Problemi con modem Dlink DSL-300T
  • 174 Risposte
  • 88901 Visite
Re: Problemi con modem Dlink DSL-300T
« Risposta #135 il: 13 Settembre 2005, 19:20 »
I remember you could telnet one of them, I suppose the nr. 2 (the other seems really a good JTAG customer  :o) , please confirm...
Offline SilverDesertRain
  • 29
« Risposta #136 il: 13 Settembre 2005, 19:25 »
« Risposta #137 il: 13 Settembre 2005, 22:38 »
OK SilverDesertRain, I have read again your posts. As I told you before make this try:
Configure the tcp/ip ethernet adapter with these values
IP=192.168.1.2
Gateway=192.168.1.1
Subnet Mask=255.255.255.0
Switch on the modem (nr. 2)
At the command prompt put the following command:
telnet 192.168.1.1
then enter
root
as login name
and your web configuration page password
if everything will go fine you'll get a screen like this one:
BusyBox v1.00 (2005.02.14-19:59+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
It's very important you do this try. If you get the above screen I can tell you a method for substituting the ADAM2 version with a working one.
Recently I discovered that some new 300t with Intel flashrom have an adam2 for AMD flashrom version and because of that they can't be flashed getting the unfamous "550 Flash erase failed" error message.
The solution is telnet to the modem in the busybox environment (not adam2) and with some simple commands change the wrong adam2 version.
Offline theone
  • 44
« Risposta #138 il: 14 Settembre 2005, 00:44 »
@arsenico
ho visto sulla pagina di libero assistenza adsl che la connessione da impostare è PPPoA con incapsulazione VC.
Al di la di questo ti posto il log del mio modem quando si connette in PPPoA:
ep  8 12:00:11> Valid Configuration Tree
Sep  8 12:00:20> Firewall NAT service started
Sep  8 12:00:22> Bridge Created: br0
Aug  9 12:01:00> Bridge Interface Added: eth0
Aug  9 12:01:07> DSL Carrier is down
Aug  9 12:12:37> DSL Carrier is up
Aug  9 12:12:39> pppd 2.4.1 started by root, uid 0
Aug  9 12:12:39> Connect: ppp0 {--}
Aug  9 12:12:42> WAN IP address 82.54.43.123
Aug  9 12:12:42> PPPoA Connect with IP Address 82.54.43.123
Aug  9 12:12:42> WAN gateway 192.168.100.1
Aug  9 12:12:43> PPPoA Connection Successfully Established
Aug  9 12:12:43> PPPoA Connect with Gateway IP Address: 192.168.100.1
Aug  9 12:12:43> primary   DNS address 85.37.17.43
Aug  9 12:12:43> secondary DNS address 151.99.125.1
rispetto a questo log
Dal log di sistema ricavo il seguente...
Aug  9 12:01:03> Valid Configuration Tree
Aug  9 12:01:15> Firewall NAT service started
Aug  9 12:01:00> Bridge Created: br0
Aug  9 12:01:01> pppd 2.4.1 started by root, uid 0
Aug  9 12:01:01> WAN IP address 10.64.64.64
Aug  9 12:01:01> WAN gateway 10.112.112.112
Aug  9 12:01:05> DSL Carrier is training
Aug  9 12:01:15> DSL Carrier is up
Aug  9 12:01:21> pppd 2.4.1 started by root, uid 0
Aug  9 12:01:21> WAN IP address 10.64.64.64
Aug  9 12:01:21> WAN gateway 10.112.112.112
postato da te qualche tempo fa mancano le righe che ho messo in neretto che mi sembrano importanti,soprattutto
'Connect: ppp0 {--} '
non mi ricordo se hai provato a impostare tutti i tipi di connessione possibile provando sia con PPPoA LLC che con PPPoA VC e PPPoE(che di default è LLC)
Quasi sicuramente il modem USB usa PPPoA VC come tipo di connessione,dunque credo bisognerebbe insistere con quella.Se non funziona sinceramente non saprei se in fase di negoziazione la mancanza di quelle due righe possa essere imputabile al modem(o Al firmware malfunzionante,ma mi sembra le facesse anche una volta flashato in 300t normale)o al provider.Prova con PPPoA VC !
Offline Fodistrass
  • 29
« Risposta #139 il: 14 Settembre 2005, 09:02 »
@Marven
Ecco i risultati delle prove di ieri sera:
Ipconfig /all
Configurazione IP di windows
Tipo di nodo ..............sconosciuto
Routing IP abilitato ......No
Proxy Wins abilitato ......No
Scheda Ethernet LAN
Suffisso specificato per connessione ....... :
Descrizione ................................ 3COM Gigabit LOM (3C940)
Indirizzo fisico ........................... 00 - 0C - 6E - CE - 0C - 0B
DHCP abilitato ............................. No
Indirizzo IP ............................... 192.168.1.2
Subnet Mask  ............................... 255.255.255.0
Gateway predefinito ........................ 192.168.1.1
Con questa configurazione , con ciclamab, ho tentato di riflhasare i fw di samy 1.1, ma niente.
Ho poi cambiato gli IP come da te suggerito
IP 192.168.0.99
SM 255.255.255.0
GW 192.168.0.1
Ma ciclamab al passo 2 dice : Al modem /router verrà assegnato l'IP 192.168.1.1
L'IP del PC (192.168.0.99) non è valido. Bisogna sostituire 192.168.1.x (x variabile da 2 a 254)
Stessa cosa accade per i secondi IP suggeriti:
IP 10.8.8.99
SM 255.255.255.0
GW 10.8.8.8
Con qualsiasi configurazione di IP, l'unico ping che va a buon fine è sul 127.0.0.1,
Cosa strana (almeno per me) è quella che se cambio IP  (mantengo i primi tre valori cioè pingo sull'IP 127.0.0.x)  mi dà sempre " Risposta da 127.0.0.1 positiva" come se esistesse solo l'IP 127.0.0.1.
