disconnessioni e calo portante modem guasto o problemi della linea?
  • 9 Risposte
  • 8614 Visite
Offline omarele
  • 39
Ciao a tutti da qualche settimana ho continue disconnessioni del modem con conseguente riaggancio di una portante piu' bassa. qualcuno puo' dirmi dal system log che incollo di seguito se si tratta di un problema del modem o del gestore telefonico (infostrada)?
il modem e' l'AGPWI con il seguente firmware:
Software Version:
TEO_4.2.6.0012
Configuration Version:   DW_4.2.6.0011
Firmware Version:
4.5.3   Upgrade
System Has Been Up For:   117 hours, 0 minutes
e di seguito il system log
Time Event Event-Type Details
Apr 8 17:55:23 2014 System Log Message daemon.warn sys_if_ioctl_mii_execute:488: Both tried MII ioclts 8947/89F0 failed: Operation not supported.
 [repeated 2 times, last time on Apr 8 17:55:23 2014]
Apr 8 17:55:17 2014 System Log Message daemon.err GC: login_cb
Apr 8 17:53:42 2014 System Log Message kern.warn [420194.485] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 17:53:05 2014 System Log Message kern.warn [420157.920] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 17:43:59 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 17:40:46 2014 System Log Message daemon.warn sys_if_ioctl_mii_execute:488: Both tried MII ioclts 8947/89F0 failed: Operation not supported.
 [repeated 2 times, last time on Apr 8 17:40:46 2014]
Apr 8 17:39:57 2014 System Log Message daemon.err GC: login_cb
Apr 8 16:58:43 2014 System Log Message kern.warn [416896.180] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Apr 8 16:56:04 2014 System Log Message kern.warn [416736.575] wl0: wlc_recv: dropping a frame with invalid src mac address a1:0b:77:6c:30:00
Apr 8 16:43:58 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 16:29:11 2014 System Log Message kern.warn [415123.940] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 16:23:01 2014 System Log Message kern.warn [414753.945] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 16:22:41 2014 System Log Message kern.warn [414733.910] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 16:06:51 2014 System Log Message kern.warn [413783.885] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 15:58:35 2014 System Log Message kern.warn [413287.010] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Apr 8 15:58:31 2014 System Log Message kern.warn [413283.850] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 15:54:39 2014 System Log Message kern.warn [413051.105] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 15:54:37 2014 System Log Message kern.warn [413049.290] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 15:43:57 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 15:22:01 2014 System Log Message kern.warn [411093.580] wl0: wlc_ampdu_recv_delba: AMPDU OFF: tid 0 initiator 1 reason 39
Apr 8 15:04:22 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 14:43:57 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 13:58:18 2014 System Log Message kern.warn [406070.140] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Apr 8 13:54:29 2014 System Log Message kern.warn [405841.955] wl0: ampdu_resp_timeout: cleaning up resp tid 0 waiting for seq 0x2eb for 200 ms
Apr 8 13:43:56 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 13:27:38 2014 System Log Message kern.warn [404230.445] wl0: non-802.1X frame from unauthorized station d0:e1:40:c0:63:b7
Apr 8 13:27:38 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 13:27:37 2014 System Log Message kern.warn [404229.980] wl0: non-802.1X frame from unauthorized station d0:e1:40:c0:63:b7
Apr 8 13:17:58 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 13:17:57 2014 System Log Message kern.warn [403650.070] wl0: non-802.1X frame from unauthorized station d0:e1:40:c0:63:b7
Apr 8 13:17:57 2014 System Log Message kern.warn [403650.055] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from d0:e1:40:c0:63:b7
Apr 8 13:11:00 2014 System Log Message kern.warn [403232.280] wl0: wlc_recv: dropping a frame with invalid src mac address 97:85:77:6c:30:00
Apr 8 12:58:10 2014 System Log Message kern.warn [402462.485] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Apr 8 12:43:55 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 12:22:58 2014 System Log Message kern.warn [400350.040] wl0: wlc_recv: dropping a frame with invalid src mac address 97:85:77:6c:30:00
Apr 8 11:58:01 2014 System Log Message kern.warn [398853.305] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Apr 8 10:43:27 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
 [repeated 2 times, last time on Apr 8 11:43:27 2014]
Apr 8 09:49:44 2014 System Log Message kern.warn [391156.875] wl0: wlc_recv: dropping a frame with invalid src mac address 27:8c:77:6c:30:00
Apr 8 09:43:26 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 08:57:34 2014 System Log Message kern.warn [388027.250] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Apr 8 08:46:10 2014 System Log Message kern.warn [387342.305] wl0: ampdu_resp_timeout: cleaning up resp tid 0 waiting for seq 0xc15 for 200 ms
Apr 8 08:43:25 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 08:38:48 2014 System Log Message kern.warn [386900.390] wl0: wlc_recv: dropping a frame with invalid src mac address 75:11:77:6c:30:00
