  • 6081215 Visite
Offline puandr
  • 309
    • Riconoscimi
« Risposta #3225 il: 30 Ottobre 2017, 10:46 »
Buongiorno a tutti,
sono nuovo del forum,
sono riuscito ad installare e configurare OpenVPN, ho ancora qualche problemino con OpenSSL, ma sono sulla buona strada.
Di seguito la procedura di installazione di OpenVPN, OpenSSL e Easy-RSA:
wget -P /tmp http://brcm63xx-tch.ddns.net/base/libltdl_2.4-1_brcm63xx-tch.ipk
opkg install /tmp/libltdl_2.4-1_brcm63xx-tch.ipk
wget -P /tmp http://brcm63xx-tch.ddns.net/packages/collectd_5.4.2-2_brcm63xx-tch.ipk
opkg install /tmp/collectd_5.4.2-2_brcm63xx-tch.ipk
wget -P /tmp http://brcm63xx-tch.ddns.net/packages/collectd-mod-openvpn_5.4.2-2_brcm63xx-tch.ipk
opkg install /tmp/collectd-mod-openvpn_5.4.2-2_brcm63xx-tch.ipk
wget -P /tmp http://brcm63xx-tch.ddns.net/base/openssl-util_1.0.2g-1_brcm63xx-tch.ipk
opkg install /tmp/openssl-util_1.0.2g-1_brcm63xx-tch.ipk
wget -P /tmp http://brcm63xx-tch.ddns.net/base/openvpn-easy-rsa_2013-01-30-2_brcm63xx-tch.ipk
opkg install /tmp/openvpn-easy-rsa_2013-01-30-2_brcm63xx-tch.ipk
cp /etc/easy-rsa/openssl-1.0.0.cnf /etc/easy-rsa/openssl.cnf
wget -P /tmp http://brcm63xx-tch.ddns.net/base/kmod-tun_3.4.11-rt19-1_brcm63xx-tch.ipk
opkg install --nodeps  /tmp/kmod-tun_3.4.11-rt19-1_brcm63xx-tch.ipk
wget -P /tmp http://brcm63xx-tch.ddns.net/base/liblzo_2.08-1_brcm63xx-tch.ipk
opkg install /tmp/liblzo_2.08-1_brcm63xx-tch.ipk
wget -P /tmp http://brcm63xx-tch.ddns.net/base/openvpn-openssl_2.3.6-5_brcm63xx-tch.ipk
opkg install /tmp/openvpn-openssl_2.3.6-5_brcm63xx-tch.ipk
Con vi va aggiunta la seguente interfaccia sul config di network
vi /etc/config/network
config interface 'vpn0'
        option ifname 'tap0'
        option proto 'none'
        option auto '1'
E la seguente regola sul firewall
vi /etc/config/firewall
config rule 'Allow_OpenVPN_Inbound'
        option target 'ACCEPT'
        option src '*'
        option proto 'udp'
        option dest_port '1194'
dopodiché va fatto il reload
/etc/init.d/network reload
/etc/init.d/firewall reload
Poi andiamo a creare le chiavi RSA:
pkitool --initca
pkitool --server my-server
pkitool my-client
openssl dhparam -out dh2048.pem 2048
Ma già qui nascono i primi problemi:
pkitool my-client
dovrebbero creare anche i certificati CRT, ma non li creano, quindi devo forzare la creazione con:
pkitool --sign my-client
pkitool --sign my-server
Ma il certificato my-server.crt viene creato con
            X509v3 Extended Key Usage:
                TLS Web Client Authentication
e non 'TLS Server Authentication'
Pertanto fallisce l'handshake all'apertura della connessione OpenVPN:
2017-10-29 20:02:37 VERIFY ERROR: depth=0, error=unsupported certificate purpose: C=US, ST=CA, L=SanFrancisco, O=Fort-Funston, OU=MyOrganizationalUnit, CN=my-server, name=EasyRSA, [email protected]
2017-10-29 20:02:37 OpenSSL: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Ciao Andrea
Offline kkurt
  • 78
« Risposta #3226 il: 30 Ottobre 2017, 10:59 »
Puoi anche creare le chiavi su un'altra piattaforma e poi copiarle dentro.
Offline Lumanuel
  • 92
« Risposta #3227 il: 30 Ottobre 2017, 11:50 »
Apprezzo l'ottimo lavoro ma "GETAWAY" alla napoletana al posto di GATEWAY proprio non si può vedere.  :hahaha:
Grazie mille, @TeddyRaspin76! L'ho controllato addirittura cinque volte. Eh... niente, quando sei stanco, bisogna dormire. Non c'è nulla da fare! :P
Spero di avere del tempo, anche se la vedo dura!
