DSL-300T Problema Status dopo Firmware 1.2.5
  • 44 Risposte
  • 18024 Visite
Offline Eva01
  • 16
Re: DSL-300T Problema Status dopo Firmware 1.2.5
« Risposta #30 il: 07 Marzo 2006, 20:24 »
ciao a tutti ^___^
ciao piefav... allora:
siccome non siuscivo tramite telnet l'ho copiati da ciclamab.... va bene ?
se si eccoli qua:
Questo è l'env che ho dopo aver aggiornato al firm di submax:
Adam2_Release  9 2005
autoload  1
autoload_timeout  5
azcpmac_config  1
bootloaderVersion  0.22.02
bootserport  tty0
connection0  0x4715
cpufrequency  150000000
firstfreeaddress  0x9401d888
flashsize  0x00200000
HWRevision  Unknown
maca  00:13:46:7B:AC:85
memsize  0x00800000
modetty0  38400,n,8,1,hw
modetty1  38400,n,8,1,hw
modulation  MMODE
mtd0  0x900a0000,0x901f0000
mtd1  0x90010000,0x900a0000
mtd2  0x90000000,0x90010000
mtd3  0x901f0000,0x90200000
my_ipaddress  192.168.1.1
pppoe_dmac  0:0:0:0:0:0
pppoe_sid  0
ProductID  AR7DB
prompt  Adam2_AR7DB
req_fullrate_freq  125000000
SerialNumber  none
StaticBuffer  120
sysfrequency  125000000
usb_board_mac  00:0D:88:99:99:9A
usb_man  N/A
usb_pid  0x0
usb_prod  N/A
usb_rndis_mac  00:0D:88:99:99:9B
usb_serial  00:0D:88:99:99:9A
usb_vid  0x0
vcc_encaps0  0.0
vcc_encaps1  0.0
vcc_encaps2  0.0
vcc_encaps3  0.0
vcc_encaps4  0.0
vcc_encaps5  0.0
vcc_encaps6  0.0
vcc_encaps7  0.0
Questo è l'env dopo averlo riportato al firm originale:
autoload  1
autoload_timeout  5
azcpmac_config  1
bootserport  tty0
connection0  0x5416
HWRevision  Unknown
memsize  0x00800000
modulation  MMODE
mtd0  0x90087000,0x901f0000
mtd1  0x90010000,0x90087000
pppoe_sid  0
ProductID  AR7DB
prompt  Adam2_AR7DB
SerialNumber  none
StaticBuffer  120
usb_man  N/A
usb_pid  0x0
usb_prod  N/A
usb_vid  0x0
vcc_encaps0  0.0
vcc_encaps1  0.0
vcc_encaps2  0.0
vcc_encaps3  0.0
vcc_encaps4  0.0
vcc_encaps5  0.0
vcc_encaps6  0.0
vcc_encaps7  0.0
Ecco.... anche stasera ho riprobato...nulla..... solo il torrent va sempre... tutto il resto nada de nada...
Offline piefav
  • 37
« Risposta #31 il: 07 Marzo 2006, 22:29 »
vcc_encaps0  0.0
vcc_encaps1  0.0
vcc_encaps2  0.0
vcc_encaps3  0.0
vcc_encaps4  0.0
vcc_encaps5  0.0
vcc_encaps6  0.0
vcc_encaps7  0.0
questo io non lo trovo nel mio (io uso la 1.2.5 di osvi) però se non ho capito male (dalle partizioni) tu hai messo quello di submax e potrebbe avere questi valori in + vediamo se fa un giro lui e sentiamo cosa dice.
Piefav
Offline Eva01
  • 16
« Risposta #32 il: 07 Marzo 2006, 22:36 »
ok vediamo che dice..... speriamo bene  :)
io osvi cmq nelle mie centinaia di riflashamenti ho provato a mettere....ma se non erro è quello dove devo schiacciare il reset, far parite il recovery tool no ? quello nn riuscivo a farlo partire.... si vede che sbaglio nel metodo iniziale...
cmq aspeto sub...ormai ho fatto 30...facciamo 31 :)
grazie piefav per l'aiuto
Offline piefav
  • 37
« Risposta #33 il: 07 Marzo 2006, 22:51 »
no no lo carichi sempre con ciclamab
Qui trovi tutto comprese le guide passo a passo
http://dlinkpedia.net/index.php/Dlinkpedia
PieFav
Offline Eva01
  • 16
« Risposta #34 il: 07 Marzo 2006, 23:47 »
scusate domanda che mi hanno fattto un amico online...ma sto modem regge la adsl2 ???
non intendo il protocollo PPPoE ma proprio la adsl2
sulla scatola e suil manuale non ci sta scritto.... ne sapete qualcosa voi ?
