dsl-302T
  • 23 Risposte
  • 9489 Visite
Offline talpina
  • 18
Re: dsl-302T
« Risposta #15 il: 05 Aprile 2006, 15:08 »
Ciao Liquid, fatta l'interfaccia ho il log di quello che fa il modulo
Se devo essere sincero non so che cosa ho in flash come fw, pero' ti mando il log
ADAM2 Revision 0.22.02
(C) Copyright 1996-2003 Texas Instruments Inc. All Rights Reserved.
(C) Copyright 2003 Telogy Networks, Inc.
Usage: setmfreq [-d] [-s sys_freq, in MHz] [cpu_freq, in MHz]
Memory optimization Complete!
Adam2_AR7RD >
Press any key to abort OS load, or wait 5 seconds for OS to boot...
-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|Launching kernel LZMA decompressor.
Kernel decompressor was successful ... launching kernel.
LINUX started...
Config serial console: ttyS0,38400
CPU revision is: 00018448
Primary instruction cache 16kb, linesize 16 bytes (4 ways)
Primary data cache 16kb, linesize 16 bytes (4 ways)
Number of TLB entries 16.
Linux version 2.4.17_mvl21-malta-mips_fp_le (tesivarie@ws_000002.tesivarie.crazynet.org) (gcc version 2.95.3 20010315 (release/MontaVista)) #7 gio dic 8 23:21:13 CET 2005
Determined physical RAM map:
 memory: 14000000 @ 00000000 (reserved)
 memory: 00020000 @ 14000000 (ROM data)
 memory: 00fe0000 @ 14020000 (usable)
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line:
the pacing pre-scalar has been set as 600.
calculating r4koff... 000b71b0(750000)
CPU frequency 150.00 MHz
Calibrating delay loop... 149.91 BogoMIPS
Freeing Adam2 reserved memory [0x14001000,0x0001f000]
Memory: 14376k/16384k available (1529k kernel code, 2008k reserved, 115k data, 52k init)
Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
Checking for 'wait' instruction...  unavailable.
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Disabling the Out Of Memory Killer
devfs: v1.7 (20011216) Richard Gooch ([email protected])
devfs: boot_options: 0x1
Squashfs 2.1-r2 (released 2004/12/15) (C) 2002-2004 Phillip Lougher
pty: 32 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with no serial options enabled
ttyS00 at 0xa8610e00 (irq = 15) is a 16550A
ttyS01 at 0xa8610f00 (irq = 16) is a 16550A
block: 64 slots per queue, batch=16
Using the MAC with internal PHY
PPP generic driver version 2.4.1
PPP MPPE Compression module registered
avalanche flash device: 0x400000 at 0x10000000.
Physically mapped flash: Found 1 x16 devices at 0x0 in 16-bit bank
 Intel/Sharp Extended Query Table at 0x0035
cfi_cmdset_0001: Erase suspend on write enabled
Looking for mtd device :mtd0:
Found a mtd0 image (0x90000), with size (0x160000).
Looking for mtd device :mtd1:
Found a mtd1 image (0x10000), with size (0x80000).
Looking for mtd device :mtd2:
Found a mtd2 image (0x0), with size (0x10000).
Looking for mtd device :mtd3:
Found a mtd3 image (0x1f0000), with size (0x10000).
Looking for mtd device :mtd4:
Creating 4 MTD partitions on "Physically mapped flash":
0x00090000-0x001f0000 : "mtd0"
0x00010000-0x00090000 : "mtd1"
0x00000000-0x00010000 : "mtd2"
0x001f0000-0x00200000 : "mtd3"
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 1024)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 52k freed
init started:  BusyBox v1.00 (2005.03.01-00:28+0000) multi-call binary
Starting pid 10, console /dev/tts/0: '/etc/init.d/rcS'
Algorithmics/MIPS FPU Emulator v1.5
 Standard Configproc write:Calling Configuration
uration File
Numodule =  1
STATE =  1
STATE =  2
STATE =  3
STATE =  4
module =  2
STATE =  1
STATE =  2
module =  3
STATE =  1
STATE =  2
STATE =  3
module =  5
STATE =  1
STATE =  2
STATE =  3
module =  6
STATE =  1
STATE =  2
STATE =  3
module =  9
STATE =  1
STATE =  2
STATE =  3
STATE =  4
STATE =  5
mber of State Elements = 20
Total Length = 164
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/atm/tiatm.o
Warning: loading tiatm will taint the kernel: no license
  See http://www.tux.org/lkml/#export-tainted for information about tainted modules
registered device TI Avalanche SAR
Initializing DSL interface
size=10120
size=38720
size=46432
size=45312
Texas Instruments ATM driver: version:[4.02.05.00]
info, diap server (v0.9.7) started
Please press Enter to activate this console. Sep  8 12:00:08 cm_monitor: Monitor Starting
logic: /proc/led_mod/ar7reset: [1]
Try to do Reboot at Startup!!
