  • 3535 Risposte
  • 1707577 Visite
Offline Ni-Cola
  • 33
« Risposta #675 il: 16 Aprile 2020, 09:33 »
Sì
nb: ho trasformato i repo in http://github blob
Downloading http://github.com/FrancYescO/789vacv2_opkg/blob/master/base/Packages.gz
Updated list of available packages in /var/opkg-lists/base
Downloading http://github.com/FrancYescO/789vacv2_opkg/blob/master/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/packages
Downloading http://github.com/FrancYescO/789vacv2_opkg/blob/master/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/luci
Downloading http://github.com/FrancYescO/789vacv2_opkg/blob/master/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/routing
Downloading http://github.com/FrancYescO/789vacv2_opkg/blob/master/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/telephony
Downloading http://github.com/FrancYescO/789vacv2_opkg/blob/master/management/Packages.gz
Updated list of available packages in /var/opkg-lists/management
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/base/Packages.gz
Updated list of available packages in /var/opkg-lists/chaos_calmer
Removing package libuci from root...
Installing libiwinfo-lua (2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371) to root...
Installing libuci (2017-04-12.1-2) to root...
Installing libiwinfo (2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/base/libiwinfo_2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371_brcm63xx.ipk
Package libiwinfo (2015-06-01-ade8b1b299cbd5748db1acf80dd3e9f567938371) installed in root is up to date.
Installing libuci-lua (2017-04-12.1-2) to root...
Package libuci (2017-04-12.1-2) installed in root is up to date.
Installing rpcd-mod-file (2016-06-30-23417e94d25570e6d62542bac46edd51e8e0243a) to root...
Installing rpcd (2016-06-30-23417e94d25570e6d62542bac46edd51e8e0243a) to root...
Installing rpcd-mod-iwinfo (2016-06-30-23417e94d25570e6d62542bac46edd51e8e0243a) to root...
Installing rpcd-mod-rpcsys (2016-06-30-23417e94d25570e6d62542bac46edd51e8e0243a) to root...
Package rpcd (2016-06-30-23417e94d25570e6d62542bac46edd51e8e0243a) installed in root is up to date.
Installing uhttpd-mod-lua (2015-11-08-fe01ef3f52adae9da38ef47926cd50974af5d6b7) to root...
Installing uhttpd (2015-11-08-fe01ef3f52adae9da38ef47926cd50974af5d6b7) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/base/uhttpd_2015-11-08-fe01ef3f52adae9da38ef47926cd50974af5d6b7_brcm63xx.ipk
Installing uhttpd-mod-ubus (2015-11-08-fe01ef3f52adae9da38ef47926cd50974af5d6b7) to root...
Package uhttpd (2015-11-08-fe01ef3f52adae9da38ef47926cd50974af5d6b7) installed in root is up to date.
Configuring libuci.
Configuritg-LuCI Install Script: Restoring tch uci.so...
tg-LuCI Install Script: Installing LuCI...
Collected errors:
 * opkg_conf_parse_file: Duplicate src declaration (luci http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci). SkUnknown package 'luci'.
Unknown package 'luci-lib-json'.
Unknown package 'luci-lib-jsonc'.
Unknown package 'luci-lib-nixio'.
Unknown package 'luci-mod-rpc'.
pping.
 * opkg_conf_parse_file: Duplicate src declaration (routing http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/routing). Skipping.
 * opkg_conf_parse_file: Duplicate src declaration (packages http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/packages). Skipping.
 * opkg_conf_parse_file: Duplicate src declaration (telephony http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/telephony). Skipping.
 * opkg_install_cmd: Cannot install package luci.
 * opkg_install_cmd: Cannot install package luci-lib-json.
 * opkg_install_cmd: Cannot install package luci-lib-jsonc.
 * opkg_install_cmd: Cannot install package luci-lib-nixio.
 * opkg_install_cmd: Cannot install package luci-mod-rpc.
tg-LuCI Install Script: Patching LuCI to load uci_luci.so...
sed: /usr/lib/lua/luci/model/uci.lua: No such file or directory
tg-LuCI Install Script: Moving LuCI www to www_luci...
mv: can't rename '/www/cgi-bin': No such file or directory
mv: can't rename '/www/luci-static': No such file or directory
mv: can't rename '/www/index.html': No such file or directory
tg-LuCI Install Script: Changing uhttpd ports to 9080/9443...
tg-LuCI Install Script: Committing changes and restarting uhttpd...
tg-LuCI Install Script: LuCI is now READY!
