Voip Eutelia su Alice Gate VoIP 2 Plus Wi-Fi
  • 13 Risposte
  • 9321 Visite
Offline caphix
  • 19
« il: 29 Gennaio 2013, 01:02 »
Salve, ho sbloccato un router alice con firmware 4.6.2 attraverso payload.
ho poi inserito i parametri:
Cliccate su "Voice Over IP" e mettete queste impostazioni:
Codice:
Signaling Protocol:             -> SIP
Local SIP Port:                 -> 5060
Use Strict SIP Message Checking -> SI
Enable transparent SIP Mode     -> SI
Enable Server look-up           -> NO
Enable Sip on Interface:        -> vuoto
RTP
Local RTP Port Range - Contiguous Series of 494 Ports Starting From:   -> 5004
Quality of Service
Type Of Service (Hex):                         -> 0xb8
    Use MSS Clamping to Reduce Voice Delay    -> NO
Codecs
Supported Codecs                          Packetization Time (milliseconds)
SI ->   G.729, 8kbps              -> 20
SI ->   G.711, 64kbps, A-Law      -> 20
SI ->   G.711, 64kbps, u-Law      -> 20
NO ->G.723, 5.3/6.3kbps         -> 20
NO ->G.726-32, 32kbps           -> 30
Silence Suppression
Enable Silence Suppression      -> NO
Enable Comfort Noise            -> NO
Echo Cancellation
Enable Echo Cancellation        -> SI
DSP Country
DSP Country:                    -> Italy
34. Ora andate in "Line Settings" dove troverete queste scritte:
Codice:
Line                 User ID                  Display Name           Status
 1                         0000000001          Line1                  Checking Status
35. Cliccate sulla matita che sta accanto alla linea 1 e mettete queste impostazioni:
Codice:
Line Number:            -> 1
User ID:               -> 0968.........(N. Eutelia)
Block Caller ID         -> NO
Display Name:           -> Line 1 Voip Eutelia
Services
Enable Call Waiting                   -> SI
Enable 3-Way Calling                  -> SI
Enable Message Waiting Indication     -> SI
Enable Do Not Disturb                 -> NO
Enable Call Forwarding Always         -> NO
Enable Call Forwarding on Busy        -> NO
Enable Call Forwarding on No Answer   -> NO
SIP Account
Authentication User Name:   -> 0968.........(N. Eutelia)
Authentication Password:      -> ......(Password abbinata al numero Eutelia)
SIP Proxy
Use SIP Proxy                          -> SI
Host Name or Address:                  -> voip.eutelia.it
Port:                                    -> 5060
Register with Proxy                    -> SI
Register Expires:                        -> 3600 seconds
Use Proxy Address as User Agent Domain -> SI
User agent domain                      -> voip.eutelia.it
Outbound Proxy
Use Outbound Proxy           -> SI
Port:                        -> 5060
Fax Transmission
Fax Transmission Method: -> None
Numbering Plan
Minimum Number of Digits:       ->     1
Maximum Number of Digits:       ->    40
Inter-Digit Timer: milliseconds   ->  3000
Prefixes
Prefix Range   Maximum Number of Digits   Facility Action   Action
Cliccando sulla matitina si apre una pagina ove bisogna inserire I seguenti dati:
Prefix Range:                                                      ¬-> *72
Minimum Number of Digits:                               ->     3
Number of Digits to Remove from Beginning:   ->    0
Facility Action:                                              VoIP Call
New Entry
Advanced SIP Settings
DTMF Transmission Method:   -> Out-of-band by Negotiation (RFC2833)
Compatibility Mode:           -> Off
ma se vado in settings di Voice Over IP mi compare    Proxy unreachable.
ho letto tanti topic ma nulla di fatto.
l'unica cosa che non ho fatto è: conf set/voip/line/0/enable1 ecc..
ma se vado nel pannello voce del menu non nascosto mi da:
Numero Telefonico   Stato             Tipo Terminale       Tipo Collegamento
xxxxxxxxxxxxxx   Associato         Analogico            Line 1
e il led è sempre rosso. C'è qualcosa in cui sbaglio? avese un discus.conf funzionante?
Offline catpeople
  • 14
Re:Voip Eutelia su Alice Gate VoIP 2 Plus Wi-Fi
« Risposta #1 il: 29 Gennaio 2013, 02:02 »
Devi sostituire il nome dell` Host (Eutelia) con il suo numero ip ( a memoria dovrebbe essere 62.94.159.69 ma controlla )
Prova e fa sapere, vedrai che risolvi ;)
Offline caphix
  • 19
« Risposta #2 il: 29 Gennaio 2013, 13:45 »
grazie cat, ho inserito 62.94.159.69 nell'host ma nulla di fatto
salvo, poi vado a rivedere nei settings e ricompare   voip.eutelia.it
Volevo spiegare che la mia connesione è questa
                      lan                                   wifi
Tel----->AGPF----->Access Point (Dlink)------->AGPF-->Internet(Telecom)
il software per pc 3CX funziona, riesco a ricevere le telefonate
« Ultima modifica: 29 Gennaio 2013, 13:56 da caphix »
Offline catpeople
  • 14
« Risposta #3 il: 29 Gennaio 2013, 14:23 »
Son certo che funzioni poiche avevo lo stesso problema.
