ALADINO VOIP NEW CORDLESS ETHERNET BY THOMSON
  • 8672 Visite
Offline toretto_5
  • 1226
« il: 04 Dicembre 2012, 22:29 »
Salve a tutti... oggi vi presento il LOG seriale del cordless di ALADINO VOIP NEW in questione che la nostra mamma telecom ha come il suo solito modo di fare, bloccare i suoi FANTASTICI prodotti per impedirne l'uso con altri gestori e compagnie....
è basato su processore BROADCOM 6338KFBG.
redboot non si ferma
a voi il LOG SERIALE:
@AABCB9655432101201234
Non masked hardware version 0xE6 BIPA REV.5 TI
56+678ESA: 00:19:df:48:ec:3a
WEP KEY : FFFFFFFFFFFFFFFFFFFFFFFFFF
EXTERNAL PHY ID : 0x00000000 not defined, switch to Internal PHY mode
INTERNAL PHY ID : 0x00406240 Broadcom 63xx internal PHY, one port mode
Auto-negotiation timed-out
10 MB Half-Duplex (assumed)
Ethernet eth0: MAC address 00:19:df:48:ec:3a
IP: 10.7.58.112, Default server: 0.0.0.0
Hardware version 0x06 BIPA REV.5 TI
Factory Settings Recovery Switch OFF Low (GPIO Register : a4)
RedBoot(tm) bootstrap and debug environment [ROM]
Non-certified release, version rom_release-bipa-ipdect-ti - built 11:40:30, Mar  9 2007
Platform: Blue_5g (MIPS32 4Kc)
Copyright (C) 2000, 2001, 2002, Red Hat, Inc.
RAM: 0x80000000-0x81000000, [0x80434880-0x80fe2000] available
FLASH: 0xbf800000 - 0xc0000000, 128 blocks of 0x00010000 bytes each.
== Executing boot script in 0.200 seconds - enter ^C twice to abort
RedBoot> fis load -b 0x80010000 -m squashfs -r user_2_fs -f Image user_fs
Partition is : 0xbf830000 - 0x360000
mlen : 0x22c034
begin_tag : 0xbfa5c000, end : 0xbfa5c034
Verif OK
Looking for Image in squashfs user_fs partition
Found a valid SQUASHFS superblock on user_fs.
Inodes are compressed
Data is compressed
Fragments are compressed
Check data is not present in the filesystem
Fragments are  present in the filesystem
Always_use_fragments option is not specified
Duplicates are  removed
Filesystem size 2275245 bytes
Block size 65536
Number of fragments 16
Number of inodes 755
Number of uids 1
Number of gids 0
Scanning existing filesystem...
Read existing filesystem, 754 inodes scanned
Return with root_try==0
RedBoot> then exec -c "boot_loader=RedBoot root=1F01 mem=16M" 0x80010000
root_try == 0 : leave boot cmd alone
Now booting linux kernel:
 Base address 0x8000fc00 Entry 0x80010000
 Cmdline : boot_loader=RedBoot root=1F01 mem=16M hwversion="BIPA REV.5-TI (0x06)" redbootversion="rom_release-bipa-ipdect-ti-Mar  9 2007-11:40:30"
Linux version 2.6.12.6 (forguesb@bfo) (gcc version 3.4.2) #1 Tue Jun 26 10:37:53 CEST 2007
C0 config : 2147516544x
CPU revision is: 00029010
Determined physical RAM map:
 memory: 01000000 @ 00000000 (usable)
On node 0 totalpages: 4096
  DMA zone: 4096 pages, LIFO batch:1
  Normal zone: 0 pages, LIFO batch:1
  HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: boot_loader=RedBoot root=1F01 hwversion="BIPA REV.5-TI (0x06)" redbootversion="rom_release-bipa-ipdect-ti-Mar  9 2007-11:40:30"
brcm mips: enabling icache and dcache...
Primary instruction cache 16kB, physically tagged, 2-way, linesize 16 bytes.
Primary data cache 8kB, 2-way, linesize 16 bytes.
Synthesized TLB refill handler (19 instructions).
Synthesized TLB load handler fastpath (31 instructions).
Synthesized TLB store handler fastpath (31 instructions).
Synthesized TLB modify handler fastpath (30 instructions).
PID hash table entries: 128 (order: 7, 2048 bytes)
Using 120.000 MHz high precision timer.
