]         :E: mmAppSetUbusPriority:1851 - Configured priority value 0 or negative, priority not modified for mmubus
Fri Feb 16 18:57:10 2018 user.debug mmpbxd[5880]: [MMUCI]         :E: mmUciCommonAllocateContext:248 - Error loading the UCI config from file for mmpbxbrcmsi3226x: UCI_ERR_NOTFOUND
Fri Feb 16 18:57:10 2018 user.debug mmpbxd[5880]: [MMUCI]         :E: mmUciCommonAllocateContext:248 - Error loading the UCI config from file for mmpbxbrcmsi3217x: UCI_ERR_NOTFOUND
Fri Feb 16 18:57:10 2018 kern.info kernel: [   94.949000] endptInitThreadFunc: Thread voice_EPINIT awakened, task:INIT
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   94.959000] BOS: Enter bosInit
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   94.962000] BOS: Exit bosInit
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   94.968000] bosTaskCreate: Task Name: aoRT Binding 0xd4d500e0
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.018000] ******* DSP: Found BCM63138 *******
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.022000] ******* DSP: In PCM Mode *******
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.027000] ******* DSP: PCM running in 16 bit mode *******
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.032000] gInterruptCounter     = 0xBFB57460
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.037000] gInterruptErrors      = 0xBFB57464
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.042000] halShimEntryCount     = 0x00000002
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.046000] gDectTestMode           = 0xbfb575ac
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.051000] dectBuffStart           = 0xbfb57594
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.056000] gDectRxOutOfSyncCounter = 0xbfb575b0
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.061000] gDectTxOutOfSyncCounter = 0xbfb575b4
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.065000] ddrAddrTxV              = 0xbfb57538
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.070000] ddrAddrRxV              = 0xbfb5753c
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.076000] 32 ms ECAN tail-length
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.079000] *** dmaCtl[0].rx[0].descVirt = 0xFFDE7000
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.084000] *** dmaCtl[0].rx[1].descVirt = 0xFFDE7008
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.089000] *** dmaCtl[0].tx[0].descVirt = 0xFFDE77D0
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.094000] *** dmaCtl[0].tx[1].descVirt = 0xFFDE77D8
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.099000] *** buffer size: 640
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.103000] *** Ownership for TX desc 1 not set. Use this buffer.
Fri Feb 16 18:57:10 2018 kern.warn kernel: [   95.110000] bosTaskCreate: Task Name: HTSK Binding 0xd4d64080
Fri Feb 16 18:57:11 2018 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Fri Feb 16 18:57:11 2018 daemon.notice wansensing: WAN Sensing Mobile: 1
Fri Feb 16 18:57:11 2018 kern.warn kernel: [   96.227000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=200 MARK=0x8000
Fri Feb 16 18:57:11 2018 user.notice cwmpd:  Voice not up yet ... delaying startup
Fri Feb 16 18:57:12 2018 kern.warn kernel: [   97.019000] boardHalInit completed
Fri Feb 16 18:57:12 2018 kern.warn kernel: [   97.022000] bosTaskCreate: Task Name: HRTBEAT Binding 0xd4d9d6a0
Fri Feb 16 18:57:12 2018 kern.warn kernel: [   97.029000] bosTaskCreate: Task Name: VRGDISP Binding 0xd327f0a0
Fri Feb 16 18:57:12 2018 kern.warn kernel: [   97.036000] bosTaskCreate: Task Name: HCAS Binding 0xd4fc56e0
Fri Feb 16 18:57:12 2018 kern.warn kernel: [   97.043000] DSP: Interrupt Ids
Fri Feb 16 18:57:12 2018 kern.warn kernel: [   97.046000] ---------------
Fri Feb 16 18:57:12 2018 kern.warn kernel: [   97.049000] InterruptId      = 148
Fri Feb 16 18:57:12 2018 user.notice postmortem: core dumped to /root/transmission-da.5838.11.1518803830.core.gz
Fri Feb 16 18:57:13 2018 kern.warn kernel: [   97.697000] EndpointInit completed
Fri Feb 16 18:57:13 2018 kern.warn kernel: [   97.700000] dgasp: kerSysRegisterDyingGaspHandler: endpoint registered
