  • 1597 Risposte
  • 915524 Visite
« Risposta #1080 il: 20 Maggio 2020, 10:00 »
BoLaMN > kernel 3.4 quindi non funziona
per scaricare quel file l'indirizzo è
https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/base/openssl-util_1.0.2t-1_arm_cortex-a9_neon.ipk
Come hai fatto tu hai tentato di installare un indirizzo e non un pacchetto.
Offline a1pollo
  • 172
« Risposta #1081 il: 20 Maggio 2020, 14:41 »
@mgmellia
Se installi la gui di ansuel ti mette in automatico tutto, anche i feed.
Oppure se non vuoi la gui mod, dai quanto segue:
echo "dest root /
dest ram /tmp
lists_dir ext /var/opkg-lists
option overlay_root /overlay
arch all 100
arch arm_cortex-a9 200
arch arm_cortex-a9_neon 300
src/gz chaos_calmer_base https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/base
src/gz chaos_calmer_packages https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/packages
src/gz chaos_calmer_luci https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/luci
src/gz chaos_calmer_routing https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/routing
src/gz chaos_calmer_telephony https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/telephony
src/gz chaos_calmer_core https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/target/packages" > /etc/opkg.conf
#repository macoers
curl https://www.macoers.com/repository/homeware/18/brcm63xx-tch/customfeeds-VANTW.conf --output /etc/opkg/customfeeds.conf
curl -k https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/base/openssl-util_1.0.2t-1_arm_cortex-a9_neon.ipk -o /tmp/openssl-util_1.0.2t-1_arm_cortex-a9_neon.ipk
opkg install /tmp/openssl-util_1.0.2t-1_arm_cortex-a9_neon.ipk
curl -k https://raw.githubusercontent.com/Ansuel/GUI_ipk/kernel-4.1/base/libopenssl_1.0.2t-1_arm_cortex-a9_neon.ipk -o /tmp/libopenssl_1.0.2t-1_arm_cortex-a9_neon.ipk
opkg install /tmp/libopenssl_1.0.2t-1_arm_cortex-a9_neon.ipk
Offline mgmellia
  • 14
« Risposta #1082 il: 20 Maggio 2020, 22:41 »
Funzionato alla perfezione  :clap: :clap:
Offline sob0
  • 18
« Risposta #1083 il: 21 Maggio 2020, 11:08 »
Buongiorno (:
Chiedo intanto scusa per la mia inesperienza e se le domande fatte saranno banali, ce la sto mettendo tutta.
Ho una connessione FTTH (metroweb) della fastweb a 100/50 mb\s. Volevo passare da un TG1100 al DGA4131.
Lo stato attuale del DGA4131 è aggiornato alla v.18, rootato e con accesso in SSH. L'ho collegato tramite l'ONT sulla porta laterale. Il cavo di rete invece è collegato alla porta 4.
Il problema è che non ho linea. Ho provato anche a clonare il MAC del tg1100 ma non ho avuto esiti diversi.
Ho anche il dubbio di non aver configurato correttamente il file network, ma non saprei nemmeno da dove cominciare (sono andato un po' a naso, c'è modo eventualmente di ripristinare il file?)
Grazie per l'attenzione.
Update: ho ripreso a smanettare dentro il file network. Il computer mi rileva la linea presente, se provo a dare comandi di ping e traceroute vanno a buon fine. Ma non riesco a navigare (né da PC, né da altri dispositivi in wifi ) e non funziona il VoIP.
Le spie sono accese tutte di bianco.
Update 2: quanto scritto sopra vale solamente se do il comando di reload del network. Se riavvio il router non funziona fino a quando non so il comando etc/init.d/network reload
« Ultima modifica: 21 Maggio 2020, 12:26 da sob0 »
« Risposta #1084 il: 21 Maggio 2020, 17:13 »
devi disabilitare il wansensing, mettere eth4lanwan mode in etc/config/ethernet su 1, e poi verificare che in etc/config/network tu abbia eth4 e non vlan_eth4 come ifname per l'interfaccia wan.
Offline sob0
  • 18
« Risposta #1085 il: 22 Maggio 2020, 13:53 »
Ciao,
intanto grazie per le dritte, e mi scuso per il ritardo nella risposta ma ho avuto qualche contrattempo.