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 13732k/16384k available (1825k kernel code, 2632k reserved, 234k data, 108k init, 0k highmem)
Calibrating delay loop... (HZ=200) 239.20 BogoMIPS (lpj=598016)
Mount-cache hash table entries: 512
Checking for 'wait' instruction...  unavailable.
NET: Registered protocol family 16
Squashfs 2.2 (released 2005/07/03) (C) 2002-2005 Phillip Lougher
devfs: 2004-01-31 Richard Gooch ([email protected])
devfs: boot_options: 0x1
JFFS2 version 2.2. (C) 2001-2003 Red Hat, Inc.
Initializing Cryptographic API
io scheduler noop registered
lo:register_netdevice:2847
PPP generic driver version 2.4.2
NET: Registered protocol family 24
initialize redboot parser
Found: AMD AM29LV640MB BIP
Inventel Blue5G Flash: Found 1 x16 devices at 0x0 in 16-bit bank
number of JEDEC chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
parse_redboot_partitions
Searching for RedBoot partition table in Inventel Blue5G Flash at offset 0x7f0000
6 RedBoot partitions found on MTD device Inventel Blue5G Flash
Creating 6 MTD partitions on "Inventel Blue5G Flash":
0x00000000-0x00030000 : "RedBoot"
0x00030000-0x00390000 : "user_fs"
0x00390000-0x006f0000 : "user_2_fs"
0x006f0000-0x007f0000 : "jffs_system"
0x007f0000-0x007ff000 : "FIS directory"
0x007ff000-0x00800000 : "RedBoot config"
bcm963xx_serial driver v2.0
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
ip_conntrack version 2.1 (128 buckets, 1024 max) - 212 bytes per conntrack
ip_tables: (C) 2000-2002 Netfilter core team
NET: Registered protocol family 17
Ebtables v2.0 registered
NET: Registered protocol family 8
NET: Registered protocol family 20
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 108k freed
init started:  BusyBox v1.1.3 (2007.06.26-08:39+0000) multi-call binary
Starting pid 15, console /dev/tts/0: '/etc_ro_fs/init.d/sysinit'
Algorithmics/MIPS FPU Emulator v1.5
SYSINIT
INVENTEL version : v1.02.26-ipdect-it
Mounting proc filesystem ...
Mounting tmpfs filesystem ...
Reopening /var/tmp/spawn
Reloading /etc/inittab
> NORMAL BOOT <
+ [ -f /etc_ro_fs/autoconf.conf ]
+ . /etc_ro_fs/autoconf.conf
+ CONFIG_TARGET_NAME=IPDECT
+ CONFIG_GENERATION_BIPA=y
+ CONFIG_GATEWAY_RESIDENTIAL=y
+ CONFIG_BCM_VARIANT=6348
+ CONFIG_LINUX_2_6=y
+ CONFIG_LB2_NONE=y
+ CONFIG_RELEASE=y
+ CONFIG_STRIP_LIBS=y
+ CONFIG_DEFAULT_KERNEL_CONFIG_FILE=Config-BIPA
+ CONFIG_DEFAULT_BUSYBOX_CONFIG_FILE=Config-Dev
+ CONFIG_ROOT_SQUASHFS=y
+ CONFIG_ROOT_SPLIT=y
+ CONFIG_RELEASE_BASE_DIR_HOME=y
+ CONFIG_ALTERNATE_CROSSCOMPILE=y
+ CONFIG_GENERATE_PROGKIT=y
+ CONFIG_GENERATE_PROGKIT_PATH=redboot_6338_sdram_128mbit_flash_64mbit_20070309_release_ti
+ CONFIG_GENERATE_WEBUPDATE=y
+ CONFIG_GENERATE_WEBUPDATE_COMPLETEUPGRADECLONE=y
+ CONFIG_GENERATE_WEBUPDATE_PARTIALUPGRADECLONE=y
+ CONFIG_DEFAULT_UPDATE_DIRECTORY=inventel/bipa/ti_ipdect/release
+ CONFIG_DEFAULT_UPDATE_MACHINE=apdg.inventel.com
+ CONFIG_DEFAULT_UPDATE_USERNAME=inventel
+ CONFIG_DEFAULT_UPDATE_PASSWORD=inventel
+ CONFIG_UPDATE_AUTOUPDATE_DELAY=0
+ CONFIG_AUTOUPDATE_NONE=y
+ CONFIG_VERSION_NAME_MAJOR=1.02
+ CONFIG_VERSION_NAME_MINOR_TYPE=.
