cpa-znte62fwb openwrt abilitare chiavetta wifi nella presa usb posteriore
  • 19 Risposte
  • 15462 Visite
Offline franchino2
  • 213
con il modem fastweb cpa-znte62fwb openwrt vorrei abilitare chiaveta wifi nella presa usb posteriore
con putty do questo comando
root@OpenWrt:~# lsusb
-ash: lsusb: not found
devo istallare qualche pacchetto?
« Ultima modifica: 10 Marzo 2016, 22:33 da Miguel89 »
Non sono un esperto di OpenWrt, ma credo che devi caricare il kmod contenente il driver del chip della tua chiavetta wi-fi
Offline franchino2
  • 213
ho istallato questo:
opkg update
opkg install kmod-usb-uhci      Modules for USB 1.1
opkg install kmod-usb-ohci
opkg install kmod-usb2           Modules for USB 2.0
dato questo comando
root@OpenWrt:~# dmesg
[    0.000000] Linux version 3.3.8 (blogic@Debian-60-squeeze-64-minimal) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Sat Mar 23 18:09:20 UTC 2013
[    0.000000] Detected Broadcom 0x6358 CPU revision a1
[    0.000000] CPU frequency is 300 MHz
[    0.000000] 32MB of RAM installed
[    0.000000] registering 40 GPIOs
[    0.000000] gpiochip_add: registered GPIOs 0 to 39 on device: bcm63xx-gpio
[    0.000000] board_bcm963xx: Boot address 0xbe000000
[    0.000000] board_bcm963xx: CFE version: 1.0.37-3.9
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU revision is: 0002a010 (Broadcom BMIPS4350)
[    0.000000] board_bcm963xx: board name: CPVA642
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 02000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Zone PFN ranges:
[    0.000000]   Normal   0x00000000 -> 0x00002000
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000000 -> 0x00002000
[    0.000000] On node 0 totalpages: 8192
[    0.000000] free_area_init_node: node 0, pgdat 802dab70, node_mem_map 81000000
[    0.000000]   Normal zone: 64 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 8128 pages, LIFO batch:0
[    0.000000] Reserving 0MB of memory at 0MB for crashkernel
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
[    0.000000] Kernel command line:  root=/dev/mtdblock2 rootfstype=squashfs,jffs2 noinitrd console=ttyS0,115200
[    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[    0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Primary instruction cache 16kB, VIPT, 2-way, linesize 16 bytes.
[    0.000000] Primary data cache 16kB, 2-way, VIPT, cache aliases, linesize 16 bytes
[    0.000000] Memory: 29024k/32768k available (2358k kernel code, 3744k reserved, 501k data, 204k init, 0k highmem)
[    0.000000] NR_IRQS:128
[    0.000000] Calibrating delay loop... 297.98 BogoMIPS (lpj=595968)
[    0.036000] pid_max: default: 32768 minimum: 301
[    0.040000] Mount-cache hash table entries: 512
[    0.052000] NET: Registered protocol family 16
[    0.068000] registering PCI controller with io_map_base unset
[    0.072000] registering PCI controller with io_map_base unset
[    0.092000] bio: create slab <bio-0> at 0
[    0.100000] PCI host bridge to bus 0000:00
[    0.104000] pci_bus 0000:00: root bus resource [mem 0x30000000-0x37ffffff]
[    0.108000] pci_bus 0000:00: root bus resource [io  0x8000000-0x8007fff]
[    0.112000] pci 0000:00:01.0: [1814:0401] type 0 class 0x000280
[    0.112000] pci 0000:00:01.0: reg 10: [mem 0xffff8000-0xffffffff]
[    0.124000] pci 0000:00:01.0: BAR 0: assigned [mem 0x30000000-0x30007fff]
[    0.128000] PCI host bridge to bus 0000:01
[    0.132000] pci_bus 0000:01: root bus resource [mem 0x38000000-0x3fffffff]
[    0.136000] pci_bus 0000:01: root bus resource [io  0x8008000-0x800ffff]
