Come richiedere un router (gratis) per monitorare le performance della rete xDSL
  • 598 Risposte
  • 254473 Visite
Offline fulmine500
  • 1322
Re:Metodo semplice per rimediare un router gratis !
« Risposta #105 il: 19 Ottobre 2014, 11:33 »
Ieri sera ho finalmente saldato la seriale
Vi posto il bootlog
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.10.19 11:26:45 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot 1.1.4 (Sep  9 2013 - 14:28:41)
U-boot DB120
DRAM:  128 MB
id read 0x100000ff
flash size 8MB, sector count = 128
Flash:  8 MB
Using default environment
PCIe Reset OK!!!!!!
In:    serial
Out:   serial
Err:   serial
Net:   ag934x_enet_initialize...
No valid address in Flash. Using fixed address
 wasp  reset mask:c03300
WASP  ----> S17 PHY *
: cfg1 0x7 cfg2 0x7114
eth0: ba:be:fa:ce:08:41
athrs17_reg_init: complete
eth0 up
eth0
Autobooting in 1 seconds
## Booting image at 9f020000 ...
   Uncompressing Kernel Image ... OK
Starting kernel ...
[    0.000000] Linux version 3.3.8 ([email protected]) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #6 Fri Jan 11 10:50:18 GMT 2013
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 0001974c (MIPS 74Kc)
[    0.000000] SoC: Atheros AR9344 rev 2
[    0.000000] Clocks: CPU:560.000MHz, DDR:450.000MHz, AHB:225.000MHz, Ref:40.000MHz
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 08000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone PFN ranges:
[    0.000000]   Normal   0x00000000 -> 0x00008000
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000000 -> 0x00008000
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line:  board=TL-WDR4300 console=ttyS0,115200 rootfstype=squashfs,jffs2 noinitrd
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] Memory: 126596k/131072k available (2105k kernel code, 4476k reserved, 400k data, 208k init, 0k highmem)
[    0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:51
[    0.000000] Calibrating delay loop... 278.93 BogoMIPS (lpj=1394688)
[    0.070000] pid_max: default: 32768 minimum: 301
[    0.070000] Mount-cache hash table entries: 512
[    0.080000] NET: Registered protocol family 16
[    0.080000] gpiochip_add: registered GPIOs 0 to 22 on device: ath79
[    0.090000] MIPS: machine is TP-LINK TL-WDR3600/4300/4310
[    0.090000] registering PCI controller with io_map_base unset
[    0.310000] bio: create slab <bio-0> at 0
[    0.310000] PCI host bridge to bus 0000:00
[    0.320000] pci_bus 0000:00: root bus resource [mem 0x10000000-0x13ffffff]
[    0.320000] pci_bus 0000:00: root bus resource [io  0x0000]
[    0.330000] pci 0000:00:00.0: invalid calibration data
[    0.330000] pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x1001ffff 64bit]
[    0.340000] pci 0000:00:00.0: BAR 6: assigned [mem 0x10020000-0x1002ffff pref]
[    0.340000] pci 0000:00:00.0: using irq 40 for pin 1
[    0.350000] Switching to clocksource MIPS
[    0.350000] NET: Registered protocol family 2
[    0.360000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.360000] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.370000] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.370000] TCP: Hash tables configured (established 4096 bind 4096)
[    0.380000] TCP reno registered
[    0.380000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.390000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.390000] NET: Registered protocol family 1
[    0.410000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.420000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.430000] msgmni has been set to 247
[    0.430000] io scheduler noop registered
[    0.440000] io scheduler deadline registered (default)
[    0.440000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.470000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
[    0.470000] console [ttyS0] enabled, bootconsole disabled
[    0.490000] m25p80 spi0.0: found s25fl064k, expected m25p80
[    0.490000] m25p80 spi0.0: s25fl064k (8192 Kbytes)
[    0.500000] 5 tp-link partitions found on MTD device spi0.0
[    0.510000] Creating 5 MTD partitions on "spi0.0":
[    0.510000] 0x000000000000-0x000000020000 : "u-boot"
[    0.520000] 0x000000020000-0x0000001003e4 : "kernel"
[    0.520000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.540000] 0x0000001003e4-0x0000007f0000 : "rootfs"
[    0.540000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.550000] mtd: partition "rootfs" set to be root filesystem
[    0.560000] mtd: partition "rootfs_data" created automatically, ofs=540000, len=2B0000
[    0.570000] 0x000000540000-0x0000007f0000 : "rootfs_data"
[    0.580000] 0x0000007f0000-0x000000800000 : "art"
[    0.580000] 0x000000020000-0x0000007f0000 : "firmware"
[    0.720000] ag71xx_mdio: probed
[    0.720000] eth0: Atheros AG71xx at 0xb9000000, irq 4
[    1.300000] eth0: Atheros AR8327 switch driver attached.