Apr 8 08:22:43 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 08:22:42 2014 System Log Message kern.warn [385934.685] wl0: non-802.1X frame from unauthorized station d0:e1:40:c0:63:b7
Apr 8 07:57:26 2014 System Log Message kern.warn [384419.580] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Apr 8 06:43:23 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
 [repeated 2 times, last time on Apr 8 07:43:24 2014]
Apr 8 06:30:44 2014 System Log Message kern.warn [379216.835] wl0: ampdu_resp_timeout: cleaning up resp tid 0 waiting for seq 0xf5 for 200 ms
Apr 8 06:00:50 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 06:00:49 2014 System Log Message kern.warn [377421.980] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 06:00:49 2014 System Log Message kern.warn [377421.975] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 06:00:49 2014 System Log Message kern.warn [377421.970] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 06:00:49 2014 System Log Message kern.warn [377421.965] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 06:00:49 2014 System Log Message kern.warn [377421.960] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:57:10 2014 System Log Message kern.warn [377202.720] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Apr 8 05:53:59 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 05:53:58 2014 System Log Message kern.warn [377010.400] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:53:58 2014 System Log Message kern.warn [377010.395] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:53:58 2014 System Log Message kern.warn [377010.390] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:53:58 2014 System Log Message kern.warn [377010.385] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:53:58 2014 System Log Message kern.warn [377010.380] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:53:58 2014 System Log Message kern.warn [377010.375] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:53:58 2014 System Log Message kern.warn [377010.370] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:45:05 2014 System Log Message kern.warn [376477.505] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:45:05 2014 System Log Message kern.warn [376477.095] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:45:05 2014 System Log Message kern.warn [376477.085] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:45:05 2014 System Log Message kern.warn [376477.080] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:45:05 2014 System Log Message kern.warn [376477.075] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:45:05 2014 System Log Message kern.warn [376477.070] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:45:05 2014 System Log Message kern.warn [376477.065] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:44:19 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 05:44:18 2014 System Log Message kern.warn [376430.365] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:44:18 2014 System Log Message kern.warn [376430.355] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:44:18 2014 System Log Message kern.warn [376430.350] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:44:18 2014 System Log Message kern.warn [376430.345] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:43:23 2014 System Log Message daemon.err permst_read_header: read header sector 3 (offset 0x7E0000)
Apr 8 05:34:39 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 05:34:38 2014 System Log Message kern.warn [375850.715] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:38 2014 System Log Message kern.warn [375850.340] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:37 2014 System Log Message kern.warn [375850.330] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:37 2014 System Log Message kern.warn [375850.320] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:37 2014 System Log Message kern.warn [375850.315] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:37 2014 System Log Message kern.warn [375850.310] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:37 2014 System Log Message kern.warn [375850.305] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:37 2014 System Log Message kern.warn [375850.300] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:37 2014 System Log Message kern.warn [375850.295] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:34:37 2014 System Log Message kern.warn [375850.290] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:24:56 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.635] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.585] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from 28:e1:4c:3c:e5:05
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.580] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from 28:e1:4c:3c:e5:05
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.575] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from 28:e1:4c:3c:e5:05
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.570] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from 28:e1:4c:3c:e5:05
