[GUIDA] Flash, Root e Modding Technicolor TG788vn v2 (VDNT-W)
  • 433 Risposte
  • 252451 Visite
Re:technicolor tg788vn-v2
« Risposta #60 il: 28 Marzo 2019, 11:15 »
Ma non ti aggancia proprio la portante o non va per alzare la PPP?
Ci dovrebbe essere anche la versione 17.2 0360 (quella che si vede nel video sopra) ma e' caccia all'rbi ...
17.2.0360-2249000 per la precisione
« Ultima modifica: 28 Marzo 2019, 11:36 da LuKePicci »
« Risposta #61 il: 28 Marzo 2019, 11:17 »
Comunque lo avevo già portato on-line con questa configurazione manuale.
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd06:aaa3:a2ac::/48'
option vlanmode 'bcmvopi'
config interface 'lan'
option type 'bridge'
option ipaddr '192.168.1.254'
option ip6assign '64'
option force_link '0'
option ipv6 '1'
list pppoerelay ''
list pppoerelay ''
list ifname 'eth0'
list ifname 'eth1'
list ifname 'eth2'
list ifname 'eth3'
config switch 'bcmsw'
option reset '1'
option enable_vlan '0'
option qosimppauseenable '1'
config interface 'wan'
option proto 'pppoe'
option vendorid 'Technicolor'
option authfail '0'
option ipv6 '0'
option release '1'
option iface6rd '0'
option auto '1'
option username 'timadsl'
option mtu '1492'
option password 'timadsl'
option ifname 'wanptm0'
config interface 'vdsl_check'
option ifname 'ptm0'
option keepalive '5,10'
option auto '0'
option graceful_restart '1'
option authfail '0'
option mtu '1500'
option ipv6 '0'
option release '1'
option iface6rd '0'
config interface 'wan6'
option ifname '@wan'
option proto 'dhcpv6'
option reqopts '3 12 21 22 23 24 25 31 56 64 67 82 83'
option noslaaconly '1'
option iface_464xlat '0'
option reqaddress 'none'
config device 'ptm0'
option mtu '1508'
option name 'ptm0'
config device 'waneth4'
option enabled '1'
option type '8021q'
option name 'waneth4'
option vid '835'
config device 'wanptm0'
option enabled '1'
option type '8021q'
option name 'wanptm0'
option vid '835'
config config 'config'
option wan_mode 'pppoe'
Appena posso riprovo con la gui
« Risposta #62 il: 28 Marzo 2019, 11:28 »
Ma quando mi hai fatto il dump con quei due comandi lo avevi connesso via dsl o eth?
  • 3404
« Risposta #63 il: 28 Marzo 2019, 11:36 »
non alzava la ppp, era sicuramente qualcosa di molto stupido che ho sbagliato, forse appunto solo un servizio non riavviato per fargli prendere la config
di default nella config telmex ci sono quelle sezioni bcmvopi che non ho ben capito se lavorano diversamente..
« Risposta #64 il: 28 Marzo 2019, 12:00 »
Broadcom VOPI (VLAN Operations Interface) è un modo diverso da 802.1q di fare vlan. Se vuoi connetterlo a TIM non sono sicuro tu possa usare ptm0_v881 o una sua analoga ptm0_v835 che è di tipo bcmvopi (non so se è 802.1q compatibile), potresti doverne crearne una nuova del solito tipo 8021q. Tra l'altro, bada a quel network.globals.vlanmode='bcmvopi'
PS: come se non fosse già abbastanza un casino, c'è anche una collisione di acronimi con VOPI (Voice over Private Internet), anche se in questo caso non dovrebbe interessarvi.
« Ultima modifica: 28 Marzo 2019, 12:11 da LuKePicci »
« Risposta #65 il: 28 Marzo 2019, 12:58 »
Se ti riferivi a me i comandi li avevo dati con il collegamento eth.
