Disconnessioni serali.. ALICE Vela Beghiero firmware
  • 0 Risposte
  • 3961 Visite
Offline nottolotto
  • 12
« il: 09 Ottobre 2008, 23:31 »
Salve ho in questo periodo una serie di cadute linea e riconnessione ogni 5 / 10 minuti.. a volte anche durante il giorno e a volte va bene per delle ore.. ho un amico tecnico in telecom ma come posso settare il logger del router per evidenziare gli errori ??
Ho il favoloso firmware di Beghiero 3.04L.01.-080110_2315
Date/Time     Facility     Severity     Message
Oct 10 01:07:22    daemon    critical    pppd[577]: Received valid IP address from server. Connection UP.
Oct 10 01:07:22    daemon    critical    pppd[577]: PPP LCP UP.
Oct 10 01:07:13    user    critical    kernel: ADSL link up, interleaved, us=448, ds=3840
Oct 10 01:07:12    user    critical    kernel: ADSL G.992 message exchange
Oct 10 01:07:08    user    critical    kernel: ADSL G.992 channel analysis
Oct 10 01:07:05    user    critical    kernel: ADSL G.992 started
Oct 10 01:07:03    user    critical    kernel: ADSL G.994 training
Oct 10 01:07:03    daemon    critical    pppd[577]: Clear IP addresses. PPP connection DOWN.
Oct 10 01:07:03    daemon    critical    pppd[577]: Clear IP addresses. Connection DOWN.
Oct 10 01:07:02    user    critical    kernel: ADSL link down
Oct 10 01:06:21    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=87.7.146.208 DST=87.7.131.171 LEN=40 TOS=0x00 PREC=0x00 TTL=121 ID=18517 PROTO=TCP SPT=25771 DPT=139 WINDOW=16384 RES=0x00 SYN URGP=0
Oct 10 01:06:06    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=87.7.1.15 DST=87.7.131.171 LEN=52 TOS=0x00 PREC=0x00 TTL=57 ID=65028 DF PROTO=TCP SPT=39611 DPT=139 WINDOW=60352 RES=0x00 SYN URGP=0
Oct 10 01:05:43    daemon    critical    pppd[577]: Received valid IP address from server. Connection UP.
Oct 10 01:05:42    daemon    critical    pppd[577]: PPP LCP UP.
Oct 10 01:05:33    user    critical    kernel: ADSL link up, interleaved, us=480, ds=6816
Oct 10 01:05:32    user    critical    kernel: ADSL G.992 message exchange
Oct 10 01:05:28    user    critical    kernel: ADSL G.992 channel analysis
Oct 10 01:05:25    user    critical    kernel: ADSL G.992 started
Oct 10 01:05:24    daemon    critical    pppd[577]: Clear IP addresses. PPP connection DOWN.
Oct 10 01:05:24    daemon    critical    pppd[577]: Clear IP addresses. Connection DOWN.