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.565] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from 28:e1:4c:3c:e5:05
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.560] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from 28:e1:4c:3c:e5:05
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.555] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from 28:e1:4c:3c:e5:05
Apr 8 05:24:55 2014 System Log Message kern.warn [375267.550] wl0.0: wlc_wsec_recvdata_enc_toss unsupported encrypted unicast frame from 28:e1:4c:3c:e5:05
Apr 8 05:17:55 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 05:17:54 2014 System Log Message kern.warn [374847.130] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:17:54 2014 System Log Message kern.warn [374846.810] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:17:54 2014 System Log Message kern.warn [374846.805] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:17:54 2014 System Log Message kern.warn [374846.800] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:13:41 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
Apr 8 05:13:40 2014 System Log Message kern.warn [374592.980] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:13:40 2014 System Log Message kern.warn [374592.970] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:13:40 2014 System Log Message kern.warn [374592.965] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:13:40 2014 System Log Message kern.warn [374592.960] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:13:40 2014 System Log Message kern.warn [374592.955] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:13:40 2014 System Log Message kern.warn [374592.950] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:13:40 2014 System Log Message kern.warn [374592.945] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:13:40 2014 System Log Message kern.warn [374592.940] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
Apr 8 05:11:39 2014 System Log Message daemon.warn Bridge: Can't find cache entry for mac 00:00:00:00:00:00 ret=-1
« Ultima modifica: 10 Maggio 2014, 15:38 da Miguel89 »
In questo log vedo solo errori sulla wl0 (interfaccia wi-fi)
Offline omarele
  • 39
vero eppure ho riscontrato delle disconnessioni con riaggangio di una portante piu' bassa  da quel log non si riesce a capire il motivo?
In questo log non sono nemmeno segnalate!
Offline omarele
  • 39
Ciao a tutti, ditemi invece se da questo log si riesce a capire qualcosa di pių sulle continue disconnessioni della mia linea
May 10 10:42:24 2014 System Log Message daemon.warn sys_if_ioctl_mii_execute:488: Both tried MII ioclts 8947/89F0 failed: Operation not supported.
 [repeated 2 times, last time on May 10 10:42:24 2014]
May 10 10:41:56 2014 System Log Message kern.warn [ 14.585] wl0: wlc_send_bar: seq 0x18f tid 0
May 10 10:41:47 2014 System Log Message kern.warn [ 5.375] 0112: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.370] 0096: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.365] 0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.360] 0064: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.355] 0048: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.350] 0032: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.345] 0016: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.340] 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.340] retry_seq:
May 10 10:41:47 2014 System Log Message kern.warn [ 5.335] 0048: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.330] 0032: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.325] 0016: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.320] 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.320] txretry:
May 10 10:41:47 2014 System Log Message kern.warn [ 5.315] 0000: 00 00 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.310] barpending:
May 10 10:41:47 2014 System Log Message kern.warn [ 5.305] 0000: 00 40 00 00 00 00 00 00
May 10 10:41:47 2014 System Log Message kern.warn [ 5.305] ackpending:
May 10 10:41:47 2014 System Log Message kern.warn [ 5.300] retry_head 24 retry_tail 24 retry_cnt 0
May 10 10:41:47 2014 System Log Message kern.warn [ 5.295] bar_ackpending 0 free_me 0 alive 0 retry_bar 0
May 10 10:41:47 2014 System Log Message kern.warn [ 5.290] start_seq 0x18e max_seq 0x18e tx_exp_seq 0x18e bar_ackpending_seq 0x0
May 10 10:41:47 2014 System Log Message kern.warn [ 5.285] ba_state 3 ba_wsize 32 tx_in_transit 1 tid 0 rem_window 31
May 10 10:41:47 2014 System Log Message kern.warn [ 5.280] wl0: wlc_ampdu_send_delba: tid 0 initiator 1 reason 39
May 10 10:41:47 2014 System Log Message kern.warn [ 5.275] wl0: ampdu_watchdog: cleaning up ini tid 0 due to no progress for 2 secs
May 10 10:40:54 2014 System Log Message daemon.err permst_read_header: read header sector 2 (offset 0x7D0000)
May 10 10:40:53 2014 System Log Message daemon.info igmprx: Init IGMP proxy module
May 10 10:40:53 2014 System Log Message daemon.info igmprx: Uninit IGMP proxy module
May 10 10:40:53 2014 System Log Message daemon.info SNMP: Un-binding agent from 1.1.1.1
May 10 10:40:53 2014 System Log Message daemon.info SNMP: Binding agent on 151.33.61.240
May 10 10:40:53 2014 System Log Message daemon.err mt_igd_tree_rebuild: UPnP reconfiguring tree...
