ancora ddns su aga 2plus wfi samba 1.6.5
  • 4949 Visite
Offline massimo1
  • 31
« il: 07 Aprile 2008, 12:43 »
ma allora non e proprio possibile avere il ddns su il samba 1.6.5 funzionante come  il firware usr
Offline carlotto
  • 2551
Re: ancora ddns su aga 2plus wfi samba 1.6.5
« Risposta #1 il: 11 Aprile 2008, 19:37 »
Ma ... usi l' aggiornamento dell' IP verso il tuo dynamic name ?
DYNDNS UPDATER README FILE
© 2001-2006 by Kana Solution
This is readme file for DynDNS Updater version 3.1.0.7.
This readme file covers the following topics:
DESCRIPTION
COMPATIBILITY ISSUES
WHAT'S NEW
UPGRADING
VERSION HISTORY
FILE LIST
CONTACT
DESCRIPTION
DynDNS Updater is an utility, which can be used to
automatically update your IP address database on DynDNS
server. Updating your IP address is required to maintain
your dynamic domain name so it still can be reachable.
DynDNS Updater version 3 contains many features that make
updating your hostname very easy.
By default, DynDNS Updater version 3 only supports
DynDNS.org. If you want to enable the multi service
providers support, create an entry IsDynDNS=0 inside
[Options] section of dyndns.ini file. If you do that, your
dyndns.ini file will look like:
[Options]
IsDynDNS=0
DynDNS Updater can be run as service. The service will be
installed with the following dependencies: DHCP Client,
Remote Access Connection Manager, and Workstation. If you
are using Windows NT 4 and using LAN connection, you may not
have Remote Access Connection Manager installed. In this
case, you can just delete the dependencies to Remote Access
Connection Manager by editing the Windows registry.
Please see Microsoft's KB article to delete the dependency
(the URL is wrapped):
http://support.microsoft.com/default.aspx?scid=kb;en-
us;193888&Product=win2000
WHAT'S NEW
DynDNS Updater version 3 adds the following new features:
• Run as regular application or Windows service.
• Update using secure connection.
• Wizard to configure DynDNS Updater for the first run.
• Automatic hostname download for DynDNS.org.
• Automatic connection type detection. Default configuration
  should be suitable for most users.
• Improved user interface to make the program easier to
  maintain.
• The email client supports mail server that required SSL
  connection.
• Supports multi languages through language DLL file. If you
  are interested in translating it into your language,
  please visit http://www.kanasolution.com.
UPGRADING
If you want to upgrade DynDNS Updater from previous version,
you need to replace all old files by the new one. If you are
using Setup program, the Setup wizard will do that
automatically.
VERSION HISTORY
See History.txt file for version history.
FILE LIST
DynDNS Updater distributed with the following list of files:
  DynDNS.exe          - main executable program.
  DynDNS.chm          - help file.
  Readme.txt          - the file that you read now.
  History.txt         - development history.
  libeay32.dll        - openSSL library file.
  ssleay32.dll        - OpenSSL library file.
  OpenSSL-Licence.txt - OpenSSL licence.
CONTACT
For feature request and bug report, please visit
Offline massimo1
  • 31
« Risposta #2 il: 12 Aprile 2008, 10:35 »
scusa mo non o capito la risposta quale aggiornamento mi puoi spiegare
Offline carlotto
  • 2551
« Risposta #3 il: 12 Aprile 2008, 11:30 »
L' aggiornamento del DDNS riferito a www.ddydns.org ...
Ci sono tre modalità di uso del dyndns ... se hai scelto la prima e se l' IP che ti assegna il provider cambia il tuo "Miiohost.ddydns.org" non è più raggiungibile se non utilizzi il programma di aggiornamento automatico e con Alice di Telecom ultimamente il cambio di IP avviene anche 2-3 volte in un giorno come se spegnessi e riaccendessi il router. Vai nel sito e leggi attentamente così capirai. Con il Firmware USR l' IP assegnato dal provider non cambia nemmeno se spegni per pochi minuti il modem ... con il Samba alla riaccensione è sicuramente cambiato.
