  • 1597 Risposte
  • 913766 Visite
Offline a1pollo
  • 172
« Risposta #435 il: 12 Ottobre 2019, 10:34 »
Ciao e grazie,questo e' il risultato:
root@OpenWrt:~# cat /etc/opkg/*.conf
# add your custom package feeds here
# src/gz example_feed_name http://www.example.com/path/to/files
src/gz chaos_calmer http://downloads.openwrt.org/chaos_calmer/15.05.1/brcm63xx-tch/VBNTJ/packages
root@OpenWrt:~#
ora provo ad aggiungere quelle linee
 mi da' questo:
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/base/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/base/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/packages/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/packages/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/luci/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/luci/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/routing/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/routing/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/telephony/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/telephony/Packages.gz
Downloading https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/management/Packages.gz
*** Failed to download the package list from https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch/packages/management/Packages.gz
Downloading http://downloads.openwrt.org/chaos_calmer/15.05.1/brcm63xx-tch/VBNTJ/packages/Packages.gz
*** Failed to download the package list from http://downloads.openwrt.org/chaos_calmer/15.05.1/brcm63Collected errors:
 * opkg_install_cNo packages removed.
Unknown package 'libuci-lua'.
Unknown package 'luci'.
Unknown package 'rpcd'.
stall_cmd: Cannot install package rpcd.
« Ultima modifica: 12 Ottobre 2019, 10:55 da MisterFTTH »
  • 3401
« Risposta #436 il: 12 Ottobre 2019, 11:10 »
Quando apri la modal di installazione app hai mica il messaggio che ti avverte che devi installare le app specifiche?
Era connesso a internet il modem quando hai installato la GUI?
altrimenti devi scaricare manualmente i soliti pacchetti di wget e openssl per fixare il problema di opkg che non riesce a scaricare da link https..
Offline a1pollo
  • 172
« Risposta #437 il: 12 Ottobre 2019, 11:23 »
Ciao, e grazie ancora
da interfaccia grafica e' tutto ok, non mi scrive nulla.
il pc era connesso su internet, l'ho installata da riga di comando con putty, inserendo il comando:
curl -k https://raw.githubusercontent.com/Ansuel/gui-dev-build-auto/master/GUI.tar.bz2 --output /tmp/GUI.tar.bz2
bzcat /tmp/GUI.tar.bz2 | tar -C / -xvf -
/etc/init.d/rootdevice force
 pero' alla fine dell'installazione mi ha reso vari errori, poi da interfaccia grafica visto che non riuscivo ad installare luci ho aggiornato alla versione developer, che posso aprire ma non installa luci o transmission.
  • 3401
« Risposta #438 il: 12 Ottobre 2019, 11:30 »
È importante sapere quali errori hai avuto, comunque la soluzione dovrebbe essere quella scritta sopra, devi installare libopenssl e forse anche wget mettendo manualmente il pacchetto ipk sul modem
Offline a1pollo
  • 172
« Risposta #439 il: 12 Ottobre 2019, 11:38 »
potresti indicarmi esattemente i comandi da dare poiche' io sono ancora un po' :noob:
gli errori li ha scritti alla fine dopo il comando /etc/init.d/rootdevice force
infatti non le ho dato peso, pensavo e' gia roottato
la gui mi funziona bene
  • 3401
« Risposta #440 il: 12 Ottobre 2019, 12:37 »
guarda qui: https://www.ilpuntotecnico.com/forum/index.php/topic,77856.msg255138.html#msg255138 il problema è simile ma forse hai bisogno di cambiare l'URL con quello dei feed giusti per questo modem (ho ipotizzato quelli https://repository.ilpuntotecnico.com/files/roleo/public/agtef/1.1.0/brcm63xx-tch si potessero adattare)
« Risposta #441 il: 12 Ottobre 2019, 14:11 »
Si, i repo sono per lo più quelli, anche se alcune cose erano state aggiornate badando specificamente alla collezione di pacchetti presenti sui modelli tim, per cui alcune cose non combaciano alla perfezione e altre mancano del tutto (tipo sqm-scripts, di cui su questo fastgate ci sono gia i driver necessari installati e che sui Tim non sono possibili da ricreare).
Offline a1pollo
  • 172
« Risposta #442 il: 12 Ottobre 2019, 15:31 »
Credo che la gui di ansuel per questo modello abbia ancora dei bugs, anche se l'interfaccia funziona perfettamente.
A questo punto non mi rimane che fare un reset, sapete indicarmi come farlo, considerate che il router e' dell'operatore fastweb in comodato d'uso.
Offline Tommy03
  • 16
« Risposta #443 il: 12 Ottobre 2019, 15:36 »
Qualcuno gentile mi ha aiuta a capire come mai ottengo sempre connection refused quando faccio ssh [email protected]? Ho seguito tutti passaggi ma non mi lascia entrare.
Offline a1pollo
  • 172
« Risposta #444 il: 12 Ottobre 2019, 15:45 »
ciao io ho seguito tutta la guida, e mi e' riuscito bene al primo colpo.
io uso putty, pero' ho provato anche a connettermi con la shell di windows eha funzionato.
forse non hai abilitato l' accesso di root.
Offline Tommy03
  • 16
« Risposta #445 il: 12 Ottobre 2019, 15:47 »
Puoi dirmi i passaggi che hai eseguito? Proprio esattamente.
Offline Tommy03
  • 16
« Risposta #446 il: 12 Ottobre 2019, 16:03 »
Utilizzando nmap noto che la porta 22 è chiusa, ma non so spiegarmi perche.
  • 3401
« Risposta #447 il: 12 Ottobre 2019, 18:54 »
@a1pollo che possano esserci ancora bug non c'è dubbio ma che io ricordi il grosso funzionava tutto.. il reset come sempre si fa con il tastino
@Tommy03 qualcosa hai sbagliato fai un bel reset e inizia da capo, la guida è quella al primo post
Offline Tommy03
  • 16
« Risposta #448 il: 12 Ottobre 2019, 19:56 »
@FrancYescO basta che tenga pigiato il tastino dietro con uno stecchino giusto?
« Risposta #449 il: 13 Ottobre 2019, 00:55 »
@Tommy03 e @prisco99 quando ho scritto la giuda ho tenuto conto di ogni possibile problema che mi veniva in mente e nel corso del tempo l'ho migliorata man mano che scoprivo nuovi possibili problemi avuti da altri, se seguendola passo passo non vi ha funzionato provate a riseguirla da capo dopo un factory reset (tastino premuto per circa dieci secondi) e a documentare con screen e log tutto quello che vi appare facendolo così se c'è qualcosa di anomalo possiamo accorgercene. Quell'errore nvset non capisco da cosa viene fuori, mentre il connection refused appare quando dropbear non è stato configurato correttamente o lo script di sblocco non è stato eseguito. Naturalmente do per scontato che abbiate una delle solite versioni firmware già note (l'ultima che conosco è la 248), altrimenti dovete indicarlo nei vostri messaggi perchè se no potremmo essere completamente fuori strada.