« Risposta #676 il: 16 Aprile 2020, 10:12 »
@FrancYescO
Credo che sono i tuoi repo che rompono l'anima. Ho rimosso luci. Ho ripulito opkg.conf e distfeeds.conf  lanciato lo script manualmente: luci si installa senza problemi.
root@dsldevice:/tmp# ./install.sh
tg-LuCI Install Script: Adding achitecture...
tg-LuCI Install Script: Adding chaos_calmer feeds into distfeeds.conf...
tg-LuCI Install Script: Updating opkg...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/Packages.gz
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/management/Packages.gz
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/routing/Packages.gz
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/packages/Packages.gz
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/telephony/Packages.gz
tg-LuCI Install Script: Downloading recompiled packages...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   131  100   131    0     0    285      0 --:--:-- --:--:-- --:--:--   311
100  129k  100  129k    0     0  86565      0  0:00:01  0:00:01 --:--:--  143k
tg-LuCI Install Script: Untarring tg-luci.tar.gz...
tg-LuCI Install Script: Backing up tch uci.so...
tg-LuCI Install Script: Installing LuCI depends...
Configuring libuci.
Configuring libuci-lua.
Configuring rpcd.
Configuring libiwinfo.
Configuring libiwinfo-lua.
Configuring rpcd-mod-file.
Configuring uhttpd.
Configuring uhttpd-mod-lua.
Configuring rpcd-mod-rpcsys.
Configuring rpcd-mod-iwinfo.
Configuring uhttpd-mod-ubus.
Installing luci (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci_git-16.043.44305-e2f9172-1_all.ipk
Installing luci-lib-nixio (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-lib-nixio_git-16.043.44305-e2f9172-1_brcm63xx.ipk
Installing luci-lib-ip (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-lib-ip_git-16.043.44305-e2f9172-1_brcm63xx.ipk
Installing luci-base (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-base_git-16.043.44305-e2f9172-1_brcm63xx.ipk
Installing luci-mod-admin-full (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-mod-admin-full_git-16.043.44305-e2f9172-1_brcm63xx.ipk
Installing luci-theme-bootstrap (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-theme-bootstrap_git-16.043.44305-e2f9172-1_all.ipk
Installing luci-app-firewall (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-app-firewall_git-16.043.44305-e2f9172-1_all.ipk
Installing luci-proto-ppp (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-proto-ppp_git-16.043.44305-e2f9172-1_all.ipk
Installing luci-proto-ipv6 (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-proto-ipv6_git-16.043.44305-e2f9172-1_all.ipk
Upgrading luci-lib-json on root from git-15.248.30277-3836b45-1 to git-16.043.44305-e2f9172-1...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-lib-json_git-16.043.44305-e2f9172-1_all.ipk
Upgrading luci-lib-jsonc on root from git-15.248.30277-3836b45-1 to git-16.043.44305-e2f9172-1...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-lib-jsonc_git-16.043.44305-e2f9172-1_brcm63xx.ipk
Package luci-lib-nixio (git-16.043.44305-e2f9172-1) installed in root is up to date.
Installing luci-mod-rpc (git-16.043.44305-e2f9172-1) to root...
Downloading http://archive.openwrt.org/chaos_calmer/15.05.1/brcm63xx/smp/packages/luci/luci-mod-rpc_git-16.043.44305-e2f9172-1_all.ipk
Configuring luci-lib-json.
Configuring luci-mod-rpc.
Configuring luci-lib-ip.
Configuring luci-theme-bootstrap.
Configuring luci-app-firewall.
Configuring luci-proto-ppp.
Configuring luci-lib-nixio.
Configuring luci-base.
Configuring luci-mod-admin-full.
Configuring luci-proto-ipv6.
Configuring luci-lib-jsonc.
Configuring luci.
Edit confermo ho sostituito nello script i tuoi repo: l'installazione va a buon fine ma luci non funziona
./install.sh
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/base/Packages.gz
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/packages/Packages.gz
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/Packages.gz
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/routing/Packages.gz
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/telephony/Packages.gz
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/management/Packages.gz
100   131  100   131    0     0    292      0 --:--:-- --:--:-- --:--:--   315
100  129k    0  129k    0     0  77614      0 --:--:--  0:00:01 --:--:--  301k
Configuring libuci.