+ CONFIG_VERSION_NAME_MINOR=26
+ CONFIG_VERSION_NAME_SUFFIX=-ipdect-it
+ CONFIG_BUILD_VERSION=004
+ CONFIG_VERSION_FQN=v1.02.26-ipdect-it
+ CONFIG_SW_VERSION=1.02.26
+ CONFIG_HW_VERSION=4.1
+ CONFIG_INCLUDE_PUBKEY=y
+ CONFIG_PUBKEY_FILENAME=release-ti
+ CONFIG_ADDRESS_192_168=y
+ CONFIG_ADDRESS_IP_0=192.168.1.1
+ CONFIG_ADDRESS_NETMASK_0=255.255.255.0
+ CONFIG_ADDRESS_BROADCAST_0=192.168.1.255
+ ADVANCE_MEMORY_CONFIGURATION=y
+ CONFIG_FLASH_64MBIT=y
+ CONFIG_SDRAM_128MBIT=y
+ CONFIG_FLASH_MAPPING_IPDECT=y
+ CONFIG_PAIRABLE_TIMEOUT=180
+ CONFIG_STACK_BLUEZ=y
+ CONFIG_BT_WATCHDOG=y
+ CONFIG_DECT_HCI=y
+ CONFIG_DECT_BUTTON_PAIRING=y
+ CONFIG_DECT_BUTTON_PAGING=y
+ CONFIG_DECT_BUTTON_TI_IPDECT=y
+ CONFIG_DECT_CHARGE_HYPER_LOADER=y
+ CONFIG_DECT_CHARGE_CONTACT_LOADER=y
+ CONFIG_DECT_CHARGE_CONTACT_UPDATE_DIRECTORY=inventel/dect_handset/ti_ipdect/release
+ CONFIG_DECT_CHARGE_CONTACT_LOADER_UK=y
+ CONFIG_DECT_RAD=y
+ CONFIG_DECT_RAD_UK=y
+ CONFIG_DECT_MMI_TI_UCP=y
+ CONFIG_DECT_SPI=y
+ CONFIG_DECT_VOIP_TI_IPDECT=y
+ CONFIG_BLUEZ_TEST=y
+ CONFIG_DEVGATEWAY=y
+ CONFIG_SUPPORT_TELNETD=y
+ CONFIG_SUPPORT_TELNETD_STDLOGIN=y
+ CONFIG_SUPPORT_TELNETD_WEBSTARTUP=y
+ CONFIG_SUPPORT_NFS_CLIENT=y
+ CONFIG_PROD_TEST_DISABLED=y
+ CONFIG_INCLUDE_ENGLISH_INV=y
+ CONFIG_DEFAULT_ENGLISH_INV=y
+ CONFIG_ADSL_BRIDAGE_NONE=y
+ CONFIG_ADSL_VP=8
+ CONFIG_ADSL_VC=35
+ CONFIG_ADSL_PROTOCOL=pppoe
+ CONFIG_ADSL_ENCAPS=LLCMUX
+ CONFIG_ADSL_MAX_CONNECT_TIME=0
+ CONFIG_BCM_USB_PRODUCT_NAME=Inventel Gateway
+ CONFIG_DISABLE_DHCP=y
+ CONFIG_ENABLE_DHCP_CLIENT=y
+ CONFIG_COUNTRY_FRANCE=y
+ CONFIG_SUPPORT_NO_WIFI_SECURITY=y
+ CONFIG_TI_IPDECT_PASSWORD=y
+ CONFIG_SUPPORT_AXTLS=y
+ CONFIG_WEB=y
+ CONFIG_WEB_LEFT_MENU_STYLE=y
+ CONFIG_WEB_LOGIN=admin
+ CONFIG_WEB_PASSWORD=admin
+ CONFIG_WEB_TI_IPDECT=y
+ CONFIG_UPNP_DEFAULT=y
+ CONFIG_GET_DECT_STATUS=y
+ CONFIG_LED_MANAGER=y
+ CONFIG_VOIP=y
+ CONFIG_VOIP_RADVISION=y
+ CONFIG_VOIP_RADVISION_TELECOM_ITALIA=y
+ CONFIG_VOIP_KRTP_G729A_DYNAMIC_PAYLOAD_TYPE_102=y
+ CONFIG_STUND=y
+ CONFIG_VOIP_SMSIP=y
+ CONFIG_VOIP_RADVISION_WIDEBAND=y
+ CONFIG_TR69=y
+ CONFIG_ACCESS_GATEWAY_DAEMON=y
+ [ ! -f /etc_ro_fs/autoconf.conf ]
+ [ -z y ]
+ cat /proc/mtd
+ + cut -f1 -d:
grep user.*_fs
+ mtdlist=mtd1
mtd2
+ [ -h /dev/root ]
+ ls -al /dev/root
+ sed s/.* -> mtdblock/mtd/
+ mtdroot=mtd1
+ echo mtd1 mtd2
+ sed s/mtd1//
+ mtdlist= mtd2
+ echo mtd2
+ sed s/mtd//
+ mtdlist=2
+ echo 2
2
+ echo Try to mount /dev/mtdblock2 on /usr
+ flash_verify /dev/mtd2 0x29032005
Magic: 29032005
/dev/mtd2: opening...
