[GUIDA] Flash, Root e Modding Technicolor TG788vn v2 (VDNT-W)
  • 433 Risposte
  • 256644 Visite
Re:technicolor tg788vn-v2
« Risposta #75 il: 31 Marzo 2019, 14:35 »
Ho usato questa configurazione:
config interface 'loopback'
        option ifname 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fd44:c6aa:46d9::/48'
        option vlanmode 'bcmvopi'
config interface 'lan'
        option ifname 'eth0 eth1 eth2 eth3'
        option type 'bridge'
        option ipaddr '192.168.1.254'
        option ip6assign '64'
        option force_link '0'
        option ipv6 '1'
        list pppoerelay ''
config switch 'bcmsw'
option reset '1'
option enable_vlan '0'
option qosimppauseenable '1'
config interface 'wan'
option vendorid 'Technicolor'
option authfail '0'
option ipv6 '0'
option release '1'
option iface6rd '0'
option auto '1'
option username 'timadsl'
option mtu '1492'
option password 'timadsl'
option proto 'pppoe'
option ifname 'ptm0_v835'
config interface 'wan6'
option ifname '@wan'
option proto 'dhcpv6'
option reqopts '3 12 21 22 23 24 25 31 56 64 67 82 83'
option noslaaconly '1'
option iface_464xlat '0'
option reqaddress 'none'
config device 'ptm0'
option mtu '1508'
option name 'ptm0'
config device 'waneth4'
option enabled '1'
option type '8021q'
option name 'waneth4'
option vid '835'
config device 'wanptm0'
option enabled '1'
option type '8021q'
option name 'wanptm0'
option vid '835'
option ifname 'ptm0'
config config 'config'
option wan_mode 'pppoe'
config bcmvopi 'ptm0_v835'
option if 'ptm0'
option vid '835'
option dscp2pbits 'yes'
config interface 'ipoe'
option proto 'dhcp'
option metric '1'
option release '1'
option ipv6 '1'
E mi alzato pppoe-wan
ptm0
ptm0_v835
  • 3417
« Risposta #76 il: 01 Aprile 2019, 01:40 »
ah eccco, hai aggiunto la sezione wanptm0 per far andare tutto up (il che ha rotto anche le prove di luke).. a questo punto vorrei capire in messico secondo quale logica questi cosi riescono a funzionare ... magari basta un option enabled '1' nella bcmvopi ptm0_v835  o qualcosa del genere ma da stock chi glielo metterebbe ?!
« Risposta #77 il: 01 Aprile 2019, 06:55 »
Con la gui stock wanptm0 e ptm0_v835 funziona solo con il wansensing abilitato e i file di configurazione del wansensing di UNO.
Con i file di configurazione stock ptm0_v835 funziona solo col il wansensing disabilitato mentre wanptm0 non funziona proprio.
Con il wansensing abilitato in wan mi mette ptm0_v881 e non funziona. Se provo a mettere il vlan id da gui me lo trasforma in qualcosa del tipo ptm0_v881.835 che nella configurazione non esiste. Se riesco faccio altre prove magari a fare come dici tu o mettere config interface 'ptm0_v881.835' o altro.
@FrancYescO
Va bene che il mondo è sottosopra ma così si esagera.
