TIM HUB DGA 4132 Router WIFI night off settings and IPv6 problem !
  • 4 Risposte
  • 6402 Visite
Offline makili
Hi,
I have a problem to setup both WIFI signals ( 2,4GHZ and 5GHz) during the night to go offline.  If i name them separately the times are always overlapped and I canīt define rules for both of them.
Even if I have both of them under same name only for instance 2.4GHz goes offline but not 5GHz signal.
Also, my ISP gives me IPv6 but how to configure it within settings, IPv4 works great.
thanks
Offline zoomx
  • 589
Re:TIM HUB DGA 4132 Router WIFI night off settings and IPv6 problem !
« Risposta #1 il: 06 Dicembre 2018, 11:50 »
The simplest way may be a wifi up and wifi down in cron. It is described here
https://oldwiki.archive.openwrt.org/doc/uci/wireless
in Start/Stop Wireless section.
There is a discussion starting from here, about two pages...
https://www.ilpuntotecnico.com/forum/index.php/topic,78162.msg237609.html#msg237609
this seems to work
https://www.ilpuntotecnico.com/forum/index.php/topic,78162.msg237622.html#msg237622
Since othe models use ToD daemon
https://www.ilpuntotecnico.com/forum/index.php?topic=79713.0
maybe it's the same on Tim Hub.
I never shut down wifi since I have some devices that send data H24.
Offline makili
« Risposta #2 il: 06 Dicembre 2018, 12:43 »
Thank you very much,
Iīll check this out today.
Any idea on IPV6, does it work with 1.1.0 firmware with latest stable Ansuel GUI?
By the way, why canīt I directly reach Ansuel through this forum, no private messages possible?
cheers
« Risposta #3 il: 06 Dicembre 2018, 12:51 »
Maybe has set the account up in order to receive MPs from admins only :)
« Ultima modifica: 06 Dicembre 2018, 12:52 da MisterFTTH »
Offline makili
« Risposta #4 il: 06 Dicembre 2018, 13:04 »
Thatīs nice.