Non ho tuttavia sottomano il router per poter controllare l`indirizzo ip inserito. Ricordo di averlo trovato con Google.
Il nome dell`host nei settings DEVE esser salvato, riprova. Ti succede anche con altre impostazioni?
Nel caso improbabile tu abbia delle difficolta, inseriscilo provvisoriamente da discus.
Prova a pingare poi direttamente dalla voce del menu dedicata del router verso l`ip Eutelia, cosi ti accerti subito del funzionamento.
Se non va, prova un altro indirizzo ip.
« Ultima modifica: 29 Gennaio 2013, 14:33 da catpeople »
Offline caphix
  • 19
« Risposta #4 il: 29 Gennaio 2013, 15:08 »
ho provato anche con 83.211.227.21 ma niente.
scusa, ricordi di che colore si fa il led quando il voip funziona?
a me è sempre rosso.
non hai il file Discus.conf?
Offline catpeople
  • 14
« Risposta #5 il: 30 Gennaio 2013, 18:39 »
Il led vira al verde.
Non ho con me il router, diversamente te lo avrei già inviato il discus.
Vuol dire che semplicemente l`indirizzo IP non è giusto.
Mi ripeto segnati quelli che riesci a trovare e inseriscili volta per volta dove ti ho indicato (non lo ricordo a memoria ma c`è sicuramente una voce che ti permetterà di pingare verso quell`indirizzo ...a memoria "diagnostica").
Parto dal presupposto che tu abbia seguito le guide in merito e abbia quindi abilitato le linee voip, settato correttamente ecc (ovviamente)
Per esserne sicuro vai appunto in diagnostica e pinga il server Eutelia, se ti restituisce non raggiungibile o simili è errato l`indirizzo, non ci son santi
Offline caphix
  • 19
« Risposta #6 il: 30 Gennaio 2013, 19:11 »
grazie mille cat per la tua disponibilità. si i ping si fanno in diagnostica e li ho fatti, per tutti gli indirizzi ip di eutelia. ma non pingano. per sicurezza ho fatto ping anche all'indirizzo ip di google, ma nemmeno questo pinga (8.8.8.8) se però lo pingo da CMD mi da risposta.
allora per quanto riguarda il routerlo sbloccato attraverso payload, poi ho abilitato il telnet e disabilitato la telegestione. poi mi son messo a configurare il voip.
io ho il pc connesso a questo router    PC e Tel----->AGPF----->Access Point (Dlink)------->AGPF-->Internet(Telecom)
e navigo tranquillamente.
Offline toretto_5
  • 1226
« Risposta #7 il: 30 Gennaio 2013, 19:44 »
quanti giri tra router e modem....:D prova sul router collegato alla linea adsl
« Ultima modifica: 30 Gennaio 2013, 19:48 da toretto_5 »
Offline caphix
  • 19
« Risposta #8 il: 30 Gennaio 2013, 20:06 »
Ho un appartamento su 3 livelli :-)
ho provato ma nemmeno il router che si collega a internet pinga gli ip nella sezione diagnostic, allora o disattivato i firwall di entrambi gli AGPF ma niennte ping. però le pagine internet si aprono
Offline toretto_5
  • 1226
« Risposta #9 il: 31 Gennaio 2013, 03:39 »
li hai tutti e 3 sulla stessa subnet 255.255.255.0??? soprattutto gli indirizzi ip dei router sono diversi 192.168.1.x??
Offline caphix
  • 19
« Risposta #10 il: 31 Gennaio 2013, 09:01 »
gli indirizzi ip dei router sono diversi 192.168.1.3 (Internet) e 192.168.1.1
Offline toretto_5
  • 1226
« Risposta #11 il: 01 Febbraio 2013, 12:38 »
e il dlink???? calcola anche che devi aver disabilitato il dhcp al router slave + il dlink e lasciarlo abilitato solo a quello collegato all'adsl
« Ultima modifica: 01 Febbraio 2013, 12:40 da toretto_5 »
Offline caphix
  • 19
« Risposta #12 il: 01 Febbraio 2013, 22:33 »
disattivato anche il dhcp ma nulla ancora: "Proxy unreachable"
Offline piscione75
  • 15
« Risposta #13 il: 27 Marzo 2014, 13:15 »
Salve a tutti..sono nuovo (di registrazione) ma seguo da molto il forum :)
Mi riallaccio al post .. ho un problema simile .. il problema principale è di configurare Eutelia Voip nel Router Alice Gate 2 Plus Wi-fi (dial face) AGIF_1.2.1- premetto che tramite openssl riesco a modificare il file .Kry. (in realtà ne avrei 1 altro Pirelli 4.5.7 che vorrei downloadare)
questa è la mia situazione.. una volta configurato se possibile traferire il Voip attraverso wi-fi in cascata.. cioè:
Internet---->alice gate sbloccato con Voip Eutelia--->AP o Repetear wi-fi -----> router netgate Eutelia ------> Telefono Voip
Questo perchè per ora non ho possibilità di passare cavi. è possibile...??? Consigli???
grazieeeeee