Facendo come mi hai consigliato tu, ora ho linea e riesco a navigare MA solo su alcuni siti (ad esempio, youtube funziona, amazon anche, speedtest no, il meteo nemmeno, sia sul fisso con cavo che su cellulare). Ho notato anche che la maggior parte dei siti che dovrebbero indicarmi il mio IPv4 attuale me lo danno come "assente" e mi mostrano soltanto quello IPv6.
Inoltre non funziona ancora il telefono di casa (ma quello potrebbe essere un problema con il file "firewall").
Inoltre con il tg1100 avevo un ip fisso (2.xxx) ma provando ad impostarlo nel file network (ho cambiato solo le voci proto e ipadrr, non so se serva modificare altro) semplicemente non ottengo la linea.
Hai idea da cosa possa dipendere? Serve che giro qui qualche file di configurazione?
Grazie ancora e buona giornata
PS: ho provato ad impostare telegram in modo diverso. Se gli tolgo il permesso di utilizzare l 'IPv6, non riesce a collegarsi alla rete.
Quindi presumo ci sia un problema lato IPv4, ma non saprei dove mettere le mani :)
« Ultima modifica: 22 Maggio 2020, 15:45 da MisterFTTH »
« Risposta #1086 il: 22 Maggio 2020, 15:57 »
 L'IP statico devi comunque fartelo assegnare in DHCP, magari in aggiunta all'altro e non al suo posto. Per il resto credo manchi qualche rotta, rimetti la wan in DHCP e vedi che succede.
Offline sob0
  • 18
« Risposta #1087 il: 22 Maggio 2020, 16:38 »
La WAN è già in dhcp altrimenti non riesco proprio a navigare. Ho solo fatto una prova in statico ma appunto non c'era verso di navigare, quindi sono tornato in DHCP.
« Ultima modifica: 22 Maggio 2020, 17:10 da MisterFTTH »
Offline matteoa91
  • 18
« Risposta #1088 il: 27 Maggio 2020, 08:57 »
credo di avere inteso, non conoscedo il device potrei avere sbagliato i numeri porta o altro.
Sei poi riuscito usando questa configurazione?
io ho provato ma non mi vanno lo stesso le porte, nonostante io riesca a entrare tramite ssh sul dga.
« Ultima modifica: 27 Maggio 2020, 09:13 da MisterFTTH »
Offline matteoa91
  • 18
« Risposta #1089 il: 28 Maggio 2020, 08:40 »
@xasor61400  Certo! sotto puoi trovare i due network.
Il router è il netgear R7800 con openwrt. Quello che sto cercando di fare è di creare un trunk in cui nella vlan 2 ho la lan, e nella vlan 3 ho la wan, e quindi estendere il numero di porte lan che ho e poter utilizzare anche le porte lan del dga.
Per ora, come ti dicevo, funziona la wan e la lan fino al dga, cioè riesco ad entrare tramite ssh ma le porte poi non vanno.
### R7800
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fdb7:dd80:0567::/48'
option packet_steering '1'
config interface 'lan'
option type 'bridge'
option ifname 'eth0.2 eth1.1'
option ipaddr '192.168.1.1'
option ip6assign '60'
option delegate '0'
config interface 'wan'
option ifname 'eth0.3'
option proto 'dhcp'
option vendorid 'Technicolor_DGA4131FWB/dslforum.org'
option peerdns '0'
list dns '1.1.1.1'
list dns '1.0.0.1'
option delegate '0'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '6t 1 2 3 4'
option vid '1'
config switch_vlan
option vlan '2'
option ports '0t 5t'
option vid '2'
config switch_vlan
option vlan '3'
option vid '3'
### config DGA4131
option ifname 'lo'
option ula_prefix 'fd2d:292b:fdc6::/48'
option default_ps '0'
option ifname 'eth0.2 eth1.2 eth2.2 eth3.2'
option ip6assign '64'
option force_link '0'
option ip6class '6rd'
option ip6hint '0'
option ip6weight '1'
option stp '1'
option ipv6 '0'
    list pppoerelay ''
option ipaddr '192.168.1.2'
config switch 'bcmsw'
option reset '1'
option enable_vlan '0'
option qosimppauseenable '0'
option jumbo '0'
option unit '0'
config switch 'bcmsw_vlan'
option reset '1'
option jumbo '0'
option unit '1'
config switch_vlan
option device 'bcmsw_vlan'
option vlan '2'
option vid '2'
option ports '0t 1 2 3 8t'
config switch_vlan
option vlan '3'
option vid '3'
option ports '0t 8t'
config device 'vlan_ptm0'
option type '8021q'
option ifname 'ptm0'
option mtu '1500'
option name 'vlan_ptm0'
option vid '100'
    option ifname 'eth0.3 vlan_ptm0'
config interface 'mgmt'
config interface 'wwan'