[    0.140000] pci 0000:01:1e.0: [14e4:6358] type 2 class 0x000607
[    0.140000] pci 0000:01:1e.0: CardBus bridge to [bus 02-05]
[    0.144000] pci 0000:01:1e.0:   bridge window [io  0x0001-0x0000]
[    0.148000] pci 0000:01:1e.0:   bridge window [io  0x0001-0x0000]
[    0.152000] pci 0000:01:1e.0:   bridge window [mem 0x00000001-0x00000000]
[    0.156000] PCI: Enabling device 0000:01:1e.0 (0000 -> 0003)
[    0.160000] pci 0000:01:1e.0: setting latency timer to 64
[    0.160000] Switching to clocksource MIPS
[    0.172000] NET: Registered protocol family 2
[    0.176000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.184000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[    0.192000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.200000] TCP: Hash tables configured (established 1024 bind 1024)
[    0.208000] TCP reno registered
[    0.208000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.216000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.224000] NET: Registered protocol family 1
[    0.228000] PCI: CLS 0 bytes, default 16
[    0.232000] audit: initializing netlink socket (disabled)
[    0.236000] type=2000 audit(0.236:1): initialized
[    0.244000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.252000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.260000] msgmni has been set to 56
[    0.264000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[    0.272000] io scheduler noop registered
[    0.276000] io scheduler deadline registered (default)
[    0.284000] bcm63xx_uart.0: ttyS0 at MMIO 0xfffe0100 (irq = 10) is a bcm63xx_uart
[    0.292000] console [ttyS0] enabled, bootconsole disabled
[    0.312000] physmap platform flash device: 02000000 at 1e000000
[    0.316000] physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x0000c2 Chip ID 0x0022c9
[    0.328000] physmap-flash.0: Found an alias at 0x800000 for the chip at 0x0
[    0.328000] physmap-flash.0: Found an alias at 0x1000000 for the chip at 0x0
[    0.328000] physmap-flash.0: Found an alias at 0x1800000 for the chip at 0x0
[    0.328000] Amd/Fujitsu Extended Query Table at 0x0040
[    0.332000]   Amd/Fujitsu Extended Query version 1.1.
[    0.340000] physmap-flash.0: Swapping erase regions for top-boot CFI table.
[    0.344000] number of CFI chips: 1
[    0.348000] bcm63xxpart: CFE boot tag found with version 6 and board type CPVA642
[    0.356000] bcm63xxpart: Partition 0 is CFE offset 0 and length 10000
[    0.364000] bcm63xxpart: Partition 1 is kernel offset 10100 and length fff00
[    0.372000] bcm63xxpart: Partition 2 is rootfs offset 110000 and length 6e0000
[    0.380000] bcm63xxpart: Partition 3 is nvram offset 7f0000 and length 10000
[    0.388000] bcm63xxpart: Partition 4 is linux offset 10000 and length 7e0000
[    0.392000] bcm63xxpart: Spare partition is offset 2d0004 and length 51fffc
[    0.400000] 5 bcm63xxpart partitions found on MTD device physmap-flash.0
[    0.408000] Creating 5 MTD partitions on "physmap-flash.0":
[    0.412000] 0x000000000000-0x000000010000 : "CFE"
[    0.424000] 0x000000010100-0x000000110000 : "kernel"
[    0.428000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.444000] 0x000000110000-0x0000007f0000 : "rootfs"
[    0.452000] mtd: partition "rootfs" set to be root filesystem
[    0.460000] mtd: partition "rootfs_data" created automatically, ofs=2D0000, len=520000
[    0.468000] 0x0000002d0000-0x0000007f0000 : "rootfs_data"
[    0.476000] 0x0000007f0000-0x000000800000 : "nvram"
[    0.488000] 0x000000010000-0x0000007f0000 : "linux"