Configuring rpcd.
Configuring uhttpd.
Installing luci (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci_git-15.248.30277-3836b45-1_all.ipk
Installing luci-lib-nixio (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-lib-nixio_git-15.248.30277-3836b45-1_brcm63xx-tch.ipk
Installing luci-lib-ip (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-lib-ip_git-15.248.30277-3836b45-1_brcm63xx-tch.ipk
Installing luci-base (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-base_git-15.248.30277-3836b45-1_brcm63xx-tch.ipk
Installing luci-mod-admin-full (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-mod-admin-full_git-15.248.30277-3836b45-1_brcm63xx-tch.ipk
Installing luci-theme-bootstrap (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-theme-bootstrap_git-15.248.30277-3836b45-1_all.ipk
Installing luci-app-firewall (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-app-firewall_git-15.248.30277-3836b45-1_all.ipk
Installing luci-proto-ppp (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-proto-ppp_git-15.248.30277-3836b45-1_all.ipk
Installing luci-proto-ipv6 (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-proto-ipv6_git-15.248.30277-3836b45-1_all.ipk
Installing luci-lib-json (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-lib-json_git-15.248.30277-3836b45-1_all.ipk
Installing luci-lib-jsonc (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-lib-jsonc_git-15.248.30277-3836b45-1_brcm63xx-tch.ipk
Package luci-lib-nixio (git-15.248.30277-3836b45-1) installed in root is up to date.
Installing luci-mod-rpc (git-15.248.30277-3836b45-1) to root...
Downloading https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci/luci-mod-rpc_git-15.248.30277-3836b45-1_all.ipk
Configuring luci.
/usr/lib/lua/luci/dispatcher.lua:255: No valid theme found
stack traceback:
[C]: in function 'assert'
/usr/lib/lua/luci/dispatcher.lua:255: in function 'dispatch'
/usr/lib/lua/luci/dispatcher.lua:168: in function </usr/lib/lua/luci/dispatcher.lua:167>
Credo che il problema sia sorto con l'aggiunta dei repo + openssl-util per risolvere il problema di wget/https
Edit2 Dato upgradegui in modo da reinserire i tuoi repo e commentando
#src/gz luci https://raw.githubusercontent.com/FrancYescO/789vacv2_opkg/master/luci
L'installazione va a buon fine.
« Ultima modifica: 16 Aprile 2020, 11:00 da larsen64it »
  • 3404
« Risposta #677 il: 16 Aprile 2020, 12:22 »
Ok ci sta, l'aggiunta dei miei repo dalla gui stessa in fase di installazione è recente, al contrario prima non metteva alcun repo sul 789, lo faceva solo in fase di installazione di luci, e metteva quelli ufficiali di openwrt.
Ora le cose son due, o faccio fuori completamente i miei repo, e faccio in modo che anche la GUI metta quelli di openwrt (e credo sia meglio)
O li tolgo, faccio l'install di luci e poi li rimetto (che schifo..)
credo la domanda da farsi è... cosa hanno in più/di meglio i miei repo rispetto quelli di openwrt con la patch dell'architettura?
« Risposta #678 il: 16 Aprile 2020, 12:30 »
Boh!
Opzione: mettere i tuo repo senza
e vedere come vanno.
Offline kuntz_79
« Risposta #679 il: 17 Aprile 2020, 15:33 »
Salve a tutti,
grazie al lavoro di tutti quelli che vivono questo forum per i preziosi consigli e guide messe a sdisposizione. Mi sono cimentato nel mod del AGTEF e tutto è andato benone dopo  un po di smanettamenti.
Ho provato dopo la mod amontarlo su linea Fastweb ma, si allineava a una velocità più bassa del modem Fastweb stesso, e soprattutto non sono riuscito a connettermi, ne usando la configurazione guidata ne provando a mano (non sono riuscito a inserire tutti i dati richiesti a quanto pare, non ho trovato dove andare a metterli). Esiste una guida per la configurazione dei vari provider per questa GUI??
