zyxel P-660H-T1-v3s (cerco firmware)
  • 0 Risposte
  • 4063 Visite
Offline leofante7
« il: 26 Agosto 2017, 10:15 »
Ciao, sono venuto in possesso di questo modem/router che probabilmente a causa di un errato aggiornamento del firmware e' defunto.
Collegandomi  sulla seriale ottengo:
Bootbase Version: VTC_SPI_WR1.10 | 2010/06/23 09:32:52
RAM: Size = 16384 Kbytes
DRAM POST: Testing: 16384K
OK
Found SPI Flash 2MiB Winbond W25Q16 at 0xbfc00000
SPI Flash Quad Enable
Turn off Quad Mode
RAS Version: 3.40(TSC.1)
Press any key to enter debug mode within 3 seconds.
signature error!
Interrompendo nei 3 secondi:
OK
Turn off Quad Mode
Enter Debug Mode
at
OK
athe
======= Debug Command Listing =======
AT          just answer OK
ATHE          print help
ATBAx         change baudrate. 1:38.4k, 2:19.2k, 3:9.6k 4:57.6k 5:115.2k
ATENx,(y)     set BootExtension Debug Flag (y=password)
ATSE          show the seed of password generator
ATRLx         display the 32-bit value of address x
ATGO(x)       run program at addr x or boot router
ATGR          boot router
ATRTw,x,y(,z) RAM test level w, from address x to y (z iterations)
ATSH          dump manufacturer related data in ROM
ATTD          download router configuration to PC via XMODEM
ATUR          upload router firmware to flash ROM
ATLC          upload router configuration file to flash ROM
ATXSx         xmodem select: x=0: CRC mode(default); x=1: checksum mode
ATLD          Upload Configuration File and Default ROM File to Flash
ATCD          Convert Running ROM File to Default ROM File into Flash
OK
il problema e' che sui siti della zyxel (ad es questo ftp://ftp.zyxel.dk/) non sono riuscito a trovare il firmware per questo modello.
Ho provato a mettere firmware di modelli simili ma non funziona
atur
Starting XMODEM upload (CRC mode)....
C
Total  1284608 bytes received.
Wrong product firmware!!
Please upgrade the newest firmware version!!
ERROR
c'e' qualcuno che ha il firmware per questo modello (zyxel P-660H-T1-v3s)?
foto della scheda
https://drive.google.com/open?id=0B6H9MgZEPvHJa0NqNEk2WVlZRkk
grazie in anticipo
« Ultima modifica: 27 Agosto 2017, 10:05 da leofante7 »
