how setup alice gate voip 2 plus wifi
  • 34 Risposte
  • 27125 Visite
Offline barribar
  • 17
« il: 04 Aprile 2014, 11:54 »
hi all
I have alice gate voip 2 plus wifi that I want to setup (I have just BRIDGED no ROUTED)
I want to use with my ADSL service and wifi
anyone can help a newbies
thank you
« Ultima modifica: 04 Aprile 2014, 12:09 da barribar »
Offline gabnik
  • 715
Re:how setup alice gate voip 2 plus wifi
« Risposta #1 il: 04 Aprile 2014, 19:30 »
hi all
thank you
Hi, what is your ISP. There are 2 different version of Alice Gate VoIP 2 Plus Wi-Fi.
AGIF= Dial Face Factory
AGPF= Pirelli Factory
so if you have an AGIF you will set this with the serial console
if you have an AGPF you set with the wto pin for the serial.
Offline barribar
  • 17
« Risposta #2 il: 04 Aprile 2014, 20:35 »
thank you for your reply
I downloaded another file DISCUS and now I have Bridged + ROUTED
but I can not connect (see pic)
Can you help me please ?
Offline gabnik
  • 715
« Risposta #3 il: 05 Aprile 2014, 08:01 »
What your ISP (Internet Provider)? The Telegestione is the TR069, Telecom uses this protocol for upgrade the devices. So, you will do not the flag on TR069. The telnet is enable on the router? For the telnet WIN+R and telnet 192.168.1.1 the user and password are admin. Before disable the TR069 you will check that telnet is enable on the router. How do you access to the advacend menu?
Offline barribar
  • 17
« Risposta #4 il: 05 Aprile 2014, 17:15 »
the TR-069 is not  enabled
I can telnet 192.168.1.1 with user and pass (admin)
I can access to the advanced menu with
http://192.168.1.1/admin.html
my ISP is foreigner provider
The problem I can access the network with my pc see pic
but I want that router can access the network without my pc and I can use my wifi
here is my Network Connections
thank you
« Ultima modifica: 05 Aprile 2014, 17:20 da barribar »
Offline gabnik
  • 715
« Risposta #5 il: 05 Aprile 2014, 17:30 »
For enable telnet: download the discus from the router and open it with a text editor (Wordpad, Textedit...) and find this:
(telnets
     (disabled(1))
     (ports
You change it with:
(telnets
     (disabled(0))
     (ports
Upload the new file in the router and wait the reboot
Now the telnet is enabled on the router: WIN+R --> telnet 192.168.1.1
Let's disable TR069C, for do this go to Remote Administration, and do not the flag on TR-069
Now from telnet write this:
conf set /cwmp/enabled 0
conf reconf 1
Your ISP is PPPOE or PPOA?
Offline barribar
  • 17
« Risposta #6 il: 05 Aprile 2014, 17:38 »
(telnets
     (disabled(1))
     (ports
You change it with:
(telnets
     (disabled(0))
     (ports
conf reconf 1
ok for set /cwmp/enabled 0
my ISP is PPPOE
Offline gabnik
  • 715
« Risposta #7 il: 05 Aprile 2014, 17:41 »
my ISP is PPPOE
Ok. You configured the new connection of your ISP in the router?
Offline barribar
  • 17
« Risposta #8 il: 05 Aprile 2014, 17:47 »
yes I think
with quick setup see pic
Offline gabnik
  • 715
« Risposta #9 il: 05 Aprile 2014, 17:53 »
now maintain active the connection: download the discus and find this
(ppp2
      (enabled(0))
change it with:
(ppp2
      (enabled(1))
Offline gabnik
  • 715
« Risposta #10 il: 05 Aprile 2014, 17:55 »
now upload the new discus in the router.
Offline barribar
  • 17
« Risposta #11 il: 05 Aprile 2014, 18:02 »
(ppp2
      (enabled(0))
change it with:
(ppp2
      (enabled(1))
Ok I changed 0 to 1 and I uplaoded into router
but when the router restart I see that PPP2 become 0
(ppp2
      (enabled(0))
      (logical_network(1))
« Ultima modifica: 05 Aprile 2014, 18:06 da barribar »
Offline gabnik
  • 715
« Risposta #12 il: 05 Aprile 2014, 18:25 »
(ppp2
      (enabled(0))
Please post an image of the Connection Wizard
Offline barribar
  • 17
« Risposta #13 il: 05 Aprile 2014, 18:42 »
look here
do I have to change this user and password in Bridged Properties>PPP>Login User Name and Login Password  Like here :
« Ultima modifica: 05 Aprile 2014, 19:27 da barribar »
Offline gabnik
  • 715
« Risposta #14 il: 05 Aprile 2014, 20:35 »
Click Network Connections, all the connections, the maps and post the image please.