[    0.508000] bcm63xx-wdt bcm63xx-wdt:  started, timer margin: 30 sec
[    0.516000] Registered led device: CPVA642:red:power
[    0.516000] Registered led device: CPVA642:green:power
[    0.516000] Registered led device: CPVA642:red:wifi
[    0.516000] Registered led device: CPVA642:green:wifi
[    0.520000] Registered led device: CPVA642:red:link
[    0.520000] Registered led device: CPVA642:green:link
[    0.520000] Registered led device: CPVA642:green:ether
[    0.520000] Registered led device: CPVA642:green:phone1
[    0.520000] Registered led device: CPVA642:green:phone2
[    0.524000] Registered led device: CPVA642:green:usb
[    0.524000] TCP cubic registered
[    0.528000] NET: Registered protocol family 17
[    0.532000] Bridge firewalling registered
[    0.536000] 8021q: 802.1Q VLAN Support v1.8
[    0.552000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[    0.560000] Freeing unused kernel memory: 204k freed
[    3.416000] eth0: link forced UP - 100/full - flow control off/off
[    3.480000] roboswitch: Probing device eth0: Failed to enable switch
[    3.488000] roboswitch: Probing device eth1: No such device
[    3.496000] roboswitch: Probing device eth2: No such device
[    3.500000] roboswitch: Probing device eth3: No such device
[    5.920000] Button Hotplug driver version 0.4.1
[    6.116000] input: gpio-keys-polled as /devices/platform/gpio-keys-polled.0/input/input0
[   10.184000] JFFS2 notice: (363) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 25 of xref (0 dead, 8 orphan) found.
[   13.628000] Compat-drivers backport release: compat-drivers-2012-09-04-2-gddac993
[   13.636000] Backport based on wireless-testing.git master-2012-09-07
[   13.644000] compat.git: wireless-testing.git
[   13.708000] cfg80211: Calling CRDA to update world regulatory domain
[   13.716000] cfg80211: World regulatory domain updated:
[   13.720000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   13.728000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   13.736000] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   13.744000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   13.752000] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   13.760000] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   14.032000] There is already a switch registered on the device 'eth0'
[   14.036000] roboswitch: Probing device eth1: No such device
[   14.044000] roboswitch: Probing device eth2: No such device
[   14.048000] roboswitch: Probing device eth3: No such device
[   14.272000] usbcore: registered new interface driver usbfs
[   14.276000] usbcore: registered new interface driver hub
[   14.284000] usbcore: registered new device driver usb
[   14.788000] PCI: Enabling device 0000:00:01.0 (0000 -> 0002)
[   14.796000] rt61pci 0000:00:01.0: setting latency timer to 64
[   14.808000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[   14.812000] Registered led device: rt61pci-phy0::radio
[   14.812000] Registered led device: rt61pci-phy0::assoc
[   15.152000] Broadcom 43xx driver loaded [ Features: PNL ]
[   15.388000] PPP generic driver version 2.4.2
[   15.608000] ip_tables: (C) 2000-2006 Netfilter Core Team
[   15.872000] NET: Registered protocol family 24
[   15.956000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[   16.068000] bcm63xx_ehci bcm63xx_ehci.0: BCM63XX integrated EHCI controller
[   16.072000] bcm63xx_ehci bcm63xx_ehci.0: new USB bus registered, assigned bus number 1
[   16.108000] bcm63xx_ehci bcm63xx_ehci.0: irq 18, io mem 0xfffe1300
