  • 4741 Risposte
  • 2591284 Visite
« Risposta #3195 il: 18 Marzo 2020, 14:45 »
Apri il file /etc/config/network e facci vedere cosa c'è dentro
Offline aledebbb
  • 34
« Risposta #3196 il: 18 Marzo 2020, 14:52 »
Ho scoperto che in SSH il router non si connette ad internet, il ping con dispositivi locali funziona... il ping con altri ip esterni non vanno a buon fine.
Internet funziona solo se connessi tramite WI-FI.
il contenuto è il seguente:
config interface 'loopback'
        option ifname 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'auto'
        option default_ps '0'
config interface 'lan'
        option type 'bridge'
        option force_link '0'
        option igmp_snooping '1'
        option ipv6 '0'
        option ip6assign '64'
        option ipaddr '192.168.1.50'
        list ifname 'vlan_eth0'
        list ifname 'vlan_eth1'
        list ifname 'vlan_eth2'
        list ifname 'vlan_eth3'
config device 'eth0'
        option mtu '1500'
        option name 'eth0'
config device 'eth1'
        option mtu '1500'
        option name 'eth1'
config device 'eth2'
        option mtu '1500'
        option name 'eth2'
config device 'eth3'
        option mtu '1500'
        option name 'eth3'
config device 'vlan_eth0'
        option type '8021q'
        option ifname 'eth0'
        option name 'vlan_eth0'
        option mtu '1500'
        option vid '1'
config device 'vlan_eth1'
        option type '8021q'
        option ifname 'eth1'
        option name 'vlan_eth1'
        option mtu '1500'
        option vid '1'
config device 'vlan_eth2'
        option type '8021q'
        option ifname 'eth2'
        option name 'vlan_eth2'
        option mtu '1500'
        option vid '1'
config device 'vlan_eth3'
        option type '8021q'
        option ifname 'eth3'
        option name 'vlan_eth3'
        option mtu '1500'
        option vid '1'
config switch 'bcmsw_int'
        option reset '1'
        option type 'bcmsw'
        option qosimppauseenable '0'
        option jumbo '1'
        option unit '0'
        option enable_vlan '0'
config switch 'bcmsw_ext'
        option reset '1'
        option type 'bcmsw'
        option unit '1'
        option enable_vlan '1'
        option jumbo '1'
config switch_vlan 'lan_switch'
        option device 'bcmsw_ext'
        option vlan '1'
        option ports '1* 2* 3* 4* 8t'
config interface 'vdsl_check'
        option proto 'pppoe'
        option ifname 'ptm0'
        option keepalive '5,10'
        option auto '0'
        option vendorid 'Technicolor'
        option graceful_restart '1'
        option authfail '0'
        option mtu '1500'
        option ipv6 '0'
        option release '1'
        option iface6rd '0'
config device 'eth4'
        option mtu '1500'
        option name 'eth4'
config device 'ptm0'
        option mtu '1508'
        option name 'ptm0'
config device 'vlan_wan'
        option type '8021q'
        option mtu '1508'
        option name 'vlan_wan'
        option vid '101'
config config 'config'
« Ultima modifica: 18 Marzo 2020, 15:08 da MisterFTTH »
Ciao!
« Risposta #3197 il: 18 Marzo 2020, 15:08 »
@aledebbb i tag CODE esistono per essere usati...
Offline aledebbb
  • 34
« Risposta #3198 il: 18 Marzo 2020, 15:18 »
scusate sono nuovo  :'(, la prossima volta li userò! Grazie
Ciao!
« Risposta #3199 il: 18 Marzo 2020, 15:29 »
SE ci sarà, una prossima volta....
 >:D
« Risposta #3200 il: 18 Marzo 2020, 16:26 »
@aledebbb sì, che lui di suo non abbia accesso ad internet è naturale, essendo in modalità AP almeno che non gli configuriamo anche epr se stesso una connessione non potrà raggiungere internet. Solo non mi aspettavo che la modalità AP lasciasse la connessione WAN appesa e non connessa, pensavo la disattivasse del tutto. A questa cosa puoi pensarci dopo, ora bisogna capire perchè gli altri connessi via cavo non arrivano ad internet.
Stai usando solo le quattro porte gialle o lo hai collegato dalla porta rossa?
Offline aledebbb
  • 34
« Risposta #3201 il: 18 Marzo 2020, 21:08 »
solo le porte gialle
Ciao!
« Risposta #3202 il: 18 Marzo 2020, 21:59 »
Che succede agli altri connessi via cavo quando provano a navigare in internet? Si apre una pagina in particolare o non prendono proprio un ip?
Offline aledebbb
  • 34
« Risposta #3203 il: 18 Marzo 2020, 22:35 »
non carica proprio la pagina.
Se volessi mettere la custom gui, devo farlo prima o posso farlo dopo aver risolto il problema?
Ciao!
« Risposta #3204 il: 19 Marzo 2020, 01:09 »
Devi farlo dopo altrimenti non sappiamo dov'è il problema. Ma la custom GUI su un dispositivo non dotato di accesso ad internet francamente non credo serva a nulla.
Controlla che il pc connesso via cavo prenda correttamente un ip dal dhcp del router a monte. Dai il comando "/etc/init.d/intercept disable" e riavvia l'ap, vedi se cambia qualcosa.
Offline aledebbb
  • 34
« Risposta #3205 il: 19 Marzo 2020, 09:45 »
è cambiato qualcosa, perché prima il router nella lista dei dispositivi sulla pagina del router principale non compariva (però era accessibile dal suo IP), ora compare anche lui nella lista IP e anche i dispositivi connessi a lui con i relativi IP
Ciao!
« Risposta #3206 il: 19 Marzo 2020, 12:19 »
Scusa, curiosità, ma il router principale per caso è una Vodafone station?
A parte questo ora i dispositivi cablati funzionano?
« Ultima modifica: 19 Marzo 2020, 12:22 da LuKePicci »
Offline aledebbb
  • 34
« Risposta #3207 il: 19 Marzo 2020, 12:34 »
ora controllo.
Si è la station revolution
Ciao!
« Risposta #3208 il: 19 Marzo 2020, 12:37 »
Ok allora è per quello che prima non funzionavano gli altri cablati. La station revolution è insofferente a questi setup con ap in cascata. Ogni tanto la sua risoluzione arp si inceppa e va riavviata. Ora va pure avanti ma al poto tuo avrei di sicuro fatto l'inverso e messo il 789 come router e la VSR come ap.
Offline frisa8860
« Risposta #3209 il: 19 Marzo 2020, 17:03 »
Con un pò di difficoltà sono riuscito ad installare iiNet.
Volevo continuare i settaggi ma mi accorgo che ssh non è funzionante. :worry:
Come posso abilitarlo?
Da qui, si può passare ad installare UNO?
Grazie per l'aiuto
