FIRMWARE D-LINK 320T (FALLITO)
  • 35 Risposte
  • 19721 Visite
Offline michele1969
  • 11
« il: 20 Novembre 2007, 23:14 »
Ciao a tutti.
Ho provato a caricare il firmare moddato Acorp/McMcc ma ho dovuto ricaricare quello della D-LINK perchè non riesco a collegarmi a internet.
Ho seguito le istruzioni della guida all'impostazione del firmware ma la verifica della connessione "connection status" mi da esito negativo.i
Prima di eseguire l'aggiornamento del firmware avevo impostato ip fisso x la scheda di rete:
IP 192.168.1.2
SUBNET 255.255.255.0
gateway 192.168.1
e i DNS di infostrada: 193.70.152.15 (preferito) e 193.70.152.25 (alternativo)
La verifica dell'attività log dal firmaware Acorp è questa:
Sep 16 12:00:08 | Valid Configuration Tree
Sep 16 12:00:08 | DSL Polling Timer Started succesfully.
Sep 16 12:00:08 | PSP Boot environment  Modem Modulation Change: 1
Sep 16 12:00:09 | Firewall NAT service started
Sep 16 12:00:09 | Bridge Created: br0
Sep 16 12:00:10 | Bridge Created: br1
Sep 16 12:00:12 | Bridge Interface Added: eth0
Sep 16 12:00:18 | DSL Carrier is down
Sep 16 12:00:28 | DSL Carrier is up
Sep 16 12:00:29 | sar read trained mode (5)(ADSL_2plus)
Sep 16 12:00:30 | ---}}} Start of connection delayed for 24 sec
Sep 16 12:00:43 | modulation(1)
Sep 16 12:00:54 | PPPoE Launch after conn delay timeout ...
Sep 16 12:00:55 | sar_set keytype(1)(1), key(modulation)
Sep 16 12:00:55 | sar settings
Sep 16 12:00:55 | set modulation(0x3)
Sep 16 12:00:55 | chk ret(1)
Sep 16 12:00:55 | PSP Boot environment  Modem Modulation Change: 0x3
Sep 16 12:00:55 | pppd 2.4.1 started by root, uid 0
Sep 16 12:00:56 | modulation(0x3)
Sep 16 12:01:08 | DSL Carrier is down
Sep 16 12:01:08 | PPPD was Properly Stopped. Current State=2
Sep 16 12:01:08 | PPPD Restart Filter = 0
Sep 16 12:01:18 | DSL Carrier is up
Sep 16 12:01:19 | sar read trained mode (1)(ADSL_G.dmt)
Sep 16 12:01:19 | pppd 2.4.1 started by root, uid 0
se qualcuno può aiutarmi. Grazie.
Offline rocco.10
Re: FIRMWARE D-LINK 320T (FALLITO)
« Risposta #1 il: 21 Novembre 2007, 10:45 »
ciao. Io mi trovo nella tua stessa condizione. Provider infostrada, modem aggiornato con il firmware suggerito in un altra discussione di questo forum, e naturalmente modem che non si collega ad internet! Sto veramente impazzendo!
Premetto che non me ne intendo molto ma di solito cercando sui forum riesco sempre a risolvere i miei problemi.
Io però non ho impostato tutti i dati che hai impostato tu (tipo DSN specifico per infostrada..) perchè mi era stato detto che era fatto tutto in automatico durante l'installazione. A questo punto mi chiedo: devo cambiare forse i dati manualmente? Utilizzare dei settaggi specifici in base all'operatore?
C'è una guida o un manuale completo in lingua italiana?
Offline michele1969
  • 11
« Risposta #2 il: 21 Novembre 2007, 14:33 »
io risco a navigare. non ho rpoblemi. solo se carico il firmware moddato non entro nella rete.
ma tu che modem hai?? d-link?? sistema operativo winxp??
dopo aver impostato i parametri su connessioni di rete > tasto dx sulla connessione locale > proprietà, controlla impostazioni TCP/IP. I DNS me li ha comunicati INFOSTRADA. Con il firmware originale ho impostato TCP/IP "automaticamente" perchè sennò non riesco a navigare. Controlla  che su "autenticazione" non sia abilitata autenticazione IEE ..... smart card o altro certificato.
Ciao....
Offline rocco.10
« Risposta #3 il: 21 Novembre 2007, 15:08 »
Hai ragione...mi riferivo au un DLink DSL 320-T collegato ad un portatile con su Windows Vista. E' per quello che ho aggiornato col firmware come da precedente discussione sempre su questo forum....
https://www.ilpuntotecnico.com/forum/index.php?topic=3928.msg42308
Purtroppo tutto inutile, cosa dici provo a impostare il DSN di Infostrada? Quali sono i parametri?
Offline michele1969
  • 11
« Risposta #4 il: 22 Novembre 2007, 15:08 »
dns preferito: 193.70.152.15
dns alternativo: 193.70.152.25
Prova anche selezionare "ottieni automaticamente un indirizzo IP"
Ciao.
Offline bovirus1963
  • 1072
« Risposta #5 il: 22 Novembre 2007, 16:58 »
Con i fw originali Dlink si naviga solo con ip autoamatico.
Per aggiornare il modem via interfaccia web bisogna usare un ip fisso.
