USB over IP su dga4132 (e technicolor in generale)
  • 5 Risposte
  • 4471 Visite
Offline dragonx
  • 480
« il: 24 Luglio 2023, 12:57 »
Salve a tutti, qualcuno può dirmi come installare usb over ip su dga4132? da qui https://openwrt.org/docs/guide-user/services/usb.iptunnel ho eseguito questi comandi
- opkg update
- opkg install kmod-usb-ohci usbip-server usbip-client
ottenendo i seguenti risultati
root@accesspoint:~# opkg update
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/base/Pac            kages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_base
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/packages            /Packages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_packages
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/luci/Pac            kages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_luci
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/routing/            Packages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_routing
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/telephon            y/Packages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_telephony
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/target/p            ackages/Packages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_core
Downloading https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/base/P            ackages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_base_macoers
Downloading https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/packag            es/Packages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_packages_maco            ers
Downloading https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/luci/P            ackages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_luci_macoers
Downloading https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/routin            g/Packages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_routing_macoe            rs
Downloading https://repository.macoers.com/homeware/18/brcm63xx-tch/VANTW/teleph            ony/Packages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer_telephony_mac            oers
root@accesspoint:~# opkg install kmod-usb-ohci usbip-server usbip-client
Installing kmod-usb-ohci (4.1.38-1) to root...
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/target/p            ackages/kmod-usb-ohci_4.1.38-1_arm_cortex-a9_neon.ipk
Unknown package 'usbip-server'.
Unknown package 'usbip-client'.
Configuring kmod-usb-ohci.
Collected errors:
 * opkg_install_cmd: Cannot install package usbip-server.
 * opkg_install_cmd: Cannot install package usbip-client.
poi da un altro link ho trovato altri comandi da eseguire
root@accesspoint:~# opkg list | grep -i usbip
root@accesspoint:~# opkg install usbip
Unknown package 'usbip'.
Collected errors:
 * opkg_install_cmd: Cannot install package usbip.
root@accesspoint:~# opkg install kmod-usbip
Unknown package 'kmod-usbip'.
Collected errors:
 * opkg_install_cmd: Cannot install package kmod-usbip.
root@accesspoint:~# opkg install kmod-usbcore
Unknown package 'kmod-usbcore'.
Collected errors:
 * opkg_install_cmd: Cannot install package kmod-usbcore.
root@accesspoint:~# opkg install kmod-usb-core
Package kmod-usb-core (git_gitolite_openwrt__openwrt_broadcom_bcm963xx_5_02L_07_git-tch_bcm5_02L_07patch1_wlan19_1_1p2-1) installed in root is up to date.
root@accesspoint:~# opkg install kmod-usb-storage
Package kmod-usb-storage (git_gitolite_openwrt__openwrt_broadcom_bcm963xx_5_02L_07_git-tch_bcm5_02L_07patch1_wlan19_1_1p2-1) installed in root is up to date.
root@accesspoint:~# opkg install kmod-usb2
Installing kmod-usb2 (4.1.38-1) to root...
Downloading https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/target/packages/kmod-usb2_4.1.38-1_arm_cortex-a9_neon.ipk
Configuring kmod-usb2.
root@accesspoint:~# opkg install kmod-usb3
Unknown package 'kmod-usb3'.
Collected errors:
 * opkg_install_cmd: Cannot install package kmod-usb3.
root@accesspoint:~# opkg files usbip
Collected errors:
 * opkg_files_cmd: Package usbip not installed.
root@accesspoint:~# opkg install kmod-usbip-server
Unknown package 'kmod-usbip-server'.
Collected errors:
 * opkg_install_cmd: Cannot install package kmod-usbip-server.
Collected errors:
moltissimi package sono inesistenti. Qualcuno sa come fare?
Offline dragonx
  • 480
Re:USB over IP su dga4132 (e technicolor in generale)
« Risposta #1 il: 28 Luglio 2023, 15:25 »
nessuno può aiutarmi?
« Risposta #2 il: 28 Luglio 2023, 15:52 »
Ormai il forum è diventato un deserto.
Credo che tu debba abbondare qualsiasi progetto che preveda di installare pacchetti del kernel, questo perché o non presenti o non funzionati, in mancanza di sorgenti da  compilare. Qualche cosa si riusciva a fare con il kernel 3.4 e versioni del firm molto vecchie.
Mi spiace.
Offline dragonx
  • 480
« Risposta #3 il: 29 Luglio 2023, 09:41 »
Mi spiace.
Perchè dici che mancano i sorgenti? quelli che hanno preso quei pacchetti da qualche parte li devono pure aver presi? Puoi essere più chiaro, io non conosco bene il mondo linux
« Risposta #4 il: 29 Luglio 2023, 11:39 »
I driver broadcom sono proprietari e servono per ricompilare tutto il kernel. In loro assenza si può forzare la ricompilazione del kernel, ma il risultato è inconsistente  e genera dei pacchetti non installabili o che mandano in crash il sistema. Per quei pacchetti che non necessitano del kernel per essere compilati e sono opensource, "nessun" problema per la loro compilazione ed installazione ... previo test.
Offline dragonx
  • 480
« Risposta #5 il: 01 Agosto 2023, 11:26 »
i pacchetti sopra citati necessitano del kernel oppure no?