option proto 'mobiled'
option session_id '0'
option profile '1'
option iface_464xlat '0'
option auto '0'
option enabled '0'
config device 'if0atm'
option enable '1'
option name 'atm0'
option macaddr '10:13:31:F3:7B:F0'
config device 'if1atm'
option enable '1'
option name 'atm1'
option macaddr '10:13:31:F3:7B:F1'
config interface 'sfp'
option ifname 'eth4'
option ipaddr '169.0.0.2'
config config 'config'
config interface 'hotspot'
config interface 'gre'
option peeraddr '10.254.3.85'
option mtu '1400'
option df '1'
option zone 'wan'
option tunlink 'wan'
option ttl '100'
option proto 'gretap'
option network 'hotspot'
« Risposta #1090 il: 28 Maggio 2020, 11:29 »
Mi sembra tutto giusto sul DGA ma non mi è chiaro perchè sul Netgear stai mandando le due lan vid 1 e vid 2 separatamente al SoC per poi bridgiarle in software. Non so se sul Netgear la porta 5 e la 6 rappresentano due porte dello stesso switch entrambe connesse alla cpu o cos'altro, ma io terrei tutto sulla stessa vlan. Se mi spieghi come sono le porte del Netgear ti dico anche come.
Ad intuito, direi una cosa del genere, poi vedi tu cosa farne di eth1 e 6t che io non so a cosa ti servono.
### R7800
 option ifname 'lo'
 option ifname 'eth0.2'
 option delegate '0'
 option proto 'dhcp'
 option peerdns '0'
 list dns '1.1.1.1'
 list dns '1.0.0.1'
 option delegate '0'
config switch
 option reset '1'
config switch_vlan
 option vlan '2'
 option ports '0t 1 2 3 4 5t'
 option vid '2'
config switch_vlan
 option vlan '3'
 option vid '3'
« Ultima modifica: 28 Maggio 2020, 11:33 da LuKePicci »
Offline matteoa91
  • 18
« Risposta #1091 il: 28 Maggio 2020, 12:49 »
@LuKePicci lo avevo messo all'inizio come prova senza tanto ragionarci su, la configurazione corretta è quella che ha messo poco dopo xasor.
@xasor61400 si ho visto la config che avevi messo, ora la metto uguale anche io (tenendo la vlan 2 per la lan e la 3 per la wan).
ad ogni modo, non è questo il problema perchè comunque le porte continuano a non andare (lo so perchè era una cosa che avevo già provato, e per sicurezza l'ho messa prima di rispondere).
non so se possa essere d'aiuto, ma questo è l'ifconfig del dga:
root@matel-mdm01:~# ifconfig
bcmsw     Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          RX packets:1928 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1294 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:588392 (574.6 KiB)  TX bytes:365652 (357.0 KiB)
          Base address:0xffff
br-lan    Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          inet addr:192.168.1.2  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:1808 errors:0 dropped:0 overruns:0 frame:0
          TX packets:47 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:527191 (514.8 KiB)  TX bytes:8916 (8.7 KiB)
br-wan    Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          inet6 addr: fe80::1213:31ff:fef3:7bf0/64 Scope:Link
          RX packets:13 errors:0 dropped:0 overruns:0 frame:0
          TX packets:11 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4098 (4.0 KiB)  TX bytes:1042 (1.0 KiB)
eth0      Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          RX packets:11689 errors:0 dropped:3 overruns:0 frame:0
          TX packets:15507 errors:0 dropped:16 overruns:0 carrier:0
          RX bytes:2749819 (2.6 MiB)  TX bytes:14913601 (14.2 MiB)
eth0.2    Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          RX packets:1789 errors:0 dropped:0 overruns:0 frame:0
          TX packets:135 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:525430 (513.1 KiB)  TX bytes:13492 (13.1 KiB)
eth0.3    Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          RX packets:16 errors:0 dropped:0 overruns:0 frame:0
          TX packets:25 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4664 (4.5 KiB)  TX bytes:3215 (3.1 KiB)
eth1      Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth1.2    Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