Per usare emule sarebbe preferibile avere un ip fisso e quindi utilizzare il fw moddato (il servizio dhcp del modem va in crah ripetetutamente)
Per i fw moddati provate a creare la connessione in PPOA/VCMUX o PPAO/LLC  (nel log attuale è in PPOE) attraverso il wizard (VPI=8 VCI=35)
Quale versione di firmware moddato è stata utilizzata esattamente (stringa Version nella pagina home dell'interfaccai web)?
La linea ADSL Infostrada è una 4Mb / 12 Mb o che altro?
Offline michele1969
  • 11
« Risposta #6 il: 22 Novembre 2007, 22:15 »
Ciao Bovirus.
Io ho ADSL 4 MB infostrada.
Ho cercato di aggiornare il modem con IP fisso come da istruzioni. Ho anche provato con la connessione PPOA, ora provo con le altre e ti faccio sapere. Grazie.
la versione del firmware caricata è questa:
DSL-320T_McMcc_1.1.00.RU_20070908_20071016_DSP_7.0.4_Mknspimg_ZB.zip
Offline bovirus1963
  • 1072
« Risposta #7 il: 22 Novembre 2007, 22:28 »
Io ho la stessa versione e aggancio sia in PPOE che in PPOA con Infostrada tutto incluso.
Dai un'occhiata ai valori SNMR Margin (UL/DL) e Attenuation (UL/DL) in Modem Status.
Hai resettato il modem al default via interfaccia web e poi impostato la connessione?
La connessione l'hai creata in manuale o attraverso il Wizard?
Offline michele1969
  • 11
« Risposta #8 il: 22 Novembre 2007, 23:25 »
Ciao Bovirus, ho riprovato con il firmware moddato. poi ho resettato il modem e ho seguito la procedura della guida rapida. la connessione lo creata attraverso wizard.
Questi sono i valori su Modem Status
Modem Status
 Connection Status   Disconnected
Us Rate (Kbps)   0
Ds Rate (Kbps)   0
US Margin   28
DS Margin   14
Trained Modulation   NO_MODE
LOS Errors   0
DS Line Attenuation   29
US Line Attenuation   16
Peak Cell Rate   0 cells per sec
CRC Rx Fast   0
CRC Tx Fast   1
CRC Rx Interleaved   0
CRC Tx Interleaved   0
Path Mode   Fast Path
DSL Statistics
 Near End F4 Loop Back Count   0
Near End F5 Loop Back Count   0
Anche su "connestion status":
Description  Type  IP  State  Online  Disconnect Reason
Wizard pppoe N/A Not Connected 0 DSL Line is Disconnected
Wizard pppoa N/A Not Connected 0 DSL Line is Disconnected
boh... già ne capisco poco...
Probabilmente sbaglio io qualcosa.
se puoi consigliarmi ti ringrazio.
Offline michele1969
  • 11
« Risposta #9 il: 22 Novembre 2007, 23:27 »
Se non trovo una soluzione, ritorno al mio vecchio modem USB che funziona con tutto benissimo.
Offline furiob
« Risposta #10 il: 23 Novembre 2007, 09:20 »
@michele1969
Non demordere sei a un passo dalla soluzione, se non parte la ADSL devi controllare con con cura che tutti i parametri di connessione siano ok ad es. per PPPoA che sia spuntato VC parametri 8 e 35 MTU 1500 e sopratutto password e id corretti
Molte volte la fretta di vedere se tutto funziona ci fa dimenticare cose banali . Ho provato molti fw e tutti hanno funzionato più o meno bene ma sempre tutto OK. :)
Offline bovirus1963
  • 1072
« Risposta #11 il: 25 Novembre 2007, 21:48 »
Us Rate (Kbps)   0
Ds Rate (Kbps)   0
Sembra che il cavo DSL sia sconnesso. Il modem non rileva la portante ADSL.
O è un problema di linea (staccata) o di modem che non rileva la portante ADSL.
Offline rocco.10
« Risposta #12 il: 27 Novembre 2007, 10:06 »
Ciao a tutti. Forse io ho risolto il problema. Bisogna scaricare il Firmware originale Dlink (specifico per vista) che trovate sul sito dlink (attenzione la versione UK). Fatemi sapere.
Offline bovirus1963
  • 1072
« Risposta #13 il: 27 Novembre 2007, 11:03 »
E' la versione 3.10.EU (disponibile sia per DSL-320T che per DSL-524T /DSL-G624T)
Se non rileva la portante non è comunque un problema di fw (la rilevazione di portante è indipendente dalla versione per fw).
Il fw 3.10 serve a risolvere problemi di utilizzo dell'interfaccia web e utilizzo del modem in ista.
ftp://cci_rcc_adsl:[email protected]/DSL-320T_Dlink_3.10B01T01.EU_20070613.zip
A quale sito esattamente (tra i tanti) ufficali Dlink ti riferisci?
Offline _Kurosaki_Ichigo_
« Risposta #14 il: 27 Novembre 2007, 17:46 »
e infatti..visto che a breve comprerò un pc nuovo con vista...e un mio amico mi ha detto che il modem 320-t non è compatibile...avrà ragione lui oppure aggiornando il firmware risolvo il tutto??....comunque su xp non ho settato nulla e va tutto alla perfezione