[    2.460000] ag71xx ag71xx.0: eth0: connected to PHY at ag71xx-mdio.0:00 [uid=004dd034, driver=Atheros AR8216/AR8236/AR8316]
[    2.480000] TCP cubic registered
[    2.480000] NET: Registered protocol family 17
[    2.480000] 8021q: 802.1Q VLAN Support v1.8
[    2.490000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[    2.500000] Freeing unused kernel memory: 208k freed
- preinit -
Press the [f] key and hit [enter] to enter failsafe mode
[    5.510000] eth0: link up (1000Mbps/Full duplex)
- regular preinit -
[    7.310000] JFFS2 notice: (449) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 10 of xref (0 dead, 2 orphan) found.
switching to jffs2
- init -
[    7.400000] eth0: link down
Please press Enter to activate this console. [    8.090000] Compat-drivers backport release: compat-drivers-2012-09-04-2-gddac993
[    8.100000] Backport based on wireless-testing.git master-2012-09-07
[    8.110000] compat.git: wireless-testing.git
[    8.130000] cfg80211: Calling CRDA to update world regulatory domain
[    8.140000] cfg80211: World regulatory domain updated:
[    8.140000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[    8.150000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.160000] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[    8.170000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[    8.180000] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.180000] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    8.390000] NET: Registered protocol family 10
[    8.520000] usbcore: registered new interface driver usbfs
[    8.520000] usbcore: registered new interface driver hub
[    8.530000] usbcore: registered new device driver usb
[    8.970000] ieee80211 phy0: Atheros AR9340 Rev:0 mem=0xb8100000, irq=47
[    8.970000] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
[    8.990000] ieee80211 phy1: Atheros AR9300 Rev:4 mem=0xb0000000, irq=40
[    9.010000] cfg80211: Calling CRDA for country: US
[    9.010000] cfg80211: Regulatory domain changed to country: US
[    9.020000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[    9.020000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[    9.030000] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
[    9.040000] cfg80211:   (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    9.050000] cfg80211:   (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    9.060000] cfg80211:   (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[    9.060000] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
[    9.160000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    9.170000] ehci-platform ehci-platform: Generic Platform EHCI Controller
[    9.170000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[    9.210000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[    9.230000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[    9.230000] hub 1-0:1.0: USB hub found
[    9.240000] hub 1-0:1.0: 1 port detected
[    9.570000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    9.720000] hub 1-1:1.0: USB hub found
[    9.720000] hub 1-1:1.0: 4 ports detected
[   11.500000] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   11.870000] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.860000] eth0: link up (1000Mbps/Full duplex)
[   13.880000] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
BusyBox v1.19.4 (2012-11-21 13:26:44 GMT) built-in shell (ash)
Enter 'help' for a list of built-in commands.
                     _
 ___  __ _ _ __ ___ | | ___ __   _____      _____
/ __|/ _` | '_ ` _ \| |/ / '_ \ / _ \ \ /\ / / __|
\__ \ (_| | | | | | |   <| | | | (_) \ V  V /\__ \
|___/\__,_|_| |_| |_|_|\_\_| |_|\___/ \_/\_/ |___/
       P E R F O R M A N C E   M O N I T O R I N G
 OS: OpenWRT Attitude Adjustment, r35093
 SW: WDR3600 Build
root@OpenWrt:/#
Printenv uboot
db12x> printenv
bootargs=console=ttyS0,115200 root=31:02 rootfstype=squashfs init=/sbin/init mtdparts=ath-nor0:256k(u-boot),64k(u-boot-env),6336k(rootfs),1408k(uImage),64k(mib0),64k(ART)
bootcmd=bootm 0x9f020000
bootdelay=1
baudrate=115200
ethaddr=0xba:0xbe:0xfa:0xce:0x08:0x41
ipaddr=192.168.1.111
serverip=192.168.1.100
dir=
lu=tftp 0x80060000 ${dir}u-boot.bin&&erase 0x9f000000 +$filesize;cp.b $fileaddr 0x9f000000 $filesize
lf=tftp 0x80060000 ${dir}db12x${bc}-jffs2&&erase 0x9f050000 +0x630000;cp.b $fileaddr 0x9f050000 $filesize
lk=tftp 0x80060000 ${dir}vmlinux${bc}.lzma.uImage&&erase 0x9f680000 +$filesize;cp.b $fileaddr 0x9f680000 $filesize
stdin=serial
stdout=serial
stderr=serial
ethact=eth0
Environment size: 686/65532 bytes
« Ultima modifica: 19 Ottobre 2014, 14:08 da fulmine500 »
« Risposta #106 il: 19 Ottobre 2014, 11:36 »
Solo 8 mb di flash :O CHE TIRCHI....
