  • 4741 Risposte
  • 2612309 Visite
Offline Whabek
  • 21
« Risposta #4410 il: 29 Agosto 2021, 16:42 »
Allora esattamente come dici, tutte quelle linee in errore corrispondono a linee vuote.
Le estensioni dei file sono corrette, niente txt o simili.
Visto che però sh  /tmp/run/mountd/sda/setup/voip/tiscali.sh è l'unico comando che non riesce a prendere, ho pensato di digitarlo io direttamente e colpo di scena, lo ha preso!
Di questi linguaggi però non ne capisco niente...
root@dsldevice:~# sh  /tmp/run/mountd/sda/setup/voip/tiscali.sh
root@dsldevice:~# no process in pidfile '/var/run/led-fw-interface.lua.pid' found; none killed
pid 13543's current scheduling policy: SCHED_OTHER
pid 13543's current scheduling priority: 0
pid 13543's new scheduling policy: SCHED_RR
pid 13543's new scheduling priority: 75
pid 13544's current scheduling policy: SCHED_OTHER
pid 13544's current scheduling priority: 0
pid 13544's new scheduling policy: SCHED_RR
pid 13544's new scheduling priority: 75
pid 13545's current scheduling policy: SCHED_OTHER
pid 13545's current scheduling priority: 0
pid 13545's new scheduling policy: SCHED_RR
pid 13545's new scheduling priority: 75
pid 13554's current scheduling policy: SCHED_OTHER
pid 13554's current scheduling priority: 0
pid 13554's new scheduling policy: SCHED_RR
pid 13554's new scheduling priority: 75
pid 13538's current affinity mask: 3
pid 13538's new affinity mask: 2
pid 13543's current affinity mask: 3
pid 13543's new affinity mask: 2
pid 13544's current affinity mask: 3
pid 13544's new affinity mask: 2
pid 13545's current affinity mask: 3
pid 13545's new affinity mask: 2
pid 13554's current affinity mask: 3
pid 13554's new affinity mask: 2
pid 13782's current affinity mask: 3
pid 13782's new affinity mask: 2
pid 13784's current affinity mask: 3
pid 13784's new affinity mask: 2
pid 13785's current affinity mask: 3
pid 13785's new affinity mask: 2
pid 13786's current affinity mask: 3
pid 13786's new affinity mask: 2
pid 13805's current affinity mask: 3
pid 13805's new affinity mask: 2
pid 13806's current affinity mask: 3
pid 13806's new affinity mask: 2
pid 13538's current scheduling policy: SCHED_OTHER
pid 13538's current scheduling priority: 0
pid 13538's new scheduling policy: SCHED_FIFO
pid 13538's new scheduling priority: 99
vedi per caso altri errori?
« Ultima modifica: 29 Agosto 2021, 20:16 da MisterFTTH »
« Risposta #4411 il: 29 Agosto 2021, 17:43 »
No, sono i messaggi dovuti al comando
/etc/init.d/mmpbxd restart
Offline Andreyo
  • 19
« Risposta #4412 il: 06 Settembre 2021, 11:26 »
Salve a tutti, spero di non porre l’ennesima domanda duplicata, ma leggersi quasi 300 pagine di topic è impensabile.
Il mio technicolor con gui ansuel ha fatto sempre il suo egregio lavoro. Ma, essendo passato ora alla gigabit di of, é diventato superfluo è obsoleto (quest’ultimo lo era già in realtà).
Ora vorrei trovargli altra destinazione, ma OpenWRT 15 in alcuni casi è una palla al piede. So che aggiornando (e la mia domanda è se questo è possibile) andrei a perdere molti driver che Broadcom non rende disponibili al pubblico, ma, nello specifico, cosa andrei a perdere? Ciò che serve a me è bene o male tutto tranne la parte xDSL, posso anche fare a meno della WiFi, anche se una possibile destinazione d’uso è proprio quella di access point.
Tutto questo ovviamente si rifà alla possibilità o meno di compilare una build installabile, dato che nei repo di openwrt non esiste una release già pronta.
« Risposta #4413 il: 06 Settembre 2021, 12:21 »
Openwrt non supporta il tg789. Non vedo altre vie. E' vecchio ed obsoleto ma molto meno di molti router che alcuni ISP spacciano per aggiornati (kernel 2.6 con firmware derivato da AA dentro).
Offline Andreyo
  • 19
« Risposta #4414 il: 06 Settembre 2021, 14:01 »
Su questo non avevo alcun dubbio, ma OpenWRT può essere compilato per qualsiasi piattaforma, a patto di reperire i driver giusti. Sul loro sito c'è una distro linux che permette proprio di fare una build personalizzata.
« Risposta #4415 il: 06 Settembre 2021, 14:39 »
Il problema è trovare un bootloader sbloccato che vada bene per questo router e sostituirlo. Poi "tutto" si fa. I driver se usi openwrt sono quelli FOSS. Altrimenti devi usa una toolchain sviluppata dai venditori di hardware che alla fine della giostra generi un'immagine da caricare sul bootloader che lo accetti come buona.
Oppure ti costruisci tutto da solo.
Offline Andreyo
  • 19
« Risposta #4416 il: 06 Settembre 2021, 20:18 »
Dunque, in poche, se nessuno ci ha provato, un motivo valido c'è.
Peccato perché ha comunque una dotazione hw ancora passabile, come ap potrebbe andar bene.
Colgo l'occasione per togliermi un dubbio, da LuCi, è normale che nella sezione wifi ho entrambe le interfacce riportate come disattivate? Non posso fare scan, cambiare alcun parametro da gui (ho dovuto impostare tutto da /etc/wireless).
« Risposta #4417 il: 06 Settembre 2021, 20:35 »
Luci non gestisce il driver wifi, switch, dsl.
Offline Andreyo
  • 19
« Risposta #4418 il: 06 Settembre 2021, 21:04 »
Ottimo, quindi non sbagliavo nulla. Ti ringrazio per la delucidazione.
Offline Whabek
  • 21
« Risposta #4419 il: 07 Settembre 2021, 20:14 »
Software Uno installato e configurato correttamente e senza GUI (incluso voip) per linea FTTC Tiscali ma non si connette a internet;
c'è per caso un wizard per la connessione?
Nel menu "Accesso a internet" non è possibile inserire alcun dato a parte nome utente e password e rimane così: https://prnt.sc/1ri59ca
Qualche anima gentile mi potrebbe dare una mano? Anche in privato se preferite, grazie
« Risposta #4420 il: 07 Settembre 2021, 20:50 »
Offline Whabek
  • 21
« Risposta #4421 il: 08 Settembre 2021, 19:55 »
Vai in gateway e scorri in basso trovi la voce setup  qualche cosa del genere:
https://my.gradwell.com/s/article/how-to-setup-a-technicolor-tg588v-router-for-use-with-gradwell-adsl-broadband-services
Da me nel menu gateway non ci sono tutte quelle cose. Neanche il tasto per le opzioni avanzate. È normale?
https://prnt.sc/1rl2wgi
Offline lorenzocanalelc
  • 678
« Risposta #4423 il: 08 Settembre 2021, 22:38 »
@Whabek Devi prima effettuare il login premendo sign in in alto a destra nella pagina principale
Offline Jackdispade
  • 20
« Risposta #4424 il: 11 Settembre 2021, 00:50 »
Buonasera, penso di avere briccato questo modem. Dopo un riavvio resta led fisso arancione. Non riesco a flashare un nuovo firmware con ftpd, il modem non comunica assolutamente col programma anche se appare connesso al pc. Non riesco nemmeno a fare il fail boot, non becco i timing giusti presumo. Aiuto?