Failed to erase mtd, region [0x1f0000,0x10000]
anne qs is null
firmware main entered
firmware main entered in FLASH_UPGRADE_SUPPORT flag
Starting flash upgrade...
process file:/var/tmp/fw.bin
copy_config_file: Upgrading cfg:
copy_config_file: totalLen: 5cd7
copy_config_file: successful!
##############    flash upgrade OK!!!! ##########################
copy default config file to mtd...
Restarting system.
Adam2_AR7RD >
Domanda, poichè ovviamente ero sicuro che tutto funzionasse e non ho fatto il backup del fw originale non è che tu ne hai uno certificato da te che posso riprovare a flashare?
Grazie e cioa
Offline Liquidsky
  • 1944
  • Rastagatt vaibrescio...
    • CICLaMaB
Re: dsl-302T
« Risposta #16 il: 05 Aprile 2006, 15:56 »
Ehm... Passo la palla a qualcun'altro...
Vedo degli errori, ma non saprei che dirti...
Per il firmware prova quello della dlink, o un altro di quelli segnalati sul forum
CICLaMaB lo trovi qui!
Re: dsl-302T
« Risposta #17 il: 05 Aprile 2006, 16:37 »
@talpina
Il firmware che c'e' dentro il tuo 30xt non e' abbastanza collaudato, mettici quello stable di dlinkpedia v. 1.2.5
Offline talpina
  • 18
Re: dsl-302T
« Risposta #18 il: 05 Aprile 2006, 18:04 »
ok domani provo poi magari vi posto il risultato del log.
Mi sembra di vedre che per qualche motivo fallisce sulla partizione md3, non è che conviene mettere qualche opzione in cicalmab?
Re: dsl-302T
« Risposta #19 il: 05 Aprile 2006, 18:57 »
L'unica opzione di Ciclamab relativa alla mtd3 o meglio al congi.xml e' "empty".
Offline JackTheVendicator
  • 1913
  • I'm watching you.
    • Firmware modificati
Re: dsl-302T
« Risposta #20 il: 07 Aprile 2006, 19:44 »
Questo e' il kernel che ho compilato io... *credo* sia anche nel pacchetto della 1.2.5 stable di osvi...
Che strano... praticamente la riga "logic: /proc/led_mod/ar7reset: [1]" vuol dire che il modem crede proprio che ci sia il tastino di reset premuto... che ci sia davvero il pulsantino danneggiato (o cortocircuitato) come dici tu?
Essendo premuto il reset all'accensione, il modem tenta anche di cancellare la configurazione, ma essendoci una flash Intel (e non essendo ancora stata sbloccata dal programma apposito, azione che deve essere fatta premendo un tasto nella interfaccia web), non ci riesce ("Failed to erase mtd, region [0x1f0000,0x10000]").
anne qs is null
Che cosa vuol dire questo? o_O
Qua ha tentato di scrivere un config di default su mtd3, pero', come detto prima, la flash e' bloccata e non glielo permette.
Restarting system.
Adam2_AR7RD >
E qua si e' riavviato...
Grazie e cioa
Il firmware ufficiale per 302T lo trovi su: http://www.dlink-me.com/ftp/modems/DSL-302T/FW%20V1.00B02T02.EU.20040630.zip
Offline talpina
  • 18
Re: dsl-302T
« Risposta #21 il: 10 Aprile 2006, 08:06 »
Allora, per essere preciso ho "Estratto" il tasto di REset, quindi ora non esiste più.
Comunque quando vadoa fare una misra con un tester vedoche c'è un quasi corto tra i due pin.
Mah!
Re: dsl-302T
« Risposta #22 il: 10 Aprile 2006, 10:33 »
scusami ma cosa c'entra il tasto reset?
Offline talpina
  • 18
Re: dsl-302T
« Risposta #23 il: 10 Aprile 2006, 11:51 »
la mia paura era che fosse rotto e che magari la scheda fosse sempre resettata, visto che quello era il suo comportamento, ragion per cui l'ho "gentilmente" estratto dalla scheda. Il problema è che il tutto continua a non funzionare.
