Ripristinare un AGPF in bootloop
  • 2 Risposte
  • 2957 Visite
Offline marraag
« il: 31 Ottobre 2015, 21:43 »
Ho un modem alice gate 2 plus voip che si riavvia in continuazione dopo aver caricato l'immagine AGPF_4.4.2. Il mio scopo era quello di sbloccarlo per usarlo come extender range (c'è qualcosa che mi sfugge). di seguito i messaggi della porta seriale, arriva all'ultima istruzione , e riprende da capo. Grazie in anticipo :)
"[21474538.100] Freeing unused kernel memory: 2106420k freed"
"^[[?6c"
remaining to flash .......  00014240
*** Image flash done *** !
Resetting board...
CFE version 1.0.37-8.7 for AGPF 0004 BCM96358 (32bit,SP,BE)
Build Date: Fri Oct 26 15:01:06 CEST 2007 ( claudio2@buildserver )
Copyright (C) 2000-2005 Broadcom Corporation.
Boot Address 0xbe000000
Initializing Arena.
Initializing Devices.
Flash info:
device_id : 2201
meminfo.nsect : 128
totalSize : 1000000
query.num_erase_blocks : 1
query.device_size : 1000000
Parallel flash device: name AM29LV320MT, id 0x2201, size 16384KB
CPU type 0x2A010: 300MHz, Bus: 133MHz, Ref: 64MHz
CPU running TP0
Total memory: 33554432 bytes (32MB)
Total memory used by CFE:  0x80401000 - 0x80528BD0 (1211344)
Initialized Data:          0x8041E880 - 0x804203E0 (7008)
BSS Area:                  0x804203E0 - 0x80426BD0 (26608)
Local Heap:                0x80426BD0 - 0x80526BD0 (1048576)
Stack Area:                0x80526BD0 - 0x80528BD0 (8192)
Text (code) segment:       0x80401000 - 0x8041E878 (120952)
Boot area (physical):      0x00529000 - 0x00569000
Relocation Factor:         I:00000000 - D:00000000
Board IP address                  : 192.168.1.1:ffffff00
Host IP address                   : 192.168.1.100
Gateway IP address                :
Run from flash/host (f/h)         : f
Default host run file name        : vmlinux
Default host flash file name      : openrg.img
Boot delay (0-9 seconds)          : 1
Boot image (0=latest, 1=previous) : 0
Board Id (0-2)                    : AGPF-S0
Number of MAC Addresses (1-32)    : 13
Base MAC Address                  : 02:10:18:01:00:01
PSI Size (1-64) KBytes            : 24
Main Thread Number [0|1]          : 0
*** Press any key to stop auto run (1 seconds) ***
Auto run second count down: 0
Sizeof Tag Used : 256
Two valid image tags found ...
Trying to boot from FIRST image copy (0x80010000) ...
 latest imageSequence found: ... 18
 - Flash Kernel Address: 0xBE020100
 - Tag->kernelLen: 0x007236A0
 - Tag Kernel crc : 0xE383F1B8 - calculated: 0xE383F1B8
Decompression OK! - starting 0
Entry at 0x80010000
Distribution: AGPF
Version: AGPF_4.4.2
Build Date: 2009/02/18-18:04
Closing network.
Starting program at 0x80010000
SGP START PARTITION: 0
Uncompressing Linux....................................................
Initializing Arena.
Flash info:
device_id : 2201
meminfo.nsect : 128
totalSize : 1000000
CPU running TP0
Entry at 0x80010000
Distribution: AGPF
Version: AGPF_4.4.2
Closing network.
Uncompressing Linux.............................................................        ................................................................................        ................................................................................        ................................................................Ok
Booting the kernel
[21474536.480] Linux version 2.6.16.14 #2 Wed Feb 18 18:04:13 CET 2009
[21474536.480] AGPF-S0 prom init
[21474536.480] CPU revision is: 0002a010
[21474536.480] Determined physical RAM map:
[21474536.480]  memory: 01f00000 @ 00000000 (usable)
[21474536.480] Built 1 zonelists
[21474536.480] Kernel command line:
[21474536.480] brcm mips: enabling icache and dcache...
[21474536.480] Primary instruction cache 32kB, physically tagged, 2-way, linesiz        e 16 bytes.
[21474536.480] Primary data cache 16kB, 2-way, linesize 16 bytes.
[21474536.480] Synthesized TLB refill handler (21 instructions).
[21474536.480] Synthesized TLB load handler fastpath (33 instructions).