/dev/mtd2: reading signature...
Signature (48 bytes):
    94 00 03 02 00 14 dc f2 0f aa e4 2a 41 a6 49 e0
    40 b6 f9 f8 45 c2 76 31 b0 02 00 14 61 56 8c 8a
    c7 15 33 69 f5 eb 9f 65 43 d2 b5 a7 11 47 bc 69
/dev/mtd2: hashing...
/dev/mtd2: importing public key...
/dev/mtd2: verifying hash...
/dev/mtd2: verification OK
+ mount -t squashfs /dev/mtdblock2 /usr
+ result=0
+ [ ! 0 -eq 0 ]
+ rm -f /var/run/rescue_boot
+ break
+ [ ! -e /etc/rc.d ]
+ rm -f /tmp/touch.test
+ [ -z y ]
+ false
+ [ 1 = 0 ]
+ [ -n mtd0 ]
+ cat /proc/mtd
dev:    size   erasesize  name
mtd0: 00030000 00010000 "RedBoot"
mtd1: 00360000 00010000 "user_fs"
mtd2: 00360000 00010000 "user_2_fs"
mtd3: 00100000 00010000 "jffs_system"
mtd4: 0000f000 00010000 "FIS directory"
mtd5: 00001000 00010000 "RedBoot config"
+ cat /proc/mtd
+ sed -n s/\(mtd\)\(.*\):\(.\)*/\2/p
+ grep jffs_system
+ mount -t jffs2 -o rw /dev/mtdblock3 /mnt/jffs2/jffs2_3
+ touch /tmp/touch.test
+ [ ! -e /tmp/touch.test ]
+ [ -e /tmp/touch.test ]
+ [ ! -f /mnt/jffs2/jffs2_3/etc/issue ]
+ [ ! -f /mnt/jffs2/jffs2_3/etc/finished ]
+ cat /etc/issue.bluedsl
+ grep version
+ x=INVENTEL version : v1.02.26-ipdect-it
+ cat /etc_ro_fs/issue.bluedsl
+ grep version
+ y=INVENTEL version : v1.02.26-ipdect-it
+ [ INVENTEL version : v1.02.26-ipdect-it = INVENTEL version : v1.02.26-ipdect-it ]
+ echo Up to date version INVENTEL version : v1.02.26-ipdect-it
+ [ -f /usr/etc_ro_fs/init.d/usrboot ]
+ /usr/etc_ro_fs/init.d/usrboot
+ [ ! -f /usr/etc/finished ]
+ cat /usr/etc/issue.bluedsl
+ grep version
+ cat /usr/etc_ro_fs/issue.bluedsl
+ grep version
+ echo /usr up to date version INVENTEL version : v1.02.26-ipdect-it
+ exit 0
+ exit 0
Starting pid 99, console /dev/tts/0: '/etc_ro_fs/init.d/rc.sysinit'
Mounting other filesystems ...
cp: /etc/crontab_root: No such file or directory
+ echo Switching to RUNLEVEL 1 ...