Fri Feb 16 18:57:13 2018 user.debug mmpbxd[5880]: [REFMEDIAFILEGENIMPL]:E: refMediaFileGenImplInit:225 - Configured priority value 0 or negative, priority not modifiedfor mmpbxrefmediafilegen
Fri Feb 16 18:57:13 2018 kern.warn kernel: [   98.247000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=220 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=200 MARK=0x8000
Fri Feb 16 18:57:13 2018 kern.warn kernel: [   98.264000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76 MARK=0x8000
Fri Feb 16 18:57:14 2018 user.debug mmpbxd[5880]: [MMRVSIPIMPL]   :E: mmNetImplRvSipSetMtfPriority:145 - Configured priority value 0 or negative, priority not modified for mtf thread
Fri Feb 16 18:57:14 2018 kern.warn kernel: [   99.159000] [sched_delayed] sched: RT throttling activated
Fri Feb 16 18:57:14 2018 user.notice postmortem: Rebooting due to core dump and system.coredump.reboot=1
Fri Feb 16 18:57:14 2018 daemon.info procd: - shutdown -
Fri Feb 16 18:57:15 2018 user.notice watchdog-tch: shutdown, stop this service
Fri Feb 16 18:57:15 2018 daemon.info watchdog-tch[1139]: stopping daemon (5.13)
Fri Feb 16 18:57:15 2018 user.notice watchdog-tch: shutdown, then stop pinging the kernel watchdog
Fri Feb 16 18:57:15 2018 user.notice watchdog-tch: ubus response {
   "status": "stopped",
   "timeout": 180,
   "frequency": 5
Fri Feb 16 18:57:15 2018 user.notice dlnad: Stopping dlnad
Fri Feb 16 18:57:15 2018 user.debug mmpbxd[5880]: [MMRVSIPIMPL::REGTERMOBJ]:E: profileTimerCb:444 - no matching IP address, the registration will be aborted
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [+390xxxxxxx] ACR deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [line1] ACR deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [line2] ACR deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [+390xxxxxxxx] BARGE_IN deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [line1] BARGE_IN deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [line2] BARGE_IN deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [+390xxxxxx] CALL_RETURN deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [line1] CALL_RETURN deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [line2] CALL_RETURN deactivated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [FXS 1] CALL_WAITING activated
Fri Feb 16 18:57:15 2018 user.info mmpbxd[5880]: [FXS 2] CALL_WAITING activated
Fri Feb 16 18:57:16 2018 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Fri Feb 16 18:57:16 2018 user.err [mud][5048]: mud_cleanup (571): No profiled partition available
Fri Feb 16 18:57:16 2018 user.notice cwmpd:  Voice not up yet ... delaying startup
Fri Feb 16 18:57:17 2018 daemon.notice wansensing: WAN Sensing Mobile: 1
Fri Feb 16 18:57:20 2018 user.notice postmortem: core dumped to /root/transmission-da.6002.11.1518803840.core.gz
Fri Feb 16 18:57:20 2018 daemon.info procd: Instance watchdog-tch::instance1 pid 1139 not stopped on SIGTERM, sending SIGKILL instead
Fri Feb 16 18:57:20 2018 daemon.warn nginx: 2018/02/16 18:57:20 [warn] 5002#0: *2 [lua] session.lua:343: new(): new session for default user, client: 192.168.1.9, server: localhost, request: "POST /ajax/mobiletab.lua?auto_update=true HTTP/1.1", host: "192.168.1.1", referrer: "http://192.168.1.1/"
Fri Feb 16 18:57:20 2018 daemon.err nginx: 2018/02/16 18:57:20 [error] 5002#0: *2 [lua] sessionmgr.lua:231: redirectIfNotAuthorized(): Unauthorized request, client: 192.168.1.9, server: localhost, request: "POST /ajax/mobiletab.lua?auto_update=true HTTP/1.1", host: "192.168.1.1", referrer: "http://192.168.1.1/"
Fri Feb 16 18:57:20 2018 kern.warn kernel: [  105.299000] dosprotect rpfilter drop IN=br-lan OUT= MAC= SRC=192.168.1.1 DST=192.168.1.255 LEN=96 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=137 DPT=137 LEN=76 MARK=0x8000
Fri Feb 16 18:57:21 2018 user.notice cwmpd:  Voice not up yet ... delaying startup
Fri Feb 16 18:57:22 2018 daemon.notice igmpproxy[4332]: Send IGMP packet to group 224.0.0.1 on intf br-lan
Fri Feb 16 18:57:22 2018 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Fri Feb 16 18:57:22 2018 daemon.notice wansensing: WAN Sensing Mobile: 1
Fri Feb 16 18:57:23 2018 user.notice postmortem: Rebooting due to core dump and system.coredump.reboot=1
Fri Feb 16 18:57:23 2018 user.notice mud: mud stopped.