[21474536.480] Synthesized TLB store handler fastpath (33 instructions).
[21474536.480] Synthesized TLB modify handler fastpath (32 instructions).
[21474536.480] PID hash table entries: 128 (order: 7, 2048 bytes)
[21474536.480] Using 150.000 MHz high precision timer.
[21474536.485] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[21474536.490] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[21474536.500] Memory: 22228k/31744k available (2110k kernel code, 9516k reserve        d, 341k data, 116k init, 0k highmem)
[21474536.610] Mount-cache hash table entries: 512
[21474536.615] Checking for 'wait' instruction...  available.
[21474536.690] NET: Registered protocol family 16
[21474536.695] SCSI subsystem initialized
[21474536.700] usbcore: registered new driver usbfs
[21474536.705] usbcore: registered new driver hub
[21474536.735] fuse init (API version 7.6)
[21474536.740] io scheduler noop registered
[21474536.745] io scheduler anticipatory registered (default)
[21474536.750] io scheduler deadline registered
[21474536.755] io scheduler cfq registered
[21474536.900]
[21474536.900] Random: 0x55122f2b
[21474537.200] loop: loaded (max 8 devices)
[21474537.205] PCI: Enabling device 0000:00:0a.0 (0000 -> 0002)
[21474537.215] ehci_hcd 0000:00:0a.0: EHCI Host Controller
[21474537.220] ehci_init: 1
[21474537.220] ehci_init: 2
[21474537.225] ehci_init: 3
[21474537.225] ehci_init: 4
[21474537.230] ehci-hcd: writing 96358 extended usb registers
[21474537.260] ehci_hcd 0000:00:0a.0: new USB bus registered, assigned bus numbe        r 1
[21474537.265] ehci_hcd 0000:00:0a.0: irq 18, io mem 0xfffe1300
[21474537.270] ehci_hcd 0000:00:0a.0: USB f.f started, EHCI 1.00, driver 10 Dec        2004
[21474537.275] usb usb1: configuration #1 chosen from 1 choice
[21474537.280] hub 1-0:1.0: USB hub found
[21474537.285] hub 1-0:1.0: 2 ports detected
[21474537.395] hub 1-0:1.0: over-current change on port 1
[21474537.400] PCI: Enabling device 0000:00:09.0 (0000 -> 0002)
[21474537.405] ohci_hcd 0000:00:09.0: OHCI Host Controller
[21474537.410] ohci_hcd 0000:00:09.0: new USB bus registered, assigned bus numbe        r 2
[21474537.415] ohci_hcd 0000:00:09.0: irq 13, io mem 0xfffe1400
[21474537.475] usb usb2: configuration #1 chosen from 1 choice
[21474537.480] hub 2-0:1.0: USB hub found
[21474537.480] hub 2-0:1.0: 2 ports detected
[21474537.505] hub 1-0:1.0: over-current change on port 2
[21474537.615] usbcore: registered new driver usblp
[21474537.615] /home/sj1mingofu/telecom/AGPF_4_4_2/openrg/rg/os/linux-2.6/driver        s/usb/class/usblp.c: v0.13: USB Printer Device Class driver
[21474537.620] Initializing USB Mass Storage driver...
[21474537.625] usbcore: registered new driver usb-storage
[21474537.630] USB Mass Storage support registered.