+ runlevel_manage 1
+ local previous
+ runlevel=1
+ [ -f /var/run/runlevel ]
+ previous=N
+ [ 1 = N ]
+ local scriptlist directorylist
+ directorylist=/etc/rc1.d/:/usr/etc/rc1.d/
+ OLDIFS=
+ IFS=:
+ scriptlist=
+ find /etc/rc1.d/ -name K*
+ sed s,/etc/rc1.d/,,
+ scriptlist=
+ find /usr/etc/rc1.d/+ sed s,/usr/etc/rc1.d/,,
 -name K*
+ scriptlist=
+ sort -u
+ scriptlist=
+ echo 1
+ echo 108
+ scriptlist=
+ find /etc/rc1.d/ -name S*
+ scriptlist=S20network
S10adsl
S19pair
S22tr69
S21agc
S01ledmgr
S22backlight
S05hardware
S22http_server
S99printkoff
S25dhcp_dns_server
+ find /usr/etc/rc1.d/ -name S*
+ scriptlist=S19bluez_mod
S28krtp
S85voip
S20mdg
S97rad S20network
S10adsl
S19pair
S22tr69
S21agc
S01ledmgr
S22backlight
S05hardware
S22http_server
S99printkoff
S25dhcp_dns_server
+ echo S19bluez_mod
+ echo S28krtp
+ echo S85voip
+ echo S20mdg
+ sort -u
+ echo S97rad
+ echo S20network
+ echo S10adsl
+ echo S19pair
+ echo S22tr69
+ echo S21agc
+ echo S01ledmgr
+ echo S22backlight
+ echo S05hardware
+ echo S22http_server
+ echo S99printkoff
+ echo S25dhcp_dns_server
+ scriptlist=S01ledmgr
S05hardware
S10adsl
S19bluez_mod
S19pair
S20mdg
S20network
S21agc
S22backlight
S22http_server
S22tr69
S25dhcp_dns_server
S28krtp
S85voip
S97rad
S99printkoff
+ [ -f /etc/rc1.d/S01ledmgr ]
+ realscript=/etc/rc1.d/S01ledmgr
+ [ 1 != N ]
+ number=01ledmgr
+ echo 01ledmgr
+ cut -c 1-2
+ number=01
+ echo 01
+ suffix=ledmgr
+ stop=/etc/rc1.d/K[0-9][0-9]ledmgr
+ echo /etc/rc1.d/
+ sed s,rc1,rcN,
+ previous_start=/etc/rcN.d/S[0-9][0-9]ledmgr
+ [ -f /etc/rcN.d/S[0-9][0-9]ledmgr ]
+ sh /etc/rc1.d/S01ledmgr start
Starting Led Manager Daemon
-II- Led Manager Daemon v1.0
-II- Copyright Thomson Inventel APDG - Paris 2006
+ break
+ [ -f /etc/rc1.d/S05hardware ]
+ realscript=/etc/rc1.d/S05hardware
+ [ 1 != N ]
+ number=05hardware
+ echo 05hardware
+ cut -c 1-2
+ number=05
+ echo 05
+ suffix=hardware
+ stop=/etc/rc1.d/K[0-9][0-9]hardware
+ echo /etc/rc1.d/
+ sed s,rc1,rcN,
+ previous_start=/etc/rcN.d/S[0-9][0-9]hardware
+ [ -f /etc/rcN.d/S[0-9][0-9]hardware ]
+ sh /etc/rc1.d/S05hardware start
Starting core drivers...
watchdog: module license 'unspecified' taints kernel.
Watchdog init Build:  Jun 26 2007  10:40:20
irq register OK
Broadcom BCM6338A2 Ethernet Network Device v0.3 Jun 26 2007 10:37:33
Config Internal PHY Through MDIO
BCM63xx_ENET: Auto-negotiation timed-out
BCM63xx_ENET: 10 MB Half-Duplex (assumed)
eth0:register_netdevice:2847
eth0: MAC Address: 00:07:3A:FF:FF:FF
insmod: bcm_usb.ko: no module by that name found
  Error: Can't start USB.