May 10 10:40:53 2014 System Log Message daemon.err RTNL: Received ERROR reply 'No such process' for message type 0x19
May 10 10:40:53 2014 System Log Message daemon.err Set device ppp0 default queue length: 100
May 10 10:40:53 2014 System Log Message daemon.info remote IP address 151.6.130.72
May 10 10:40:53 2014 System Log Message daemon.info local IP address 151.33.61.240
May 10 10:40:50 2014 System Log Message daemon.info Connecting: ppp0
May 10 10:40:50 2014 System Log Message daemon.info mt_disk_mng_hotplug_notify:634: Not interesting hot-plug event
May 10 10:40:50 2014 System Log Message kern.warn [21474784.940] bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=901000, DS=901000
May 10 10:40:50 2014 System Log Message kern.warn [21474784.165] bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=901000, DS=901000
May 10 10:40:50 2014 System Log Message kern.warn [21474784.160] bcmxtmcfg: XTM Link Information, portid = 0, State = UP, Service Support = ATM
May 10 10:40:50 2014 System Log Message kern.crit [21474784.155] Line 0: ADSL link up, Bearer 0, us=901, ds=15709
May 10 10:40:50 2014 System Log Message daemon.err mt_igd_tree_rebuild: UPnP reconfiguring tree...
May 10 10:40:50 2014 System Log Message daemon.info ppp0 started
May 10 10:40:50 2014 System Log Message daemon.warn Failed to set device ethoa0 netmask: Cannot assign requested address
May 10 10:40:50 2014 System Log Message daemon.warn sys_if_ioctl_mii_execute:488: Both tried MII ioclts 8947/89F0 failed: Operation not supported.
May 10 10:40:50 2014 System Log Message daemon.err Set device ethoa0 default queue length: 100
May 10 10:40:50 2014 System Log Message daemon.err dev: ethoa0 -> mac: 30:39:f2:88:e9:64
May 10 10:40:50 2014 System Log Message daemon.err xtm_connect: excuted xtmctl operate conn --addq 1.8.35 100 0, err=0
May 10 10:40:50 2014 System Log Message daemon.err xtm_connect: excuted xtmctl operate conn --addq 1.8.35 100 1, err=0
May 10 10:40:50 2014 System Log Message daemon.err xtm_connect: excuted xtmctl operate conn --addq 1.8.35 100 2, err=0
May 10 10:40:50 2014 System Log Message daemon.err ethoa_connect: itf ethoa0, vpi=8, vci=35
May 10 10:40:49 2014 System Log Message kern.crit [21474783.745] Line 0: ADSL G.992 message exchange
May 10 10:40:47 2014 System Log Message daemon.info estream_connect_ssl_efd 44: failed ssl connetion
May 10 10:40:44 2014 System Log Message kern.crit [21474778.745] Line 0: ADSL G.992 channel analysis
May 10 10:40:44 2014 System Log Message kern.warn [21474778.660] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
May 10 10:40:44 2014 System Log Message kern.warn [21474778.655] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
May 10 10:40:44 2014 System Log Message kern.warn [21474778.650] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
May 10 10:40:44 2014 System Log Message kern.warn [21474778.645] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
May 10 10:40:44 2014 System Log Message kern.warn [21474778.640] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
May 10 10:40:44 2014 System Log Message kern.warn [21474778.635] wl0: non-802.1X frame from unauthorized station 28:e1:4c:3c:e5:05
May 10 10:40:44 2014 System Log Message kern.warn [21474778.605] wl0: wlc_send_bar: seq 0x0 tid 0