Offline Eva01
  • 16
« Risposta #35 il: 07 Marzo 2006, 23:59 »
aspettate aspettate...ma regge la adsl2 sto modem ???
non sara mica per sta cosa eh ??? sul manula e esulle caratteristiche in iternet nn ne parla di adsl 2.....
cosa che i modem adsl 2 specificano ......
sta a vedere che si spegne perche nn regge la adsl2 ?
« Risposta #36 il: 08 Marzo 2006, 00:41 »
Non sono Submax, ma in qualita' di beta tester del suo firmware vi posso assicurare che l'ho usato piu' dello stesso autore  ;) e confermo che quelle variabili, e non solo quelle, sono state introdotte dal firmware di Sub. Tutti i firmware ADSL2+, anche quello ufficiale D-link, introducono  quelle variabili. Anche cancellandole ricompaiono (ovviamente se non si cambia firmware), e' il filesystem che le riscrive.
Si che la regge, basta mettere il firmware aggiornato ADSL2+
Offline piefav
  • 37
« Risposta #37 il: 08 Marzo 2006, 00:48 »
preso da
http://dlinkpedia.net/index.php/FAQ
Davvero supporta l'ADSL2?
MCMCC ha sostituito il driver ATM, rendendolo compatibile con le future ADSL. Quindi il downstream arriva potenzialmente fino a 12 Mbps e 1 Mbps in upstream. Direi d'obbligo per la nuova offerta Wind! Gli standard supportati sono... per ora... adsl/adsl2 ma NON adsl2+.
PieFav
@marven
stavo scrivendo mentre postavi e non avevo letto il tuo ultimo post, quindi quello di submax che non ho mai provato regge anche ADSL2+ Bene!!!!
« Ultima modifica: 08 Marzo 2006, 00:54 da piefav »
« Risposta #38 il: 08 Marzo 2006, 01:00 »
@piefav
Si quella faq e' verissima pero' riguarda solo il  il firmware per 30xt di McMcc (ormai da tempo non piu' supportato) e i firmware da esso derivati come quello di Osvi.
« Risposta #39 il: 08 Marzo 2006, 18:37 »
marven ha ragione.... scusate ma ho avuto dei problemi con l'adsl ... ho visto solo ora ;)
Offline Eva01
  • 16
« Risposta #40 il: 08 Marzo 2006, 20:06 »
ciaoa tutti  :)
oggi ho notato un firm nuovo sul sito ufficiale della dlink italia... pare che queto firm supporti la adsl2+.
adesso ho installato sto firm per vedere se va anche perche purtroppo il firm di sub non riesco a farlo andare... solo il torrent va tutto il resto no....
Vi faro' sapere se è un firm valido..anche perche se non lo è giuro che lo brucio sto modem  >:(
Sub non so che dirti io si vede che sono troppo scemo e nn capisco come settare il tuo....
Il negoziante parla di linea che si intasa, su internet del modem e io nel mezzo nn ci capisco piu nulla....
vi faro sapere nuove news :)
Per chi interessa.... il link al firm che sto utilizzando e di cui parlavo prima è:
http://www.dlink.it/?go=jN7uAYLx/oIJaWVTALoZU9f8nJUIKOZXSsy3PeKkxQHnXYlpxu5vbMYiOadt6itsRWm5kCJP/Y4YB9vg3aPpLUkXtA==
« Risposta #41 il: 08 Marzo 2006, 21:52 »
lo sò dovevi settare i dns .... nel mio firmware.... altrimenti la versione attuale non và bene...
Offline Eva01
  • 16
« Risposta #42 il: 09 Marzo 2006, 12:16 »
Ciao a tutti :)
Ok manco col firm ufficiale nuovo va nulla... stesso problema  :'(
Settare i DSN..... uhm... e come si fa ?
Offline Eva01
  • 16
« Risposta #43 il: 09 Marzo 2006, 12:40 »
Errata corrige... non tanto come, piu che altro che mettere.....  ;D
« Risposta #44 il: 09 Marzo 2006, 22:35 »
si chiamano DNS. per sapere quali sono devi chiedere al tuo isp......