[   16.124000] bcm63xx_ehci bcm63xx_ehci.0: USB 2.0 started, EHCI 1.00, overcurrent ignored
[   16.132000] hub 1-0:1.0: USB hub found
[   16.136000] hub 1-0:1.0: 2 ports detected
[   16.188000] nf_conntrack version 0.5.0 (456 buckets, 1824 max)
[   16.452000] usb 1-1: new high-speed USB device number 2 using bcm63xx_ehci
[   16.664000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   16.776000] bcm63xx_ohci bcm63xx_ohci.0: BCM63XX integrated OHCI controller
[   16.780000] bcm63xx_ohci bcm63xx_ohci.0: new USB bus registered, assigned bus number 2
[   16.788000] bcm63xx_ohci bcm63xx_ohci.0: irq 13, io mem 0xfffe1400
[   16.856000] hub 2-0:1.0: USB hub found
[   16.860000] hub 2-0:1.0: 1 port detected
[   16.924000] uhci_hcd: USB Universal Host Controller Interface driver
[   22.852000] eth0: link forced UP - 100/full - flow control off/off
[   22.864000] device eth0 entered promiscuous mode
[   22.872000] br-lan: port 1(eth0) entered forwarding state
[   22.876000] br-lan: port 1(eth0) entered forwarding state
[   24.880000] br-lan: port 1(eth0) entered forwarding state
[   32.864000] wlan0: authenticate with 00:14:5c:90:ae:cc
[   32.884000] wlan0: send auth to 00:14:5c:90:ae:cc (try 1/3)
[   32.892000] wlan0: authenticated
[   32.928000] wlan0: associate with 00:14:5c:90:ae:cc (try 1/3)
[   32.936000] wlan0: RX AssocResp from 00:14:5c:90:ae:cc (capab=0x411 status=0 aid=6)
[   32.948000] wlan0: associated
Edit:
ho risolto cosi:
opkg update
opkg install kmod-usb2 kmod-usb-storage kmod-usb-storage-extras block-mount hotplug2
opkg install usbutils
con questi comandi ho risolto il funzionamento di "lsusb"
infatti adesso mi rileva la chiavetta wifi:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
quali driver devo istallare?
Facendo una ricerca nella lista dei pacchetti disponibili scrivendo "kmod RT" ti esce qualche pacchetto per il RT5370?
P.S. NON modificare i messaggi dopo che un utente ti ha risposto! E poi usa il TAG "code" quando devi inserire dei comandi e/o degli output di comandi
« Ultima modifica: 10 Marzo 2016, 22:37 da Miguel89 »
Offline franchino2
  • 213
Facendo una ricerca nella lista dei pacchetti disponibili scrivendo "kmod-rt" mi esce questo:
upload
che sono i tag code?a che servono?
quale programma ftp migliore per modificare i file "network" e "wireless" ?va bene total commander?
« Ultima modifica: 11 Marzo 2016, 12:01 da franchino2 »
Cercando su google ho trovato questo link:
https://dev.openwrt.org/ticket/13951
Il pacchetto che ti serve dovrebbe essere "kmod-rt2800-usb", comunque controlla se nella tua versione è buggato.
P.S. Il tag "code" è uno dei BB Code e serve a racchiudere del testo in una casella e formattarlo in un modo diverso. Guarda come ho modificato il tuo post precedente
P.P.S. Se devi postare un'immagine dello schermo non devi fare una fotografia... In Windows 10 hai ben 4 modi per farlo (ti consiglio lo "Strumento di cattura")
« Ultima modifica: 11 Marzo 2016, 14:41 da Miguel89 »
Offline franchino2
  • 213
per andare sul sicuro,ho trovato un alfetta da 2 watt,collegata alla presas usb mi da questo:
Bus 001 Device 003: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
quali driver dovrei istallare?
kmod-rt2800-usb
questo potrebbe andare bene?
« Ultima modifica: 11 Marzo 2016, 16:27 da franchino2 »
Una semplice ricerca su google con le parole "rt2870/rt3070 openwrt" ti da come rimo risultato questo link con la risposta alla tua domanda:
https://forum.openwrt.org/viewtopic.php?id=45166
P.S. Ti ho già scritto che DEVI USARE il tag CODE quando posti del codice!
