agpf brikkato dopo agg firmware tantativo di recupero con jtag
  • 18 Risposte
  • 10470 Visite
Offline genno
  • 17
salva a tutti,
sto impazzendo con sto alice gate 2 wifi, l'ho brikkato luce adsl rossa fissa..ho costruito la jtag per flasharlo ma i risultati sono questi....
lancio la prova e mi legge tutto poi qualsiasi comando che do sia erase che falsh mi da quel risultato...qualkuno mi puoi cortesemente aiutare ??
C:\alice>alice03 -probeonly
EJTAG Debrick Utility for Alice routers v0.3
Probing bus ... Done
Instruction Length set to 5
CPU Chip ID: 00000110001101011000000101111111 (0635817F)
*** Found a Broadcom BCM6358 Rev 1 CPU chip ***
    - EJTAG IMPCODE ....... : 00000000100000011000100100000100 (00818904)
    - EJTAG Version ....... : 1 or 2.0
    - EJTAG DMA Support ... : Yes
Issuing Processor / Peripheral Reset ... Done
Enabling Memory Writes ... Done
Halting Processor ... <Processor did NOT enter Debug Mode!> ... Done
Clearing Watchdog ... Done
Probing Flash at (Flash Window: 0x1f000000) ...
Probe using cmd_type for AMD
Flash Vendor ID: 0000FFFF
Flash Device ID: 0000FFFF
Probing Flash at (Flash Window: 0x1f400000) ... Done
Flash Vendor ID: 00000000000000000000000011000010 (000000C2)
Flash Device ID: 00000000000000000010001001111110 (0000227E)
*** Found a MX29LV640MT 4Mx16 TopB     (8MB) Flash Chip ***
    - Flash Chip Window Start .... : 1e000000
    - Flash Chip Window Length ... : 00800000
    - Selected Area Start ........ : 00000000
    - Selected Area Length ....... : 00000000
 *** REQUESTED OPERATION IS COMPLETE ***
C:\alice>alice03 -erase:wholeflash
Probe using cmd_type for SST
Probing Flash at (Flash Window: 0x1f800000) ...
Probing Flash at (Flash Window: 0x1fc00000) ...
Probing Flash at (Flash Window: 0x20000000) ... DMA Read Addr = 20000000  Data =
 (00000000)ERROR ON READ
DMA Read Addr = 20000002  Data = (00000000)ERROR ON READ
DMA Read Addr = 20000000  Data = (00000000)ERROR ON READ
Done
*** Unknown or NO Flash Chip Detected ***
Offline nave54
Re:agpf brikkato dopo agg firmware tantativo di recupero con jtag
« Risposta #1 il: 19 Giugno 2014, 20:53 »
Scusami hai un agpf o un altro modem?Consulta questa pagina  https://www.ilpuntotecnico.com/forum/index.php/topic,74233.0.html
Offline genno
  • 17
« Risposta #2 il: 19 Giugno 2014, 23:33 »
Ciao,
Si è un agpf perché è anche VoIP... Sono riuscito a far partire la procedura di flash con wholeflash.bin però è fermo da 3 ore allo stesso punto...è normale ?
Total block to erase: 135
Erasing block: 1 <addr = 1e000000>...
Intanto Grazie per la risposta
Edit:
12 ore sempre fermo così...mi sa che si è bloccato  :-\
Nota: Post unificato per chiarezza
« Ultima modifica: 20 Giugno 2014, 13:57 da Miguel89 »
Offline jlbhfa
  • 590
« Risposta #3 il: 20 Giugno 2014, 15:13 »
8 MB?
Qui non mi è chiaro L'Agpf per lo più monta una Spansion S29GL128P (flash da 16mb).
https://www.ilpuntotecnico.com/wiki/index.php?title=File:Alice_voip_2_0001.JPG
Che versione alice03 hai usato?