Oct 10 01:05:23    user    critical    kernel: ADSL G.994 training
Oct 10 01:05:22    user    critical    kernel: ADSL link down
Oct 10 00:56:01    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=79.35.42.222 DST=79.35.21.241 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=2832 DF PROTO=TCP SPT=4450 DPT=135 WINDOW=60352 RES=0x00 SYN URGP=0
Oct 10 00:45:55    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=79.35.42.222 DST=79.35.21.241 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=34864 DF PROTO=TCP SPT=48879 DPT=135 WINDOW=60352 RES=0x00 SYN URGP=0
Oct 10 00:36:07    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=79.53.64.147 DST=79.35.21.241 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=49752 DF PROTO=TCP SPT=12684 DPT=445 WINDOW=60352 RES=0x00 SYN URGP=0
Oct 10 00:27:59    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=79.35.42.222 DST=79.35.21.241 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=63758 DF PROTO=TCP SPT=42735 DPT=135 WINDOW=60352 RES=0x00 SYN URGP=0
Oct 10 00:19:02    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=79.35.42.222 DST=79.35.21.241 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=43278 DF PROTO=TCP SPT=39653 DPT=135 WINDOW=60352 RES=0x00 SYN URGP=0
Oct 10 00:07:24    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=151.50.5.154 DST=79.35.21.241 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=17966 DF PROTO=TCP SPT=1449 DPT=65259 WINDOW=65535 RES=0x00 SYN URGP=0
Oct 10 00:07:21    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=151.50.5.154 DST=79.35.21.241 LEN=48 TOS=0x00 PREC=0x00 TTL=119 ID=17963 DF PROTO=TCP SPT=1449 DPT=65259 WINDOW=65535 RES=0x00 SYN URGP=0
Oct 10 00:05:49    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=79.53.64.147 DST=79.35.21.241 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=44296 DF PROTO=TCP SPT=60243 DPT=445 WINDOW=60352 RES=0x00 SYN URGP=0
Oct 10 00:05:46    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=79.53.64.147 DST=79.35.21.241 LEN=52 TOS=0x00 PREC=0x00 TTL=58 ID=43780 DF PROTO=TCP SPT=60243 DPT=445 WINDOW=60352 RES=0x00 SYN URGP=0
Oct 10 00:05:36    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=84.18.192.101 DST=79.35.21.241 LEN=48 TOS=0x00 PREC=0x00 TTL=117 ID=17682 PROTO=TCP SPT=29615 DPT=22 WINDOW=65535 RES=0x00 SYN URGP=0
Oct 10 00:05:33    daemon    critical    pppd[577]: Received valid IP address from server. Connection UP.
Oct 10 00:05:32    daemon    critical    pppd[577]: PPP LCP UP.
Oct 10 00:05:23    user    critical    kernel: ADSL link up, interleaved, us=480, ds=3872
Oct 10 00:05:18    user    critical    kernel: ADSL G.992 channel analysis
Oct 10 00:05:16    user    critical    kernel: ADSL G.992 started
Oct 10 00:05:13    user    critical    kernel: ADSL G.994 training
Oct 10 00:05:12    daemon    critical    pppd[577]: Clear IP addresses. PPP connection DOWN.
Oct 10 00:05:12    daemon    critical    pppd[577]: Clear IP addresses. Connection DOWN.
Oct 10 00:05:12    user    critical    kernel: ADSL link down
Oct 10 00:03:15    daemon    critical    pppd[577]: Received valid IP address from server. Connection UP.
Oct 10 00:03:15    daemon    critical    pppd[577]: PPP LCP UP.
Oct 10 00:03:06    user    critical    kernel: ADSL link up, interleaved, us=448, ds=3840
Oct 10 00:03:01    user    critical    kernel: ADSL G.992 channel analysis
Oct 10 00:02:59    user    critical    kernel: ADSL G.992 started
Oct 10 00:02:57    daemon    critical    pppd[577]: Clear IP addresses. PPP connection DOWN.
Oct 10 00:02:56    user    critical    kernel: ADSL G.994 training
Oct 10 00:02:55    user    critical    kernel: ADSL link down
Oct 9 23:52:03    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=81.214.75.152 DST=82.59.161.38 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=23103 DF PROTO=TCP SPT=2371 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
Oct 9 23:45:44    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=84.201.254.253 DST=82.59.161.38 LEN=48 TOS=0x00 PREC=0x20 TTL=109 ID=35659 DF PROTO=TCP SPT=3026 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0
Oct 9 23:32:55    user    alert    kernel: Intrusion -> IN=ppp_8_35_1 OUT= MAC= SRC=202.63.124.37 DST=82.59.161.38 LEN=60 TOS=0x00 PREC=0x00 TTL=54 ID=48538 DF PROTO=TCP SPT=17160 DPT=22 WINDOW=5840 RES=0x00 SYN URGP=0
Oct 9 23:27:45    syslog    emergency    BCM96345 started: BusyBox v1.00 (2008.01.10-22:08+0000)
« Ultima modifica: 10 Ottobre 2008, 01:19 da nottolotto »