May 10 10:40:40 2014 System Log Message kern.crit [21474774.745] Line 0: ADSL G.992 started
May 10 10:40:24 2014 System Log Message kern.crit [21474758.745] Line 0: xDSL G.994 training
May 10 10:40:23 2014 System Log Message kern.warn [21474757.740] bcmxtmcfg: Connection DOWN, LinkActiveStatus=0x0
May 10 10:40:23 2014 System Log Message kern.warn [21474757.735] bcmxtmcfg: XTM Link Information, portid = 0, State = DOWN, Service Support = ATM
May 10 10:40:23 2014 System Log Message kern.crit [21474757.735] Line 0: ADSL link down
May 10 10:40:22 2014 System Log Message kern.crit [21474756.735] Line 0: ADSL G.992 message exchange
May 10 10:40:18 2014 System Log Message kern.crit [21474752.735] Line 0: ADSL G.992 channel analysis
May 10 10:40:13 2014 System Log Message kern.crit [21474747.735] Line 0: ADSL G.992 started
May 10 10:39:59 2014 System Log Message daemon.info estream_connect_ssl_efd 44: failed ssl connetion
May 10 10:39:58 2014 System Log Message daemon.err permst_read_header: read header sector 2 (offset 0x7D0000)
May 10 10:39:58 2014 System Log Message daemon.info SNMP: Binding agent on 1.1.1.1
May 10 10:39:58 2014 System Log Message daemon.err Set device br0:0 default queue length: 100
May 10 10:39:57 2014 System Log Message kern.crit [21474731.630] Line 0: xDSL G.994 training
May 10 10:39:47 2014 System Log Message daemon.info igmprx: Init IGMP proxy module
May 10 10:39:47 2014 System Log Message daemon.info igmprx: Uninit IGMP proxy module
May 10 10:39:47 2014 System Log Message daemon.info mt_disk_mng_hotplug_notify:634: Not interesting hot-plug event
May 10 10:39:47 2014 System Log Message kern.warn [21474720.615] bcmxtmcfg: Connection DOWN, LinkActiveStatus=0x0
May 10 10:39:47 2014 System Log Message kern.warn [21474720.610] bcmxtmcfg: XTM Link Information, portid = 0, State = DOWN, Service Support = ATM
May 10 10:39:47 2014 System Log Message kern.crit [21474720.605] Line 0: ADSL link down
May 10 10:39:47 2014 System Log Message daemon.err dev_if_bcm96368_adsl_tryup::665
May 10 10:39:46 2014 System Log Message daemon.info PPP Exit.
May 10 10:39:45 2014 System Log Message daemon.info Connection terminated.
May 10 10:39:45 2014 System Log Message daemon.err mt_igd_tree_rebuild: UPnP reconfiguring tree...
May 10 10:39:45 2014 System Log Message daemon.info SNMP: Un-binding agent from 151.33.104.79
May 10 10:39:41 2014 System Log Message kern.warn [21474715.665] wl0: wlc_recv: dropping a frame with invalid src mac address 1b:d1:77:6c:30:00
May 10 10:39:37 2014 System Log Message kern.warn [21474711.690] wl0: wlc_recv: dropping a frame with invalid src mac address ff:ff:ff:ff:ff:ff
Jan 1 01:02:23 2003 System Log Message daemon.info TOD got new time 1399714761
Jan 1 01:02:23 2003 System Log Message daemon.err permst_read_header: read header sector 2 (offset 0x7D0000)
Jan 1 01:02:22 2003 System Log Message daemon.info igmprx: Init IGMP proxy module
Jan 1 01:02:22 2003 System Log Message daemon.info igmprx: Uninit IGMP proxy module
Jan 1 01:02:22 2003 System Log Message daemon.info SNMP: Un-binding agent from 1.1.1.1
Jan 1 01:02:22 2003 System Log Message daemon.info SNMP: Binding agent on 151.33.104.79
Jan 1 01:02:22 2003 System Log Message daemon.err mt_igd_tree_rebuild: UPnP reconfiguring tree...