eth2      Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          RX packets:41 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1017 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:7186 (7.0 KiB)  TX bytes:300838 (293.7 KiB)
eth2.2    Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          TX packets:1009 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:291584 (284.7 KiB)
eth3      Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
eth3.2    Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
eth4      Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          inet addr:169.0.0.2  Bcast:169.0.0.255  Mask:255.255.255.0
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:70 errors:0 dropped:0 overruns:0 frame:0
          TX packets:70 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4764 (4.6 KiB)  TX bytes:4764 (4.6 KiB)
ptm0      Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          RX packets:15192 errors:0 dropped:0 overruns:0 frame:0
          TX packets:9434 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:14852540 (14.1 MiB)  TX bytes:2099769 (2.0 MiB)
vlan_ptm0 Link encap:Ethernet  HWaddr 10:13:31:F3:7B:F0
          RX packets:14 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1977 (1.9 KiB)  TX bytes:1729 (1.6 KiB)
attualmente la eth0 la uso per il trunk, mentre nella eth2 ho attaccato un dispositivo (ps4)
la cosa a mio parere strana è che si vede che ci sono pacchetti mandati e ricevuti nella eth2, mentre nella eth2.2 ci sono solo pacchetti mandati. non saprei però che pesci pigliare sinceramente,
« Risposta #1092 il: 28 Maggio 2020, 13:03 »
Io passo, nelle vostre config vedo numeri di porte a caso che non comprendo. prima eth0 ed eth1 sull'asus, ora eth2, ma avete installato una build DSA? E poi le porte, vedo apparire 0 1 2 3 4 5 6 … ma quante porte ha quell'aggeggio?? XD Vedo 0t e 5t da una parte e nessuna porta 0 dall'altra. quindi questa cosa per me non assomiglia minimamente a quello che stavi cercando di fare.
Penso dobbiate chiedere aiuto a qualcuno che conosca il vostro device, Per quanto riguarda il dga4131 non mi sembra ci siano problemi.
« Ultima modifica: 28 Maggio 2020, 13:06 da LuKePicci »
Offline matteoa91
  • 18
« Risposta #1093 il: 28 Maggio 2020, 13:43 »
la configurazione da me è praticamente speculare a quella che hai appena messo.
la ps4 va in timeout tentando di acquisire l'ip via dhcp, se volete però provo anche con il pc!
sul dga è tutto disabilitato, dal wansensing al dhcp e il wifi.
anche secondo me il problema è sul dga, è per quello che ho messo l'output del comando ifconfig lanciato dal dga, secondo me c'entra qualcosa il traffico su eth2 e eth2.2 (che sulla seconda trasmette e basta)
« Risposta #1094 il: 28 Maggio 2020, 14:21 »
Ok, dall'immagine ho capito che le due porte verso la cpu sono 6 (eth1) e 0 (eth0) e che il dga è connesso sulla porta 5. Per cui la config giusta per @matteoa91 del Netgear è questa:
### R7800
 option ifname 'lo'
 option ifname 'eth1.2'
 option delegate '0'
 option proto 'dhcp'
 option peerdns '0'
 list dns '1.1.1.1'
 list dns '1.0.0.1'
 option delegate '0'
config switch
 option reset '1'
config switch_vlan
 option vlan '2'
 option ports '6t 1 2 3 4 5t'
 option vid '2'
config switch_vlan
 option vlan '3'
 option vid '3'
Quella di @xasor61400 è corretta ma usa in modo invertito vid 2 e 3 ed anche la porta 0 (eth0) al posto della 6 (eth1).
PS comunque se usate le due porte cpu distinte per lan e wan credo possiate anche evitare di taggarle lato cpu. Una cosa del genere (sempre secondo le convenzioni di @matteoa91) dovrebbe funzionare ugualmente:
### R7800
 option ifname 'lo'
 option ifname 'eth1'
 option delegate '0'
 option ifname 'eth0'
 option proto 'dhcp'
 option peerdns '0'
 list dns '1.1.1.1'
 list dns '1.0.0.1'
 option delegate '0'
config switch
 option reset '1'
config switch_vlan
 option vlan '2'
 option ports '6 1 2 3 4 5t'
 option vid '2'
config switch_vlan
 option vlan '3'
 option ports '0 5t'
 option vid '3'
« Ultima modifica: 28 Maggio 2020, 14:35 da LuKePicci »
