Problemi Con 300t
  • 246 Risposte
  • 108407 Visite
Offline kyxx
  • 21
Problemi Con 300t
« Risposta #30 il: 31 Gennaio 2005, 16:21 »
ciao gigiowind,
ho un po' di problemi..
mi indicheresti passo passo come hai fatto l'upgrade?
i 3 file si caricano sul 300T con il recovery tool? dove trovo quest'ultimo? il link indicato dal forum non funziona più.
thanks
kyxx
Offline ArTiKO
  • 819
    • ArTiKO The Best of WWW
Problemi Con 300t
« Risposta #31 il: 31 Gennaio 2005, 18:52 »
Vi posto la risposta del ragazzo russo:
> hi!
> I have use your version 300t@500t, but this version don't have support of
> USB port, right?
Company D-Link sells in Russia devices DSL-xxxT without support USB, it officially, therefore in our
firmwares there is no setup and work USB...
> in your archive RAR have two fs (firmware image):
> - DLinkRU_DSL-500T_fs_V1.00B02T02.RU.20041224.MC.00_dsp1010000
> - DLinkRU_DSL-500T_fs_V1.00B02T02.RU.20041224.MC.00_dsp3000800
> why?
These firmwares differ only different versions DSP HAL firmware, it is necessary for the decision
of a problem of the part connected in work ADSL. DSP1010000 - the old version also is intended for
work with old DSLAM modems, support only ADSL v.1. DSP3000800 - works with new DSLAM modems
and supports ADSL2/2+. Unfortunately c DSP3 there are problems with old DSLAM devices, just as
with DSP1 at connection to new DSLAM to devices. Therefore to have to do 2 versions fs_images...
> this firmware have usb support?
Support USB to make not difficultly, the problem can be only in adjustments, it will be necessary to study
such opportunity in ours firmwares, driver USB and necessary web pages can be taken from UK firmware.
> I'm Mattia.
> I have found this link for resolv router and emule problems.
> http://www.adslzone.net/html.php?file=tuto...rs/14/index.htm
> Can you set this var into the firmware:
> echo 2048 > /proc/sys/net/ipv4/netfilter/ip_conntrack_max
> echo 50 > /proc/sys/net/ipv4/netfilter/ip_conntrack_generic_timeout
> echo 5 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_close
> echo 120 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_close_wait
> echo 1200 >
> /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_established
> echo 120 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_fin_wait
> echo 60 > /proc/sys/net/ipv4/netfilter/ip_conntrack_tcp_timeout_time_wait
> echo 10 > /proc/sys/net/ipv4/netfilter/ip_conntrack_udp_timeout
> this var resolv the problems with emule... Did you just know?
Yes... It at us for a long time mades up:)...
Offline M74T
  • 22
    • http://www.m74t.altervista.org
Problemi Con 300t
« Risposta #32 il: 31 Gennaio 2005, 19:56 »
Grazie 1000 artiko  :lol:
Lo immaginavo infatti sul mio 504t eMule stà girando alla grande orami da 2 gg, l'ho impostato su 300 connessioni.
Ora sto preparando una guida e una raccolta di vari firmware  :D
« Ultima modifica: 31 Gennaio 2005, 20:11 da M74T »
Offline M74T
  • 22
Problemi Con 300t
« Risposta #33 il: 31 Gennaio 2005, 20:10 »
Scusami artiko dimenticavo ...
Ma esiste un forum inglese ?
Io li trovo tutti Russi  :(
« Ultima modifica: 31 Gennaio 2005, 20:12 da M74T »
Offline Patry83
  • 371
Problemi Con 300t
« Risposta #34 il: 31 Gennaio 2005, 21:23 »
mmmh...ho capito poco sui 2 firmware del russo...io ho messo su il DSP3 ecc...
e mi funziona bene...l'unico probl è che quando stacco l'alimentazione del modem mi perde l'ora...ma fa niente...
il DSP1? è meglio/peggio?
cosa mi consigliate?
nn dite di mettere i files del 502t perchè nn mi va di usare una versione che supporta l'USB quando io nel mio 300t nn ho porte USB... :)
aspetto risposte...e possibilmente spiegazioni in italiano  :D sulla differenza tra i 2 firmware
Offline Max
  • 363
Problemi Con 300t
« Risposta #35 il: 01 Febbraio 2005, 09:35 »
Siccome il forum ha un vincolo per l'upload di file per poter fare una raccolta dei firmware, programmi, ecc.... completa in modo da poterli conservare senza la paura che vengano segati gli altri siti ho messo a disposizione un account ftp anonimo raggiungibile qua ftp://ftp.ilpuntotecnico.com
Se qualcuno ha qualche file che vuole uppare me lo mandi in allegato all'indirizzo [email protected] e io provvederò a upparlo.
ciao
Problemi Con 300t
« Risposta #36 il: 01 Febbraio 2005, 13:58 »
io ho aggiornato a dsp3 e va da dio..............per quanto riguarda le differenze von dsp v1 supporta in più adsl2+ e con tele2 va una bomba! ora mi pare sia uscita http://mcmcc.bat.ru/dlinkt/dsl300Tto500T_2...3b_firmware.rar qualcono l'ha provata come va??? dovrebbe aggiornare busybox a 1.0 e anche il resto dei software
Problemi Con 300t
« Risposta #37 il: 01 Febbraio 2005, 14:11 »
x M74T la password per telnet dovrebbe essere root o admin
Offline Bravo Yankee 17
Problemi Con 300t
« Risposta #38 il: 01 Febbraio 2005, 14:12 »
Io ancora non ho capito se conviene mettere il dsp3 o dsp1...Ho Alice Flat e vorrei tanto far andare eMule per più di un'ora e mezza di seguito...un'altra questione, se aggiorno con il firmware del russo, devo ancora impostare il bridge al modem o posso usare la modalità PPPoE? Help me please.
« Ultima modifica: 01 Febbraio 2005, 14:13 da Bravo Yankee 17 »
Problemi Con 300t
« Risposta #39 il: 01 Febbraio 2005, 14:16 »
io lo uso in modalità pppoa con tele2 e va benissimo
Problemi Con 300t
« Risposta #40 il: 01 Febbraio 2005, 14:26 »
Offline rodelgrim
Problemi Con 300t
« Risposta #41 il: 02 Febbraio 2005, 15:24 »
Ma se passo dal 300t al 500t (dei russi), i settaggi nella proc per far funzionare correttamente emule sono già quelli giusti o devo risettarli io come dice il tizio spagnolo segnalato da artiko?
Problemi Con 300t
« Risposta #42 il: 02 Febbraio 2005, 18:39 »
penso di si..... a me emule/amule va benissimo anche se negli ultimi giorni dopo un pò di tempo (ore) mi si disconnette.... non capisco... ma non so :blink:
Offline rodelgrim
Problemi Con 300t
« Risposta #43 il: 02 Febbraio 2005, 19:45 »
mmm, hai provato a modificare i setaggi del NAT nella procfs?  Forse i russi hanno lasciato quelli originali che NON vanno benei...
Problemi Con 300t
« Risposta #44 il: 02 Febbraio 2005, 20:20 »
potresti spiegarmi meglio.... :huh:
