  • 6067882 Visite
Offline shdf
  • 981
« Risposta #2295 il: 09 Ottobre 2017, 21:40 »
install libstdcpp http://brcm63xx-tch.ddns.net/base/libstdcpp_4.8-linaro-1_brcm63xx-tch.ipk
Grazie ! spero che non mi abbia rotto tutto....
root@modemtim:~# opkg install http://brcm63xx-tch.ddns.net/base/libstdcpp_4.8-linaro-1_brcm63xx-tch.ipk
Downloading http://brcm63xx-tch.ddns.net/base/libstdcpp_4.8-linaro-1_brcm63xx-tch.ipk.
Multiple packages (libstdcpp and libstdcpp) providing same name marked HOLD or PREFER. Using latest.
Upgrading libstdcpp on root from 4.6-linaro-1 to 4.8-linaro-1...
Removing obsolete file /usr/lib/libstdc++.so.6.0.16-gdb.py.
Removing obsolete file /usr/lib/libstdc++.so.6.0.16.
Configuring libstdcpp.
Offline ItalianGamer91
  • 408
« Risposta #2296 il: 09 Ottobre 2017, 21:43 »
technicolor finalmente mi ha mandato i sorgenti dell'Xtream 16.2.7384
@Ansuel
brutta notizia non ti hanno dato il kernel source code quello lo devi far richiedere da linux ma il bello che dentro e pieno di source code di software opkg ma niente kernel l'archivio deve pesare 450-550mbyte compresso 300mbyte
« Ultima modifica: 09 Ottobre 2017, 21:48 da ItalianGamer91 »
Offline pigr8
  • 175
« Risposta #2297 il: 09 Ottobre 2017, 21:52 »
i installed that package, nothing is broken :asd: i even started aria2 some pages ago, it works
« Ultima modifica: 09 Ottobre 2017, 21:59 da pigr8 »
  • 408
« Risposta #2298 il: 09 Ottobre 2017, 21:52 »
ragazzi rimango esterrefatto
* OS:
    Ubuntu 12.04 / Ubuntu 14.04
* Use bash shell instead of dash default:
  $ dpkg-reconfigure dash
* Install required tools:
  $ apt-get install git-core build-essential libssl-dev libncurses5-dev unzip gawk
* Toolchain:
    gcc-4.6-linaro (https://releases.linaro.org/archive/13.05/components/toolchain/gcc-linaro/4.6/)
* The following source code files are covered by a dual license Broadcom Proprietary/GPL-v2.
  Given the agreement with Broadcom, the proprietary license terms are chosen with priority by Technicolor:
    bcm_userspace/broadcom_apps/shared/opensource/boardparms/bcm963xx/boardparms_voice.c
    bcm_userspace/broadcom_apps/shared/opensource/boardparms/bcm963xx/boardparms.c
    bcm_userspace/broadcom_apps/shared/opensource/boardparms/bcm963xx/bp_defs.h
    bcm_userspace/broadcom_apps/shared/opensource/spi/bcmHsSpi.c
    bcm_userspace/broadcom_apps/shared/opensource/spi/bcmSpiRes.c
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/bcmTag.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/robosw_reg.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63138_cpu.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/robosw_reg_shared.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6368_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/bcmnetlink.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/bcm_misc_hw_init.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/boardparms.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6818_intr.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/60333_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6318_cpu.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6328_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63148_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6318_intr.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6318_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/boardparms_voice.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63138_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/flash_api.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/60333_cpu.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63381_intr.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/bcm_mm.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6838_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6828_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63138_intr.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/bcm_ethsw.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6362_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63148_intr.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/bcm_hwdefs.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63381_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6838_intr.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/bcm_chip_arch.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63268_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63381_cpu.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/60333_intr.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6838_cpu.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/6818_map_part.h
    bcm_userspace/broadcom_apps/shared/opensource/include/bcm963xx/63148_cpu.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_apm.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_drv.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/BPCM.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/command.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_usb.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_sata.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_sar.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_dsl.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/clk_rst.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_pcie.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_pcm.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_switch.h
    bcm_userspace/broadcom_apps/shared/opensource/include/pmc/pmc_cpu_core.h
    bcm_userspace/broadcom_apps/shared/opensource/include/drv/unimac/unimac_drv.h
    bcm_userspace/broadcom_apps/shared/opensource/include/drv/mdio/mdio_drv.h
    bcm_userspace/broadcom_apps/shared/opensource/include/drv/phys/extphy/extphy_drv.h
    bcm_userspace/broadcom_apps/shared/opensource/include/drv/phys/egphy/egphy_drv.h
    bcm_userspace/broadcom_apps/shared/opensource/include/drv/phys/phys_common_drv.h
    bcm_userspace/broadcom_apps/shared/opensource/include/drv/dpi/data_path_init.h
    bcm_userspace/broadcom_apps/shared/opensource/include/drv/dpi/oren_data_path_init.h
    bcm_userspace/broadcom_apps/shared/opensource/include/drv/dpi/bcm63138_data_path_init.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_eth.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_ubus.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/96838_rdp_map.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_psram.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_drv_bbh.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_subsystem_common.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_gponclkout_cfg.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/base/packing.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_ms1588.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_map.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_cpu_ring_sim.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_ih.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/access_macros.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_runner.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_cpu_ring_inline.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_bpm.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/bl_os_wraper.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_bbh.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_gpon.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_drv_sbpm.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/hwapi_mac.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_drv_ih.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_dma.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_drv_bpm.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/963148_rdp_map.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_cpu_ring.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/963138_rdp_map.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_wan.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_sbpm.h
    bcm_userspace/broadcom_apps/shared/opensource/include/rdp/rdp_mm.h
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl2/Makefile
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl2/pmc_sysfs.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl2/pmc_pcie.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl2/command.h
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl2/pmcapp.h
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl2/pmc_drv.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl2/clk_rst.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/Makefile
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_sysfs.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/app63381.h
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_dsl.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_pcie.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/restart.h
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_apm.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmcapp.h
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_drv.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_sar.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/restart_a42.h
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_pcm.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_usb.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/clk_rst.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_switch.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_sata.c
    bcm_userspace/broadcom_apps/shared/opensource/pmc/impl1/pmc_cpu_core.c
    bcm_userspace/broadcom_apps/shared/opensource/drv/unimac/unimac_drv_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drv/mdio/mdio_drv_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drv/phys/phys_common_drv.c
    bcm_userspace/broadcom_apps/shared/opensource/drv/phys/extphy/extphy_drv_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drv/phys/egphy/egphy_drv_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drv/dpi/oren_data_path_init.c
    bcm_userspace/broadcom_apps/shared/opensource/drv/dpi/bcm63138_data_path_init.c
    bcm_userspace/broadcom_apps/shared/opensource/flash/spinandflash.c
    bcm_userspace/broadcom_apps/shared/opensource/flash/cfiflash.c
    bcm_userspace/broadcom_apps/shared/opensource/flash/flash_api.c
    bcm_userspace/broadcom_apps/shared/opensource/flash/nandflash.c
    bcm_userspace/broadcom_apps/shared/opensource/flash/flash_common.c
    bcm_userspace/broadcom_apps/shared/opensource/flash/spiflash.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/Makefile
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_drv_sbpm.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_bbh_arrays.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_drv_ih.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_cpu_ring.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_dma_arrays.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_drv_bbh.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_runner_arrays.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_drv_bpm.c
    bcm_userspace/broadcom_apps/shared/opensource/rdp/rdp_ubus_arrays.c
    bcm_userspace/broadcom_apps/shared/opensource/utils/shared_utils.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_misc_hw_init_impl2.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_pinmux_impl2.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_chip_arch.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_led_impl3.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_gpio_impl2.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_ethsw_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_misc_hw_init_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_led_impl2.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_misc_hw_init_impl4.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_ethsw_impl2.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_pinmux_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_gpio_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_misc_hw_init_impl3.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/wan_drv_impl1.c
    bcm_userspace/broadcom_apps/shared/opensource/drivers/bcm_led_impl1.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_msg/oal.h
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_msg/msg.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_msg/linux/Makefile
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_msg/linux/oal_msg.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/unicode.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/prctl.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/led.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/passwd.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/timer.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/assert.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/errorcodes.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/memory.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/random.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/hexbinary.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linklist.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/eid_parser.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/ftrace.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/oal.h
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/strconv.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/data_model_selector.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/xml.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/eid.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/tokenizer.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/image_modsw_linux.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/strconv2.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_memory.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_file.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_readlog.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_strconv.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_passwd.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_timestamp.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_prctl.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_logging.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_network.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/linux/oal_pid.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/image_modsw_linux.h
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/psp.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/file.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/logging.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/network.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/timestamp.c
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_util/image.c
    bcm_userspace/broadcom_apps/userspace/public/libs/stlport/Makefile
    bcm_userspace/broadcom_apps/userspace/public/libs/httpdshared/httpdshared.c
    bcm_userspace/broadcom_apps/userspace/public/libs/httpdshared/httpdshared.h
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_boardctl/linux/Makefile
    bcm_userspace/broadcom_apps/userspace/public/libs/cms_boardctl/linux/board.c
    bcm_userspace/broadcom_apps/userspace/public/libs/bcm_flashutil/bcm_flashutil.c
    bcm_userspace/broadcom_apps/userspace/public/libs/bcm_flashutil/bcm_flashutil.h
    bcm_userspace/broadcom_apps/userspace/public/libs/bcm_util/bcm_crc.c
    bcm_userspace/broadcom_apps/userspace/public/libs/bcm_util/bcm_crc.h
    bcm_userspace/broadcom_apps/userspace/public/include/Makefile
    bcm_userspace/broadcom_apps/userspace/public/include/prctl.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_ftrace.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_tmr.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_tokenizer.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_errorcodes.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_util.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_hexbinary.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_msg_homeplug.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_mem.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_strconv2.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_boardcmds.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_params.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_dlist.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_params_modsw.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_image.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_boardioctl.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_tms.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_data_model_selector.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_xml.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_ast.h
    bcm_userspace/broadcom_apps/userspace/public/include/uuid.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_led.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_strconv.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_net.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_unicode.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_linklist.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_log.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_rand.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_fil.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_eid.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_psp.h
    bcm_userspace/broadcom_apps/userspace/public/include/linux/os_defs.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_base64.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_msg_modsw.h
    bcm_userspace/broadcom_apps/userspace/public/include/simcard_ctl_api.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_msg.h
    bcm_userspace/broadcom_apps/userspace/public/include/cms_pwd.h
    bcm_userspace/broadcom_apps/userspace/public/apps/send_cms_msg/Makefile
    bcm_userspace/broadcom_apps/userspace/public/apps/send_cms_msg/send_cms_msg.c
    bcm_userspace/broadcom_apps/userspace/public/apps/cgroupctl/Makefile
    bcm_userspace/broadcom_apps/userspace/public/apps/tracectl/Makefile
    bcm_userspace/broadcom_apps/userspace/public/apps/psictl/psictl.c
    bcm_userspace/broadcom_apps/userspace/public/apps/bcm_boot_launcher/Makefile
    bcm_userspace/broadcom_apps/userspace/public/apps/bcm_boot_launcher/bcm_boot_launcher.c
    bcm_userspace/broadcom_apps/userspace/public/apps/simcard/Makefile
    bcm_userspace/broadcom_apps/userspace/public/apps/simcard/simcard_sample.c
    bcm_userspace/broadcom_apps/userspace/public/apps/bdmf_shell/bdmf_shell_client.c
    bcm_userspace/broadcom_apps/userspace/public/apps/scratchpadctl/scratchpadctl.c
    bcm_userspace/broadcom_apps/userspace/public/apps/ledctl/ledctl.c
    bcm_userspace/broadcom_apps/userspace/public/apps/memaccess/memaccess.c
    bcm_userspace/broadcom_apps/userspace/public/apps/sendpackets/sendpackets.c
    bcm_userspace/broadcom_apps/userspace/gpl/apps/udhcp/bcmqos.c
    * <:copyright-BRCM:2010:DUAL/GPL:standard
    *    Copyright (c) 2010 Broadcom Corporation
    *    All Rights Reserved
    * Unless you and Broadcom execute a separate written software license
    * agreement governing use of this software, this software is licensed
    * to you under the terms of the GNU General Public License version 2
    * (the "GPL"), available at http://www.broadcom.com/licenses/GPLv2.php,
    * with the following added to such license:
    *    As a special exception, the copyright holders of this software give
    *    you permission to link this software with independent modules, and
    *    to copy and distribute the resulting executable under terms of your
    *    choice, provided that you also meet, for each linked independent
    *    module, the terms and conditions of the license of that module.
    *    An independent module is a module which is not derived from this
    *    software.  The special exception does not apply to any modifications
    *    of the software.
    * Not withstanding the above, under no circumstances may you combine
    * this software in any way with any other Broadcom software provided
    * under a license other than the GPL, without Broadcom's express prior
    * written consent.
che famo
Offline pigr8
  • 175
« Risposta #2299 il: 09 Ottobre 2017, 21:54 »
ma no, c'è tutto :asd: controlla bene
c'è anche scritto di scaricare il 3.4.11 da qui https://www.kernel.org/pub/linux/kernel/v3.x/linux-3.4.11.tar.bz2
« Ultima modifica: 09 Ottobre 2017, 21:57 da pigr8 »
Offline shdf
  • 981
« Risposta #2300 il: 09 Ottobre 2017, 22:05 »
@pigr8
Sai come fare funzionare il webui Ariang o webui-aria2 con aria2c ?
Ho installato la webui su http://192.168.1.1/aria2/index.html
ma dice sempre "not connected".
Ho provato a installare i package xmlrpc-* ma non cambia niente...
Offline roleo
  • 4601
« Risposta #2301 il: 09 Ottobre 2017, 22:12 »
Ciao roleo, ho installato il pacchetto kmod-tun tramite l' opzione  nodeps e successivamente provveduto ad installare openvpn e tutte le dipendenze. Dopo aver configurato il tutto e riavviato il router riesco a vedere openvpn attivo tramite il comando ps | grep "openvpn" ma non vedo l interfaccia del  tunnel tramite ifconfig. Qualche consiglio? grazie
Prova ifconfig -a
Se non ricordo male l'interfaccia va su solo a tunnel stabilito.
Ti consiglio anche di utilizzare la libopenssl del repository e disinstallare quella presente di default.
Usate il pulsante "Ricerca".
  • 408
« Risposta #2302 il: 09 Ottobre 2017, 22:15 »
https://www.google.com/maps?ll=51.53949,-0.31061&z=9&t=m&hl=it-IT&gl=US&mapclient=embed cioè sti figli della mignotta scusate il linguaggio scurrile prendono e da gran Bretagna mandano la roba domani con la mia sim virgin mobile prendo e gli dico ei belli datemi anche a me il sorgente del tg789vac pero versione v2
che poi il loro sito e un sito di upload che tiene la roba per 5 giorni e poi la rendono in accessibile
Offline pigr8
  • 175
« Risposta #2303 il: 09 Ottobre 2017, 22:21 »
@pigr8
was the deamon running when you tried to connect?
launch it using
aria2c --enable-rpc --rpc-listen-all=true --rpc-allow-origin-all
as you can see it it's running, and i had the webinterface working too.
Offline pigr8
  • 175
« Risposta #2304 il: 09 Ottobre 2017, 22:24 »
se glielo chiedi gentilmente, ti mostri preparato e soprattutto nel tuo caso riesci a farti capire loro non hanno problemi a mandarti tutto il materiale, con me sono stati disponibili e preparati e mi hanno mandato tutto, ora gli ho chiesto se mi mandano anche i sorgenti per il dga sia 16.11 che 17.x, vediamo che dicono.
Offline shdf
  • 981
« Risposta #2305 il: 09 Ottobre 2017, 22:24 »
yes i did the  aria2c --enable-rpc --rpc-listen-all=true --rpc-allow-origin-all
but no connection.
How did you install your aria2 web interface ? did you modified like me the nginx.conf ?
Offline pigr8
  • 175
« Risposta #2306 il: 09 Ottobre 2017, 22:28 »
but no connection.
nope, i didn't install it, it was running on another machine just to test the connection i then removed aria2.
  • 408
« Risposta #2307 il: 09 Ottobre 2017, 22:43 »
c'e un client come aria2 per scaricare torrent?? se si come lo installo
ps mi addi su skype cosi posso parlarti di una cosa
Offline shdf
  • 981
« Risposta #2308 il: 09 Ottobre 2017, 22:50 »
@ItalianGamer91
si c'è Transmission + webui
c'è anche rtorrent + webui
Segnalo che Transmission (client BitTorrent) e' perfettamente funzionante installando questi 3 pacchetti:
libevent2_2.0.22-1_brcm63xx-tch.ipk
transmission-daemon_2.84-3_brcm63xx-tch.ipk
transmission-web_2.84-3_brcm63xx-tch.ipk
Una volta installati bisogna editare il file /etc/config/transmission ed impostare:
option enabled 1
e specificare i vari percorsi per il download (ovviamente su hdd esterno collegato alla porta usb).
fatto questo riavviare il servizio con /etc/init.d/transmission restart
L'interfaccia e' accessibile da http://indirizzodelrouter:9091
Ho monitorato l'utilizzo della cpu durante il download e non supera il 17-18% quindi non compromette le prestazioni del router.
« Ultima modifica: 09 Ottobre 2017, 22:52 da shdf »
  • 408
« Risposta #2309 il: 09 Ottobre 2017, 22:55 »
@ItalianGamer91
thanks bro if you make a tuto for me how to install