Ho anche provato a flashare con i firmware originali e il config.xlm fatto prima di tutto il casino, ma niente da fare.
« Risposta #140 il: 14 Settembre 2005, 12:15 »
@Fodistrass
Se l'IP del PC e' 192.168.0.99 in Ciclamab (ti consiglio la versione 1.9.96) devi impostare  IP=192.168.0.1 cioe' = IP del gateway impostato nella configurazione di rete.
Ipconfig ha riportato dei dati corretti. L'unica cosa strana e' che non pinghi il tuo IP.
Possibili problemi:
1) Firewall di XP o altro firewall o antivirus con funzioni di firewall. Soluzione = Disattiva tutto almeno temporaneamente.
2) Stack tcp/ip corrotto. Soluzione = scaricati winsockfix:
http://www.softpedia.com/progDownload/WinSockFix-Download-15337.html
eseguilo e riavvia il pc. Se la situazione non cambia disinstalla e reinstalla la il driver della ethernet, possibilmnete la versione piu' aggiornata.
Offline Fodistrass
  • 29
« Risposta #141 il: 14 Settembre 2005, 12:32 »
@Marven
Grazie. Proverò come al solito stasera e domani ti farò sapere.
In effetti il codice di errore 65 riguarda proprio la presenza di firewall (http://support.microsoft.com/default.aspx?scid=kb;it;316414&Product=winxpINT)
Io però durante tutte le procedure ho disattivato antivirus e firewall ( nella fattispecie mcAfee e Zone alarm) e anche il firewall di windows è disattivato.
Cmq ci ridò un'occhiata per togliermi il dubbio ( per sicurezza li disinstallo tutti e due)
Offline Fodistrass
  • 29
« Risposta #142 il: 14 Settembre 2005, 15:44 »
@Marven
Credo sia rinato !!!!!  ;D ;D
Il Log di ciclamab 1.9.96 mi dà :
226 Transfer complete.
REBOOT
221-Thank you for using the FTP service on ADAM2.
221 Goodbye.
Operazione conclusa!
Attendere il riavvio del modem/router...
* Fine operazioni  -  14/09/2005 14.13.59 *
Credo che fosse questione di firewall, come dicevi tu.
Ho disinstallato mcAfee, zone alarm e anche nel firewall di windows XP nella sezione avanzate ho tolto il segno di spunta su LAN.
Ora con Ipconfig /all ottengo
Scheda Ethernet LAN
DHCP abilitato ............................. Sì
Server DNS ................................. 193.70.192.25
                                                  193.70.152.25
Lease ottenuto ............................  mercoledì 14 settembre 2005 14.15
Scandenze Lease ...........................  mercoledì 14 settembre 2005 14.15
A questo punto sono andato avanti.
Come vedi ho reinserito gli IP alla LAN (o meglio ho selezionato "ottieni automaticamente IP" mentre i DNS sono quelli di LIbero), ho digitato http://192.168.1.1 si è aperta la pagina, mi sono logato con admin / admin , ho configurato il router, ma quando ho premuto il tasto salva , l'idicatore di avanzamento è arrivato abbastanza velocemente alla metà ma poi è rimasto lì per più di 10 minuti.
Cosa devo fare secondo te ? Aspettare oppure nelle configurazioni c'è da settare qualcosa di particolare.?
Magari sul sito c'è un manuale per questo modem/router.
A proposito, adesso lo considero router 500T a tutti gli effetti?
Offline theone
  • 44
« Risposta #143 il: 14 Settembre 2005, 16:13 »
scusa se intanto mi intrometto io...ti consiglio di svuotare la cache del browser, cosa da fare di norma dopo ogni aggiornamento firmware perchè ho notato che tende a rimanere qualcosa delle pagine vecchie che può dare fastidi
« Risposta #144 il: 14 Settembre 2005, 17:09 »
infatti............
siiiiiiii
« Risposta #145 il: 14 Settembre 2005, 17:15 »
Il problema del mancato refresh puo' essere dovuto, come ha detto giustamente theone, a dati presenti in cache che confliggono con quelli provenienti dal modem e/o dal firmware (ora mi sfugge quale hai messo tu) che puo' avere qualche piccolo bug.
Dal punto di vista delle funzionalita' si, dal punto di vista hardware ovviamente no. Il 500t ha 4 MB di RAM e il 30xt 2.
Offline Fodistrass
  • 29
« Risposta #146 il: 14 Settembre 2005, 18:14 »
@Marven
Stasera provo a fare pulizia delle cache.
Domani saprò dirti qualcosa di più preciso e come è andata a finire.
Il firmware che ho messo io è quello di Samy 1.1
  • 29
« Risposta #147 il: 14 Settembre 2005, 20:05 »
@ Marven
Thanks mate...but I have no idea how to use Busybox. I have only window xp and have no idea how to use linux...if you can help me out I will be very grateful.
Will any type of J-Tag interface work ?
« Risposta #148 il: 14 Settembre 2005, 20:35 »
 il 500t ha 4 mega di ROM e 16 di RAM ........
« Risposta #149 il: 14 Settembre 2005, 22:38 »
@submax82
Ihh... come sei pignolo...  ;D  non ti sfugge niente  :D  ;D ho solo sbagliato scrivendo... ma visto che ci sono faccio anch'io il pignolo: Alcuni 30xt, come il mio  :P, hanno 16 MB di RAM, altri piu sfigati, come quello di Submax  ;D ;D ;D, ne hanno solo 8  :-\  :(.