Jan 1 01:02:22 2003 System Log Message daemon.err RTNL: Received ERROR reply 'No such process' for message type 0x19
Jan 1 01:02:22 2003 System Log Message daemon.err Set device ppp0 default queue length: 100
Jan 1 01:02:22 2003 System Log Message daemon.info remote IP address 151.6.130.72
Jan 1 01:02:22 2003 System Log Message daemon.info local IP address 151.33.104.79
Jan 1 01:02:19 2003 System Log Message daemon.info Connecting: ppp0
Jan 1 01:02:19 2003 System Log Message daemon.info mt_disk_mng_hotplug_notify:634: Not interesting hot-plug event
 [repeated 2 times, last time on Jan 1 01:02:19 2003]
Jan 1 01:02:19 2003 System Log Message kern.warn [21474691.445] bcmxtmcfg: Connection UP, LinkActiveStatus=0x1, US=997000, DS=997000
Jan 1 01:02:19 2003 System Log Message kern.warn [21474691.440] [DoCreateDeviceReq.2362]: register_netdev done
Jan 1 01:02:19 2003 System Log Message kern.warn [21474691.430] [DoCreateDeviceReq.2360]: register_netdev
Jan 1 01:02:19 2003 System Log Message kern.warn [21474691.425] bcmxtmrt: MAC address: 00 10 18 00 00 02
Jan 1 01:02:19 2003 System Log Message kern.warn [21474690.530] bcmxtmcfg: XTM Link Information, portid = 0, State = UP, Service Support = ATM
Jan 1 01:02:19 2003 System Log Message kern.crit [21474690.525] Line 0: ADSL link up, Bearer 0, us=997, ds=16999
Jan 1 01:02:19 2003 System Log Message daemon.err mt_igd_tree_rebuild: UPnP reconfiguring tree...
Jan 1 01:02:19 2003 System Log Message daemon.info ppp0 started
Jan 1 01:02:19 2003 System Log Message daemon.warn Failed to set device ethoa0 netmask: Cannot assign requested address
Jan 1 01:02:19 2003 System Log Message daemon.warn sys_if_ioctl_mii_execute:488: Both tried MII ioclts 8947/89F0 failed: Operation not supported.