Switch module creating proc entry
+ break
+ [ -f /etc/rc1.d/S10adsl ]
+ [ -f /usr/etc/rc1.d/S10adsl ]
+ [ -f /etc/rc1.d/S19bluez_mod ]
+ [ -f /usr/etc/rc1.d/S19bluez_mod ]
+ realscript=/usr/etc/rc1.d/S19bluez_mod
+ [ 1 != N ]
+ number=19bluez_mod
+ echo 19bluez_mod
+ cut -c 1-2
+ number=19
+ echo 19
+ suffix=bluez_mod
+ stop=/usr/etc/rc1.d/K[0-9][0-9]bluez_mod
+ echo /usr/etc/rc1.d/
+ sed s,rc1,rcN,
+ previous_start=/usr/etc/rcN.d/S[0-9][0-9]bluez_mod
+ [ -f /usr/etc/rcN.d/S[0-9][0-9]bluez_mod ]
+ sh /usr/etc/rc1.d/S19bluez_mod start
Insmoding bluez modules ...
Bluetooth: Core ver 2.7
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: HCI UART driver ver 2.1
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
+ break
+ [ -f /etc/rc1.d/S19pair ]
+ realscript=/etc/rc1.d/S19pair
+ [ 1 != N ]
+ number=19pair
+ echo 19pair
+ cut -c 1-2
+ number=19
+ echo 19
+ suffix=pair
+ stop=/etc/rc1.d/K[0-9][0-9]pair
+ sed s,rc1,rcN,
+ echo /etc/rc1.d/
+ previous_start=/etc/rcN.d/S[0-9][0-9]pair
+ [ -f /etc/rcN.d/S[0-9][0-9]pair ]
+ sh /etc/rc1.d/S19pair start
Bad run level ...
+ break
+ [ -f /etc/rc1.d/S20mdg ]
+ [ -f /usr/etc/rc1.d/S20mdg ]
Starting pairing manager
+ realscript=/usr/etc/rc1.d/S20mdg
+ [ 1 != N ]
+ number=20mdg
+ echo 20mdg
+ cut -c 1-2
sh: /etc/init.d/backlight: not found
s_backlight : 1
Function cleanup_link_keys
Lancer le mode pairing
pas de hcid_pid
+ number=20
+ echo 20
+ suffix=mdg
+ stop=/usr/etc/rc1.d/K[0-9][0-9]mdg
+ sed s,rc1,rcN,
+ previous_start=/usr/etc/rcN.d/S[0-9][0-9]mdg
+ [ -f /usr/etc/rcN.d/S[0-9][0-9]mdg ]
+ sh /usr/etc/rc1.d/S20mdg start
Starting hciattach now!
rmmod: tty_spi: Success
usage: insmod tty_spi spi_cs=N
CS=0 date: Jun 26 2007 time: 10:40:19, speed 1
MDG Current Eeprom version : 2, expect 2
MDG version: 1186, expect 1186
< HCI Command: ogf 0x3a, ocf 0x010a, plen 1
  06
> HCI Event: 0x0e plen 8
  02 0A E9 12 33 05 00 00
Bad run level ...
pairingd : SIGTERM received
Pairingd stopped
+ break
+ [ -f /etc/rc1.d/S20network ]
+ realscript=/etc/rc1.d/S20network
+ [ 1 != N ]
+ number=20network
+ echo 20network
+ cut -c 1-2
spi vega reset
s_backlight : 1
HCID : 263
+ number=20
+ echo 20
+ suffix=network
+ stop=/etc/rc1.d/K[0-9][0-9]network
+ echo+ sed s,rc1,rcN,
 /etc/rc1.d/
+ previous_start=/etc/rcN.d/S[0-9][0-9]network
+ [ -f /etc/rcN.d/S[0-9][0-9]network ]
+ sh /etc/rc1.d/S20network start
Local network configuration ...
Ethernet network configuration ...
SIOCGIFFLAGS: No such device
SIOCSIFHWADDR: No such device
SIOCSIFADDR: No such device
Hostname configuration : IPDECT-EC3A
br0:register_netdevice:2847
interface usb0 does not exist!
device eth0 entered promiscuous mode
spi vega reset
interface eth1 does not exist!