[21474537.635] usbcore: registered new driver usbserial
[21474537.640] /home/sj1mingofu/telecom/AGPF_4_4_2/openrg/rg/os/linux-2.6/driver        s/usb/serial/usb-serial.c: USB Serial support registered for generic
[21474537.645] usbcore: registered new driver usbserial_generic
[21474537.650] /home/sj1mingofu/telecom/AGPF_4_4_2/openrg/rg/os/linux-2.6/driver        s/usb/serial/usb-serial.c: USB Serial Driver core
[21474537.655] /home/sj1mingofu/telecom/AGPF_4_4_2/openrg/rg/os/linux-2.6/driver        s/usb/serial/usb-serial.c: USB Serial support registered for airprime
[21474537.660] usbcore: registered new driver airprime
[21474537.665] md: raid0 personality registered for level 0
[21474537.670] md: raid1 personality registered for level 1
[21474537.675] md: raid5 personality registered for level 5
[21474537.680] md: raid4 personality registered for level 4
[21474537.685] raid5: measuring checksumming speed
[21474537.715]    8regs     :   237.600 MB/sec
[21474537.740]    8regs_prefetch:   201.600 MB/sec
[21474537.765]    32regs    :   256.800 MB/sec
[21474537.790]    32regs_prefetch:   243.200 MB/sec
[21474537.790] raid5: using function: 32regs (256.800 MB/sec)
[21474537.795] md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
[21474537.800] md: bitmap version 4.39
[21474537.805] u32 classifier
[21474537.805]     OLD policer on
[21474537.810] NET: Registered protocol family 2
[21474537.865] IP route cache hash table entries: 256 (order: -2, 1024 bytes)
[21474537.870] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[21474537.875] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[21474537.880] TCP: Hash tables configured (established 1024 bind 1024)
[21474537.885] TCP reno registered
[21474537.890] IPv4 over IPv4 tunneling driver
[21474537.895] GRE over IPv4 tunneling driver
[21474537.900] NET: Registered protocol family 1
[21474537.905] NET: Registered protocol family 17
[21474537.910] NET: Registered protocol family 8
[21474537.915] NET: Registered protocol family 20
[21474537.915] 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
[21474537.920] All bugs added by David S. Miller <[email protected]>
[21474537.925] brcmboard: brcm_board_init entry
D%G[21474537.930] -- cfi_chip_setup base : 0
[21474537.935] -- cfi_chip_setup base : 0
[21474537.940] -- cfi_chip_setup base : 0
[21474537.945] -- cfi_chip_setup base : 0
[21474537.950] Number of erase regions: 1
[21474537.955] Primary Vendor Command Set: 0002 (AMD/Fujitsu Standard)
[21474537.960] Primary Algorithm Table at 0040
[21474537.965] Alternative Vendor Command Set: 0000 (None)
[21474537.970] No Alternate Algorithm Table
[21474537.975] Vcc Minimum:  2.7 V
[21474537.980] Vcc Maximum:  3.6 V
[21474537.985] No Vpp line
[21474537.985] Typical byte/word write timeout: 128 �s
[21474537.990] Maximum byte/word write timeout: 1024 �s
[21474537.995] Typical full buffer write timeout: 128 �s
[21474538.000] Maximum full buffer write timeout: 4096 �s
[21474538.005] Typical block erase timeout: 1024 ms
[21474538.010] Maximum block erase timeout: 16384 ms
[21474538.015] Chip erase not supported
[21474538.020] Device size: 0x1000000 bytes (16 MiB)
[21474538.025] Flash Device Interface description: 0x0002
[21474538.030]   - supports x8 and x16 via BYTE# with asynchronous interface
[21474538.035] Max. bytes in buffer write: 0x20
[21474538.040] Number of Erase Block Regions: 1
[21474538.045]   Erase Region #0: BlockSize 0x20000 bytes, 128 blocks
[21474538.050] bcm963xx_flash: Found 1 x16 devices at 0x0 in 16-bit bank
[21474538.055] check_cmd_set:entry  type 2 prim:1
[21474538.060] alling :  cfi_cmdset_0002  = 2 p:1
[21474538.065]  Amd/Fujitsu Extended Query Table at 0x0040
[21474538.070] bcm963xx_flash: CFI does not contain boot bank location. Assuming        top.
[21474538.075] number of CFI chips: 1
[21474538.080] cfi_cmdset_0002: Disabling erase-suspend-program due to code brok        enness.
[21474538.085] Creating 1 MTD partitions on "bcm963xx_flash":
[21474538.090] 0x00000000-0x01000000 : "openrg"
[21474538.095] bcm963xx_flash: detected at 0x1e000000 size 16777216 bytes
[21474538.100] bcm963xx_serial driver v2.0
[21474538.105] Freeing unused kernel memory: 2106420k freed
^[[?6c
Per precisare, l'ultima riga, cioè la
^[[?6c
non è un errore ma è proprio quello che scrive il modem.
« Ultima modifica: 01 Novembre 2015, 22:23 da Miguel89 »
Re:Ripristinare un AGPF in bootloop
« Risposta #1 il: 01 Novembre 2015, 22:38 »
Molto strano... Non vorrei che ci fosse qualche problema sulla RAM perché si blocca subito dopo aver cancellato le zone non utilizzate
In ogni caso il fw Telecom non può essere utilizzato come repeater, quindi ti consiglio di caricare il fw D-Link di Roleo
Offline marraag
« Risposta #2 il: 01 Novembre 2015, 23:37 »
Grazie 1000, ho caricato il firmware che mi hai indicato ed il modem funziona perfettamente ora devo solo impostarlo per farlo funzionare da ripetitore.
Grazie nuovamente!
 :D :D :D :D :D