Jan 1 01:02:19 2003 System Log Message daemon.err Set device ethoa0 default queue length: 100
Jan 1 01:02:19 2003 System Log Message daemon.err dev: ethoa0 -> mac: 30:39:f2:88:e9:64
Jan 1 01:02:19 2003 System Log Message daemon.err xtm_connect: excuted xtmctl operate conn --addq 1.8.35 100 0, err=0
Jan 1 01:02:19 2003 System Log Message daemon.err xtm_connect: excuted xtmctl operate conn --addq 1.8.35 100 1, err=0
Jan 1 01:02:19 2003 System Log Message daemon.err xtm_connect: excuted xtmctl operate conn --addq 1.8.35 100 2, err=0
Jan 1 01:02:19 2003 System Log Message daemon.err ethoa_connect: itf ethoa0, vpi=8, vci=35
Jan 1 01:02:18 2003 System Log Message kern.crit [21474689.620] Line 0: ADSL G.992 message exchange
Jan 1 01:02:14 2003 System Log Message kern.crit [21474685.620] Line 0: ADSL G.992 channel analysis
Jan 1 01:02:10 2003 System Log Message kern.crit [21474681.620] Line 0: ADSL G.992 started
Jan 1 01:01:53 2003 System Log Message kern.crit [21474664.620] Line 0: xDSL G.994 training
Jan 1 01:01:52 2003 System Log Message kern.warn [21474663.615] bcmxtmcfg: XTM Link Information, portid = 0, State = DOWN, Service Support = ATM
Jan 1 01:01:52 2003 System Log Message kern.crit [21474663.615] Line 0: ADSL link down
Jan 1 01:01:47 2003 System Log Message kern.crit [21474658.615] Line 0: ADSL G.992 channel analysis
Jan 1 01:01:43 2003 System Log Message kern.crit [21474654.615] Line 0: ADSL G.992 started
Jan 1 01:01:27 2003 System Log Message kern.crit [21474638.615] Line 0: xDSL G.994 training
Jan 1 01:01:26 2003 System Log Message kern.warn [21474637.610] bcmxtmcfg: XTM Link Information, portid = 0, State = DOWN, Service Support = ATM
Jan 1 01:01:26 2003 System Log Message kern.crit [21474637.610] Line 0: ADSL link down
Jan 1 01:01:25 2003 System Log Message kern.crit [21474636.610] Line 0: ADSL G.992 message exchange
« Ultima modifica: 10 Maggio 2014, 15:43 da Miguel89 »
In questo log si vede una disconnessione con successivo riaggancio ad una portante pių bassa...
Postaci i dati della tua linea (SNR, portante un down e up, attenuazione ecc...) cosė possiamo valutare meglio...
P.S. Ho modificato i tuoi post inserendo i log nel tag "CODE" per evitare messaggi lunghissimi
Offline omarele
  • 39
Il punto e' che quando il modem aggancia la massima portante a cui posso collegarmi, i valori son buoni, capita poi a seguito della perdita di portante che riagganci per esempio 13 mb in down e 500kb in up con conseguente cambio di snr e attenuazione:
Technology:   DSL
Protocol:   PPPoE
User Name:   benvenuto
Mode:   ADSL2+
Type:   Fast
Line Coding:   Trellis on
Status:   No defect
Link Power State:   L16
SNR Margin:   11.9 dB Downstream / 12.6 dB Upstream
Attenuation:   10.0 dB Downstream / 8.1 dB Upstream
Output Power:   12.1 dBm Downstream / 18.8 dBm Upstream
Attainable Rate:   20908 Kbps Downstream / 1069 Kbps Upstream
Connection Speed:   16 Mbps Downstream / 997 Kbps Upstream
boh... probabilmente hai un SNR target impostato a 12 dB...
Appena hai qualche disturbo in pių la linea cade e si riconnette ad una portante minore...
Prova fare un po' di "Overcloking" variando quel valore come indicato in questa guida:
https://www.ilpuntotecnico.com/wiki/index.php?title=Modifica_del_target_SNR
Prova a dare un --snr 25 e vedi che succede...
Offline omarele
  • 39
avevo gia' provato riesco ad agganciare intorno ai 18 Mb ma poi la linea risulta instabile, diciamo che prima di ottobre ovvero prima che iniziassero i lavori nella mia centrale per la fibra a 30 Mb di telecom, la mia linea era perfetta, (Dio sa che combinano in centrale) ora ci sono giorni in cui il modem si riallinea almeno 6 volte comunque ora provero' con un altro modem chipset broadcom e vedremo se il problema era legato al mio modem che si sta guastando
« Ultima modifica: 11 Maggio 2014, 17:44 da omarele »
Offline omarele
  • 39
Ciao Miguel, volevo chiudere il post confermano che sostituendo il modem con un bellissimo netgear d6200, la linea č molto pių stabile, non salta mai ormai da una settimana e aggancio addirittura 1 Mb in pių in download. Era proprio il modem che non funzionava pių a dovere.
Grazie ancora, ciao a tutti
« Ultima modifica: 15 Maggio 2014, 19:15 da omarele »