« Risposta #3228 il: 30 Ottobre 2017, 12:04 »
Quando tutto è finito avvisami che inserisco tutto in una nuova versione... non vedo comunque i crediti... Dove ti cito per la gui nuova :O
Ottimo lavoro comunque davvero complimenti... Tim secondo me dovrebbe iniziare ad adottare questo rispetto allo schifo che c'è ora :)
Offline Lumanuel
  • 92
« Risposta #3229 il: 30 Ottobre 2017, 13:00 »
Non preoccuparti per i crediti, @Ansuel!! Ci mancherebbe. Li avevo nascosti momentaneamente, perché avevo in mente un'altra cosa: dargli ancora più "rispetto"!
Comunque è una BETA. Ci gioco tra un momento libero e un altro.
« Risposta #3230 il: 30 Ottobre 2017, 13:04 »
secondo me è meglio con lo sfondo... anche modificare lo stile del responsive per mostrare più di 4 caselle non sarebbe male...
Offline CrAcK
  • 135
« Risposta #3231 il: 30 Ottobre 2017, 13:27 »
Ragazzi, dato che ci state mettendo le mani, è possibile aumentare i secondi di refresh della pagina?
Che fastidio quando stai scorrendo e non hai nemmeno il tempo di capire dove cliccare che si riaggiorna e ti torna in testa...   :smash:
Offline shdf
  • 981
« Risposta #3232 il: 30 Ottobre 2017, 13:43 »
@puandr
con la GUI 3.16 il repository brcm63xx-tch è integrato, non è più necessario scaricare pacchetti con wget.
opkg update
opkg install libltdl
opkg install collectd
opkg install collectd-mod-openvpn
opkg install openssl-util
opkg install openvpn-easy-rsa
opkg install --nodeps kmod-tun
opkg install liblzo
opkg install openvpn-openssl
Offline aezakmi123
  • 201
« Risposta #3233 il: 30 Ottobre 2017, 14:55 »
Buongiorno a tutti,
pkitool my-client
Ma il certificato my-server.crt viene creato con e non 'TLS Server Authentication'
Ciao Andrea
Io avevo creato i certificati con
build-ca
build-dh
build-key-server my-server
build-key-pkcs12 my-client
Unica cosa ho dovuto modificare in /etc/easy-rsa/vars
# This variable should point to
# the openssl.cnf file included
# with easy-rsa.
export KEY_CONFIG=/etc/easy-rsa/openssl-1.0.0.cnf
Comunque non sono riuscito a configurarlo avendoci provato varie volte e alla fine ho lasciato stare
Offline -Mirco-
  • 1832
    • Ilpuntotecnicoeadsl
« Risposta #3234 il: 30 Ottobre 2017, 15:52 »
Buongiorno a tutti,
pkitool my-client
Ciao Andrea
Ottima guida, la inserisco nella FAQ .  :bravo:
Ayrton Senna
Offline shdf
  • 981
« Risposta #3235 il: 30 Ottobre 2017, 16:08 »
@-Mirco-
How to install Aria2 + webui : http://forum.kitz.co.uk/index.php/topic,20343.msg356456.html#msg356456
How to install Transmission + Webui : http://forum.kitz.co.uk/index.php/topic,20343.msg356335.html#msg356335
Magari qualcuno può tradurre in buon italiano? :D: :frust:
« Ultima modifica: 30 Ottobre 2017, 16:11 da shdf »
Offline -Mirco-
  • 1832
« Risposta #3236 il: 30 Ottobre 2017, 16:13 »
@-Mirco-
Good man  :bravo:
I will add this too  :good:
Ayrton Senna
Offline hyenA-
  • 19
« Risposta #3237 il: 30 Ottobre 2017, 19:14 »
@-Mirco-
In your opinion wich one is better between these two?
Offline sangria
  • 17
« Risposta #3238 il: 30 Ottobre 2017, 19:21 »
Mi interessa ma mi da' errore, thread non esistente.
E' possibile ottenere l'accesso?
Offline shdf
  • 981
« Risposta #3239 il: 30 Ottobre 2017, 19:31 »
Actualy, Transmission because Aria2 was compiled without torrent support  :smash: :smash:
But when we will have a new version in the repo (@roleo), i hope Aria2 will be compiled with support to everything. :toohappy:
« Ultima modifica: 30 Ottobre 2017, 19:32 da shdf »
