Alice Gate VoIP 2 Plus Wi-FI non monta disco USB
  • 6 Risposte
  • 6857 Visite
Offline JoeAdsl
  • 11
« il: 14 Marzo 2009, 17:40 »
ho il router in oggetto inviatomi da Telecom con il contratto "Alice tutto incluso".
Premetto che funziona tutto a meraviglia, compresa la porta USB master senza fare nessun hack al firmware.
Il problema è che non monta un disco esterno da 250 GB USB, mentre le chiavette USB (sia da 2GB che da 8GB) le monta tranquillamente in automatico.
Ecco il log con l'errore (da leggere al contrario):
Mar 14 15:45:12 2009 System Log Message daemon.warn sys_if_ioctl_mii_execute:508: Both tried MII ioclts 8947/89F0 failed: Operation not supported.
 [repeated 8 times, last time on Mar 14 15:48:22 2009]
Mar 14 15:45:04 2009 System Log Message kern.warn [50944.945] end_request: I/O error, dev sdc, sector 0
Mar 14 15:45:04 2009 System Log Message kern.info [50944.940] sd 13:0:0:0: SCSI error: return code = 0x10070000
Mar 14 15:45:04 2009 System Log Message kern.info [50943.905] sd 13:0:0:0: SCSI error: return code = 0x10070000
Mar 14 15:45:02 2009 System Log Message kern.debug [50942.780] usb-storage: device scan complete
Mar 14 15:45:02 2009 System Log Message kern.notice [50942.735] sd 13:0:0:0: Attached scsi disk sdc
Mar 14 15:45:02 2009 System Log Message kern.warn [50942.735] unable to read partition table
Mar 14 15:45:02 2009 System Log Message kern.err [50942.725] Buffer I/O error on device sdc, logical block 0
Mar 14 15:45:02 2009 System Log Message kern.warn [50942.720] end_request: I/O error, dev sdc, sector 0
Mar 14 15:45:02 2009 System Log Message kern.info [50942.715] sd 13:0:0:0: SCSI error: return code = 0x10070000
Mar 14 15:45:02 2009 System Log Message kern.err [50942.660] Buffer I/O error on device sdc, logical block 0
Mar 14 15:45:02 2009 System Log Message kern.warn [50942.660] printk: 1 messages suppressed.
Mar 14 15:45:02 2009 System Log Message kern.warn [50942.655] end_request: I/O error, dev sdc, sector 0
Mar 14 15:45:02 2009 System Log Message kern.info [50942.550] sdc:<6>sd 13:0:0:0: SCSI error: return code = 0x10070000
Mar 14 15:45:02 2009 System Log Message kern.err [50942.545] sdc: assuming drive cache: write through
Mar 14 15:45:02 2009 System Log Message kern.debug [50942.545] sdc: Mode Sense: 03 00 00 00
Mar 14 15:45:02 2009 System Log Message kern.notice [50942.540] sdc: Write Protect is off
Mar 14 15:45:02 2009 System Log Message kern.notice [50942.530] SCSI device sdc: 490234752 512-byte hdwr sectors (251000 MB)
Mar 14 15:45:02 2009 System Log Message kern.err [50942.505] sdc: assuming drive cache: write through
Mar 14 15:45:02 2009 System Log Message kern.debug [50942.505] sdc: Mode Sense: 03 00 00 00
Mar 14 15:45:02 2009 System Log Message kern.notice [50942.500] sdc: Write Protect is off
Mar 14 15:45:02 2009 System Log Message kern.notice [50942.490] SCSI device sdc: 490234752 512-byte hdwr sectors (251000 MB)
Mar 14 15:45:02 2009 System Log Message kern.notice [50942.470] Type: Direct-Access ANSI SCSI revision: 00
Mar 14 15:45:02 2009 System Log Message kern.notice [50942.465] Vendor: Maxtor 7 Model: Y250P0 Rev: 0 0
Mar 14 15:45:01 2009 System Log Message daemon.info mt_disk_mng_hotplug_notify:626: usb-block (1): dev_name(/block/sdc)
Mar 14 15:44:57 2009 System Log Message kern.debug [50937.460] usb-storage: waiting for device to settle before scanning
Mar 14 15:44:57 2009 System Log Message kern.debug [50937.460] usb-storage: device found at 23
Mar 14 15:44:57 2009 System Log Message kern.info [50937.385] scsi13 : SCSI emulation for USB Mass Storage devices;SERIAL=??????????