Offline varma
  • 283
« Risposta #107 il: 19 Ottobre 2014, 14:41 »
Ma senza alcun dubbio ci butto dentro Gargoyle!!
Offline zoomx
  • 589
« Risposta #108 il: 20 Ottobre 2014, 10:40 »
E' il modello che ha 8 mega, del resto a che sarebbe servito avere di più visto che l'immagine che usano non ha interfaccia grafica ma è solo una versione ridotta (o quasi) di openWRT?
Son quelli di TP-Link che hanno avuto il braccino corto. Ma anche loro, se riescono ad inserire in 8Mb un firmware che, secondo loro, è completo perché dovrebbero mettere una Flash da 16Mb? L'unico motivo che ci vedo è la possibilità che un reset diciamo profondo tiri fuori un firmware di riserva dalla flash, cosa che ho visto succede in alcuni dispositivi, mi viene in mente la Vodafone TV.
« Risposta #109 il: 20 Ottobre 2014, 13:16 »
Magari è strutturato come quello telecom... Meta ROM e meta backup...
Offline varma
  • 283
« Risposta #110 il: 20 Ottobre 2014, 14:45 »
Ma per rimettere il firmaware originale non è sufficiente la procedura linkata al primo post?
Quella che rimanda al wiki di openwrt e sfrutta il tftp premendo il tasto WPS in avvio?
« Ultima modifica: 20 Ottobre 2014, 14:47 da varma »
« Risposta #111 il: 20 Ottobre 2014, 14:55 »
Raga è normale che ancora non mi è arrivato il messaggio so passati 10 giorni e li ho pure contattati senza risposta :(
Offline beppe9000
  • 150
    • Roba VS2
« Risposta #112 il: 20 Ottobre 2014, 16:17 »
[Quoto /]
boh, non so che dire...
forse dipende da dove abiti/dati inseriti nel modulo di richiesta?
« Ultima modifica: 20 Ottobre 2014, 16:23 da beppe9000 »
« Risposta #113 il: 20 Ottobre 2014, 19:04 »
Mi hanno risposto e mi hanno scritto
Hello,
Your details are with our warehouse team. We will email you when the package is shipped out.
Kind regards,
Ati
The SamKnows Team
Dovrebbe essere positivo magari stanno aspettando più richieste per l'Italia....
Offline serafini
  • 27
« Risposta #114 il: 22 Ottobre 2014, 18:47 »
Sì, è così per una scelta di TP-Link: l'unica personalizzazione di SamKnows è il firmware (nessuna modifica hardware).  ;)
http://wiki.openwrt.org/toh/tp-link/tl-wdr3600
http://www.superwrt.eu/en/firmware/tp-link-wdr3600/
« Ultima modifica: 22 Ottobre 2014, 18:48 da serafini »
1x Netgear DGND3300, 1x TP-Link TL-WDR3600 (SamKnows), 1x TP-Link TL-WR1043ND, 1x TP-Link TL-SG1005D, 1x LaCie Network Space 2 1TB, 1x WD My Cloud 2TB
« Risposta #115 il: 22 Ottobre 2014, 20:09 »
Cioè dico non so pochi 8 mb :/
Cmq ancora non arriva nulla a voi è arrivato qualcosa?
Offline beppe9000
  • 150
    • Roba VS2
« Risposta #116 il: 23 Ottobre 2014, 02:15 »
Per chi fosse curioso di come sia il firmware stock questo è il simulatore ufficiale.
http://www.tp-link.it/resources/simulator/wdr3600/index.htm
Offline ax13
  • 44
« Risposta #117 il: 23 Ottobre 2014, 09:26 »
Il 10 mi è arrivata la mail di conferma, ma ancora non è arrivato niente! È normale?
Offline beppe9000
  • 150
    • Roba VS2
« Risposta #118 il: 23 Ottobre 2014, 15:24 »
tendenzialmente se vi arriva l'email di conferma allora prima o poi arriverà tutto
Offline lor-gt
  • 37
« Risposta #119 il: 23 Ottobre 2014, 21:48 »
Io ho riprovato ad iscrivermi. Si perché con il mio indirizzo mail primario mi ero già iscritto. Ora mi sono iscritto con quello secondario e quello di mia zia che però abita da un altra parte. A me non contattano...