+ break
+ [ -f /etc/rc1.d/S21agc ]
+ realscript=/etc/rc1.d/S21agc
+ [ 1 != N ]
+ number=21agc
+ echo 21agc
+ cut -c 1-2
+ number=21
+ echo 21
+ suffix=agc
+ stop=/etc/rc1.d/K[0-9][0-9]agc
+ echo /etc/rc1.d/
+ sed s,rc1,rcN,
+ previous_start=/etc/rcN.d/S[0-9][0-9]agc
+ [ -f /etc/rcN.d/S[0-9][0-9]agc ]
+ sh /etc/rc1.d/S21agc start
Starting Access Gateway Client Daemon
Starting pid 454, console /dev/tts/0: '/bin/agcd'
-II- Telecom Italia Access Gateway Client Daemon v1.0
-II- Copyright Thomson Inventel APDG - Beijing 2006
+ break
+ [ -f /etc/rc1.d/S22backlight ]
br0: port 1(eth0) entering learning state
+ [ -f /usr/etc/rc1.d/S22backlight ]
+ [ -f /etc/rc1.d/S22http_server ]
+ realscript=/etc/rc1.d/S22http_server
+ [ 1 != N ]
+ number=22http_server
+ echo 22http_server
+ cut -c 1-2
+ number=22
+ echo 22
+ suffix=http_server
+ stop=/etc/rc1.d/K[0-9][0-9]http_server
+ echo /etc/rc1.d/
+ sed s,rc1,rcN,
+ previous_start=/etc/rcN.d/S[0-9][0-9]http_server
+ [ -f /etc/rcN.d/S[0-9][0-9]http_server ]
+ sh /etc/rc1.d/S22http_server start
Websrv start ...
+ break
+ [ -f /etc/rc1.d/S22tr69 ]
+ realscript=/etc/rc1.d/S22tr69
+ [ 1 != N ]
+ number=22tr69
+ echo 22tr69
+ cut -c 1-2
+ number=22
+ echo 22
+ suffix=tr69
+ stop=/etc/rc1.d/K[0-9][0-9]tr69
+ echo /etc/rc1.d/
+ sed s,rc1,rcN,
+ previous_start=/etc/rcN.d/S[0-9][0-9]tr69
+ [ -f /etc/rcN.d/S[0-9][0-9]tr69 ]
+ sh /etc/rc1.d/S22tr69 start
br0: topology change detected, propagating
br0: port 1(eth0) entering forwarding state
Starting TR69 Daemon
spi vega reset
(INFO) Telecom Italia TR69 Daemon v1.0
(INFO) Copyright Thomson Inventel APDG - Beijing 2006
+ break
+ [ -f /etc/rc1.d/S25dhcp_dns_server ]
+ realscript=/etc/rc1.d/S25dhcp_dns_server
+ [ 1 != N ]
+ number=25dhcp_dns_server
+ echo 25dhcp_dns_server
+ cut -c 1-2
+ number=25
+ echo 25
+ suffix=dhcp_dns_server
+ stop=/etc/rc1.d/K[0-9][0-9]dhcp_dns_server
+ echo /etc/rc1.d/
+ sed s,rc1,rcN,
+ previous_start=/etc/rcN.d/S[0-9][0-9]dhcp_dns_server
+ [ -f /etc/rcN.d/S[0-9][0-9]dhcp_dns_server ]
+ sh /etc/rc1.d/S25dhcp_dns_server start
dnsmasq not configured as dhcp server
dnsmasq start ( DNS / DHCP server ) ...
+ break
+ [ -f /etc/rc1.d/S28krtp ]
+ [ -f /usr/etc/rc1.d/S28krtp ]
+ realscript=/usr/etc/rc1.d/S28krtp
+ [ 1 != N ]
+ number=28krtp
+ cut -c 1-2
+ echo 28krtp
+ number=28
+ echo 28
+ suffix=krtp
+ stop=/usr/etc/rc1.d/K[0-9][0-9]krtp
+ sed s,rc1,rcN,
+ previous_start=/usr/etc/rcN.d/S[0-9][0-9]krtp
+ [ -f /usr/etc/rcN.d/S[0-9][0-9]krtp ]
+ sh /usr/etc/rc1.d/S28krtp start
krtp start ...