Fri Feb 16 18:57:23 2018 user.warn mvfs[5024]: MVFS is shutting down
Fri Feb 16 18:57:23 2018 user.notice mvfsd: mvfsd stopped.
Fri Feb 16 18:57:23 2018 user.notice fseventd: fseventd stopped.
Fri Feb 16 18:57:23 2018 daemon.notice procd: /etc/rc.d/K10cwmpd: Command failed: Not found
Fri Feb 16 18:57:24 2018 daemon.debug urlfilterd[4607]: Exiting nfq thread
Fri Feb 16 18:57:24 2018 daemon.notice procd: /etc/rc.d/K21sfpmon: telnet: can't connect to remote host (192.168.2.1): Network is unreachable
Fri Feb 16 18:57:26 2018 lpr.info cupsd[3182]: Scheduler shutting down normally.
Fri Feb 16 18:57:26 2018 lpr.info cupsd[3182]: Saving job.cache...
Fri Feb 16 18:57:26 2018 authpriv.info dropbear[3229]: Early exit: Terminated by signal
Fri Feb 16 18:57:26 2018 user.notice dhcpsnooper: Stopping DHCP snooper daemon
Fri Feb 16 18:57:26 2018 daemon.info odhcpd[3093]: Using a RA lifetime of 0 seconds on wl1_1
Fri Feb 16 18:57:26 2018 daemon.notice odhcpd[3093]: Failed to send to ff02::1%wl1_1 (Operation not permitted)
Fri Feb 16 18:57:26 2018 daemon.info odhcpd[3093]: Using a RA lifetime of 0 seconds on wl0_1
Fri Feb 16 18:57:26 2018 daemon.notice odhcpd[3093]: Failed to send to ff02::1%wl0_1 (Operation not permitted)
Fri Feb 16 18:57:26 2018 daemon.info odhcpd[3093]: Using a RA lifetime of 0 seconds on br-lan
Fri Feb 16 18:57:26 2018 daemon.notice odhcpd[3093]: Failed to send to ff02::1%br-lan (Operation not permitted)
Arrivato all'ultimo rigo...
si blocca ssh e comincia il riavvio del router.
« Ultima modifica: 18 Marzo 2018, 22:22 da kirckc »
« Risposta #7021 il: 18 Marzo 2018, 22:27 »
@kirckc
devi essere molto veloce... fai questi comandi prima che si riavvia
questi tipi di problemi sono stati risolti con nuove versioni della gui...
crasha transmission all'avvio
uci set system.@coredump[0].reboot='0'
uci commit
Offline kirckc
  • 90
« Risposta #7022 il: 18 Marzo 2018, 22:37 »
@Ansuel
avevo anche disinstallato transmission con opkg remove transmission-web , ma a quanto pare non lo ha fatto !!
URRA!! ora non si riavvia + , cosa mi consigli di fare (mi servirebbe anche transmission)
« Risposta #7023 il: 18 Marzo 2018, 22:56 »
aggiorna la gui prima di tutto oppure semplicemente rimuovi e reinstalla dopo aver fatto opkg update...