Mar 14 15:44:57 2009 System Log Message kern.info [50937.300] usb 2-1.1: configuration #1 chosen from 1 choice
Mar 14 15:44:57 2009 System Log Message kern.info [50937.280] usb 2-1.1: not running at top speed; connect to a high speed hub
Mar 14 15:44:57 2009 System Log Message kern.info [50937.040] usb 2-1.1: new full speed USB device using ohci_hcd and address 23
Queste invece le info del router:
Nome:  Alice Gate VoIP
Versione hardware:  S1
Versione globale:  AGPF_4.3.5
Versione boot loader:  cfe-AGPF-10-0007
Versione kernel:  2.6
Versione drv ADSL:  A2pB021.d17i
Versione drv Wi-Fi:  4.150.10.5.cpe2.0
Mentre il disco è un Maxtor Y250P0 in un contenitore esterno USB della Hamlet mod. HXD3PU2_VN2
Naturalmente si sotto Wundows che Ubuntu il disco funziona, ho provato anche a formattarlo  FAT32, EXT2 e EXT3.
Qualche idea?
Offline filippo125
  • 37
Re:Alice Gate VoIP 2 Plus Wi-FI non monta disco USB
« Risposta #1 il: 15 Marzo 2009, 18:33 »
se ti è utile non è un problema di capacità del disco perchè il mio hd della lacie da 320gb lo carica senza problemi....forse non c'entra niente prova a collegarlo a windows e poi fare rimozione guidata....
Offline JoeAdsl
  • 11
« Risposta #2 il: 16 Marzo 2009, 00:49 »
Già fatto...l'ho pure formatto NTFS e smontato come da procedura...niente...non ne vuole sapere....è come se l'hardware del box non è compatibile. >:(
Offline Zibri
  • 1327
    • Zibri's Blog
« Risposta #3 il: 16 Marzo 2009, 12:54 »
joe: potrebbe anche essere un problema elettrico.
il mio usb<>ide esce con un doppio usb (uno dei due lo usa solo per prendere l'alimentazione da un'altra porta usb)...
nel 90% dei casi ne ho sempre collegata solo una, ma su certi portatili le devo collegare tutte e due.
Offline JoeAdsl
  • 11
« Risposta #4 il: 16 Marzo 2009, 13:23 »
E' un disco esterno da 3.5" con alimentatore, quindi non ha il doppio cavo USB.
Ho controllato sul sito del produttore su http://www.hamletcom.com/ProductDetails.aspx?sid=ca0531e5c29740b8aa58b50133727e4b&ProductId=3622  e risulta compatibile con il kernel 2.4.18 o superiore   ....  su ubuntu 8.10 funziona benissimo...
Offline brucox
« Risposta #5 il: 30 Marzo 2009, 07:54 »
ciao a tutti sempre riguado al modem  alice voip...da me il disco da 320  va perfettamente ,e riesco anche a condividerlo nella rete localeil problema mi sorge se  cerco di vederlo dall'esterno tramite  internet qualcuno sa come fare  ..il sistema operativo e xp pro
Offline Zibri
  • 1327
    • Zibri's Blog
« Risposta #6 il: 30 Marzo 2009, 16:01 »
JoeAdsl: non so che dirti... questi non sono kernel completi ma molto custom..
magari si sono scordati qualche driver.
Prova cosi': da Linux fai dd if=/dev/zero of=/dev/[DEVICE DELL'HD] e lascialo andare..
Poi formattalo da interfaccia Pirelli.