Prova con  /fc:xx (dove xx è il numero corrispondente alla flash che monta il tuo router).
basta fare alice03 /? per conoscerlo.
« Ultima modifica: 20 Giugno 2014, 21:28 da jlbhfa »
Offline genno
  • 17
« Risposta #4 il: 22 Giugno 2014, 23:02 »
Ciao, purtroppo non sono più riuscito a connettere i fili data la difficoltà nel saldare le gnd quelle più vicine al modulo Wi Fi.... Avevo anke provato a caricargli solo il cfe ma la procedura si bloccava al primo passo come quella del wholeflash.... A titolo di curiosità questo problema poteva derivare dai cavi un po lunghi dell interfaccia xilinix (20cm) , dal mio computer o cosa ?? Da premettere che ho usato alice 03 debrick bis
Grazie cmq per la risposta
« Risposta #5 il: 22 Giugno 2014, 23:19 »
Di cavi connessi a GND ne basta uno e lo puoi saldare su qualsiasi punto a GND sulla scheda, anche sull'involucro dell'USB (se è metallico)
P.S. Puoi farci delle foto??
Offline genno
  • 17
« Risposta #6 il: 23 Giugno 2014, 23:51 »
Ciao, purtroppo non ho più quel router che è stato reso al proprietario ma adesso sono alle prese con un aga quello con la scheda.... Questo router ogni volta che lo si accende i led si accendono random la LAN non da segni di vita e nemmeno il Wi fi... In queste condizioni si può tentare un ripristino tramite jtag ??
« Risposta #7 il: 24 Giugno 2014, 15:09 »
Molto probabilmente l'alimentatore è andato!
Controllalo con un tester o sostituiscilo con un altro con uguali caratteristiche
Offline genno
  • 17
« Risposta #8 il: 24 Giugno 2014, 16:34 »
gia fatto...ma fa sempre la stessa cosa
« Risposta #9 il: 24 Giugno 2014, 21:00 »
Hai controllato con un tester se fornisce tutti i 15V?? Se non ci sono tutti si comporta in quel modo (si accende ma va in loop)
Offline genno
  • 17
« Risposta #10 il: 28 Giugno 2014, 17:38 »
Si ci sono tutti...ho provato pure il ponticello sulla seriale ma niente e anche con la jtag non rileva nessun dispositivo 😞
Offline jlbhfa
  • 590
« Risposta #11 il: 28 Giugno 2014, 17:58 »
Solito Q3 e rileva le tensioni.
Ma sarebbe opportuno accodarti a qualche problema jtag su Aga oppure aprirne uno nuovo.
Offline logan
  • 305
  • Ing Inf
« Risposta #12 il: 28 Giugno 2014, 18:03 »
Hai costruito bene l'interfaccia jtag?
Se ti serve lo schema corretto fammi sapere che te lo mando
« Ultima modifica: 29 Giugno 2014, 02:51 da Miguel89 »
Offline genno
  • 17
« Risposta #13 il: 29 Giugno 2014, 21:40 »
Rifarò la jtag ma con l agpf aveva funzionato dovevo solo cambiare i pin e l ho fatto... Ma prima che inizi vorrei capire se qualcuno di voi sia riuscito a recuperare un router in queste condizioni cioè non brikkato per firmware errato ma che funzionava normalmente e ad un certo punto inizia a non comunicare più ne via LAN n'è wlan con i led che ogni volta si accendono senza una logica...in queste condizioni la jtag deve funzionare ?? Cmq grazie per le risposte e vorrei sottolineare la completezza e funzionalità di questo  forum dal quale ho potuto costruirmi la jtag con lo schema di roleo se non erro e scaricare i relativi firmware e immagini di questi router 😁
Offline jlbhfa
  • 590
« Risposta #14 il: 30 Giugno 2014, 09:17 »
Con la Jtag hai accesso alla flash, il che ti permette di  cancellarla e riscriverla, ma se il problema non è dovuto al firmware dubito che risolvi.