krtp ver 2.8 softdsp-vad-multiline-wb (Jun 26 2007 10:38:24)
Copyright (C) 2004 Inventel Systemes
Written 2004 by David Libault <[email protected]>
Written 2004 by Bruce Forgues <[email protected]>
Written 2004 by Eric Humbert  <[email protected]>
+ break
+ [ -f /etc/rc1.d/S85voip ]
+ [ -f /usr/etc/rc1.d/S85voip ]
+ realscript=/usr/etc/rc1.d/S85voip
+ [ 1 != N ]
+ number=85voip
+ echo 85voip
+ cut -c 1-2
+ number=85
+ echo 85
+ suffix=voip
+ stop=/usr/etc/rc1.d/K[0-9][0-9]voip
+ sed s,rc1,rcN,
+ previous_start=/usr/etc/rcN.d/S[0-9][0-9]voip
+ [ -f /usr/etc/rcN.d/S[0-9][0-9]voip ]
+ sh /usr/etc/rc1.d/S85voip start
spi vega reset
spi vega reset
voip start...
agcdctl: voip_up success
+ break
+ [ -f /etc/rc1.d/S97rad ]
+ [ -f /usr/etc/rc1.d/S97rad ]
+ realscript=/usr/etc/rc1.d/S97rad
+ [ 1 != N ]
+ number=97rad
+ echo 97rad+ cut -c 1-2
+ number=97
+ echo 97
+ suffix=rad
+ stop=/usr/etc/rc1.d/K[0-9][0-9]rad
+ sed s,rc1,rcN,
+ previous_start=/usr/etc/rcN.d/S[0-9][0-9]rad
+ [ -f /usr/etc/rcN.d/S[0-9][0-9]rad ]
+ sh /usr/etc/rc1.d/S97rad start
Bluetooth: L2CAP ver 2.7
Bluetooth: L2CAP socket layer initialized
+ break
+ [ -f /etc/rc1.d/S99printkoff ]
+ realscript=/etc/rc1.d/S99printkoff
+ [ 1 != N ]
+ number=99printkoff
+ echo 99printkoff
+ cut -c 1-2
+ number=99
+ echo 99
+ suffix=printkoff
+ stop=/etc/rc1.d/K[0-9][0-9]printkoff
+ echo /etc/rc1.d/
+ sed s,rc1,rcN,
+ previous_start=/etc/rcN.d/S[0-9][0-9]printkoff
+ [ -f /etc/rcN.d/S[0-9][0-9]printkoff ]
+ sh /etc/rc1.d/S99printkoff start
Setting printk off
+ break
+ rm -f /var/run/rc.pid
+ rm -f /var/run/runlevel_in_progress
+ rm -f /var/run/init_in_progress_stage
+ echo 1
ledmgrdctl: boot_done success
« Ultima modifica: 04 Luglio 2013, 14:35 da Miguel89 »
Offline toretto_5
  • 1226
Re:ALADINO VOIP NEW CORDLESS ETHERNET BY THOMSON
« Risposta #1 il: 04 Dicembre 2012, 22:50 »
hit '
' (0x0A)
== Executing boot script in 0.190 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.180 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.170 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.160 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.150 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.140 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.130 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.120 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.110 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.100 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.090 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.080 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.070 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.060 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.050 seconds - enter ^C twice to abort
hit '
' (0x0A)
== Executing boot script in 0.040 seconds - enter ^C twice to abort
mlen : 0x22c034
Verif OK
Data is compressed
Block size 65536
Number of uids 1
Number of gids 0
Built 1 zonelists
SYSINIT
Starting pid 21, console /dev/tts/0: '/etc_ro_fs/init.d/rc.sysinit'
mount: Cannot read /etc/fstab: No such file or directory
Please press Enter to activate this console.
Starting pid 27, console /dev/tts/0: '/bin/login'
(none) login: aladino
Password:
Login incorrect
(none) login: admin
Password:
Login incorrect
(none) login:
la console la attivo bloccando il boot premendo CTRL+C ora
quali sono use e password dato che aladino aladino, admin admin li ho provati e non funzionano ???
« Ultima modifica: 04 Luglio 2013, 14:37 da Miguel89 »
Offline sten73
« Risposta #2 il: 04 Luglio 2013, 14:29 »
Analizzando il boot log direi di provare con inventel. Prova anche root come username.
Se nel frattempo qualcuno è riuscito a sbloccarlo si faccia avanti  ;D
Sten
Offline toretto_5
  • 1226
« Risposta #3 il: 30 Aprile 2014, 17:32 »
Sten
ho provato qualsiasi user e passw......inventel, root, admin, administrator, Administrator, alice, voip, telecomitalia.....nulla di nulla. ho provato anche a variare la velocità della porta per vedere se era quello il problema ma nulla