Offline grouchos3
  • 14
« Risposta #681 il: 18 Aprile 2020, 08:45 »
il fatto che si allinei ad una velocità piu' bassa del firmware originale l'ho notato anche io su linea tim. c'è un modo per aumentare portante?? sono connesso a linea adsl
« Risposta #682 il: 18 Aprile 2020, 08:51 »
Puoi modificarele l' SNR nella tab configurazione xdsl. Di quanto? Dipende dai valori della tua linea.
Offline grouchos3
  • 14
« Risposta #683 il: 18 Aprile 2020, 09:00 »
adesso il valore snr è 0.... che valore dovrei mettere??
tieni presente che con firmware tim la portante agganciata era 6,5 mps ora 5,4 mps (adsl 7 mega)
Max Rate
5.67 Mbps
0.88 Mbps
Rate
5.39 Mbps
0.47 Mbps
Margine SNR
11.8 dB
24.3 dB
Attenuation
51.5 dB
33.7 dB
Alimentazione
0 dBm
9.6 dBm
« Ultima modifica: 18 Aprile 2020, 12:23 da MisterFTTH »
« Risposta #684 il: 18 Aprile 2020, 09:12 »
Firmware tim? Stiamo parlando del TG789vacV2?
I giro ci sono diverse tabelle che spiegano di quanto modificare l'SNR ma senza sconfinare:
https://www.ilpuntotecnico.com/modifica-del-target-snr/
Margine SNR
11.8 dB
In teoria puoi quasi dimezzare, poi devi valutare la stabilità.
50    – 3 dB
25    – 4,5 dB
1    – 5,5 dB
Offline grouchos3
  • 14
« Risposta #685 il: 18 Aprile 2020, 11:04 »
si perfetto... del TG789vacV2.
quindi se ho ben capito vado per gradi ovvero:
metto valore 50 per abbassare di 3db da 11.8 a 8.8 e vedo se linea e stabile ed eventualmente proseguo con
metto valore 25 per abbassare di 4,5db da 11.8 a 7.3
metto valore 1 per abbassare di 5,5db da 11.8 a 6.3
fino a che non trovo il giusto rapporto velocità/stabilità... corretto??
Suppongo che basta riportare il valore a 0 per ripristinare l'attuale situazione
« Risposta #686 il: 18 Aprile 2020, 11:11 »
Tutto corretto.
Offline antonio-68
  • 57
« Risposta #687 il: 18 Aprile 2020, 15:09 »
Ciao a tutti, vi chiedo aiuto per risolvere il seguente problema. Ho modificato a mano il file root del cron per inserire alcuni task automatizzati. Tutto funziona bene. Mi sono accorto che nella nuova GUI (ho la 9.5.38-ba81e28c) è stata inserita una finestra con cui visualizzare appunto tutti i task di cron: ebbene, quelli inseriti da me a mano non sono visualizzati nella finestra di dettaglio, anche se in quella sintetica (ovvero quella che appare nella schermata GUI principale) si indica il numero corretto di task cron inseriti.
Chiedo aiuto a far sì che i nuovi task inseriti a mano siano visualizzati nella finestra di dettaglio della GUI. Spero di essermi spiegato. Come firware ho il AGTHP_2.2.0
  • 3404
« Risposta #688 il: 18 Aprile 2020, 15:25 »
posta il tuo file cron, molto probabilmente è un bug della GUI.
Offline antonio-68
  • 57
« Risposta #689 il: 18 Aprile 2020, 15:32 »
eccolo (alla fine c'è una il carattere di "a capo" per far funzionare il tutto)
51 6 * * * /usr/share/transformer/scripts/checkver >/dev/null 2>&1
*/30 * 24-26 12 * /etc/christmas_tree.sh &
35 21 * * 0,1,2,3,4 /sbin/wifi24off
30 6 * * 1,2,3,4,5 /sbin/wifi24on
30 0 * * 1,2,3,4,5 /sbin/wifi05off
30 6 * * 1,2,3,4,5 /sbin/wifi05on
05 22 * * 5,6 /sbin/wifi24off
30 7 * * 0,6 /sbin/wifi24on
00 1 * * 0,6 /sbin/wifi05off
30 7 * * 0,6 /sbin/wifi05on
« Ultima modifica: 18 Aprile 2020, 15:46 da MisterFTTH »