Offline franchino2
  • 213
ho istallato i driver:
opkg install kmod-rt2800-lib kmod-rt2800-usb kmod-rt2x00-lib kmod-rt2x00-usb
reboot
tutto ok
caricare immagini
la connessione wifi "Generic MAC80211 802.11bg (radio0)" è la schedina wifi interna del modem fastweb rt2661t
la connessione wifi "Generic MAC80211 802.11bgn (radio1)" è l'alfetta da 2 watt perfetta,l'unica cosa che lavora solo a 100mwatt.....
allora non  un problema di driver...
potrebbe essere che manca qualcosa nella configurazione?
per curiosità posto questa configurazione valida:
« Ultima modifica: 11 Marzo 2016, 18:24 da franchino2 »
Invece secondo me è un problema di driver!
Infatti l'altra scheda è stata riconosciuta correttamente come "802.11bgn" senza nessuna configurazione particolare quindi non devi impostare nulla!
P.S. Ti ho già scritto che DEVI usare il tag CODE e di fare gli screenshot in un modo decente, ma noto con dispiacere che te ne freghi altamente di quello che scrivo. Sei stato già ripreso più volte per il tuo comportamento, questo è il mio ultimo avvertimento, se continui a comportarti in questo modo sarò costretto a bannarti!
Offline franchino2
  • 213
DEVI usare il tag CODE e di fare gli screenshot in un modo decente......
mi puoi spiegare come funzionano e come dovrei fare e come si fanno?
Per usare il tag code ti basta scrivere una [, poi la scritta CODE e poi ]
Poi inserisci il codice/output di comandi da racchiudere della casella
Poi metti un tag di chiusura con [/ la scritta CODE e la ]
Oppure, per far prima, premi il pulsante "Anteprima" in basso a destra così ti escono tutti i bottoni come quelli qui sotto e premi quello con il #
Se hai ancora dubbi ti basta cliccare sulla scritta "Modifica" in alto a destra di uno dei tuoi post che ho editato per vedere come dev'essere usato quel tag
Per quanto riguarda gli screeshot ti ho già inserito un link con 4 modi per farlo, quindi non credo servano altre spiegazioni!
http://www.windowsblogitalia.com/2015/08/cinque-modi-per-fare-uno-screenshot-in-windows-10/
Comunque, in ogni caso, quando vieni ripreso per un comportamento sbagliato, non è corretto IGNORARE gli avvertimenti e perseverare negli errori, ma avresti dovuto scusarti e chiedere spiegazioni se non sapevi come evitarli (o cercare su Google, che non fa mai male!)
Offline franchino2
  • 213
consiglio acquisto chiavetta wifi
« Risposta #12 il: 13 Marzo 2016, 17:16 »
Vorrei comprare una chiavetta wifi da abbinare al modem fastweb openwrt,esiste chiavetta usb wifi alfa 2 watt?
Esiste altro modello chiavetta usb  wifi potente?
Re:consiglio acquisto chiavetta wifi
« Risposta #13 il: 13 Marzo 2016, 17:32 »
Ma non ce l'hai già?!?
Leggendo un po' su google ho visto che ti funziona solo a 100mW perché secondo la normativa italiana non può essere più potente! :( Quindi non ha senso cercarne una più potente
Ci sono dei metodi per aumentare la potenza cambiando la nazione (country code) ma credo sia illegale... quindi se ti beccano di sicuro rischi qualche sanzione...
http://erriko.it/sistemi-operativi/openwrt-sistemi-operativi/openwrt-ed-alfa-network-awus036h/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+erriko+Erriko+dot+IT
P.S. Visto che la chiavetta ce l'hai già e va solo configurata ho spostato tutto nell'altro thread
« Ultima modifica: 13 Marzo 2016, 17:34 da Miguel89 »
Offline franchino2
  • 213
ho trovate 4 chiavette wifi,con putty mi da questo:
mini chiavetta wifi tplink n
Bus 001 Device 121: ID 0bda:8179 Realtek Semiconductor Corp.
chiavetta edu n
Bus 001 Device 122: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
chiavetta vodafone n
Bus 001 Device 123: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
chiavetta wifi skybox con antennina
Bus 001 Device 124: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
quali driver?
ringrazio
« Ultima modifica: 14 Marzo 2016, 19:56 da franchino2 »