Un attimo di pazienza per le prove il router è a 3 piani di distanza, tante scale ed una certa età. Se poi si impalla... cavi metti il cavo... connettori rotti vai con la  crimpatrice ... man... por... e via dicendo
Questa configurazione funziona, previo riavvio ripulita di tutti i  ptm  e atm di default
option ifname 'lo'
option ipaddr '192.168.0.254'
option ipv6 '1'
list pppoerelay ''
list pppoerelay ''
list ifname 'eth0'
list ifname 'eth1'
list ifname 'eth2'
list ifname 'eth3'
option reset '1'
option authfail '0'
option ipv6 '0'
option release '1'
option iface6rd '0'
option auto '1'
option mtu '1492'
option mtu '1508'
option name 'ptm0'
option enabled '1'
option type '8021q'
option vid '835'
option enabled '1'
option type '8021q'
option vid '835'
  • 3404
« Risposta #66 il: 28 Marzo 2019, 13:38 »
Forse era questo il mio problema, e forse bcmvopi e 802.1q non possono convivere..
« Risposta #67 il: 28 Marzo 2019, 18:44 »
Confermo che mi connetto con la configurazione ripulita postata sopra altrimenti tenta connettersi con:
config interface 'ppp_8_81'
   option ifname 'atm_8_81_v0'
   option auto '0'
si connette anche con ptm0_v835 in wan  e
config bcmvopi 'ptm0_v835'
   option if 'ptm0'
   option vid '835'
   option dscp2pbits 'yes'
Tra wanptm0 e ptm0_v835 meglio la prima.
« Ultima modifica: 28 Marzo 2019, 18:49 da larsen64it »
« Risposta #68 il: 28 Marzo 2019, 19:21 »
Ok allora sono compatibili, ma in che senso meglio la prima? (se e quando mi rifai il dump cerca di farlo mentre usi la seconda)
« Risposta #69 il: 28 Marzo 2019, 20:43 »
Nel senso che con la mia schifosa vdsl, con il primo aggancia un 10% in meno con il secondo il 15% rispetto altri router, poi dipende dai casi. Per il dump spero domani.
@FrancYescO
Ora lo scan wifi funziona ma la card è incasinata
P.S. Per l'upgrande della gui non si potrebbe usare il led upgrade?   /sys/class/leds/upgrade:blue/brightness
Vista l'abbondanza del led a disposizione non so cosa vi inventerete a capodanno
« Ultima modifica: 29 Marzo 2019, 18:40 da larsen64it »
« Risposta #70 il: 31 Marzo 2019, 12:24 »
Con la configurazione di UNO la card wifi torna a posto. Ma!
  • 3404
« Risposta #71 il: 31 Marzo 2019, 12:39 »
Si la parte led sarebbe tutta da riguardare (tipo far accendere broadband quando configurato in eth, usare il led eco che nemmeno sapevo esistesse, quando il wifi e' spento..)
con tutti i led acceso e' davvero caruccio  :D
comunque a me quel casotto sulla modal wifi non succedeva, controllo un po meglio, sara' che stavo facendo prove per cercare di aggiungere la rete guest..
« Risposta #72 il: 31 Marzo 2019, 12:54 »
Per guest l'ho messa solo sul wifi
Con la configurazione di UNO tutto OK. AriMA!
« Risposta #73 il: 31 Marzo 2019, 13:03 »
Ho dato una occhiata più attenta agli ultimi dump che hai condiviso. Qui un riepilogo di come appare configurato lo stack nei vari casi:
test1:
Device.IP.Interface.3 (wan)
Device.PPP.Interface.1 (pppoe-wan)
Device.Ethernet.VLANTermination.3 (wanptm0)
Device.Ethernet.Link.5 (wanptm0)
Device.PTM.Link.1 (ptm0)
Device.DSL.Channel.1 (dsl0)
Device.DSL.Line.1 (dsl0)
test2:
Device.Ethernet.Link.6 (wan)                  <--- ???
test3:
Come vedete, negli ultimi due casi (wan configurata su ptm0_v835) lo stack sembra sostanzialmente rotto. LA cosa antipatica è che il provisioning mi si ferma proprio dopo avergli dato in pasto lo stato descrittivo di PPP.1, contenente tra le altre cose anche il nome dell'interfaccia sottostante che in teoria dovrebbe esplorare al passo successivo.  :huh:
  • 3404
« Risposta #74 il: 31 Marzo 2019, 13:15 »
ma anche quel wanptm0 poco sotto mi sa strano, da dove viene fuori se nella config stock non c'e ?
