  • 2281 Risposte
  • 1167105 Visite
Offline donato74
  • 197
Confermo quanto riportato da Castelbravo sul traffic monitor; carica all'infinito
Offline alekos
  • 34
@alekos certo la modifica è molto veloce... riguardo la sezione mi dovresti dire l'errore che ti esce nei log (logread -f e pari la sezione)
ecco il log
root@modemtim:~# logread -f
Sun Mar 25 11:14:06 2018 daemon.err cwmpd[12586]: TRANSFORMER_PROXY: recv() time                               d out
Sun Mar 25 11:14:06 2018 daemon.warn cwmpd[12586]: TRANSFORMER_PROXY: Closing co                               nnection due to previous error
Sun Mar 25 11:14:06 2018 daemon.err cwmpd[12586]: TRANSFORMER_PROXY: cwmp_view_a                               ddsubscription_exec failed
Sun Mar 25 11:14:06 2018 daemon.warn cwmpd[12586]: CWMPUCI: pushapi_load_forceda                               ctives - set forcedactive success -  path: Device.ManagementServer.ConnectionReq                               uestURL
Sun Mar 25 11:14:06 2018 daemon.warn cwmpd[12586]: CWMPUCI: pushapi_load_forceda                               ctives - set forcedactive success -  path: Device.DSL.Line.1.LinkStatus
Sun Mar 25 11:14:06 2018 daemon.warn cwmpd[12586]: CWMPUCI: pushapi_load_forceda                               ctives - set forcedactive success -  path: Device.DSL.Line.1.StandardUsed
Sun Mar 25 11:14:06 2018 daemon.warn cwmpd[12586]: CWMPUCI: pushapi_load_forceda                               ctives - set forcedactive success -  path: Device.PPP.Interface.1.IPCP.LocalIPAd                               dress
Sun Mar 25 11:14:06 2018 daemon.info cwmpd[12586]: TRANSFORMER_PROXY: cwmp_softw                               areversion_changed -- SoftwareVersion changed = false
Sun Mar 25 11:14:08 2018 kern.warn kernel: [30384.969000] dosprotect rpfilter dr                               op IN=br-lan OUT= MAC=01:00:5e:7f:ff:fa:a6:91:b1:14:a3:55:08:00 SRC=192.168.1.25                               2 DST=239.255.255.250 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
Sun Mar 25 11:14:16 2018 daemon.err cwmpd[12586]: CDUS_TRACE: cwmp_changedustate                               api_flush CURRENTLY NOT IMPLEMENTED
Sun Mar 25 11:14:25 2018 daemon.err nginx: 2018/03/25 11:14:25 [error] 12754#0:                                *3 lua entry thread aborted: runtime error: /usr/lib/lua/web/taint.lua:280: bad                                argument #2 to 'format' (no value)
stack traceback:
coroutine 0:
        [C]: in function 'format'
        /usr/lib/lua/web/taint.lua:280: in function 'format'
        [string "broadband-bridge.lp"]:55: in function 'content'
        /usr/lib/lua/web/lp.lua:171: in function 'include'
        [string "/modals/broadband-modal.lp"]:294: in function 'content'
        /usr/lib/lua/web/web.lua:249Sun Mar 25 11:14:25 2018 daemon.err nginx: 2                               018/03/25 11:14:25 [error] 12754#0: *2 lua entry thread aborted: runtime error:                                /usr/lib/lua/web/taint.lua:280: bad argument #2 to 'format' (no value)
stack traceback:
coroutine 0:
        /usr/lib/lua/web/web.lua:249Sun Mar 25 11:14:25 2018 daemon.err nginx: 2                               018/03/25 11:14:25 [error] 12754#0: *4 lua entry thread aborted: runtime error:                                /usr/lib/lua/web/taint.lua:280: bad argument #2 to 'format' (no value)
stack traceback:
coroutine 0:
        /usr/lib/lua/web/web.lua:249Sun Mar 25 11:14:29 2018 daemon.info odhcpd[                               3000]: Using a RA lifetime of 0 seconds on wl0_1
Sun Mar 25 11:14:29 2018 daemon.notice odhcpd[3000]: Failed to send to ff02::1%w                               l0_1 (Operation not permitted)
Sun Mar 25 11:15:00 2018 cron.info crond[3026]: USER root pid 12862 cmd /sbin/trafficdata.lua
Sun Mar 25 11:15:08 2018 daemon.err nginx: 2018/03/25 11:15:07 [error] 12754#0: *5 lua entry thread aborted: runtime error: /usr/lib/lua/web/taint.lua:280: bad argument #2 to 'format' (no value)
stack traceback:
coroutine 0:
        /usr/lib/lua/web/web.lua:249Sun Mar 25 11:15:09 2018 daemon.err nginx: 2018/03/25 11:15:08 [error] 12754#0: *6 lua entry thread aborted: runtime error: /usr/lib/lua/web/taint.lua:280: bad argument #2 to 'format' (no value)
stack traceback:
coroutine 0:
« Ultima modifica: 25 Marzo 2018, 11:21 da MisterFTTH »
Offline massdass
  • 14
una domanda:
ho la la versione 6.6.1, è l'ultima stabile disponibile?
Offline donato74
  • 197
Chiedo supporto: avevo la 6.6.1 e ho provato l'ultima DEV;  mi dava problemi con CWMP e quindi sono tornato almeno per ora alla 6.6.1
Peccato che ora CWMP non funzioni manco con questa GUI.
Ho riavviato il DGA 4132 ovviamente; zero risultati.
Suggerimenti?
Offline donato74
  • 197
@massdass Si, la 6.6.1 è la ultima stable
@donato74 basta settare l'indirizzo invece di regman mon in regman-tl e a porta in 10700
E dovrebbe partire fammi sapere!
Offline donato74
  • 197
  @Ansuel No joy!
modificato la url in https://regman-tl.interbusiness.it:10700/acs/
provato a attivare e disattivare, ottengo sempre "Non è stato possibile procedere con la richiesta. Si prega di riprovare più tardi"
Premetto di non aver riavviato il tim hub per ora.
il link sulla tua linea è raggiungibile?
modificalo manualmente da winscp e poi fai /etc/init.d/cwmpd restart
Offline donato74
  • 197
Ho banalmente ripristinato una config salvata in precedenza e ora funziona, sia in WiFi che 3G. GUI 6.6.1, la url che vedo è  https://regman-mon.interbusiness.it:10800/acs/
Vuoi che riprovi con la ultima DEV o non ti serve come test?
@donato74 se vuoi ;)
comunque il monitoraggio traffico a me funziona chi mi da log a chi non funziona? provato con un riavvio?
come non detto... non ho idea del motivo per cui prima funzionava ahahha ma comunque ora è ok...
« Ultima modifica: 25 Marzo 2018, 17:55 da Ansuel »
Offline donato74
  • 197
Confermo che adesso il traffico funziona. Anche il CWMP mi pare funzioni. Curiosità, in UPnP, che differenza cè fra datamodel 1 e 2?
non ne ho idea google è il tuo amico... è stato introdotto stock solo per compatibilità
Offline CastleBravo
  • 266
ma i led una volta spenti non si riaccendono più?
Se c'è qualcosa che non va si riaccendono
Offline CastleBravo
  • 266
uhm... ma non si riesce a fare che se si riclicca si riaccendono?