Offline Rix94
  • 46
« Risposta #7024 il: 18 Marzo 2018, 23:14 »
Salve ragazzi,
con l'ultima versione della gui ho provato a cambiare il driver dsl con uno tra quelli disponibili. Dopo aver cliccato su salva perde la connessione come mi aspettavo ma non si riconnette, riavvio manualmente il modem ed entra in bootloop. Sono riuscito a resettare (col tasto dietro perchè non si riusciva ad accedere da lan), lo risblocco perchè era tornato alla gui tim, aggiorno all'ultima gui e riprovo a cambiare con un altro driver. Mi è successa nuovamente la stessa cosa solo che per riuscire a resettarlo nuovamente ci ho messo più di un ora e mezza!!!! non si resettava più, probabilmente bisogna beccare il momento giusto per resettarlo prima che si riavvii.  era per mettervi al corrente ed evitare che capiti a qualcuno.
« Ultima modifica: 18 Marzo 2018, 23:20 da Rix94 »
« Risposta #7025 il: 18 Marzo 2018, 23:27 »
Versione di partenza e che driver hai provato?
Offline rusudanion
  • 293
« Risposta #7026 il: 19 Marzo 2018, 10:46 »
ciao io...
fai questo /usr/share/transformer/scripts/upgradegui.sh
ciao sono riuscito a rimettere tutto in ordine. ho solo due problemi
1. la gui non vede per intero ma sono 8 tab.ho provato a svuotare la che del browser usare un altro ma la situazione rimane
2. non riesco piu a vedere sul telfono di casa l'id delle chiamate CLIP mi sa che si chiama.
sono partito da firmware nuovo con il tool di sblocco e li i tab si vedevano tutti,ho configurato vdsl e telefono e tutto andava tranne che l'id chiamate ho messo poi ultima gui trammite telnet e ora ho i due problemmi di cui sopra.
Offline verdes
  • 279
« Risposta #7027 il: 19 Marzo 2018, 14:03 »
Buongiorno. Ripropongo:
Su DGA4130 con sblocco effettuato ed ancora gui tim originale, mi dite come posso vedere se la telegestione é disabilitata oppure é abilitata? Grazie
« Risposta #7028 il: 19 Marzo 2018, 14:24 »
questo dovrebbe essere per disattivare la telegestione da ssh
/etc/init.d/cwmpd stop
/etc/init.d/cwmpd disable
/etc/init.d/cwmpdboot stop
/etc/init.d/cwmpdboot disable
Offline verdes
  • 279
« Risposta #7029 il: 19 Marzo 2018, 14:28 »
@mixmax  A me interessava sapere se ora con sblocco fatto e gui tim originale, se  la telegestione fosse abilitata o disabilitata
« Risposta #7030 il: 19 Marzo 2018, 14:32 »
con Gui Tim stock è abilitata ,perlomeno con il vecchio tool e con 1.0.3 e 1.0.4 era così .Solo con Gui di Ansuel quando facevi il Root potevi scegliere prima ,o dopo sulla tab di abilitarla o no. Probabilmente con WinSCP ci sarà il modo di vedere ,o un comando ssh da fare ,ma io non lo so.
edit:
@verdes  puoi disabilitarla anche da ssh con i comandi che ti ho dato ,ma non credo sia un problema ,poi se attivata funziona sicuro l' app mytimfisso
« Ultima modifica: 19 Marzo 2018, 14:42 da mixmax »
Offline verdes
  • 279
« Risposta #7031 il: 19 Marzo 2018, 14:38 »
Ok grazie allora sarà sicuramente abilitata e quindi ora cercherò di inserire una gui non originale
Offline giulio63
  • 232
« Risposta #7032 il: 19 Marzo 2018, 14:41 »
se puoi collegarti al router, dai il comando :
uci show cwmpd.cwmpd_config.state
se ottieni   cwmpd.cwmpd_config.state='0'   vuol dire che è disabilitata,  mentre se  ottieni  cwmpd.cwmpd_config.state='1' che è abilitata
Fritz!Box 7590
Fritz!Box 5530 Fiber
Offline verdes
  • 279
« Risposta #7033 il: 19 Marzo 2018, 14:53 »
@giulio63  Inviato il comando e mi esce config.state=1  quindi é abilitata; sapresti dirmi se si può disabilitare senza cambiare gui. Grazie
Offline giulio63
  • 232
« Risposta #7034 il: 19 Marzo 2018, 15:01 »
Direi con i comandi che ha scritto mixmax pochi messaggi fa....fermi il processo e la disabiliti
Fritz!Box 7590