« Ultima modifica: 01 Aprile 2019, 07:04 da larsen64it »
  • 3417
« Risposta #78 il: 01 Aprile 2019, 10:25 »
mettere il . dopo un'interfaccia serve per definire una VLAN con una notazione diversa, in pratica con ptm0_v881.835 e' come se mettesse la VLAN 835 sotto quella 881 (ammesso che ptm0_v881 abbia come option vid 881) insomma credo sia tutto sbagliato ma e' perche' la GUI non ha mai gestito le interfacce bcmvopi
ad esempio potresti mettere nel blocco wan come interfaccia ptm0.835 e tutto dovrebbe funzionare
quello che si dovrebbe fare e' mandarlo online "come mamma l'ha fatto" (quindi niente wanptm0 che e' un nome di interfaccia che mette la GUI custom, e ho paura lo faccia anche facendo un reset di fabbrica perche' e' inserito "vicino" ai comandi che si assicurando di fare il rooting post reset) il problema e' che anche mettendo a mano un vid diverso (l'835 "italiano") nella config bcmvopi ptm0_v881 io non ero riuscito a farlo andare online
« Risposta #79 il: 01 Aprile 2019, 10:39 »
Ho rifatto il test da zero e l'ho rimandato a LuKePicci
La connessioni si alza solo con questa configurazione:
root@OpenWrt:~# cat /etc/config/network
option ifname 'lo'
option ula_prefix 'fde8:fb4a:d952::/48'
option ipv6 '1'
list pppoerelay ''
option reset '1'
option authfail '0'
option ipv6 '0'
option release '1'
option iface6rd '0'
option auto '1'
option mtu '1492'
option if 'ptm0'
option vid '835'
option enabled '1'
root@OpenWrt:~#
Questa è la configurazione originale
root@OpenWrt:~# cat /etc/config/network.orig
option ifname 'lo'
option ipv6 '1'
list pppoerelay ''
option reset '1'
option keepalive '5,10'
option pppoe_backoff '1,32'
option username '[email protected]'
option password '5fb12d6e0cdd72fdc2a747c8fe412b'
option ifname 'ptm0_v881'
option auto '1'
config interface 'ppp_8_35'
option ifname 'atm_8_35_v0'
option auto '0'
config interface 'ppp_8_81'
option ifname 'atm_8_81_v0'
option auto '0'
config bcmvopi 'atm_8_35_v0'
option if 'atm_8_35'
option vid '0'
option defvid 'yes'
config bcmvopi 'atm_8_81_v0'
option if 'atm_8_81'
option vid '0'
option defvid 'yes'
config bcmvopi 'ptm0_v881'
option if 'ptm0'
option vid '881'
root@OpenWrt:~#
Noterai che in fondo ne manca un pezzo, non vorrei che lo usassero solo per l'adsl.
Offline ItalianGamer91
  • 408
« Risposta #81 il: 01 Aprile 2019, 11:18 »
E' quello che stiamo usando.
  • 408
« Risposta #82 il: 01 Aprile 2019, 11:47 »
Allora cerco altri firmware. Niente non esiste nessun altro firmware forse provare con telnor oppure in grecia da wind grecia
« Risposta #83 il: 01 Aprile 2019, 11:56 »
Ci dovrebbe essere un fantomatico  17.2.0360 sempre messicano. Wind grecia esiste ma per un modello simile. Telnor non ho idea.
  • 408
« Risposta #84 il: 01 Aprile 2019, 12:42 »
« Risposta #85 il: 01 Aprile 2019, 12:45 »
E' per VDNT-4   il tg788vn V2 è VDNT-W, con tutte queste sigle ci fanno diventare scemi. Magari sono uguali ma con bootloader diverso
« Risposta #86 il: 03 Aprile 2019, 10:19 »
Attivato il wifi guest
  • 3417
« Risposta #87 il: 03 Aprile 2019, 11:08 »
Condividi conf che risparmi un po di lavoro per la GUI :)
« Risposta #88 il: 03 Aprile 2019, 11:18 »
Basta chiedere.
https://www62.zippyshare.com/v/Tz2FXKzX/file.html
P.S. & O.T. Usando la stessa configurazione network sono riuscito a mettere la wan/eth5 nel bridge dello scolapasta bianco, ovvio lo switch eth5/wan non è attivo.
Comandi switch 2.4/5 GHZ
wl down
wl band a # o auto ma la gui mostra canali sballati
wl chanspec 36
wl up
wifionoff.sh
wifionoff.sh
« Ultima modifica: 03 Aprile 2019, 11:33 da larsen64it »
« Risposta #89 il: 04 Aprile 2019, 12:01 »
Installato luci, GUI Telstra, Cups 2.1.4 ed attivato printersharing. Lo spazio disponibile è questo
Non so se convenga tenere le applicazioni per il p2p, visto che girerebbero con moooolta fatica.
