  • 6025269 Visite
Offline shdf
  • 981
Offline shdf
  • 981
« Risposta #2312 il: 09 Ottobre 2017, 23:07 »
Aria2c con Webui, funziona  :good:  :toohappy:
it doesn't work when you install the web interface on the router, but it works when you run the web interface from your PC.
i don't know why it doesn't work on the router...
How to :
Download webui-aria2 from https://github.com/ziahamza/webui-aria2
extract all in a folder on your PC.
in configuration.js replace localhost with your router ip (192.168.1.1)
Click the index.html file, enjoy !  :great:
of course on the router you must do first : aria2c --enable-rpc --rpc-listen-all=true --rpc-allow-origin-all
« Ultima modifica: 09 Ottobre 2017, 23:17 da shdf »
Offline pigr8
  • 175
« Risposta #2313 il: 09 Ottobre 2017, 23:29 »
 :good:
Offline ItalianGamer91
  • 408
« Risposta #2314 il: 09 Ottobre 2017, 23:41 »
:good:
pigr8 ora che ho il sorgente come compilo una immagine openwrt da ambiente windows?
  • 408
« Risposta #2315 il: 09 Ottobre 2017, 23:53 »
Prova questo:
wl -i wl0 chanspec -c 6 -b 2 -w 40 -s -1
wl -i wl0 down
wl -i wl0 up
-c = Canale 6
-b = Banda (2.4Ghz)
-w = Width (40Mhz)
-s = ??
Visto qui : https://wiki.openwrt.org/doc/hardware/soc/soc.broadcom.bcm47xx
Per me funziona...
je suis complete investigation in wireless config /etc/config/wireless de channelwidth is auto now i am put 40
root@modemtim:~# wlctl radarargs40 npulses set
radarargs40
        Get/Set Radar parameters for 40Mhz channel in
        order as version, npulses, ncontig, min_pw, max_pw, thresh0,
        thresh1, blank, fmdemodcfg, npulses_lp, min_pw_lp, max_pw_lp,
        min_fm_lp, max_span_lp, min_deltat, max_deltat,
        autocorr, st_level_time, t2_min, fra_pulse_err, npulses_fra,
        npulses_stg2, npulses_stg3, percal_mask, quant,
        min_burst_intv_lp, max_burst_intv_lp, nskip_rst_lp, max_pw_tol, feature_mask
« Ultima modifica: 10 Ottobre 2017, 00:05 da ItalianGamer91 »
Offline cicciokim1
  • 48
« Risposta #2316 il: 10 Ottobre 2017, 00:00 »
Per chi fosse interessato, ho aggiornato e fixato la mia utility per AGTEF https://we.tl/QjbblX0hf3
  • 408
« Risposta #2317 il: 10 Ottobre 2017, 00:06 »
puoi mettere un sistema che cambia i colore della interfaccia e che metta il wireless 40mhz su 2g
PS Sei un mago ma devi dirgli di avviare una connessione ssh a me telnet non va
Offline cicciokim1
  • 48
« Risposta #2318 il: 10 Ottobre 2017, 00:24 »
La utility non ha funzioni proprie, puoi inserire tutti i comandi che vuoi ed associarli ad una icona per l'invio rapido direttamente dalla system tray.
Hai attivato telnet dalla gui del modem? è strano che non funzioni.
Per SSH al momento no. Troppo complicato da implementare ed al momento non ho tempo.
Offline donato74
  • 197
« Risposta #2319 il: 10 Ottobre 2017, 01:09 »
Dunque, dopo un paio di riavvii e alcuni neuroni (i pochi rimasti) bruciati, ho sbloccato e riesco ad entrare in SSH. Vorrei però aggiornare alla ultima gui, sto provando con i comandi manuali, ma quando do il comando  bzcat /tmp/GUI.tar.bz2 | tar -C / -xvf –
mi risponde tar: can't open '–': No such file or directory
Cosa sbaglio?
  • 408
« Risposta #2320 il: 10 Ottobre 2017, 01:28 »
Cosa sbaglio?
devi mettere un trattino -
  • 408
« Risposta #2321 il: 10 Ottobre 2017, 01:31 »
però devi mettere lo sfondo nero in console telnet ho si no nn si vede nulla
Offline donato74
  • 197
« Risposta #2322 il: 10 Ottobre 2017, 01:43 »
E ora tar: can't open '▒': No such file or directory :)
Offline ^NiCo^
  • 1258
« Risposta #2323 il: 10 Ottobre 2017, 01:48 »
Uppa il file GUI.tar.bz2 in /tmp con winscp e poi il comando corretto è -> "bzcat /tmp/GUI.tar.bz2 | tar -C / -xvf -" (senza le ").
Poi dai un paio di volte il comando "/etc/init.d/rootdevice force" tramite ssh (la prima volta da errore, la seconda lo accetta).
Edit
Stavo aggiornando e ora non si comporta più come prima quando si dà /etc/init.d/rootdevice force, l' ultima che funzionava dandolo 2 volte era la 3.9
« Ultima modifica: 10 Ottobre 2017, 01:59 da ^NiCo^ »
Offline cicciokim1
  • 48
« Risposta #2324 il: 10 Ottobre 2017, 01:54 »
Fix: https://we.tl/feahIRRDOY
Corertto il colore di sfondo finestra telnet. Anzichè il nero avevo preso il colore "active caption" (un colore di sistema) che nel mio tema di windows era nero ma su altri pc no....
